commit aff132d95ffe14eca96cab90597cdd010b457af7 upstream.
The amount of memory required for tracking chain buffers is rather
large, and when the host credit count is big, memory allocation
failure occurs inside __get_free_pages.
The fix is to limit the number of chains to 100,000. In addition,
the number of host credits is limited to 30,000 IOs. However this
limitation can be overridden this using the command line option
max_queue_depth. The algorithm for calculating the
reply_post_queue_depth is changed so that it is equal to
(reply_free_queue_depth + 16), previously it was (reply_free_queue_depth * 2).
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 30c43282f3d347f47f9e05199d2b14f56f3f2837 upstream.
Added code to release the spinlock that is used to protect the
raid device list before calling a function that can block. The
blocking was causing a reschedule, and subsequently it is tried
to acquire the same lock, resulting in a panic (NMI Watchdog
detecting a CPU lockup).
commit 9ae89b0296e275d5a556068b40b7c2557a556a85 upstream.
mpt2sas_base_detach() call was removed from _scsih_remove() while
doing some code shuffling. Mainly when we work on adding code for
scsih_shutdown(). I have added back mpt2sas_base_detach() which will
get callled from _scsih_remove().
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Upstrem commit: 911ae9434f83e7355d343f6c2be3ef5b00ea7aed
There's a bug in the MSIX backup and restore routines that cause a crash on
non-x86 (direct access to PCI space not via read/write). These routines are
unnecessary and were removed by the above commit, so also remove them from
stable to fix the crash.
commit f6a290b419a2675c4b77a6b0731cd2a64332365e upstream.
_scsih_smart_predicted_fault is called in an interrupt and therefore
must allocate memory using GFP_ATOMIC.
commit 0167ac67ff6f35bf2364f7672c8012b0cd40277f upstream.
Fix for issue : While discovery is in progress, hot unplug and hot plug of
enclosure connected to the controller card is causing system to hang.
When a device is in the process of being detected at driver load time then
if it is removed, the device that is no longer present will not be added
to the list. So the code in _scsih_probe_sas() is rearranged as such so
the devices that failed to be detected are not added to the list.
entry in MPI message
Issue:
This issue is seen on LSI H/W WarpDrive SSS6200 When filed direct I/O
is tried as volume I/O the scmd field in internal lookup table get
cleared and because of that the retried volume I/O never gets reported
as completed to SML.
Result:
I/O timeout and Error handling thread will kicking off
Fix:
Setting back the scmd in the lookup table before retrying the failed
direct i/o
shutdown call
Driver should not call shutdown call from _scsih_remove otherwise,
The scsi midlayer can be deadlocked when devices are removed from the driver
pci_driver->shutdown handler.
Properly handling of target reset in multi-initiator environment
Clean up in broadcast change handling:
(1) Need to look at the status of each task management request, and retry
the TM when there are failures.
(2) Need quiescence IO so the driver doesn't take on more IO request while
it's in the middle of sending TM request to firmware
(3) Add support to keep track of how many pending broadcast AEN events
are received while the broadcast handling is active, then loop back at
the end of this routine if there were any events received.
Clean up in mpt2sas_scsih_issue_tm routine:
(1) Make sure proper status is returned when host reset fails
(2) Clean up sanity checks near end of routine, insuring all outstanding
IOs were completed.
This feature is to override the default
max_sectors setting at load time, taking max_sectors as an
command line option when loading the driver. The setting is
currently hard-coded in the driver to 8192 sectors (4MB transfers).
If max_sectors is specified at load time, minimum specified
setting will be 64, and the maximum is 8192. The driver will
modify the setting to be on even boundary. If max_sectors is not
specified, the driver will default to 8192.
mpt2sas driver revision q header update:
(1) Modified the descriptions of the LocalAddress bit in the
Flags field of the MPI SGE Format description and the MPI
Simple Element.
(2) Modified Data Location Address Space bits in the Flags field
of the IEEE Chain Element.
(3) Added more detail to the description of the DataLength field
for the SCSI IO Request and Target Assist Request. Removed
restriction on using chained SGLs when using multicast or
bidirectional support.
(4) In Manufacturing Page 7, added ReceptacleID field to
ConnectorInfo, and reworked how the Pinout field is used.
(5) In IO Unit Page 7, added BoardTemperature and
BoardTemperatureUnits fields.
(6) In IOC Page 1, changed CoalescingTimeout to units of
half-microsecond and updated descriptions.
(7) Modified descriptions of SATASlumberTimeout and
SASSlumberTimeout fields in SAS IO Unit Page 5 to indicate
the timers start after partial mode is entered.
(8) Added Extended Manufacturing configuration pages.
This patch addresses many endian issues solved by runing sparse with the
option __CHECK_ENDIAN__ turned on.
Ensure that the initial reference tag is passed on to the HBA firmware
for DIF Type 2 devices.
Acked-by: Kashyap Desai <Kashyap.Desai@lsi.com>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
context
Driver was a sending a SEP request during interrupt context which
required to go to sleep.
The fix is to rearrange the code so a fake event
MPT2SAS_TURN_ON_FAULT_LED is fired from interrupt context, then later
during the kernel worker threads processing, the SEP request is issued
to firmware.
Cc: stable@kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (110 commits)
[SCSI] qla2xxx: Refactor call to qla2xxx_read_sfp for thermal temperature.
[SCSI] qla2xxx: Unify the read/write sfp mailbox command routines.
[SCSI] qla2xxx: Clear complete initialization control block.
[SCSI] qla2xxx: Allow an override of the registered maximum LUN.
[SCSI] qla2xxx: Add host number in reset and quiescent message logs.
[SCSI] qla2xxx: Correctly read sfp single byte mailbox register.
[SCSI] qla2xxx: Add qla82xx_rom_unlock() function.
[SCSI] qla2xxx: Log if qla82xx firmware fails to load from flash.
[SCSI] qla2xxx: Use passed in host to initialize local scsi_qla_host in queuecommand function
[SCSI] qla2xxx: Correct buffer start in edc sysfs debug print.
[SCSI] qla2xxx: Update firmware version after flash update for ISP82xx.
[SCSI] qla2xxx: Fix hang during driver unload when vport is active.
[SCSI] qla2xxx: Properly set the dsd_list_len for dsd_chaining in cmd type 6.
[SCSI] qla2xxx: Fix virtual port failing to login after chip reset.
[SCSI] qla2xxx: Fix vport delete hang when logins are outstanding.
[SCSI] hpsa: Change memset using sizeof(ptr) to sizeof(*ptr)
[SCSI] ipr: Rate limit DMA mapping errors
[SCSI] hpsa: add P2000 to list of shared SAS devices
[SCSI] hpsa: do not attempt PCI power management reset method if we know it won't work.
[SCSI] hpsa: remove superfluous sleeps around reset code
This patch has Support for the new solid state device product SSS6200
from LSI and relavent features w.r.t SSS6200.
The major feature added in this driver is supporting Direct-I/O to the
SSS6200 storage.There are some additional changes done to avoid exposing
the RAID member disks to the OS and hiding/exposing drives based on the
OEM Specific Flag in Manufacturing Page10 (this is required to handle
specific changes in the SSS6200 firmware).
Each and every changes are listed below.
1. Hiding IR related messages.
For SSS6200, the driver is modified not to print IR related events.
Even if the debugging is enabled the IR related messages will not be displayed.
In some places if there is a need to display a message related to IR the
string "IR" is replaced with string "DD" and the string "volume" is replaced
with "direct drive". But the function names are not changed hence there are
some places where the reference to volume can be seen if debug level is set.
2. Removed RAID transport support
In Linux the user can retrieve RAID volume information from the sysfs directory.
This support is removed for SSS6200.
3. Direct I/O support.
The driver tries to enable direct I/O when a volume is reported to the driver
by the firmware through IRCC events and the driver does this just before
reporting to the OS, hence all the OS issued I/O can go through direct path
if they can, The first validation is to see whether the manufacturing page10
flag is set to expose all drives always. If that is set, the driver will not
enable direct I/O and displays the message "DDIO" is disabled globally as
drives are exposed. The driver checks whether there is more than one volume
in the controller, if so the direct I/O will be disabled globally for all
volumes in the controller and the message displayed will be "DDIO is disabled
globally as number of drives > 1.
If retrieving number of PD is failed the driver will not enable direct I/O
and displays the message Failure in computing number of drives DDIO disabled.
If memory allocation for RAIDVolumePage0 is failed, the driver will not enable
direct I/O and displays the message Memory allocation failure for
RVPG0 DDIO disabled. If retrieving RAIDVolumePage0 is failed the driver will
not enable direct I/O and displays the message Failure in retrieving
RVPG0 DDIO disabled
If the number of PD in a volume is greater than 8, then the direct I/O will
be disabled.
If any of individual drives handle retrieval is failed then the DD-IO will
be disabled.
If the volume is not RAID0 or if the block size is not 512 then the DD-IO will
be disabled.
If the volume size is greater than 2TB then the DD-IO will be disabled.
If the driver is not able to find a valid stripe exponent using the configured
stripe size then the DD-IO will be disabled
When the DD-IO is enabled the driver will check every I/O request issued to
the storage and checks whether the request is either
READ6/WRITE6/READ10/WRITE10, if it is and if the complete I/O transfer
is within a stripe size then the I/O is redirected to
the drive directly instead of the volume.
On completion of every I/O, if the completion is failure means if the reply
is address reply with a reply frame associated with it, then the type of I/O
will be checked, if the I/O is direct then the I/O will be retried to
the volume once.
Reviewed-by: Eric Moore <eric.moore@lsi.com>
Reviewed-by: Sathya Prakash <sathya.prakash@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The SCSI midlayer stops all command processing when in error handling, which
means there is no chance for command reuse when the abort handler is called.
Acked-by: "Moore, Eric" <Eric.Moore@lsi.com>
At two points in handling device ioctls via /dev/mpt2ctl, user-supplied
length values are used to copy data from userspace into heap buffers
without bounds checking, allowing controllable heap corruption and
subsequently privilege escalation.
Additionally, user-supplied values are used to determine the size of a
copy_to_user() as well as the offset into the buffer to be read, with no
bounds checking, allowing users to read arbitrary kernel memory.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Eric Moore <eric.moore@lsi.com>
Added Vendor specific branding message support.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits)
[SCSI] scsi_dh_rdac: Add MD36xxf into device list
[SCSI] scsi_debug: add consecutive medium errors
[SCSI] libsas: fix ata list corruption issue
[SCSI] hpsa: export resettable host attribute
[SCSI] hpsa: move device attributes to avoid forward declarations
[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)
[SCSI] sd: Logical Block Provisioning update
[SCSI] Include protection operation in SCSI command trace
[SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try)
[SCSI] target: Fix volume size misreporting for volumes > 2TB
[SCSI] bnx2fc: Broadcom FCoE offload driver
[SCSI] fcoe: fix broken fcoe interface reset
[SCSI] fcoe: precedence bug in fcoe_filter_frames()
[SCSI] libfcoe: Remove stale fcoe-netdev entries
[SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h
[SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument
[SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs
[SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out"
[SCSI] libfc: Fixing a memory leak when destroying an interface
[SCSI] megaraid_sas: Version and Changelog update
Fix up trivial conflicts due to whitespace differences in
drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
Simple conversions to drop flush_scheduled_work() usages in
drivers/scsi. More involved ones will be done in separate patches.
* NCR5380, megaraid_sas: cancel_delayed_work() +
flush_scheduled_work() -> cancel_delayed_work_sync().
* mpt2sas_scsih: drop unnecessary flush_scheduled_work().
* arcmsr_hba, ipr, pmcraid: flush the used work explicitly instead of
using flush_scheduled_work().
Upgrade driver version from 7.100.00.00 to 8.100.00.00
Basic Code Cleanup:
(1) _base_get_cb_idx and mpt2sas_base_free_smid were reorganized in
similar fashion so the order of obtaining the cbx and smid are
scsiio,
hi_priority, and internal.
(2) The hi_priority and internal request queue struct was made
smaller
by removing the scmd and chain_tracker, thus saving memory
allocation.
(3) For scsiio request, a new structure was created having the same
elements from the former request tracker struct.
Add support for Customer specific branding messages when device driver loads,
based on specific customer subsystem vendor and device Ids
Revision P MPI Header Update:
a) Added enable/disable SATA NCQ operations to SAS IO Unit Control
Request.
b) Modified Host Based Discovery Action Request message format.
c) Removed Device Path bit from IO Unit Page 1 Flags field.
d) Added description of ChainOffset field for Diagnostic Data Upload
Tool.Chaining is not allowed.
Removed mpi2_history.txt file
Issue:
IR shutdown(sending) and IR shutdown(complete) messages not
listed in /var/log/messages when driver is removed.
The driver needs to issue a MPI2_RAID_ACTION_SYSTEM_SHUTDOWN_INITIATED
request when the driver is unloaded so the IR metadata journal is updated.
If this request is not sent, then the volume would need a "check
consistency" issued on the next bootup if the volume was roamed from one
initiator to another. The current driver supports this feature only when the
system is rebooted, however this also need to be supported if the driver is
unloaded
Fix:
To fix this issue, the driver is going
to need to call the _scsih_ir_shutdown prior to reporting
the volumes missing from the OS, hence the device handles
are still present.
There was a configuration page timing out during the initial port
enable at driver load time. The port enable would fail, and this would
result in the driver unloading itself, meanwhile the driver was accessing
freed memory in another context resulting in the panic. The fix is to
prevent access to freed memory once the driver had issued the diag reset
which woke up the sleeping port enable process. The routine
_base_reset_handler was reorganized so the last sleeping process woken up was
the port_enable.
completion
False timeout after hard resets, there were two issues which leads
to timeout.
(1) Panic because of invalid memory access in the broadcast asyn
event processing routine due to a race between accessing the scsi command
pointer from broadcast asyn event processing thread and completing
the same scsi command from the interrupt context.
(2) Broadcast asyn event notifcations are not handled due to events
ignored while the broadcast asyn event is activity being processed
from the event process kernel thread.
In addition, changed the ABRT_TASK_SET to ABORT_TASK in the
broadcast async event processing routine. This is less disruptive to other
request that generate Broadcast Asyn Primitives besides target
reset. e.g clear reservations, microcode download,and mode select.
The ioc->hba_queue_depth is not properly resized when the controller
firmware reports that it supports more outstanding IO than what can be fit
inside the reply descriptor pool depth. This is reproduced by setting the
controller global credits larger than 30,000. The bug results in an
incorrect sizing of the queues. The fix is to resize the queue_size by
dividing queue_diff by two.
The "internal device reset complete" event is not supported
for older firmware prior to MPI Rev K We added
a check in the driver so the "internal device reset" event is
ignored for older firmware. When ignored, the tm_busy flag doesn't
get set nor cleared. Without this fix, IO queues would be froozen
indefinetly after the "internal device reset" event, as the "complete" event
never sent to clear the flag.
When zoning end devices, the driver is not sending device
removal handshake alogrithm to firmware. This results in controller
firmware not sending sas topology add events the next time the device is
added. The fix is the driver should be doing the device removal handshake
even though the PHYSTATUS_VACANT bit is set in the PhyStatus of the
event data. The current design is avoiding the handshake when the
VACANT bit is set in the phy status.
Changing debug print to correct string.
Fix oops loading driver when there is direct attached
SEP device
The driver set max phys count to the value reported in sas iounit page
zero. However this page doesn't take into account additional virutal
phys. When sas topology event arrives, the phy count is larger than
expected, and the driver accesses memory array beyond the end of
allocated space, then oops. Manufacturing page 8 contains the info
on direct attached phys.
For this fix will making sure that sas topology event is not
processing phys greater than the expected phy count.
change_queue_depth callback API changed
The change_queue_depth callback changed where there is now an additional
parameter called reason, with SCSI_QDEPTH_DEFAULT, SCSI_QDEPTH_QFULL,
and SCSI_QDEPTH_RAMP_UP codes.
remove support for MPI2_EVENT_TASK_SET_FULL
This event is obsoleted, so this processing of this event
needs to be removed from the driver. The controller firmware is going
to handle TASK_SET_FULL, the driver doesn't need to do anything.
Even though we are removing the EVENT handling, the behavour has not
changed between driver versions becuase fimrware will still be handling
queue throttling, and retrying of commands when the target device queues
are full.
MPI2 Rev header files.
1) Removed Task Set Full Event. Modified description of Disable SCSI
Initiator Task Set Full Handling bit in the Flags field of IO Unit
Page 1. Modified the descriptions for the three queue depth fields in
SAS IO Unit Page 1.
(2) Added new value for the Current Operation bits of the Flags field
in the RAID Volume Indicator Structure to indicate that the Make Data
Consistent operation is running.
(3) Added a value of 0x6 to various SAS link rate fields to indicate an
attached PHY that is not using any commonly supported settings.
(4) Added Volume Not Consistent bit to the VolumeStatusFlags field of
RAID Volume Page 0.
(5) Added a new value for the IncompatibleReason field of RAID Physical
Disk Page 0 to indicate an incompatible media type.
(6) Added Diagnostic Data Upload tool for the Toolbox Request.
Issue : Switch swap doesn't work when device missing delay is enabled.
(1) add support to individually add and remove phys to and from
existing ports. This replaces the routine
_transport_delete_duplicate_port.
(2) _scsih_sas_host_refresh - was modified to change the link rate
from zero to 1.5 GB rate when the firmware reports there is an
attached device with zero link.
(3) add new function mpt2sas_device_remove, this is wrapper function
deletes some redundant code through out driver by combining into one
subrountine
(4) two subroutines were modified so the sas_device, raid_device, and
port lists are traversed once when objects are deleted from the list.
Previously it was looping back each time an object was deleted from the
list.
Create a pool of chain buffers, instead of dedicated per IO:
This enahancment is to address memory allocation failure when asking
for more than 2300 IOs per host. There is just not enough contiquious
DMA physical memory to make one single allocation to hold both message
frames and chain buffers when asking for more than 2300 request. In order
to address this problem we will have to allocate memory for each chain
buffer in a seperate individual memory allocation, placing each chain
element of 128 bytes onto a pool of available chains, which can be
shared amoung all request.
Ability to override/set the ReportDeviceMissingDelay and
IODeviceMissingDelay from driver: Add new command line option missing_delay,
this is an array, where the first element is the device missing delay,
and the second element is io missing delay. The driver will program
sas iounit page 1 with the new setting when the driver loads. This is
programmed to the current and persistent configuration page so this takes
immediately, as will be sticky across host reboots.
Sometime it is seen that controller
firmware returns an invalid system message id (smid).
the oops is occurring becuase mpt_callbacks pointer is referenced to
either null or invalid virtual address. this is due to cb_idx set
incorrectly from routine _base_get_cb_idx. the cb_idx was set incorrectly
becuase there is no check to make sure smid is less than maxiumum
anticapted smid. to fix this issue, we add a check in
_base_get_cb_idx to make sure smid is not greater than
ioc->hba_queue_depth. in addition, a similar check was added to make
sure the reply address was less than the largest anticapated address.
Newer firmware has sovled this issue, however it good to have this sanity
check.
The compiler throws warning messages while compiling without
CONFIG_SCSI_MPT2SAS_LOGGING.
Set proper ifdef for CONFIG_SCSI_MPT2SAS_LOGGING to avoid warnnings.
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (84 commits)
[SCSI] be2iscsi: SGE Len == 64K
[SCSI] be2iscsi: Remove premature free of cid
[SCSI] be2iscsi: More time for FW
[SCSI] libsas: fix bug for vacant phy
[SCSI] sd: Fix overflow with big physical blocks
[SCSI] st: add MTWEOFI to write filemarks without flushing drive buffer
[SCSI] libsas: Don't issue commands to devices that have been hot-removed
[SCSI] megaraid_sas: Add Online Controller Reset to MegaRAID SAS drive
[SCSI] lpfc 8.3.17: Update lpfc driver version to 8.3.17
[SCSI] lpfc 8.3.17: Replace function reset methodology
[SCSI] lpfc 8.3.17: SCSI fixes
[SCSI] lpfc 8.3.17: BSG fixes
[SCSI] lpfc 8.3.17: SLI Additions and Fixes
[SCSI] lpfc 8.3.17: Code Cleanup and Locking fixes
[SCSI] zfcp: Remove scsi_cmnd->serial_number from debug traces
[SCSI] ipr: fix array error logging
[SCSI] aha152x: enable PCMCIA on 64bit
[SCSI] scsi_dh_alua: Handle all states correctly
[SCSI] cxgb4i: connection and ddp setting update
[SCSI] cxgb3i: fixed connection over vlan
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
