commit a67093d46e3caed1a42d694a7de452b61db30562 upstream.
Original code incorrectly assumed only status-type-0
IOCBs would be queued to the response-queue, and thus all
entries would safely reference a VHA from the IOCB
'handle.'
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
ISPs which support this feature include 23xx and above.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Ensure MPS remains in synchronization across all NIC/FCoE
functions after a reset.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Unlike earlier ISPs, recent ISPs (ISP81xx) can in fact fail this
mailbox command.
Firmware currently provides PB and PGF TLVs.
As it may be useful during debugging to use a specific firmware
image.
Changing a lun's queue depth (/sys/block/sdX/device/queue_depth)
isn't sticky when the device is connected via a QLogic fibre
channel adapter.
The QLogic qla2xxx fibre channel driver dynamically adjusts a
lun's queue depth. If a user has a specific need to limit the
number of commands issued to a lun (say a tape drive, or a shared
raid where the total commands issued to all luns is limited at
the controller level, for example) and writes a limiting value to
/sys/block/sdXX/device/queue_depth, the qla2xxx driver will
silently and gradually increase the queue depth back to the
driver limit of ql2xmaxqdepth. While reducing this value (module
parameter) or increasing the interval between ramp ups
(ql2xqfullrampup) offers the potential for a work around it would
be better to have the option of just disabling the dynamic
adjustment of queue depth.
This patch implements an "off switch" as a module parameter.
Signed-off-by: Michael Reed <mdr@sgi.com>
Set the number of request queues to the module paramater
ql2xmaxqueues. Each vport gets a request queue. The QoS value
set to the request queues determines priority control for queued
IOs. If QoS value is not specified, the vports use the default
queue 0.
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Interface allows for the update of onboard EDC firmware
present on mezzanine ISP25xx type cards.
Signed-off-by: Lalit Chandivade <lalit.chandivade@qlogic.com>
Additional cleanups and
Ensure that an ISP-abort has completed before performing any
update. After the update do not wait for an ISP-abort completion,
instead just wait until the ISP is reset. This avoids long
delays due to waiting for loop ready in qla2x00_abort_isp().
Given the low-level interface varies from one flash-part
manufacturer to the next, the Flash-Access-Control (FAC) mailbox
command makes the specific flash type transparent to the driver
by encapsulating a basic set of accessor and update routines.
Use these new routines where applicable by querying FAC opcode
get-sector-size at init-time.
Reflects layout and format of latest specification.
Post refactoring/multi-queue additions essentially eliminated the
need for separate ISP24XX+ queuecommand as isp_ops contains a
function pointer to the associated 'start_scsi()' operation.
To ensure smooth operations amongst the FCoE and NIC side
components of the ISP81xx chip, the FCoE driver (qla2xxx) must
ensure the 10gb NIC driver (qlge) does not timeout waiting for
IDC (Inter-Driver Communication) acknowledgments. The
acknowledgment requirements are trivial -- a simple mirroring of
incoming mailbox registers during the AEN to a process-context
capable mailbox command.
processing path in multiq mode.
Correct response-queue-0 processing by instructing the firmware
to run with interrupt-handshaking disabled, similarly to what is
now done for all non-0 response queues. Since all
response-queues now run in the same mode, the driver no longer
needs the hot-path 'is-disabled-HCCR' test.
Pre-ISP81XX parts (including ISP24xx and ISP25xx) could contain a
firmware image within a segment of flash, driver would fallback
to loading this firmware if the request-firmware interface failed
(userspace .bin file). Moving forward, all ISP81XX parts will
ship with a suggested-to-be-used firmware image within flash
which all driver should first attempt to load. If the flash
firmware load fails, the driver will then fallback to loading
firmware via the request-firmware interface (ql8100_fw.bin).
Codes to support new FCoE boards.
Software should not touch this region of flash, as the firmware
will be the only writer and consumer of the region.
Following changes have been made:
1. Scan outstanding commands only in the queue where it is submitted
2. Update queue registers directly in the fast path
3. Queue specific BAR is remapped only for multiq capable adapters
Following changes have been made.
1. qla_hw_data structure holds an array for request queue pointers,
and an array for response queue pointers.
2. The base request and response queues are created by default.
3. Additional request and response queues are created at the time of vport
creation. If queue resources are exhausted during vport creation, newly
created vports use the default queue.
4. Requests are sent to the request queue that the vport was assigned
in the beginning.
5. Responses are completed on the response queue with which the request queue
is associated with.
[fixup memcpy argument reversal spotted by davej@redhat.com]
Following changes have been made to the qla2xxx FC driver in
preparation for the multi- queue and future SR IOV hardware.
1. scsi_qla_host structure has been changed to contain scsi host
specific data only.
2. A new structure, qla_hw_data is created to contain HBA specific
hardware data.
3. Request and response IO specific data strucures are created.
4. The global list of fcports for the hba is not maintained anymore,
instead a fcport list is construted on per scsi_qla_host.
Signed-of-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
To instatiate pre-configured vport entities defined within an
HBA's flash memory.
The Flash Layout Table (FLT) present on many recent HBAs encodes
flash usage information, organizes data stored into separate
regions and presents the information uniformly to the driver.
Use this information rather than using specific hard-coded values
based on ISP type.
Recent ISPs have this information written at manufacturing time,
so use the information. This also reduces future churn of the
qla_devtbl.h file contents, as the driver can now depend on the
information to be present in VPD.
iIDMA support requires the driver issue several additional
fabric-managegment (FM) commands per port discovered during SNS
scanning -- GFPN (Get Fabric Port Name) and GPSC (Get Port Speed
Capabilities). It has been found during testing that some
switches do not respond as *well* as expected to these commands
(silence -- no ACC nor BS_RJT). So, to handle such conditions,
allow the user the ability to indirectly disable the FM commands
by disabling iIDMA with the ql2xiidmaenable module-parameter.
Removed repeated or unnecessary operations during vport
creation/deletion.
Signed-off-by: Shyam Sundar <shyam.sundar@qlogic.com>
Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com>
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com>
firmware dump.
The user-initiated dump can be a useful tool in triaging complex
ISP and FC issues.
This patch makes the needlessly global qla2x00_issue_iocb_timeout()
static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Now that infrastructure is present within the midlayer and there
is a clear distinction between what is expected from a device and
target reset, convert the current device-reset codes to a
target-reset, and add codes to perform a proper device-reset (LUN
reset).
In the process of adding reset support, collapse and consolidate
large sections of mailbox-command (TMF issuance) codes,
generalize the two 'wait-for-commands-to-complete' functions, and
add a generic-reset routine for use by midlayer reset functions.
The Flash Descriptor Table (FDT) present on many recent HBAs
encodes flash accessing characteristics of the flash-part used on
the HBA. Use this information during flash manipulation (writes)
rather than using specific hard-coded values based on queried
manufacturer and device IDs.
Strip unused (DEBUG-ONLY) enabled functions, inlines, useless
wrappers, and unused DPC flags from the code. Another step in
the migration towards a cleaner (less-crusty) driver.
Recent ISPs have a region within FLASH which acts as a repository
for the logging of serious hardware and software failures.
Currently, the region is large enough to support up to 255
entries.
Supported events include LIP, LIP reset, RSCN, link up, and link
down.
To support AEN (and additional forthcoming features), we also
introduce a simple deferred-work construct to manage events which
require a non-atomic sleeping-capable context. This work-list is
processed as part of the driver's standard DPC routine.
Refactor SRB-failure completion codes in the process. Also,
signal the DPC routine to complete sooner as backend processing
at shutdown-time is superflous.
[jejb: resolve conflicts with pci_enable_device_bars removal]
FCE support enables the firmware to record FC extended link
services and basic link services frames which have been
transmitted and received by the ISP. This allows for a limited
view of the FC traffic through the ISP without using a FC
analyzer. This can be useful in situations where a physical
connection to the FC bus is not possible.
The driver exports this information in two ways -- first, via a
debugfs node exported for all supported ISPs under:
<debugfs_mount_point>/qla2xxx/qla2xxx_<host_no>/fce
where a read of the 'fce' file will provide a snapshot of the
firmware's FCE buffer; and finally, the FCE buffer will be
extracted during a firmware-dump scenario.
In preparation for FCE (Fibre Channel Event) tracing support.
- make the following needlessly global code static:
- qla_attr.c: qla24xx_vport_delete()
- qla_attr.c: qla24xx_vport_disable()
- qla_mid.c: qla24xx_allocate_vp_id()
- qla_mid.c: qla24xx_find_vhost_by_name()
- qla_mid.c: qla2x00_do_dpc_vp()
- qla_os.c: struct qla2x00_driver_template
- qla_os.c: qla2x00_stop_timer()
- qla_os.c: qla2x00_mem_alloc()
- qla_os.c: qla2x00_mem_free()
- qla_sup.c: qla2x00_lock_nvram_access()
- qla_sup.c: qla2x00_unlock_nvram_access()
- qla_sup.c: qla2x00_get_nvram_word()
- qla_sup.c: qla2x00_write_nvram_word()
- #if 0 the following unused global functions:
- qla_mbx.c: qla2x00_system_error()
- qla_os.c: remove some unneeded function prototypes
- removed unused functions:
- qla_dbg.c: qla2x00_dump_pkt()
- qla_mbx.c: qla2x00_get_serdes_params()
- qla_mbx.c: qla2x00_get_idma_speed()
- qla_mbx.c: qla24xx_get_vp_database()
- qla_mbx.c: qla24xx_get_vp_entry()
Small modifications and
Instead of abusing the semaphore interfaces for mailbox command
completions.
As the driver depends on the DPC routine to handle bottom-half
loop resynchronization in order to recover from the issue-lip
request. The issue_lip call is sleeping context capable, so just
issue the reset function there.
HBAs supporting these additional counters include ISP24xx and
ISP25xx type boards.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Newer ISPs support a mechanism to read and write flash-memory via
the firmware LOAD/DUMP memory mailbox command routines. When
supported, utilizing these mechanisms significantly reduces
overall access times.
Large code-reuse from ISP24xx, consolidate RISC memory
extraction routines during firmware-dump.
