Signed-off-by: James Smart <james.smart@emulex.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Fixed NMI watch dog panic's when resetting the hba.
deferred removal.
Make compliant with FC specs by sending LOGO after ABTS timeouts
Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com>
Locking fix and Memory leak Fixes
- Fix Locking code raises IRQ twice (NA)
- Fix mailbox and vpi memory leaks (126818)
SLI related fixes:
- Fix REG_RPI fails on SLI4 HBA putting NPort into NPR state (126230)
- Fix ELS FDISC failing with local reject / invalid RPI. (126350)
- Fix reset port when reset is needed during fw_dump (125807)
- Fix unbounded firmware revision string from port cause panic (126560)
- Fix driver behavior when receiving an ADISC (126654)
- Fix driver not returning when bad ndlp found in abts error event
handling (126209)
- Add more driver logs in area of SLI4 port error attention and reset
recovery (126813, 124466)
- Fix failure in handling large CQ/EQ identifiers in an IOV
environment (126856)
- Fix for driver using duplicate RPIs after lancer port reset (126723)
- Clear vport->fc_myDID in lpfc_els_issue_fdisc to guarentee a
zero SID (126779, 126897)
- Fix for SLI4 Port delivery for BLS ABORT ACC (126289)
FC and SCSI Discovery Fixes:
- Clear the virtual fabrics bit (word 1 bit 30) when sending the FLOGI
and FDISC. (CR 124339)
- Return a MLQUEUE_DEVICE_BUSY if the driver detects that an I/O is being
retried too quickly (CR 124668)
- Remove NDLP reference put in lpfc_cmpl_els_logo_acc for all but fabric
nodes (CR 123924)
- Only retry FDISCs every second and stop retrying after devloss number
of retries (CR 13939)
- Check to see if vports are unloading before adding them to the vport
work array. (CR 124996)
- Fixed illegal state transition during driver unload (CR 124191)
- Added missing protection on setting/clearing of vport->fc_flag bit (CR 126002)
- Set NPIV flag in lpfc_mbx_process_link_up for all ports sli3 and
above. (CR 126094)
- Clear FCP command bytes that are not used. (CR 126209)
This patch adds support for hardware that returns resource ids via
extents rather than contiguous ranges.
[jejb: checkpatch.pl fixes]
Signed-off-by: James Bottomley <jbottomley@parallels.com>
Miscellaneous Fixes and Corrections
- Remove the memset in the lpfc_sli4_remove_rpi_hdrs call.
- Correct swapping of SGE word 2 relative to offset value
- Reorganize CQ and EQ usage to comply with SLI4 Specification.
- Expand the driver to check the rn bit. Only detect an error if the error bit
is set and the RN bit is NOT set.
- If mailbox completion code is not success AND the mailbox status is success,
then and only then will the driver overwrite the mailbox status.
- When driver initializing device, if the device is on a PCIe bus, set
PCI's "needs fundamental reset" bit so that EEH uses fundamental reset
instead of hot reset for recovery.
- Prevent driver from using new WWN when changed in firmware (until driver
reload)
- When HBA reports maximum SGE size > 0xffffffff (infinite), override
with 0x80000000.
- Fixed potential missed SLI4 device initialization failure conditions.
- Added 100ms delay before driver action following IF_TYPE_2 function reset.
- Reverted patch to UNREG/REG on PLOGI to mapped/unmapped node.
- Add a check for the CVL received flag in the fcf inuse routine to avoid
unregistering the fcf if Devloss fires before Delay discover timer fires.
FC Discovery changes
- Treat received PLOGI while logged in as a relogin (unregister and reregister).
- Added a timer to delay Nport discovery when clean bit is cleared and Fabric
portname/nodename/FCID is changed.
- Invalidate Port's DID when receiving PLOGI from p2p port with CONFIG_PORT
mailbox command.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Updated commands used for ELS to utilize VPI
Allocate RPI at node creation time and pass in ELS commnads.
- Retry PLOGI up to 48 times when LS_RJT reason is
"Unable to supply requested data."
- When dev loss timeout occures do not change state if there
is an outstanding REG_LOGIN.
- Add logic to ignore REG_LOGIN completion if discovery is
restarted while waiting for REG_LOGIN.
- Only change state on REG_LOGIN completion if still in
state waiting for REG_LOGIN completion.
- Only send ADISCs to FCP-2 Targets (not Initiators).
- Add code to prevent unreg_vpi mailbox command from failing.
- Add code to reset the HBA if unreg_vpi mailbox fails with busy status.
- Remove code that was clearing the nlp_type stored during rport discovery.
- Enable NPIV by default.
- Added code to handle unsolicited LOGO on physical port.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Discovery relates changes:
- Separated VPI_REGISTERED state of physical port into VFI_REGISTERED and
VPI_REGISTERED state so that driver can unregister physical port VPI
independent of VFI.
- Add code to unregister, re-init and re-register physical port VPI
when physical port NportID change.
- Add code to unregister and re-register VPI of a vport when its Nport
ID change.
- Add code in FDISC completion path to re-start FLOGI discovery when
a FDISC complete with LOGIN_REQUIRED reason code.
- Fix a memory leak in lpfc_init_vpi_cmpl
- Add code to start a timer for vport to retry FDISC when CVL is received
by a vport or physical port. If all Nports receive CVLs, then all timers
are cancelled and a logical link level discovery will be started after
one second.
- Flush ELS commands after killing all delayed ELS commands.
Fix hardware/SLI relates issues:
- Handle XB bit so that ELS XRIs are not prematurely released.
- Handle XB bit so that FCP XRIs are not prematurely released.
- Define new security SLI Commands.
- Remove unused security SLI commands
- Skip receive data size parameter check on received FLOGI.
- Added LPFC_USE_FCPWQIDX flag to iocb to force SLI layer
to submit abort WQE on same WQ as the command WQE.
FC protocol fixes.
- Fix send sequence logic to handle multi SGL IOCBs.
- Fix FDISC completion always setting VPORT state to failed.
- Ported the fix on reporting of max_vpi to uppper layer.
- Fix incorrect number of Vports allowed to be created.
- Fixed Dead FCoE port after creating vports.
- Added handling of ELS request for Reinstate Recovery Qualifier (RRQ)
- Handle unsolicited CT exchange initiator receiving CT exchange ABTS
- Migrate LUN queue depth ramp up code to scsi mid-layer.
- Made ABTS WQE go to the same WQ as the WQE to be aborted.
- Fix Vport does not rediscover after FCF goes away.
- Fixed lpfc_unreg_vfi failure after devloss timeout.
- Fixed RPI bit leak.
- Fix hbq pointer corruption during target discovery.
Contains the following changes:
- Force vport to send LOGO to fabric controller when deleting vport
- Fixed driver failing to register login when a PLOGI is received
- Fixes for FIP discovery
- Added stricter checks for FCF addressing mode
- Added code to send only FLOGI, FDISC and LOGO to Fabric controller as FIP
- Fixed handling of LOGO from Fabric port
- Fixed consecutive link up events skipped link_down processing
Signed-off-by: James Smart <James.Smart@emulex.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Update of copyrights on modified files
SLI4 supports both FC and FCOE, with some extended topology objects.
This patch adss support for the objects, and updates the disovery
engines for their use.
The mailbox commands themselves are the same, or very similar to
their SLI3 counterparts. This patch genericizes mailbox command
handling and adds support for the new SLI4 mailbox queue.
Adds new hardware and interface definitions.
Adds new interface routines - utilizing the reorganized layout of the
driver. Adds SLI-4 specific functions for attachment, initialization,
teardown, etc.
8.3.1 Fixes/Changes :
- Fix incorrect byte-swapping on word 4 of IOCB (data length) which
caused LUNs to not be discovered on big-endian (e.g. PPC)
- Remove a bad cast of MBslimaddr which loses the __iomem (sparse)
- Make lpfc_debugfs_mask_disc_trc static (sparse)
- Correct misspelled word BlockGuard in lpfc_logmsg.h comment
- Replaced repeated code segment for canceling IOCBs from a list with
a function call, lpfc_sli_cancel_iocbs().
- Increased HBQ buffers to support 40KB SSC sequences.
- Added sysfs interface to update speed and topology parameter without
link bounce.
- Fixed bug with sysfs fc_host WWNs not being updated after changing
the WWNs.
- Check if the active mailbox is NULL in the beginning of the mailbox
timeout handler - fixes panic in the mailbox timeout handler while
running IO stress test
- Fixed system panic in lpfc_pci_remove_one() due to ndlp indirect
reference to phba through vport
- Removed de-reference of scsi device after call to scsi_done() to fix
panic in scsi completion path while accessing scsi device after
scsi_done is called.
- Fixed "Nodelist not empty" message when unloading the driver after
target reboot test
- Added LP2105 HBA model description
- Added code to print all 16 words of unrecognized ASYNC events
- Fixed memory leak in vport create + delete loop
- Added support for handling dual error bit from HBA
- Fixed a driver NULL pointer dereference in lpfc_sli_process_sol_iocb
- Fixed a discovery bug with FC switch reboot in lpfc_setup_disc_node
- Take NULL termintator into account when calculating available buffer space
- Avoid polling HBA Error Attention when HBA's PCI channel is offline
due to PCI EEH
- Fix handling of RSCN with non-zero event qualifiers
- Remove unnecessary sleeps during HBA initialization which slow down
driver load
- Fix internal and external loopback on FCoE HBAs
- Fix incorrect decrement of cmd_pending count in lpfc_queuecomand
error path
- Fix reporting of port busy events to management application
- Rename lpfc_adjust_queue_depth() to lpfc_rampdown_queue_depth() for
consistency with its partner lpfc_rampup_queue_depth()
- Delete redundant lpfc_cmd->start_time = jiffies assignment in
lpfc_queuecommand()
- Fix handling for ELS, mailbox and heartbeat time outs in the worker
thread by removing unnecessary checking of the work_port_events
flags.
- Fix NULL pointer dereference in lpfc_prep_els_iocb
- In lpfc_device_recov_npr_node(), move clearing of NLP_NPR_2B_DISC
flag after call to lpfc_cancel_retry_delay_tmo() to keep
targets-in-discovery count correct
- Remove lpfc_probe_one()'s call to scsi_scan_host() which could cause
concurrent SCSI scans to step on each other
vendor events
Added support for new sysfs attributes: lpfc_stat_data_ctrl and
lpfc_max_scsicmpl_time. The attributes control statistical reporting
of io load.
Added support for new fc vendor events for error reporting.
Miscellaneous Fixes:
- Fix the wrong variable name used for checking node active usage status
- Fix numerous duplicate log message numbers
- Fix change KERN_WARNING messages to KERN_INFO.
- Stop sending erroneous LOGO to fabric after vport is already terminated
- Fix HBQ allocates that were kalloc'ing w/ GFP_KERNEL while holding a lock.
- Fix gcc 4.3.2 compiler warnings and a sparse warning
- Fix bugs in handling unsolicited ct event queue
- Reorder some of the initial link up checks, to remove odd VPI states.
- Correct poor VPI handling
- Add debug messages
- Expand Update_CFG mailbox definition
- Fix handling of VPD data offsets
- Reorder loopback flags
- convert to use offsetof()
Miscellaneous Discovery fixes:
- Fix rejection followed by acceptance in handling RPL and RPS
unsolicited events
- Fix for vport delete crash
- Fix PLOGI vs ADISC race condition
- Fix ADISC timeout on initiators causing devloss timeout on targets
- Correct FAN processing : port state vs unreg rpi's wasn't consistent
- Correct mismatches between ASICs and PLOGI that would skip PLOGI
Multiple Discovery Fixes:
- Fix race on discovery due to link events coinciding with vport_delete.
- Use NLP_FABRIC state to filter out switch-based pseudo initiators that
reuse the same WWNs.
- Correct erroneous setting of DID=0 in lpfc_matchdid()
- Correct extra reference count that was in the lookup path for the
remoteid from an unsolicited ELS.
- Correct double-free bug in els abort path.
- Correct FDMI server discovery logic for switch that return a WWN of 0.
- Fix bugs in ndlp mgmt when a node changes address
- Correct bug that did not delete RSCNs for vports upon link transitions
- Fix "0216 Link event during NS query" error which pops up when vports
are swapped to different switch ports.
- Add sanity checks on ndlp structures
- Fix devloss log message to dump WWN correctly
- Hold off mgmt commands that were interferring with discovery mailbox cmds
- Remove unnecessary FC_ESTABLISH_LINK logic.
- Correct some race conditions in the worker thread, resulting in devloss:
- Clear the work_port_events field before handling the work port events
- Clear the deferred ring event before handling a deferred ring event
- Hold the hba lock when waking up the work thread
- Send an acc for the rscn even when we aren't going to handle it
- Fix locking behavior that was not properly protecting the ACTIVE flag,
thus allowing mailbox command order to shift.
Miscellaneous fixes:
- Fix ERRATT flag which was overlapping
- Allow RESTART mbx commands through when stopped.
- Accept incoming PLOGI when connected to an N_Port.
- Fix NPort to NPort pt2pt problems: ADISC and reg_vpi issues
- Fix vport unloading error that erroneously cleaned up RSCN buffers
- Fix memory leak during repeated unloads - in mbox handling
- Fix link bounce vs FLOGI race conditions
Correct ndlp referencing issues:
- Fix ndlp kref issues due to race conditions between threads
- Fix cancel els delay retry event which missed an ndlp reference count
Rework misplaced reference taking on node structure
Miscellaneous Discovery/ELS Fixes:
- Delay free's of ELS requests if adapter reject conditions
- Fix concurrent PLOGI vs ADISC state handling
- Add retry mechanism for GFF_ID
- Correct some illegal state transitions around RSCN timeouts
- Fix missing return in FAN handling
Miscellaneous Small Fixes - part 2
- Fix ndlp left in PLOGI state after link up
- Fix cannot rcv unsol ELS frames after running HBA resets for a few minutes
- Fix HBQ buffer_count implemention
- Fix RPI leak
- Fix crash while deleting vports while HBA is reset
- Revert the FCP Fbits offset back to 7
- Fix panic when deleting vports
- Remove unused code in switch statement outside of a case
- Reject PLOGI from invalid PName or NName of 0
- Ignore PLOGI responses from WWPName or WWNName of 0
- Fix debugfs hbqinfo display for ppc
- Added 8G to list of supported speeds for sysfs parameter
- Defer ndlp cleanup to dev-loss timeout handler
- Added support for WRITE_VPARMS mailbox command by applications
FC Discovery Fixes:
- Fix up lpfc_drop_node() vs lpfc_nlp_not_used() usage
- Clear ADISC flag when unregistering RPI and REMOVE ndlps if in recovery.
- Fix usage of UNUSED list and ndlps
- Fix PLOGI race conditions
- Reset link if NameServer PLOGI errors occur
- Synchronize GID_FT queries with PLOGI receptions
Miscellaneous Small Fixes - part 1
- Fix typo kmzlloc -> kzalloc
- Fix discovery ndlp use after free panic
- Fix link event causing flood of 0108 messages
- Relieve some mbox congestion on link up with 100 vports
- Fix broken vport parameters
- Prevent lock recursion in logo_reglogin_issue
- Split uses of error variable in lpfc_pci_probe_one into retval and error
- Remove completion code related to dev_loss_tmo
- Remove unused LPFC_MAX_HBQ #define
- Don't compare pointers to 0 for sparse
- Make 2 functions static for sparse
- Fix default rpi cleanup code causing rogue ndlps to remain on the NPR list
- Remove annoying ELS messages when driver is unloaded
- Fix Cannot issue Register Fabric login problems on link up
- Remove LPFC_EVT_DEV_LOSS_DELAY
- Fix FC port swap test leads to device going offline
- Fix vport CT flags to only be set when accepted
- Add code to handle signals during vport_create
- Fix too many retries in FC-AL mode
- Pull lpfc_port_link_failure out of lpfc_linkdown_port
Remove flawed MBX_STOP_IOCB logic
- Fix vport ndlp ref counting errors
- Fix use after free of ndlp structure
- Use the correct flag to check for LOADING setting.
- Fix driver unload bugs (related to shost references) after link down or rscn
- Fix up HBQ initialization
- Fix port_list locking around driver unload.
- Fix references to hostdata as a phba
- Fix GFFID type offset to work correctly with big endian structure.
- Only call pci_disable_msi if the pci_enable_msi succeeded
- Fix vport_delete wait/fail if in discovery
- Put a reference on the nameservers ndlp when performing CT traffic.
- Remove unbalanced hba unlock.
- Fix up HBQ processing
- Fix lpfc debugfs discovery trace output for ELS rsp cmpl
- Send ADISC when rpi is 0
- Stop FDISC retrying forever
- Unable to retrieve correct config parameter for vport
- Fix sli_validate_fcp_iocb, sli_sum_iocb, sli_abort_iocb to be vport-aware.
- Fix index-out-of-range error in iocb. Spotted by Coverity.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Rework the lpfc_printf_log() macro so that logging is enabled on a
per-vport basis. Used to be on a physical-port basis, thus logging
with large numbers of vports became a mess. Required redefinition of
the macro, and an update of every use.
- Split attributes up into vport and non-vport attributes.
- Move vport specific cfg params to vport
Many of the vport-specific behaviors were still global attributes
on the physical port. Move them to the vport itself.
Following the NPIV support, the following changes have been accumulated
in the testing and qualification of the driver:
- Fix affinity of ELS ring to slow/deferred event processing
- Fix Ring attention masks
- Defer dev_loss_tmo timeout handling to worker thread
- Consolidate link down error classification for better error checking
- Remove unused/deprecated nlp_initiator_tmr timer
- Fix for async scan - move adapter init code back into pci_probe_one
context. Fix async scan interfaces.
- Expand validation of ability to create vports
- Extract VPI resource cnt from firmware
- Tuning of Login/Reject policies to better deal with overwhelmned targets
- Misc ELS and discovery fixes
- Export the npiv_enable attribute to sysfs
- Mailbox handling fix
- Add debugfs support
- A few other small misc fixes:
- wrong return values, double-frees, bad locking
- Added adapter failure heartbeat
NPIV support is added to the driver. It utilizes the interfaces of
the fc transport for the creation and deletion of vports. Within the
driver, a new Scsi_Host is created for each NPIV instance, and is
paired with a new instance of a FC port. This allows N FC Port
elements to share a single Adapter.
NPIV support is only available via new adapter interface extensions,
termed SLI-3. This interface changes some of the basic behaviors such
as command and response ring element sizes and data structures, as
well as a change in buffer posting. Note: the new firmware extensions
are found only on our mid-range and enterprise 4Gig adapters - so NPIV
support is available only on these newer adapters. The latest firmware
can be downloaded from the Emulex support page.
