path: root/drivers/scsi/mvme147.c
2010-05-26m68k/scsi: mvme147 - Kill obsolete HOSTS_C logicGeert Uytterhoeven
Kill the obsolete HOSTS_C define and the related double inclusion of mvme147.h Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-05-26m68k/scsi: mvme147 - Kill static global mvme147_hostGeert Uytterhoeven
2010-05-02[SCSI] mvme147: Use shost_priv() and kill ugly HDATA() macroGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-02[SCSI] mvme147: ReindentationGeert Uytterhoeven
2010-05-02[SCSI] wd33c93: Kill empty wd33c93_release()Geert Uytterhoeven
wd33c93_release() has been empty since ages, and sgiwd93.c no longer calls it since its conversion to a proper platform driver 2 years ago. Also remove the callers in the m68k wd33c93 shims. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2008-04-07[SCSI] wd33c93: fix up cut and paste errorJames Bottomley
The three drivers: a2091, gvp11 and mvme147 have erroneous references to a3000_host. Fix these to be references to the proper host variable. Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] WD33C93: let platform stub override no_sync/fast/dma_modeThomas Bogendoerfer
SGI machines with WD33C93 allow usage of burst mode DMA, which increases performance noticable. To make this selectable by the sgiwd93 stub, setting the values for no_sync, fast and dma_mode has been moved to the individual platform stubs. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-12[SCSI] wd33c93: Scsi_Cmnd convertionHenrik Kretzschmar
Changes obsolete typedef'd Scsi_Cmnd to struct scsi_cmnd. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-10Merge by hand (whitespace conflicts in libata.h)James Bottomley
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
