path: root/drivers/scsi/qla2xxx/qla_mbx.c
2006-02-07[PATCH] qla2xxx: Pass input-buffer length to Get-ID-List mailbox command.andrew.vasquez@qlogic.com
Recent ISP24xx firmwares require that mailbox register 8 be set to the maximum number of bytes to transfer during DMA copying of the list. We safely set this value to zero (infinite), since the call is *only* made in FCAL topologies. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] qla2xxx: Add host-statistics FC transport attributes.andrew.vasquez@qlogic.com
2006-01-14[SCSI] qla2xxx: Collapse load RISC RAM implementations.andrew.vasquez@qlogic.com
Simplify essentially duplicate load RISC RAM implementation in qla2x00_load_ram_ext() and qla2x00_load_ram(). Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] qla2xxx: Correct excessive delay during LOAD-RISC-RAM mailbox command.andrew.vasquez@qlogic.com
Problem report (against 2.4.x driver) from Jeff Layton <jlayton@redhat.com>: An OEM noticed that the U6 qla2200 driver would hang for around 2 minutes at boot time and then proceed normally. I found that the delay was occurring when loading the new firmware into the card, and was due to a schedule_timeout(10) added to the bottom of the polling loop. Some testing showed that the load ram operation on the card was very quick (on the order of a couple of jiffies), but the sleep in the polling loop was making each operation take around 25-30. The attached patch corrects this by making it skip sleeping during the load ram operation, since I believe we only do that when the module is plugged in. It also skips sleeping if the mbox_int flag got set during the current loop. This corrected the hang on my test setup, and OEM also confirmed that it corrected the problem for them. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] qla2xxx: Use msleep() as delay during ISP polling.andrew.vasquez@qlogic.com
Mailbox commands are polled for completion during ISP initialization. During potentially 'long' mailbox commands (i.e. fabric login), we really don't want a busy-wait delay to potentially trigger a (benign) soft-lockup BUG(). Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] qla2xxx: Correct abort issue during loop-down state.Ravi Anand
Correct issue where abort I/O command was not being issued when the loop-state was down. Signed-off-by: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] qla2xxx: Correct loop-in-transition issuesRavi Anand
When mulitple initiators are coming up in an FCAL topology. Signed-off-by: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] qla2xxx: Update license.Andrew Vasquez
2005-09-04[SCSI] qla2xxx: Stop firmware execution at unintialization time.Andrew Vasquez
On ISP24xx parts, stop execution of firmware during ISP tear-down. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-04[SCSI] qla2xxx: Simplify redundant target/device reset logic.Andrew Vasquez
Remove redundant qla2x00_target_reset() function in favour of the equivalent qla2x00_device_reset(). Update callers of old function. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-04[SCSI] qla2xxx: Add FDMI support.Andrew Vasquez
2005-09-04[SCSI] qla2xxx: Export class-of-service (COS) information.Andrew Vasquez
Export COS information for the fc_host and fc_remote_port objects added by the driver. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-14[SCSI] qla2xxx: Update copyright banner.Andrew Vasquez
Update copyright banner. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-14[SCSI] qla2xxx: Code scrubbing.Andrew Vasquez
Code scrubbing. - Remove trailing whitespace from driver files. - Remove unused #defines and inlines. - Standardize on C comments (// -> /* */) Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-14[SCSI] qla2xxx: Add MBX command routines for ISP24xx support.Andrew Vasquez
Add MBX command routines for ISP24xx support. Generalize several routines [qla2x00_load_ram_ext(), qla2x00_execute_fw(), qla2x00_verify_checksum()] to handle larger addressing space. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-14[SCSI] qla2xxx: Generalize SNS generic-services routines.Andrew Vasquez
Generalize SNS generic-services routines. Consolidate completion-status checking while adding support for the ISP24xx. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-14[SCSI] qla2xxx: Add ISP24xx definitions.Andrew Vasquez
Add ISP24xx definitions. Add requisite structure definitions and #define's for ISP24xx support. Also drop volatile modifiers from device_reg_* register layouts as the members are never really accessed, only their offsets within the layout are used during reads and writes. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] remove some dead code in qla2xxxAndrew Vasquez
Original from: Christoph Hellwig <hch@lst.de> Modified and Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] qla2xxx: remove lun discovery codes...
Remove internal lun discovery routines and support structures. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
