Add ability to allow each physical port to control operating mode. Current
code forces all ports to behave in one mode (i.e. initiator, target or
dual). This patch allows user to select the operating mode for each port.
- Driver must be loaded in dual mode to allow resource allocation
modprobe qla2xxx qlini_mode=dual
- In addition user can make adjustment to exchange resources using following
command
echo 1024 > /sys/class/scsi_host/host<x>/ql2xiniexchg
echo 1024 > /sys/class/scsi_host/host<x>/ql2xexchoffld
- trigger mode change and new setting of ql2xexchoffld|ql2xiniexchg
echo [<value>] > /sys/class/scsi_host/host<x>/qlini_mode
where, value can be one of following
- enabled
- disabled
- dual
- exclusive
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
Using GPNFT/GNNFT command will be able to cover switch database with less
number of scans. This patch removes Get NportID with provided WWPN/GIDPN
switch command. By making this change, in large fabric with lots of remote
port or NPIV ports with noisy SAN, the number of GIDPN commands issued by a
port when it detects large number of remote ports going away or coming back,
can overwhelmn the switch and it can becomde unresponsive. In a case where the
fabric has not change, GIDPN is not required.
Currently, the rport registration is being called from a single work element
that is used to process QLA internal "work_list". This work_list is meant for
quick and simple task (ie no sleep). The Rport registration process sometime
can be delayed by upper layer. This causes back pressure with the internal
queue where other jobs are unable to move forward.
This patch will schedule the registration process with a new work element
(fc_port.reg_work). While the RPort is being registered, the current state of
the fcport will not move forward until the registration is done. If the state
of the fabric has changed, a new field/next_disc_state will record the next
action on whether to 'DELETE' or 'Reverify the session/ADISC'.
Pull SCSI updates from James Bottomley:
"This is mostly updates to the usual drivers: mpt3sas, lpfc, qla2xxx,
hisi_sas, smartpqi, megaraid_sas, arcmsr.
In addition, with the continuing absence of Nic we have target updates
for tcmu and target core (all with reviews and acks).
The biggest observable change is going to be that we're (again) trying
to switch to mulitqueue as the default (a user can still override the
setting on the kernel command line).
Other major core stuff is the removal of the remaining Microchannel
drivers, an update of the internal timers and some reworks of
completion and result handling"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (203 commits)
scsi: core: use blk_mq_run_hw_queues in scsi_kick_queue
scsi: ufs: remove unnecessary query(DM) UPIU trace
scsi: qla2xxx: Fix issue reported by static checker for qla2x00_els_dcmd2_sp_done()
scsi: aacraid: Spelling fix in comment
scsi: mpt3sas: Fix calltrace observed while running IO & reset
scsi: aic94xx: fix an error code in aic94xx_init()
scsi: st: remove redundant pointer STbuffer
scsi: qla2xxx: Update driver version to 10.00.00.08-k
scsi: qla2xxx: Migrate NVME N2N handling into state machine
scsi: qla2xxx: Save frame payload size from ICB
scsi: qla2xxx: Fix stalled relogin
scsi: qla2xxx: Fix race between switch cmd completion and timeout
scsi: qla2xxx: Fix Management Server NPort handle reservation logic
scsi: qla2xxx: Flush mailbox commands on chip reset
scsi: qla2xxx: Fix unintended Logout
scsi: qla2xxx: Fix session state stuck in Get Port DB
scsi: qla2xxx: Fix redundant fc_rport registration
scsi: qla2xxx: Silent erroneous message
scsi: qla2xxx: Prevent sysfs access when chip is down
scsi: qla2xxx: Add longer window for chip reset
This patch fixes regression introduced for the N2N support for FC-NVMe. For
FC-NVMe with N2N connection, instead of FW initiating the Login, Driver
starts Login process. This patch migrates that new process from a
standalone path into existing session management state machine. With this
state change now driver will not wait for pull NPort ID from FW.
Fixes: edd05de197592 ("scsi: qla2xxx: Changes to support N2N logins")
Fix race condition between switch cmd completion and timeout timer. Timer
has popped triggers command free. On IOCB completion, stale sp point was
reused. Instead, an abort will be sent to FW to nudge the command out of FW
where the normal completion will take place.
RIP: 0010:qla2x00_chk_ms_status+0xf3/0x1b0 [qla2xxx]
Call Trace:
<IRQ>
qla24xx_els_ct_entry.isra.15+0x1d4/0x2b0 [qla2xxx]
qla24xx_msix_rsp_q+0x39/0xf0 [qla2xxx]
qla24xx_process_response_queue+0xbc/0x2b0 [qla2xxx]
qla24xx_msix_rsp_q+0x8a/0xf0 [qla2xxx]
__handle_irq_event_percpu+0xa0/0x1f0
After selecting the NPort handle/loop_id, set a bit in the loop_id_map to
prevent others from selecting the same NPort handle.
Add wait for session deletion to finish before freeing an NPIV scsi host.
Fixes: 726b85487067 ("qla2xxx: Add framework for async fabric discovery")
Cc: <stable@vger.kernel.org>
Move GPSC & GFPNID commands out of session management to reduce time lag
in reporting the session state to remote port. These commands are not
essential when it comes to maintaining the rport state. Delay sending
these commands after rport state is set to Online.
This patch combines FCP and FC-NVMe scan into single scan when
driver detects FC-NVMe capability on same port.
Signed-off-by: Darren Trapp <darren.trapp@cavium.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
for session deletion, replace sess_lock with work_lock.
Under certain case sess_lock is not feasiable to acquire.
The lock is needed temporarily to make sure a single
call to schedule of the work element.
Immeadiate flag is not used for scheduling session deletion.
Remove it to simplfy session deletion code path.
add ability to use gpnft/gnnft to handle RSCN.
Migrate switch registration commands: RFTID, RFFID, RNNID and RSNN_NN
out of mailbox interface to reduce fabric scan bottle neck.
- add "async" gpn_ft, gnn_ft, gfpn_id, gnn_id switch commands.
- For 8G and newer adapters, use async commands when it comes to
fabric scan to reduce bottle neck.
Fetch actual data from firmware instead of static data
at chip reset time.
Signed-off-by: Quinn Tran <quinn.tran@qlogic.com>
Add ability to send Implicit PRLO to flush IOs
from FW back to driver.
Add option to tell FW to reserve 1/2 of emergency exchanges for ELS.
DPC thread can stall during switch scan due to slow switch response.
This will stall other work element that needs attention. Moving work
element processing and relogin logic out of DPC thread and into its
own work queue.
"This is mostly updates of the usual suspects: lpfc, qla2xxx, hisi_sas,
megaraid_sas, pm80xx, mpt3sas, be2iscsi, hpsa. and a host of minor
updates.
There's no major behaviour change or additions to the core in all of
this, so the potential for regressions should be small (biggest
potential being in the scsi error handler changes)"
scsi: lpfc: Fix hard lock up NMI in els timeout handling.
scsi: mpt3sas: remove a stray KERN_INFO
scsi: mpt3sas: cleanup _scsih_pcie_enumeration_event()
scsi: aacraid: use timespec64 instead of timeval
scsi: scsi_transport_fc: add 64GBIT and 128GBIT port speed definitions
scsi: qla2xxx: Suppress a kernel complaint in qla_init_base_qpair()
scsi: mpt3sas: fix dma_addr_t casts
scsi: be2iscsi: Use kasprintf
scsi: storvsc: Avoid excessive host scan on controller change
scsi: lpfc: fix kzalloc-simple.cocci warnings
scsi: mpt3sas: Update mpt3sas driver version.
scsi: mpt3sas: Fix sparse warnings
scsi: mpt3sas: Fix nvme drives checking for tlr.
scsi: mpt3sas: NVMe drive support for BTDHMAPPING ioctl command and log info
scsi: mpt3sas: Add-Task-management-debug-info-for-NVMe-drives.
scsi: mpt3sas: scan and add nvme device after controller reset
scsi: mpt3sas: Set NVMe device queue depth as 128
scsi: mpt3sas: Handle NVMe PCIe device related events generated from firmware.
scsi: mpt3sas: API's to remove nvme drive from sml
scsi: mpt3sas: API 's to support NVMe drive addition to SML
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: qla2xxx-upstream@qlogic.com
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: linux-scsi@vger.kernel.org
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Tested-by: Bart Van Assche <Bart.VanAssche@wdc.com>
If we discovered a topology that is N2N then we will issue a login to
the target. If our WWPN is bigger than the target's WWPN then we will
initiate login, otherwise we will just wait for the target to initiate
login.
[mkp: many whitespace errors]
Signed-off-by: Duane Grigsby <duane.grigsby@cavium.com>
Signed-off-by: Michael Hernandez <michael.hernandez@cavium.com>
Tested-by: Ewan D. Milne <emilne@redhat.com>
[mkp: fixed whitespace]
Call Trace:
[<ffffffff81341687>] dump_stack+0x6b/0xa4
[<ffffffff810c3e30>] ? print_irqtrace_events+0xd0/0xe0
[<ffffffff8109e3c3>] ___might_sleep+0x183/0x240
[<ffffffff8109e4d2>] __might_sleep+0x52/0x90
[<ffffffff811fe17b>] kmem_cache_alloc_trace+0x5b/0x300
[<ffffffff810c666b>] ? __lock_acquired+0x30b/0x420
[<ffffffffa0733c28>] qla2x00_alloc_fcport+0x38/0x2a0 [qla2xxx]
[<ffffffffa07217f4>] ? qla2x00_do_work+0x34/0x2b0 [qla2xxx]
[<ffffffff816cc82b>] ? _raw_spin_lock_irqsave+0x7b/0x90
[<ffffffffa072169a>] ? qla24xx_create_new_sess+0x3a/0x160 [qla2xxx]
[<ffffffffa0721723>] qla24xx_create_new_sess+0xc3/0x160 [qla2xxx]
[<ffffffff810c91ed>] ? trace_hardirqs_on+0xd/0x10
[<ffffffffa07218f8>] qla2x00_do_work+0x138/0x2b0 [qla2xxx]
When RSCN is delivered for specific remote port. Use ADISC to verify the
session is still valid or not.
SFP can come in 2 formats: short range/SR and long range/LR. For LR,
user the can increase the number of Buffer to Buffer credits between end
points via Cavium's command line tool. By default, FW uses a lower BB
Credit value optimized for SR. This patch will read the SFP for each
link up event and during chip reset sequence. If the SFP type and
setting are mismatch, then the chip is reset 1 time to use the
appropriate setting.
The driver held spinlocks during callbacks for NVME errors which
resulted in a deadlock because recovery LS cmds needed the same lock.
Add support to the driver to set the exchange threshold value for
the number of outstanding AENs.
Signed-off-by: Anil Gurumurthy <anil.gurumurthy@cavium.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
This patch adds switch command support for FC-4 type of FC-NVMe (0x28)
for resgistering HBA port to the management server. RFT_ID command is
used to register FC-4 type of 0x28 and RFF_ID is used to register FC-4
features bits for FC-NVMe port.
Signed-off-by: Anil Gurumurthy <anil.gurumurhty@cavium.com>
Signed-off-by: Giridhar Malavali <giridhar.malavali@cavium.com>
Reviewed-By: James Smart <james.smart@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This code provides the interfaces to register remote and local ports of
FC4 type 0x28 with the FC-NVMe transport and transports the requests
(FC-NVMe FC link services and FC-NVMe commands IUs) to the fabric. It
also provides the support for allocating h/w queues and aborting FC-NVMe
FC requests.
Added logic to change the login process into an optional PRIL step for
FC-NVMe ports as a separate operation, such that we can change type to
0x28 (NVMe).
Currently, the driver performs the PLOGI/PRLI together as one operation,
but if the discovered port is an NVMe port then we first issue the PLOGI
and then we issue the PRLI. Also, the fabric discovery logic was changed
to mark each discovered FC NVMe port, so that we can register them with
the FC-NVMe transport later.
For Target mode, user can control the work load by placing qla2xxx's irq
vector on certain CPU via the smp_affinity knob. This patch allows user
to control the number of QPair's irq to be active. The irqs are
allocated at driver load time until unload. The work itself is placed on
the QPair based on user setting.
Usage:
modprobe qla2xxx qlini_mode=disabled ql2xuctrlirq=1
mount -t debugfs none /sys/kernel/debug
echo 2 > /sys/kernel/debug/qla2xxx/qla2xxx_[host num]/naqp
echo [cpu id] > /proc/irq/[irq id]/smp_affinity_list
In Current code, Req Q 0, RespQ 0 & hardware_lock are the main resources
for sending and process completion of Target IO. These resources are now
referenced behind a new qpair/"struct qla_qpair base_qpair". Main path
IO handle will access those resources via the qpair pointer in
preparation for Target MQ.
Merge active/outstanding cmd arrays from target side and initiator side
together in prepration for Target Multi Queue support.
Previously, the ql2xexchoffld module parameter was used to control the
max number of exchanges to be offload onto host memory.
Module parameter ql_dm_tgt_ex_pct was used to control the percentage of
exchanges allocated to the Target side.
With this patch, module parameter ql_dm_tgt_ex_pct is no longer used to
control exchanges for the driver. New module parameter ql2xiniexchg is
added to control exchanges between target mode and initiator mode.
With the updated module parameters, users can control the exact number
of exchanges for either Initiator or Target. The exchange offload
feature will be automatically enabled when the total number of exchanges
exceeds 2048 limit.
For target mode, when new scsi command arrive, driver first performs
a look up of the SCSI Host. The current look up method is based on
the ALPA portion of the NPort ID. For Cisco switch, the ALPA can
not be used as the index. Instead, the new search method is based
on the full value of the Nport_ID via btree lib.
The Mailbox interface is currently over subscribed. We like
to reserve the Mailbox interface for the chip managment and
link initialization. Any non essential Mailbox command will
be routed through the IOCB interface. The IOCB interface is
able to absorb more commands.
Following commands are being routed through IOCB interface
- Get ID List (007Ch)
- Get Port DB (0064h)
- Get Link Priv Stats (006Dh)
Add routines to support T10 DIF tag.
This patch simplifies SRB structure usage in driver.
- Simplify sp->done() and sp->free() interfaces.
- Remove sp->fcport->vha to use vha pointer from sp.
- Use sp->vha context in qla2x00_rel_sp().
Signed-off-by: Joe Carnuccio <joe.carnuccio@cavium.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Current code blindly does State Change Registration when
the link is up. Move SCR behind fabric scan, so that arbitrated
loop scan would not get erroneous error message.
Some of the other improvements are as follows
- Add session deletion for TPRLO and send acknowledgment for TPRLO.
- Enable FW option to move ABTS, RIDA & PUREX from RSPQ to ATIOQ.
- Save NPort ID early in link init.
- Move ABTS & RIDA to ATIOQ helps in keeping command ordering and
link up sequence ordering.
- Save Nport ID and update VP map so that SCSI CMD/ATIO won't be dropped.
- fcport alloc does the initializes memory to zero. Remove memset to
zero since It might corrupt link list.
- Turn off Registration for State Change MB in loop mode.
Currently code performs a full scan of the fabric for
every RSCN. Its an expensive process in a noisy large SAN.
This patch optimizes expensive fabric discovery process by
scanning switch for the affected port when RSCN is received.
Currently Initiator Mode code makes login/logout decision without
knowledge of target mode. This causes driver and firmware to go
out-of-sync. This framework synchronizes both initiator mode
personality and target mode personality in making login/logout
decision.
This patch adds following capabilities in the driver
- Send Notification Acknowledgement asynchronously.
- Update session/fcport state asynchronously.
- Create a session or fcport struct asynchronously.
- Send GNL asynchronously. The command will ask FW to
provide a list of FC Port entries FW knows about.
- Send GPDB asynchronously. The command will ask FW to
provide detail data of an FC Port FW knows about or
perform ADISC to verify the state of the session.
- Send GPNID asynchronously. The command will ask switch
to provide WWPN for provided NPort ID.
- Send GPSC asynchronously. The command will ask switch
to provide registered port speed for provided WWPN.
- Send GIDPN asynchronously. The command will ask the
switch to provide Nport ID for provided WWPN.
- In driver unload path, schedule all session for deletion
and wait for deletion to complete before allowing driver
unload to proceed.
[ bvanassche: fixed spelling in patch description ]
Replaced existing multiple queue functionality with framework
that allows for the creation of pairs of request and response queues,
either at start of day or dynamically.
Queue pair creation depend on module parameter "ql2xmqsupport",
which need to be enabled to create queue pair.
Signed-off-by: Sawan Chandak <sawan.chandak@cavium.com>
Acked-by: Christoph Hellwig <hch@lst.de>
Change FC drivers to use 'struct bsg_job' from bsg-lib.h instead of
'struct fc_bsg_job' from scsi_transport_fc.h and remove 'struct
fc_bsg_job'.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Set bit 12 of additional firmware options 3 to let firmware
hold status IOCB until ABTS response is received from Target.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
