Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
The initial-control-block references are not always correct
as the use-node-name qualifier during NVRAM configuration
will cause the firmware to use the portname as a base for
the nodename.
Transition driver to exclusively use the request_firmware()
interfaces to retrieve firmware-blobs from user-space. This
will be the default behaviour going forward until the
embedded firmware-binary images are removed from the
upstream kernel.
Upon request, the driver caches the firmware image until the
driver is unloaded.
NOTE: The option is present to allow the user to continue to
use the firmware-loader modules, but, should be considered
deprecated.
Rejections fixed up and
Ok, here's a patch to add such a common API for fc transport users.
Relevant LLD changes (lpfc and qla2xxx) also present.
ISP23xx and ISP24xx chips have support for an adaptive
method of posting SCSI command completions for multiple SCSI
commands during a single system interrupt.
SCSI commands are placed on the system response queue
without interrupting the host until 1) a delay timer
expires; or 2) a SCSI command completes with an error.
As long as the host software (qla2xxx) services the response
queue for completions (this polling is done during
queuecommand()) within the 'delay timer' period, the
firmware will not generate system interrupt.
Export additional host information via the shost_attrs member in
the scsi_host template. Attributes include: driver version,
firmware version, ISP serial number, ISP type, ISP product ID,
HBA model name, HBA model description, PCI interconnect
information, and HBA port state.
Export COS information for the fc_host and fc_remote_port
objects added by the driver.
Add OS initialization codes for ISP24xx recognition.
Add ISP24xx flash-manipulation routines.
Add read/write flash manipulation routines for the ISP24xx.
Update sysfs NVRAM objects to use generalized accessor
functions.
Factor-out ISP specific functions to method-based call tables.
In anticipation of ISP24xx/ISP25xx support, factor-out ISP
specific functions into a method-based call table.
Make transport-functions structure non-static. Replace #include of
scsi_transport.h with a forward declaration.
CC [M] drivers/scsi/qla2xxx/qla_attr.o
drivers/scsi/qla2xxx/qla_attr.c: In function `qla2x00_sysfs_write_fw_dump':
drivers/scsi/qla2xxx/qla_attr.c:65: warning: implicit declaration of function `vfree'
drivers/scsi/qla2xxx/qla_attr.c:83: warning: implicit declaration of function `vmalloc'
drivers/scsi/qla2xxx/qla_attr.c:83: warning: cast to pointer from integer of different size
Also remove spurious inclusion of linux/version.h
Remove internal lun discovery routines and support
structures.
Add initial support for FC remote port infrastructure.
o Use fc_remote_port...() registration and block/unlock
functions.
o Consolidate 'attribute' (fc-remote/sysfs) helpers into
new qla_attr.c file.
