path: root/drivers/scsi/qla2xxx/qla_mbx.c
2013-12-19[SCSI] qla2xxx: Add BSG interface for read/write serdes register.Joe Carnuccio
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-12-19[SCSI] qla2xxx: Add BPM support for ISP25xx.Chad Dupuis
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-12-19[SCSI] qla2xxx: Correctly set mailboxes for extended init control block.Joe Carnuccio
2013-09-03[SCSI] qla2xxx: Correctly print out/in mailbox registers.Joe Carnuccio
At mailbox/buffer debug level, print the correct values of the outgoing and incoming mailbox registers. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] qla2xxx: Select link initialization option bits from current ↵Joe Carnuccio
operating mode. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] qla2xxx: Reconfigure thermal temperature.Joe Carnuccio
For supported ISPS, Read asic temperature by calling the GET PARAMS (type C) mailbox command. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] qla2xxx: Add setting of driver version string for vendor application.Joe Carnuccio
2013-09-03[SCSI] qla2xxx: Correct multiqueue offset calculations.Andrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] qla2xxx: Add support for ISP8044.Atul Deshmukh
[jejb: checkpatch fixes] Signed-off-by: Atul Deshmukh <atul.deshmukh@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-07-08[SCSI] qla2xxx: Do not take a second firmware dump when intentionally ↵Chad Dupuis
generating one. When we are intentionally generating a firmware dump by executing the MBC_GEN_SYSTEM_ERROR command, the command actually times out. The normal course of action when a mailbox command times out is to take a firmware dump. However, in this special case we do not want to do this since the MBA_SYSTEM_ERR AEN already generates a firmware dump. Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-07-08[SCSI] qla2xxx: Clear the MBX_INTR_WAIT flag when the mailbox time-out happens.Giridhar Malavali
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-12[SCSI] qla2xxx: Fix for locking issue between driver ISR and mailbox routinesgurinder.shergill@hp.com
The driver uses ha->mbx_cmd_flags variable to pass information between its ISR and mailbox routines, however, it does so without the protection of any locks. Under certain conditions, this can lead to multiple mailbox command completions being signaled, which, in turn, leads to a false mailbox timeout error for the subsequently issued mailbox command. The issue occurs frequently but intermittenly with the Qlogic 8GFC mezz card during card initialization, resulting in card initialization failure. Signed-off-by: Gurinder (Sunny) Shergill <gurinder.shergill@hp.com> Acked-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-04-11[SCSI] qla2xxx: Obtain loopback iteration count from bsg request.Joe Carnuccio
qla2x00_loopback_test() was hard setting the loopback iteration count to 1 rather than obtaining it from the bsg request. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-04-11[SCSI] qla2xxx: Add clarifying printk to thermal access fail cases.Joe Carnuccio
2013-04-06[SCSI] Revert "qla2xxx: Add setting of driver version string for vendor ↵Joe Carnuccio
application." The original patch was not covering all the adapters and firmwares. This commit reverts 3a11711ad00caebee07e262d188cea66f3473c38. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-02-22[SCSI] qla2xxx: Integrate generic card temperature with mezz card temperature.Joe Carnuccio
Give priority to I2C thermal. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-02-22[SCSI] qla2xxx: Add setting of driver version string for vendor application.Joe Carnuccio
2013-02-22[SCSI] qla2xxx: Correct list-iteration bug in Report-ID Acquisition codes.Andrew Vasquez
Code in qla24xx_report_id_acquisition() incorrectly assumed that upon completion of list iteration (with no match), the 'pos' (vp) variable passed to list_for_each_entry() would be set to NULL. In this context, if the firmware were to return an unrecognized vp_idx, the follow-on assignments to vp-members could result in corruption of the structure. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-02-22[SCSI] qla2xxx: Update the copyright information.Saurav Kashyap
2013-02-22[SCSI] qla2xxx: Do link initialization on get loop id failure.Joe Carnuccio
To avoid continually doing ISP resets when get loop id fails to obtain the adapter loop id, first try to do a link initialization. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-02-22[SCSI] qla2xxx: Print thermal unsupported message.Joe Carnuccio
When the Read SFP mailbox command fails on the thermal device, print a message explaining that thermal is not supported. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-02-22[SCSI] qla2xxx: Determine the number of outstanding commands based on ↵Chad Dupuis
available resources. Base the number of outstanding requests the driver will keep track of on the available resources instead of being hard-coded. Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-11-30[SCSI] qla2xxx: Fix for warnings reported by sparse.Saurav Kashyap
2012-11-30[SCSI] qla2xxx: Honor status value of 2 for report-id acquisition.Saurav Kashyap
The value of 2 is informational message and it means that port id has changed. The driver should honor the value and continue its normal course. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] qla2xxx: Enable fw attributes for ISP24xx and above.Saurav Kashyap
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] qla2xxx: Update the driver copyright.Chad Dupuis
Update the driver copyright from 2003-2011 to 2003-2012. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] qla2xxx: Add bit to identify adapters for thermal temp.Joe Carnuccio
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] qla2xxx: Implemetation of mctp.Saurav Kashyap
[jejb: fix up checkpatch errors] Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] qla2xxx: IDC implementation for ISP83xx.Santosh Vernekar
Signed-off-by: Santosh Vernekar <santosh.vernekar@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-14[SCSI] qla2xxx: Display mailbox failure by default.Saurav Kashyap
2012-05-22[SCSI] qla2xxx: Add LLD target-mode infrastructure for >= 24xx seriesNicholas Bellinger
Add LLD target mode for >= 24xx series HW. This code was originally based on external qla2x00t module based on 8.02.01-k4, and has been refactored to push the bulk of code into mainline qla2xxx.ko LLD -> qla_target.c. The implementation uses internal workqueues for I/O context submission into tcm_qla2xxx code, and includes the struct qla_tgt_func_tmpl API for external interaction to allow qla2xxx LDD to function without direct target-core dependencies: It also enables qla_target.c usage within existing qla2xxx LLD code. This includes: *) Addition of target mode specific members to existing data structures in qla_def.h and struct qla_hw_data->tgt_ops using qla_target.h:struct qla_tgt_func_tmpl *) Addition of struct qla_tgt_func_tmpl and direct calls into qla_target.c logic w/ qlt_* prefixed functions. *) Addition of qla_iocb.c:qla2x00_req_pkt() for ring processing, and qla2x00_issue_marker() for handling request/response queue processing for target mode operation *) Addition of various qla_tgt_mode_enabled() logic checks in qla24xx_nvram_config(), qla2x00_initialize_adapter(), qla2x00_rff_id(), qla2x00_abort_isp(), qla24xx_modify_vp_config(), and qla2x00_vp_abort_isp(). By default the new qlini_mode module parameter is setting initiator-mode to 'enabled' in order for 'modprobe qla2xxx' to continue to function as expected in initiator only mode. Enabling target-mode operation will currently require a: modprobe qla2xxx qlini_mode="disabled" in order to explictly disabled initiator mode and allow target-mode to be enabled via tcm_qla2xxx configfs fabric callers. (nab: Convert to qlini_mode='enabled' by default in qla_target.c) (joern: Remove loop_id from qla_tgt_make_local_sess() arguments + Remove unused s_id + fix s_id endianness bug + simplify qla_tgt_abort_work) (gerard: fix section __exit mismatch in qla_tgt_exit) (arun: Capture ATIO queue during firmware dump + Send SCR in target mode + Target mode review comments) (roland: Don't create duplicate target sessions to address tearing down ACLs with IO in flight + Add missing call to qlt_fc_port_deleted call during qla2x00_schedule_rport_del timeout) Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-22[SCSI] qla2xxx: Remove mirrored field vp_idx from struct fc_port.Joe Carnuccio
The field vp_idx in struct fc_port is a redundant/mirror copy of the same field in struct scsi_qla_host; struct fc_port has a pointer vha to scsi_qla_host which allows the original copy of vp_idx to be readily accessed. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-22[SCSI] qla2xxx: Add ql_dbg_verbose logging level.Saurav Kashyap
Add an extra layer of logging granularity for messages that are necessary in some circumstances but may flood the kernel log buffer with too many messages otherwise. Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-22[SCSI] qla2xxx: Change "Done" to "Entering" in the debug print statement in ↵Chad Dupuis
qla2x00_port_logout. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-22[SCSI] qla2xxx: Fix typo in qla_mbx.cMasanari Iida
Correct spelling "occured" to "occurred" in drivers/scsi/qla2xxx/qla_mbx.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] qla2xxx: Handle device mapping changes due to device logout.Arun Easi
A device logout sent in the delete path of a fcport would clear the port handle binding inside the firmware. This could lead to queued work items for the fcport, if any, getting incorrect results. This patch fixes the issue by checking for device name changes after a call to get port database. Signed-off-by: Arun Easi <arun.easi@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] qla2xxx: Perform firmware dump procedure on mailbox command timeout.Chad Dupuis
2012-02-19[SCSI] qla2xxx: Log messages to use correct vha.Arun Easi
2012-02-19[SCSI] qla2xxx: Print mailbox command opcode and return code when a command ↵Chad Dupuis
times out. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] qla2xxx: Reduce mbx-command timeout for Login/Logout requests.Andrew Vasquez
Don't use default 30 second mailbox-command timeout for these serial requests, instead, limit the TMO to the standard 2*RATOV plus some fudge-factor. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] qla2xxx: Perform implicit logout during rport tear-down.Andrew Vasquez
During rport tear-down, make sure we do an implicit LOGO of the fcport in our firmware to try to clear any residual commands associated with that fcport. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] qla2xxx: Consolidation of SRB processing.Giridhar Malavali
Rework the structures related to SRB processing to minimize the memory allocations per I/O and manage resources associated with and completions from common routines. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] qla2xxx: Enhancements to support ISP83xx.Giridhar Malavali
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com> Signed-off-by: Nigel Kirkland <nigel.kirkland@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-18[SCSI] qla2xxx: Complete mailbox command timedout to avoid initialization ↵Giridhar Malavali
failures during next reset cycle. Complete the mailbox command timed out before initiating another abort cycle to recover so that mailbox commands issued during next reset cycle don't fail due to pending mailbox access timeout. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-18[SCSI] qla2xxx: Clear options-flags while issuing stop-firmware mbx command.Andrew Vasquez
Not clearing the options flags in mbx1 could lead the firmware into interpreting old data in mbx1 through mbx8. This could lead to inadvertent DMA read/write operations to stale memory. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-15[SCSI] qla2xxx: Correct report-id acquisition checkGiridhar Malavali
2011-12-12[SCSI] qla2xxx: Disable generating pause frames when firmware hang detected ↵Giridhar Malavali
for ISP82xx. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-12[SCSI] qla2xxx: Clear mailbox busy flag during premature mailbox completion ↵Giridhar Malavali
2011-12-12[SCSI] qla2xxx: Return the correct value for a mailbox command if 82xx is in ↵Andrew Vasquez
reset recovery. We need to return QLA_FUNCTION_TIMEOUT immediately otherwise we mess up the mailbox command state machine. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-29[SCSI] qla2xxx: Implemeted beacon on/off for ISP82XX.Saurav Kashyap
[jejb: fix up checkpatch.pl errors] Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
