path: root/drivers/scsi/pm8001
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-12[SCSI] pm8001: simplify workqueue usageTejun Heo
pm8001 manages its own list of pending works and cancel them on device free. It is unnecessarily complex and has a race condition - the works are canceled but not synced, so the work could still be running during and after the data structures are freed. This patch simplifies workqueue usage. * A driver specific workqueue pm8001_wq is created to serve these work items. * To avoid confusion, the "queue" suffixes are dropped from work items and functions. * Delayed queueing was never used. pm8001_work now uses work_struct instead. * The driver no longer keeps track of pending works. All pm8001_works are queued to pm8001_wq and the workqueue is flushed as necessary. flush_scheduled_work() usage is removed during conversion. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-09[SCSI] pm8001: handle allocation failuresDan Carpenter
Return -ENOMEM if the allocations fail. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06[SCSI] pm8001: introduce missing kfreeJulia Lawall
Error handling code following a kmalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; expression E; identifier f,f1; position p1,p2; @@ x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); <... when != x when != if (...) { <+...x...+> } when != (x) == NULL when != (x) != NULL when != (x) == 0 when != (x) != 0 ( x->f1 = E | (x->f1 == NULL || ...) | f(...,x->f1,...) ) ...> ( return <+...x...+>; | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: jack wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-07-28[SCSI] Unify SAM_ and SAM_STAT_ macrosJames Bottomley
We have two separate definitions for identical constants with nearly the same name. One comes from the generic headers in scsi.h; the other is an enum in libsas.h ... it's causing confusion about which one is correct (fortunately they both are). Fix this by eliminating the libsas.h duplicate Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
2010-06-16fix typos concerning "management"Uwe Kleine-König
2010-05-02[SCSI] pm8001: potential null dereference in pm8001_dev_gone_notify()Dan Carpenter
In the original code we dereferenced "pm8001_dev" before checking if it was null. This patch moves the dereference inside the condition. This was found by a static checker (smatch). I looked, but I couldn't tell if "pm8001_dev" dev was ever actually null. The approach in this patch seemed like the safest response. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] pm8001: drop redundant memsetJulia Lawall
The region set by the call to memset is immediately overwritten by the subsequent call to memcpy. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e1,e2,e3,e4; @@ - memset(e1,e2,e3); memcpy(e1,e4,e3); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-18[SCSI] pm8001: Use kzalloc for allocating only one thingJulia Lawall
Use kzalloc rather than kcalloc(1,...) The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ @@ - kcalloc(1, + kzalloc( ...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by:Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-10[SCSI] pm8001: misc code cleanupjack wang
Add more data to printk's, add some spaces around arithmetic ops and improve comments. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-10[SCSI] pm8001: enable read HBA SAS address from VPDjack wang
2009-12-10[SCSI] pm8001: do not reset local sata as it will not be found if resetjack wang
2009-12-10[SCSI] pm8001: bit set pm8001_ha->flagsjack wang
2009-12-10[SCSI] pm8001:fix potential NULL pointer dereferencejack wang
2009-12-10[SCSI] pm8001: set SSC down-spreading only to get less errors on some 6G device.jack wang
2009-12-10[SCSI] pm8001: fix endian issues with SAS addressjack wang
2009-12-10[SCSI] pm8001: enhance error handle for IO patchjack wang
Enhance error handle for IO patch, when the port is down, fast return phy down for task. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-10[SCSI] pm8001: Fix for sata io circular lock dependency.jack wang
This patch fix for sata IO circular lock dependency. When we call task_done for SATA IO, we have got pm8001_ha->lock ,and in sas_ata_task_done, it will get (dev->sata_dev.ap->lock. then cause circular lock dependency .So we should drop pm8001_ha->lock when we call task_done for SATA task. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Lindar Liu <lindar_liu@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] pm8001: Fixes for tag alloc, error goto and code cleanupjack_wang
Allocate right size for bitmap tag,fix error goto and cleanup print message and undocable commemts. patch attached. Signed-off-by: Lindar Liu <lindar_liu@usish.com> Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] pm8001: enhance IOMB process modulesjack_wang
We set interupt cascading count of outbound queue to get better performance, correct some unnecessary return values and some noisy print messages. patch attached. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Lindar Liu <lindar_liu@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] pm8001: add reinitialize SPC parameters before phy startjack_wang
2009-12-04[SCSI] pm8001: add SAS/SATA HBA driverjack wang
This driver supports PMC-Sierra PCIe SAS/SATA 8x6G SPC 8001 chip based host adapters. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Lindar Liu <lindar_liu@usish.com> Signed-off-by: Tom Peng <tom_peng@usish.com> Signed-off-by: Kevin Ao <aoqingyun@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
