Adapter Interface fixes and changes
- Modify the macro field from lpfc_init_vpi_vpi to lpfc_init_vfi_vpi
- Add the new CQE_CODE_RECEIVE_V1 CQE Code, add code in the driver to handle
the new Code the same as the CQE_CODE_RECEIVE code except that there are
two new checks for this code that will cause the driver to use the new V1
macros for rq_id and fcf_id.
- Fix a bug in lpfc_prep_seq() where the size out of the first CQE was
ONLY being used, even though multiple dmabufs make up the sequence,
each have their own CQE with potentially different sizes.
- Fix bug in lpfc_bsg_ct_unsol_event() where the ulpContext and ulpWord[3]
fields of the XMIT_SEQUENCE64_CX IOCB were being calculated incorrectly.
- Do physical to logical translation before indexing into the active
XRI array.
- Populate physical vpi in the iocb data structure.
- Put the current accumulated total in each IOCB in the chain as we are
walking thru then. The last IOCB in the chain should have the total
length of the sequence.
Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com>
Signed-off-by: James Smart <james.smart@emulex.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Miscellaneous Bug fixes and code cleanup
- Fix 16G link speed reporting by adding check for 16G check.
- Change the check and enforcement of MAILBOX_EXT_SIZE (2048B)
to the check and enforcement of BSG_MBOX_SIZE - sizeof(MAILBOX_t) (3840B).
- Instead of waiting for a fixed amount of time after performing firmware
reset, the driver shall wait for the Lancer SLIPORT_STATUS register for the
readiness of the firmware for bring up.
- Add logging to indicate when dynamic parameters are changed.
- Add revision and date to the firmware image format.
- Use revision instead of rev_name to check firmware image version.
- Update temporary offset after memcopy is complete for firmware update.
- Consolidated the use of the macros to get rid of duplicated register
offset definitions.
- Removed the unused second parameter in routine lpfc_bsg_diag_mode_enter()
- Enable debugfs when debugfs is enabled.
- Update function comments for lpfc_sli4_alloc_xri and lpfc_sli4_init_rpi_hdrs.
Extend BSG infrastructure and add link diagnostics:
- Removed unnecessary copies in handling pass-through mbox cmds.
- Add embedded SLI_CONFIG support for BSG.
- Add multibuffer support.
- Implemented the setting up and tearing down Lancer FC device for performing
internal and external loopback diagnostic tests.
- Implemented the driver support for performing new link diagnostic tests
Signed-off-by: James Bottomley <jbottomley@parallels.com>
This patch adds support for hardware that returns resource ids via
extents rather than contiguous ranges.
[jejb: checkpatch.pl fixes]
Add request-firmware support:
- Add support for request_firmware interface for INTF2 SLI4 ports.
- Add ability to reset SLI4 INTF2 ports.
Extended hardware support and support dump images:
- Make the size to be MAILBOX_SYSFS_MAX (4096) so that it allows the maximum
sysfs binary access interface possible.
- Add ids and model names for new hardware
- Add capability of inducing SLI4 firmware dump obj file
Miscellaneous Fixes and Corrections
- Remove the memset in the lpfc_sli4_remove_rpi_hdrs call.
- Correct swapping of SGE word 2 relative to offset value
- Reorganize CQ and EQ usage to comply with SLI4 Specification.
- Expand the driver to check the rn bit. Only detect an error if the error bit
is set and the RN bit is NOT set.
- If mailbox completion code is not success AND the mailbox status is success,
then and only then will the driver overwrite the mailbox status.
- When driver initializing device, if the device is on a PCIe bus, set
PCI's "needs fundamental reset" bit so that EEH uses fundamental reset
instead of hot reset for recovery.
- Prevent driver from using new WWN when changed in firmware (until driver
reload)
- When HBA reports maximum SGE size > 0xffffffff (infinite), override
with 0x80000000.
- Fixed potential missed SLI4 device initialization failure conditions.
- Added 100ms delay before driver action following IF_TYPE_2 function reset.
- Reverted patch to UNREG/REG on PLOGI to mapped/unmapped node.
- Add a check for the CVL received flag in the fcf inuse routine to avoid
unregistering the fcf if Devloss fires before Delay discover timer fires.
Fixes related to new hardware
- Restrict driver to look at BAR2 or BAR4 only for if_type 0.
- Allow SLI4 with FCOE_MODE not set for new SLI4 FC adapters.
- Add Temporary RPI field to the ELS request WQE.
- Do not override CT field in issue_els_flogi for SLI4 IF type 2
- For RQ_CREATE_V2 mbx cmd: fill in the rqe_size and page_size for RQ_CREATE.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Miscellaneous fixes
- Do not limit RPI Count to a minimum of 64
- Fix FCFI incorrect on received unsolicited frames.
- Save the FCFI returned in the REG_FCFI mailbox command if it was successful.
- Fixed Vports not sending FDISC after lips.
- Align based on the SLI4_PAGE_SIZE.
- Fixed double byte swap on received RRQ.
- Fixed mask size for the wq_id mask from 0x7F to 0x7FFF.
- Clear FC_FABRIC flag when NPIV LOGO completes (and add a log message).
- Modified driver to skip round robin only when ulpStatus==LOCAL_REJECT
and word4=SEQUENCE_TIMEOUT to prevent FLOGI to disconnected FCF.
- Don't add rport if driver unloading
FC Discovery fixes
- In lpfc_sli4_bpl2sgl byte swapping the SGL in word2.
- In lpfc_sli4_iocb2wqe byteswap the data for CMD_GEN_REQUEST64_CR type WQE.
- In lpfc_sli4_seq_abort_acc do not set the oxid into the iocb's xritag field.
- In lpfc_sli4_seq_abort_acc check the return value of lpfc_sli_issue_iocb.
- Inprove messages in this area.
- Add new Queue Create Mailbox version support
- Make lpfc_bsg_wake_mbox_wait routine check the mailboxes job reference before
using it.
Critical Errors:
- Correctly handle non-zero return lpfc_workq_post_event and return ENOMEM
- Save the irq level when locking the host_lock in lpfc_findnode_did
Bug Fixes:
- Adjust payload_length and request_length for sli4_config mailbox commands.
- Add the freed sgl/XRI to the tail of the list rather than to the head.
- Set the FC_VPORT_NEEDS_INIT_VPI on vport deletes and check it before
issuing a fdisc on an els retry.
- Only call lpfc_hba_init_link() if phba->cfg_suppress_link_up
is LPFC_INITIALIZE_LINK.
- Add support for SLI-4 Performance Hints
Implement new SLI4 init procedures based on if_type:
- Add structure changes for new SLIPORT registers and BAR changes.
- Update register names to be consistent with inteface spec terms.
- Added union to encapsulate Hardward error registers.
- Rework lpfc_sli4_post_status_check() around SLI-4's SLI_INTF type
- Removed the lpfc_sli4_fw_cfg_check routine
- Segmented driver logic to include evaluation of the if_type to
engage different behaviors.
Implement the FC and SLI async event handlers:
- Updated MQ_CREATE_EXT mailbox structure to include fc and SLI async events.
- Added the SLI trailer code.
- Split physical field into type and number to reflect latest SLI spec.
- Changed lpfc_acqe_fcoe to lpfc_acqe_fip to reflect latest Spec changes.
- Added lpfc_acqe_fc_la structure for FC link attention async events.
- Added lpfc_acqe_sli structure for sli async events.
- Added lpfc_sli4_async_fc_evt routine to handle fc la async events.
- Added lpfc_sli4_async_sli routine to handle sli async events.
- Moved LPFC_TRAILER_CODE_FC to be handled by its own handler function.
Add SLI4 FC Discovery support
- Replace READ_LA and READ_LA64 with READ_TOPOLOGY mailbox command.
- Converted the old READ_LA structure to use bf_set/get instead of bit fields.
- Rename HBA_FCOE_SUPPORT flag to HBA_FCOE_MODE. Flag now indicates function
is running as SLI-4 FC or FCoE port. Make sure flag reset each time
READ_REV completed as it can dynamically change.
- Removed BDE union in the READ_TOPOLOGY mailbox command and added a define to
define the ALPA MAP SIZE. Added FC Code for async events.
- Added code to support new 16G link speed.
- Define new set of values to keep track of valid user settable link speeds.
- Used new link speed definitions to define link speed max and bitmap.
- Redefined FDMI Port sppeds to be hax values and added the 16G value.
- Added new CQE trailer code for FC Events.
- Add lpfc_issue_init_vfi and lpfc_init_vfi_cmpl routines.
- Replace many calls to the initial_flogi routine with lpfc_issue_init_vfi.
- Add vp and vpi fields to the INIT_VFI mailbox command.
- Addapt lpfc_hba_init_link routine for SLI4 use.
- Use lpfc_hba_init_link call from lpfc_sli4_hba_setup.
- Add a check for FC mode to register the FCFI before init link.
- Convert lpfc_sli4_init_vpi to be called without a vpi (get it from vport).
- Add the Lancer FC and FCoE PCI IDs
- Add new SLI4 INTF register definitions
- Implement new SLI4 doorbell register
- Add new WQE fields as defined by new SLI interface to support new hardware.
- Add the new Logical Link speed event support.
- Add RATOV and EDTOV to the REG_VFI mailbox command.
- Correct all SLI4 code to work on big endian systems.
- Move read of sli4 params earlier so returned values are used correctly.
- Add support for the INTF (Interface) PCI register.
- Add support for greater than 2 page SGLs.
- Add support for up to 32 bit BDE lengths.
- Implement the Port Capabilities Mailbox command.
- Stop checking the Minor Code in the EQE structure.
- Add init_vpi mailbox command before re-registering VPI.
- Add Fast FCF failover support.
- Call pci_save_state() after pci_restore_state() call to cope
with kernel change.
- Add support for PCI BAR region 0 if BAR0 is a 64 bit register.
Display Logical Link Speed when supported and is non-zero.
lpfc_hbadisc.c and lpfc_hw4.h accidentally got set executable.
Reported-by: Thomas Backlund <tmb@mandriva.org>
Cc: James Smart <James.Smart@Emulex.Com>
Fix hardware/SLI relates issues:
- Fix CNA uses more than one EQ when in INTx interrupt mode.
- Fix driver tries to process failed read FCF record mailbox request.
- Fix allocating single receive buffer breaks FCoE receive queue.
- Support new read FCF record mailbox error case.
Fix FC protocol errors:
- Fix multi-frame unsolicited sequences not queued properly
- Fix frames for unsolicited sequences not being associated with sequence.
- Fix unsolicited frame buffer sizes are not set properly
- Fix Sequence count for unsolicited frame headers not byte swapped.
- Fix Multi-frame sequence response frames go to wrong DID.
Hardware related Fixes and Changes.
- Added new Adapter IDs and update default Adapter names.
- Added PCI read after EQarm doorbell PCI write to flush the write
and avoid spurrious interrupts when in INTx mode.
- Phase out use of ONLINE registers.
- Fix for lost MSI interrupt
FC protocol fixes.
- Fix send sequence logic to handle multi SGL IOCBs.
- Fix FDISC completion always setting VPORT state to failed.
- Ported the fix on reporting of max_vpi to uppper layer.
- Fix incorrect number of Vports allowed to be created.
- Fixed Dead FCoE port after creating vports.
- Added handling of ELS request for Reinstate Recovery Qualifier (RRQ)
- Handle unsolicited CT exchange initiator receiving CT exchange ABTS
- Migrate LUN queue depth ramp up code to scsi mid-layer.
- Made ABTS WQE go to the same WQ as the WQE to be aborted.
- Fix Vport does not rediscover after FCF goes away.
- Fixed lpfc_unreg_vfi failure after devloss timeout.
- Fixed RPI bit leak.
- Fix hbq pointer corruption during target discovery.
FCoE Protocol fixes.
- Fixed FIP frame designation for ELS commands.
- Fix CVL received on Port 1 not processed by driver.
- Fix Zeroed frame on wire after FLOGI
- Fix vport keep-alive does not contain the correct WWN.
optimisations and devloss timout fixes
This patch includes the following changes:
- Fixed Panic/Hang when using polling mode for fcp commands
- Added support for Read_rev mbox bits indicating FIP mode of HBA
- Optimize performance of slow-path handling of els responses
- Add code to cleanup orphaned unsolicited receive sequences
- Fixed Devloss timeout when multiple initiators are in same zone
vlink events
This patch includes the following fixes and new features:
- Fix mask size for CT field in WQE
- Fix VPI base not used when unregistering VPI on port 1.
- Fix UNREG_VPI mailbox command to unreg the correct VPI
- Fixed Check for aborted els command
- Fix error when trying to load driver with wrong firmware on FCoE HBA.
- Fix bug with probe_one routines not putting the Scsi_Host back upon error
- Add support for Clear Virtual Link Async Events
- Add support for unsolicited CT exchange sequence abort
- Add 0x0714 OCeXXXXX PCI ID
Various SLI4 fixes
- Fix switch name not used in the FCF record for FCoE HBAs
- Enabled HBA UE error polling error-condition action code
- Rewrite lpfc_sli4_scmd_to_wqidx_distr() to handle counter rollover cleanly
- Modify resume_rpi mailbox data structure to match current SLI4 spec
- Do not issue mailbox command in MBX_POLL mode when LPFC_HBA_ERROR is set
- Wait for HBA POST completion before checking Online and UE registers
- Fix accumulated total length not being filled in on unsolicited IOCBs
- Use PCI config space register to determine SLI rev of HBA
- Turn on starting ELS tmo function timer during device initialization
Signed-off-by: James Smart <James.Smart@emulex.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Contains the following changes:
- Force vport to send LOGO to fabric controller when deleting vport
- Fixed driver failing to register login when a PLOGI is received
- Fixes for FIP discovery
- Added stricter checks for FCF addressing mode
- Added code to send only FLOGI, FDISC and LOGO to Fabric controller as FIP
- Fixed handling of LOGO from Fabric port
- Fixed consecutive link up events skipped link_down processing
- Set the CT field of FDISC to 3
- Fixed over allocation of SCSI buffers on SLI4
- Removed unused jump table entries
- Increase LPFC_WQE_DEF_COUNT to 256
- Updated FDISC context to VPI
- Fixed immediate SCSI command for LUN reset translation to WQE
- Extended mailbox handling to allow MBX_POLL commands in between async
MBQ commands
- Fixed SID used for FDISC
- Fix crash when accessing ctlregs from sysfs for SLI4 HBAs
- Fix SLI4 firmware version not being saved or displayed correctly
- Expand CQID field in WQE structure to 16 bits
- Fix post header template mailbox command timing out
- Removed FCoE PCI device ID 0x0705
Adds new hardware and interface definitions.
Adds new interface routines - utilizing the reorganized layout of the
driver. Adds SLI-4 specific functions for attachment, initialization,
teardown, etc.
