path: root/drivers/scsi/scsi_debug.c
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-14[SCSI] scsi_debug: add consecutive medium errorsDouglas Gilbert
A useful test case for error recovery is multiple, consecutive medium errors. When scsi_debug is started with "opts=2" a MEDIUM ERROR is generated when block 0x1234 (4660) is read. The patch extends that to 10 consecutive blocks from 0x1234 (i.e. blocks 4660 to 4669 inclusive). [0:0:0:0] disk ATA INTEL SSD 2CV1 /dev/sda /dev/sg0 80.0GB [10:0:0:0] disk Linux scsi_debug 0004 /dev/sdb /dev/sg1 1.09TB Output file not specified so no copy, just reading input >> unrecovered read error at blk=4660, substitute zeros ... >> unrecovered read error at blk=4669, substitute zeros 4670+10 records in 0+0 records out 10 unrecovered read errors lowest unrecovered read lba=4660, highest unrecovered lba=4669 time to read data: 0.047943 secs at 49.87 MB/sec BTW Change /dev/sg1 (bsg device works just as well) to /dev/sdb to see why, with faulty media, you do not want to use the block layer interface. Reason: time block layer takes to do useless retries and collateral damage to data in its 4 KB blocks (O_DIRECT mitigates the latter). ChangeLog: - extend opts=2 medium error generation at block 0x1234 to 10 consecutive blocks (i.e. blocks 0x1234 to 0x123d). Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-14[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)Martin K. Petersen
Update scsi_debug to support the Logical Block Provisioning commands and bits as defined in SBC3r26. The old tp* parameters have been transitioned to the new lbp* scheme found in the draft standard. The old tpu option to enable UNMAP is now called lbpu. tpws to signal support for WRITE SAME(16) with the UNMAP bit set is now lbpws. Support for WRITE SAME(10) with the UNMAP bit set is also available using the lpuws10 parameter. Limiting the maximum number of blocks per WRITE SAME command has been implemented and is available via the write_same_length module parameter. As part of the renaming process the parameter lists have been sorted alphabetically (request from Doug). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] scsi_debug: Fix 32-bit overflow in do_device_access causing memory ↵Darrick J. Wong
corruption If I create a scsi_debug device that is larger than 4GB, the multiplication of (block * scsi_debug_sector_size) can produce a 64-bit value. Unfortunately, the compiler sees two 32-bit quantities and performs a 32-bit multiplication, thus truncating the bits above 2^32. This causes the wrong memory location to be read or written. Change block and rest to be unsigned long long. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-22[SCSI] scsi_debug: set resid to indicate no data-in when medium errorDouglas Gilbert
set resid to the requested data-in length when a MEDIUM ERROR is simulated. This implies no valid data is returned in the data-in buffer Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-16[SCSI] scsi_debug: Convert to use root_device_register() and ↵Nicholas Bellinger
root_device_unregister() This patch updates the scsi_debug virtual LLD to use root_device_register() and root_device_unregister() from include/linux/device.h instead of device_register() and device_unregister() respectively within scsi_debug_init() and scsi_debug_exit() This simply involved converting the static struct device pseudo_primary into a pointer that is setup by the call to root_device_register(). This patch also contains the correct IS_ERR() conditional check of root_device_register() from within scsi_debug_init(). Thanks to Richard Sharpe and Dmitry Torokhov for their help with this item. Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-09[SCSI] scsi_debug: Update thin provisioning supportMartin K. Petersen
The previous thin provisioning support was not very user friendly because it depended on all the relevant options being set on the command line. Implement support for the Thin Provisioning VPD page from SBC3 r24 and add module options for TPU (UNMAP) and TPWS (WRITE SAME (16) with UNMAP bit). This allows us to have sane default and to enable thin provisioning with a simple tpu=1 or tpws=1 on the command line depending on whether we want UNMAP or WRITE SAME behavior. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] scsi_debug: fix map_region and unmap_region oopsFUJITA Tomonori
map_region and unmap_region could access to invalid memory area since they don't check the size boundary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-18[SCSI] Merge scsi-misc-2.6 into scsi-rc-fixes-2.6James Bottomley
2010-05-02[SCSI] scsi_debug: virtual_gb ignores sector_sizeDouglas Gilbert
In the scsi_debug driver, the virtual_gb option ignores the sector_size, implicitly assuming that is 512 bytes. So if 'virtual_gb=1 sector_size=4096' the result is an 8 GB (virtual) disk. Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-30[SCSI] scsi_debug: Block Limits VPD page fixesMartin K. Petersen
Add a few clarifying comments in the B0 page function and allow the optimal transfer length field to be specified on the command line using opt_blks=N. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] scsi_debug: add max_queue + no_uld parametersDouglas Gilbert
While testing the midlevel q_at_head and q_at_tail patch for sg and the block SG_IO ioctl I found it useful to reduce the queuing within the scsi_debug driver. The reason is that the midlevel queue only comes into play when the corresponding LLD queue is full. It is also useful when testing to be confident that your program is the only thing issuing commands to the (virtual) scsi_debug device. The no_uld=1 parameter will stop a scsi_debug virtual disk appearing as /dev/sd* . Changelog: - add max_queue parameter to reduce the number of queued commands the driver will accept. This parameter can be changed after the driver is loaded. - add no_uld parameter that restricts scsi_debug's virtual devices to the sg and bsg drivers - correct stale url Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04[SCSI] scsi_debug: fix Thin provisioning supportDouglas Gilbert
While testing scsi_debug with these patches I found a problem with the Block Limits VPD page function. The length returned by the inquiry_evpd_b0() function was too short. A patch to fix that and a cosmetic change (that the form factor of scsi_debug is less than 1.8 inches) is attached. Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] scsi_debug: Thin provisioning supportMartin K. Petersen
This version fixes 64-bit modulo on 32-bit as well as inadvertent map updates when TP was disabled. Implement support for thin provisioning in scsi_debug. No actual memory de-allocation is taking place. The intent is to emulate a thinly provisioned storage device, not to be one. There are four new module options: - unmap_granularity specifies the granularity at which to track mapped blocks (specified in number of logical blocks). 2048 (1 MB) is a realistic value for disk arrays although some may have a finer granularity. - unmap_alignment specifies the first LBA which is naturally aligned on an unmap_granularity boundary. - unmap_max_desc specifies the maximum number of ranges that can be unmapped using one UNMAP command. If this is 0, only WRITE SAME is supported and UNMAP will cause a check condition. - unmap_max_blocks specifies the maximum number of blocks that can be unmapped using a single UNMAP command. Default is 0xffffffff. These parameters are reported in the new and extended block limits VPD. If unmap_granularity is specified the device is tagged as thin provisioning capable in READ CAPACITY(16). A bitmap is allocated to track whether blocks are mapped or not. A WRITE request will cause a block to be mapped. So will WRITE SAME unless the UNMAP bit is set. Blocks can be unmapped using either WRITE SAME or UNMAP. No accounting is done to track partial blocks. This means that only whole blocks will be marked free. This is how the array people tell me their firmwares work. GET LBA STATUS is also supported. This command reports whether a block is mapped or not, and how long the adjoining mapped/unmapped extent is. The block allocation bitmap can also be viewed from user space via: /sys/bus/pseudo/drivers/scsi_debug/map Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] scsi_debug: Implement support for DIF Type 2Martin K. Petersen
Add support for 32-byte READ/WRITE as well as DIF Type 2 protection. Reject protected 10/12/16 byte READ/WRITE commands when Type 2 is enabled. Verify Type 2 reference tag according to Expected Initial LBA in 32-byte CDB. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-21scsi_debug: Add support for physical block exponent and alignmentMartin K. Petersen
This patch adds support for setting the physical block exponent and lowest aligned LBA in the READ CAPACITY(16) response. The B0 VPD page is adjusted accordingly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-20[SCSI] scsi_debug: fix virtual disk larger than 1TBFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] scsi_debug: DIF/DIX supportMartin K. Petersen
This patch adds support for DIX and DIF in scsi_debug. A separate buffer is allocated for the protection information. - The dix parameter indicates whether the controller supports DIX (protection information DMA) - The dif parameter indicates whether the simulated storage device supports DIF - The guard parameter switches between T10 CRC(0) and IP checksum(1) - The ato parameter indicates whether the application tag is owned by the disk(0) or the OS(1) - DIF and DIX errors can be triggered using the scsi_debug_opts mask Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] scsi_debug: add support for rotation speedMatthew Wilcox
Add support for VPD page b1 to scsi_debug SCSI VPD page b1 reports the nominal rotation speed of the device. Since scsi_debug is ram-based, claim to be a non-rotating medium. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] scsi_debug: Runtime-configurable sector sizeMartin K. Petersen
Make scsi_debug sector size configurable at load time instead of being a #define. Handy for testing 4KB sectors. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29block: make queue flags non-atomicNick Piggin
We can save some atomic ops in the IO path, if we clearly define the rules of how to modify the queue flags. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-07[SCSI] scsi_debug: remove unnecessary function declarationsFUJITA Tomonori
This patch removes function declarations with moving some functions. This cleans up them a bit to silence checkpatch.pl. There is no functional change. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: support large non-fake virtual diskFUJITA Tomonori
Currently, the maximum amount of RAM that scsi_debug can allocate is 4GB. This patch increases it to 2TB; scsi_debug can allocates 2TB memory and export it as if it were 2TB scsi disk. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: remove the duplicated code in resp_read and resp_writeFUJITA Tomonori
resp_read and resp_write performs READ_* and WRITE_* commands respectively. This sweeps up the similar code in them. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: sweep up sdebug_capacity calculationFUJITA Tomonori
sdebug_capacity is calculated at five different places. This add a helper function to calculate sdebug_capacity to sweep up the duplicatated code. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: remove unnecessary sdebug_store_sizeFUJITA Tomonori
sdebug_store_size doesn't need to be static global. It's used at startup only. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: fix lba and data length calculation bugsFUJITA Tomonori
For example, `modprobe scsi_debug virtual_gb=1100` gives: scsi7 : scsi_debug, version 1.81 [20070104], dev_size_mb=8, opts=0x0 scsi 7:0:0:0: Direct-Access Linux scsi_debug 0004 PQ: 0 ANSI: 5 sd 7:0:0:0: [sdc] 2306867200 512-byte hardware sectors (1181116 MB) sd 7:0:0:0: [sdc] Write Protect is off sd 7:0:0:0: [sdc] Mode Sense: 73 00 10 08 sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA sd 7:0:0:0: [sdc] 2306867200 512-byte hardware sectors (1181116 MB) sd 7:0:0:0: [sdc] Write Protect is off sd 7:0:0:0: [sdc] Mode Sense: 73 00 10 08 sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA sdc: unknown partition table sd 7:0:0:0: [sdc] Attached SCSI disk sd 7:0:0:0: Attached scsi generic sg6 type 0 end_request: I/O error, dev sdc, sector 2306867072 Buffer I/O error on device sdc, logical block 288358384 end_request: I/O error, dev sdc, sector 2306867072 Buffer I/O error on device sdc, logical block 288358384 end_request: I/O error, dev sdc, sector 2306867192 (snip) Note that this converts all the calculations (including the correct calculations) for unification. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: use scsi_build_sense_bufferFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
This patch removes lots of function declarations with moving scsi_debug_queuecommand. This cleans up scsi_debug_queuecommand a bit to silence checkpatch.pl Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: use list_for_each_entry_safeFUJITA Tomonori
This replaces list_for_each_safe and list_entry with list_for_each_entry_safe. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: remove unnecessary condition test in devInfoRegFUJITA Tomonori
open_devip is always non NULL. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: create new scsi_debug devices at a single placeFUJITA Tomonori
Two functions, sdebug_add_adapter and devInfoReg, creates new scsi_debug devices. To simplify the code, this patch adds a new helper function to create new scsi_debug devices (sdebug_device_create) and converts both functions to use it. I plan to add more to scsi_debug devices (e.g. using a thread for a scsi_debug device for scalability testings). This patch enable me to add such to just the new helper function instead of touching two functions, sdebug_add_adapter and devInfoReg. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: remove temporary hack around sscanf for negative valuesFUJITA Tomonori
sscanf can handle negative values. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: use sg buffer copy helper functionsFUJITA Tomonori
2008-04-07[SCSI] scsi_debug: use shost_priv macroFUJITA Tomonori
2008-04-07[SCSI] scsi_debug: remove unnecessary checkingFUJITA Tomonori
2008-04-07[SCSI] scsi_debug: remove scsi_debug.hFUJITA Tomonori
scsi_debug.h just incldues some function declarations. This patch removes it with moving the scsi_host_template. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_debug: stop including drivers/scsi/scsi.hFUJITA Tomonori
This converts scsi_debug to include header files in include/scsi/ instead of drivers/scsi/scsi.h. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] Remove random noop unchecked_isa_dma usersAndi Kleen
Lots of drivers set it to 0. Remove that. Patch should be a nop. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-18[SCSI] scsi_debug: disable clusteringFUJITA Tomonori
scsi_debug does at several places: for_each_sg(sdb->table.sgl, sg, sdb->table.nents, k) { kaddr = (unsigned char *) kmap_atomic(sg_page(sg), KM_USER0); We cannot do something like that with the clustering enabled (or we can use scsi_kmap_atomic_sg). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] scsi_debug: add XDWRITEREAD_10 supportFUJITA Tomonori
2008-01-30[SCSI] scsi_debug: add bidi data transfer supportFUJITA Tomonori
This enables fill_from_dev_buffer and fetch_to_dev_buffer to handle bidi commands. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] scsi_debug: add get_data_transfer_info helper functionFUJITA Tomonori
This adds get_data_transfer_info helper function that get lha and sectors for READ_* and WRITE_* commands (and XDWRITEREAD_10 later). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] scsi_debug: convert to use the data buffer accessorsBoaz Harrosh
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
