path: root/drivers/scsi/scsi_priv.h
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-01-24[SCSI] scsi_dh: Use scsi_devinfo functions to do matching of device_handler ↵Peter Jones
tables. Previously we were using strncmp in order to avoid having to include whitespace in the devlist, but this means "HSV1000" matches a device list entry that says "HSV100", which is wrong. This patch changes scsi_dh.c to use scsi_devinfo's matching functions instead, since they handle these cases correctly. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-24[SCSI] Add scsi_dev_info_list_del_keyed()Peter Jones
For scsi_dh.c to use devinfo lists, we have to be able to remove entries before rmmod. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06SCSI: remove fake "address-of" expressionAlan Stern
Fake "address-of" expressions that evaluate to NULL generally confuse readers and can provoke compiler warnings. This patch (as1411) removes one such fake expression, using an "#ifdef" in its place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-28[SCSI] implement runtime Power ManagementAlan Stern
This patch (as1398b) adds runtime PM support to the SCSI layer. Only the machanism is provided; use of it is up to the various high-level drivers, and the patch doesn't change any of them. Except for sg -- the patch expicitly prevents a device from being runtime-suspended while its sg device file is open. The implementation is simplistic. In general, hosts and targets are automatically suspended when all their children are asleep, but for them the runtime-suspend code doesn't actually do anything. (A host's runtime PM status is propagated up the device tree, though, so a runtime-PM-aware lower-level driver could power down the host adapter hardware at the appropriate times.) There are comments indicating where a transport class might be notified or some other hooks added. LUNs are runtime-suspended by calling the drivers' existing suspend handlers (and likewise for runtime-resume). Somewhat arbitrarily, the implementation delays for 100 ms before suspending an eligible LUN. This is because there typically are occasions during bootup when the same device file is opened and closed several times in quick succession. The way this all works is that the SCSI core increments a device's PM-usage count when it is registered. If a high-level driver does nothing then the device will not be eligible for runtime-suspend because of the elevated usage count. If a high-level driver wants to use runtime PM then it can call scsi_autopm_put_device() in its probe routine to decrement the usage count and scsi_autopm_get_device() in its remove routine to restore the original count. Hosts, targets, and LUNs are not suspended while they are being probed or removed, or while the error handler is running. In fact, a fairly large part of the patch consists of code to make sure that things aren't suspended at such times. [jejb: fix up compile issues in PM config variations] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] convert to the new PM frameworkAlan Stern
This patch (as1397b) converts the SCSI midlayer to use the new PM callbacks (struct dev_pm_ops). A new source file, scsi_pm.c, is created to hold the new callback routines, and the existing suspend/resume code is moved there. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21scsi_transport_spi: Blacklist Ultrium-3 tape for IU transfersJames Bottomley
There have been several bug reports which identified the Ultrium-3 tape as just hanging up on the bus during certain types of IU transfer. The identified culpret is type 0x02 (MULTIPLE COMMAND) transfers. The only way to prevent this tape wedging is to prevent it from using IU transfers at all. So this patch uses the exported blacklist matching technology to recognise the drive and force it not to use IU transfers. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21enhance device info matching for multiple tablesJames Bottomley
The current scsi_devinfo.c matching routines use a single table for the global blacklist. However, we're developing a need to blacklist from specific transports too (notably some tape drives using SPI which don't respond well to high speed protocols). Instead of developing separate blacklist matching for each transport class needing it, enhance the current list matching to permit multiple lists. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-13PM/Hibernate: Wait for SCSI devices scan to complete during resumeRafael J. Wysocki
There is a race between resume from hibernation and the asynchronous scanning of SCSI devices and to prevent it from happening we need to call scsi_complete_async_scans() during resume from hibernation. In addition, if the resume from hibernation is userland-driven, it's better to wait for all device probes in the kernel to complete before attempting to open the resume device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13[SCSI] modify scsi to handle new fail fast flags.Mike Christie
This checks the errors the scsi-ml determined were retryable and returns if we should fast fail it based on the request fail fast flags. Without the patch, drivers like lpfc, qla2xxx and fcoe would return DID_ERROR for what it determines is a temporary communication problem. There is no loss of connectivity at that time and the driver thinks that it would be fast to retry at the driver level. SCSI-ml will however sees fast fail on the request and DID_ERROR and will fast fail the io. This will then cause dm-multipath to fail the path and possibley switch target controllers when we should be retrying at the scsi layer. We also were fast failing device errors to dm multiapth when unless the scsi_dh modules think otherwis we want to retry at the scsi layer because multipath can only retry the IO like scsi should have done. multipath is a little dumber though because it does not what the error was for and assumes that it should fail the paths. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-26[SCSI] Support devices with protection informationMartin K. Petersen
Implement support for DMA of protection information for devices that are data integrity capable. - Add support for mapping an extra scatter-gather list containing the protection information. - Allocate protection scsi_data_buffer if host is DIX (integrity DMA) capable. - Accessor function for checking whether a device has protection enabled. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] use default attributes for scsi_hostHannes Reinecke
This patch removes the unused sysfs attibute overwriting logic for the scsi host attibutes, and plugs them into the driver core default attribute creation. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-06Revert "scsi: revert "[SCSI] Get rid of scsi_cmnd->done""Linus Torvalds
This reverts commit ac40532ef0b8649e6f7f83859ea0de1c4ed08a19, which gets us back the original cleanup of 6f5391c283d7fdcf24bf40786ea79061919d1e1d. It turns out that the bug that was triggered by that commit was apparently not actually triggered by that commit at all, and just the testing conditions had changed enough to make it appear to be due to it. The real problem seems to have been found by Peter Osterlund: "pktcdvd sets it [block device size] when opening the /dev/pktcdvd device, but when the drive is later opened as /dev/scd0, there is nothing that sets it back. (Btw, 40944 is possible if the disk is a CDRW that was formatted with "cdrwtool -m 10236".) The problem is that pktcdvd opens the cd device in non-blocking mode when pktsetup is run, and doesn't close it again until pktsetup -d is run. The effect is that if you meanwhile open the cd device, blkdev.c:do_open() doesn't call bd_set_size() because bdev->bd_openers is non-zero." In particular, to repeat the bug (regardless of whether commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d is applied or not): " 1. Start with an empty drive. 2. pktsetup 0 /dev/scd0 3. Insert a CD containing an isofs filesystem. 4. mount /dev/pktcdvd/0 /mnt/tmp 5. umount /mnt/tmp 6. Press the eject button. 7. Insert a DVD containing a non-writable filesystem. 8. mount /dev/scd0 /mnt/tmp 9. find /mnt/tmp -type f -print0 | xargs -0 sha1sum >/dev/null 10. If the DVD contains data beyond the physical size of a CD, you get I/O errors in the terminal, and dmesg reports lots of "attempt to access beyond end of device" errors." which in turn is because the nested open after the media change won't cause the size to be set properly (because the original open still holds the block device, and we only do the bd_set_size() when we don't have other people holding the device open). The proper fix for that is probably to just do something like bdev->bd_inode->i_size = (loff_t)get_capacity(disk)<<9; in fs/block_dev.c:do_open() even for the cases where we're not the original opener (but *not* call bd_set_size(), since that will also change the block size of the device). Cc: Peter Osterlund <petero2@telia.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] scsi_sysfs: restore prep_fn when ULD is removed
2008-01-02scsi: revert "[SCSI] Get rid of scsi_cmnd->done"Ingo Molnar
This reverts commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d ("[SCSI] Get rid of scsi_cmnd->done") that was supposed to be a cleanup commit, but apparently it causes regressions: Bug 9370 - v2.6.24-rc2-409-g9418d5d: attempt to access beyond end of device http://bugzilla.kernel.org/show_bug.cgi?id=9370 this patch should be reintroduced in a more split-up form to make testing of it easier. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Matthew Wilcox <matthew@wil.cx> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-02[SCSI] scsi_sysfs: restore prep_fn when ULD is removedJames Bottomley
A recent bug report: http://bugzilla.kernel.org/show_bug.cgi?id=9674 Was caused because the ULDs now set their own prep functions, but don't necessarily reset the prep function back to the SCSI default when they are removed. This leads to panics if commands are sent to the device after the module is removed because the prep_fn is still pointing to the old module code. The fix for this is to implement a bus remove method that resets the prep_fn pointer correctly before calling the ULD specific driver remove method. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] Get rid of scsi_cmnd->doneMatthew Wilcox
The ULD ->done callback moves into the scsi_driver. By moving the call to scsi_io_completion() from scsi_blk_pc_done() to scsi_finish_command(), we can eliminate the latter entirely. By returning 'good_bytes' from the ->done callback (rather than invoking scsi_io_completion()), we can stop exporting scsi_io_completion(). Also move the prototypes from sd.h to sd.c as they're all internal anyway. Rename sd_rw_intr to sd_done and rw_intr to sr_done. Inspired-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] scsi_error.c: Export some scsi_eh_* functionsDarrick J. Wong
Export a couple of functions from scsi_error that are needed to handle failed SCSI commands from the SAS EH. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> make exports GPL and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] kill scsi_rety_commandChristoph Hellwig
scsi_retry_command only has a single caller, so there is no point in having this function. Additionally the memset of the sense buffer it does is entirely superflous as scsi_request_fn already calls scsi_init_cmd_errh to perform this memset before the command is reissued. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-11[SCSI] Add ability to scan scsi busses asynchronouslyMatthew Wilcox
Since it often takes around 20-30 seconds to scan a scsi bus, it's highly advantageous to do this in parallel with other things. The bulk of this patch is ensuring that devices don't change numbering, and that all devices are discovered prior to trying to start init. For those who build SCSI as modules, there's a new scsi_wait_scan module that will ensure all bus scans are finished. This patch only handles drivers which call scsi_scan_host. Fibre Channel, SAS, SATA, USB and Firewire all need additional work. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-02[SCSI] SCSI and FC Transport: add netlink support for posting of transport ↵James Smart
events This patch formally adds support for the posting of FC events via netlink. It is a followup to the original RFC at: http://marc.theaimsgroup.com/?l=linux-scsi&m=114530667923464&w=2 and the initial posting at: http://marc.theaimsgroup.com/?l=linux-scsi&m=115507374832500&w=2 The patch has been updated to optimize the send path, per the discussions in the initial posting. Per discussions at the Storage Summit and at OLS, we are to use netlink for async events from transports. Also per discussions, to avoid a netlink protocol per transport, I've create a single NETLINK_SCSITRANSPORT protocol, which can then be used by all transports. This patch: - Creates new files scsi_netlink.c and scsi_netlink.h, which contains the single and shared definitions for the SCSI Transport. It is tied into the base SCSI subsystem intialization. Contains a single interface routine, scsi_send_transport_event(), for a transport to send an event (via multicast to a protocol specific group). - Creates a new scsi_netlink_fc.h file, which contains the FC netlink event messages - Adds 3 new routines to the fc transport: fc_get_event_number() - to get a FC event # fc_host_post_event() - to send a simple FC event (32 bits of data) fc_host_post_vendor_event() - to send a Vendor unique event, with arbitrary amounts of data. Note: the separation of event number allows for a LLD to send a standard event, followed by vendor-specific data for the event. Note: This patch assumes 2 prior fc transport patches have been installed: http://marc.theaimsgroup.com/?l=linux-scsi&m=115555807316329&w=2 http://marc.theaimsgroup.com/?l=linux-scsi&m=115581614930261&w=2 Sorry - next time I'll do something like making these individual patches of the same posting when I know they'll be posted closely together. Signed-off-by: James Smart <James.Smart@emulex.com> Tidy up configuration not to make SCSI always select NET Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-09[SCSI] hide EH backup data outside the scsi_cmndChristoph Hellwig
Currently struct scsi_cmnd has various fields that are used to backup original data after the corresponding fields have been overridden for EH commands. This means drivers can easily get at it and misuse it. Due to the old_ naming this doesn't happen for most of them, but two that have different names have been used wrong a lot (see previous patch). Another downside is that they unessecarily bloat the scsi_cmnd size. This patch moves them onstack in scsi_send_eh_cmnd to fix those two issues aswell as allowing future EH fixes like moving the EH command submissions to use SG lists like everything else. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-27[SCSI] update max sdev block limitJames Smart
Updated patch to address comments from Pat Mansfield and Michael Reed: Bumped max to 600 (10mins). Set default dev_loss_tmo to a value other than the max (30s). Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] remove scsi_request infrastructureChristoph Hellwig
With Achim patch the last user (gdth) is switched away from scsi_request so we an kill it now. Also disables some code in i2o_scsi that was broken since the sg driver stopped using scsi_requests. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] remove target parent limitiationChristoph Hellwig
When James Smart fixed the issue of the userspace scan atributes crashing the system with the FC transport class he added a patch to let the transport class check if the parent is valid for a given transport class. When adding support for the integrated raid of fusion sas devices we ran into a problem with that, as it didn't allow adding virtual raid volumes without the transport class knowing about it. So this patch adds a user_scan attribute instead, that takes over from scsi_scan_host_selected if the transport class sets it and thus lets the transport class control the user-initiated scanning. As this plugs the hole about user-initiated scanning the target_parent hook goes away and we rely on callers of the scanning routines to do something sensible. For SAS this meant I had to switch from a spinlock to a mutex to synchronize the topology linked lists, in FC they were completely unsynchronized which seems wrong. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-09[SCSI] Kill the SCSI softirq handlingJens Axboe
This patch moves the SCSI softirq handling to the block layer version. There should be no functional changes. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-12-14[SCSI] Convert SCSI mid-layer to scsi_execute_asyncMike Christie
Add scsi helpers to create really-large-requests and convert scsi-ml to scsi_execute_async(). Per Jens's previous comments, I placed this function in scsi_lib.c. I made it follow all the queue's limits - I think I did at least :), so I removed the warning on the function header. I think the scsi_execute_* functions should eventually take a request_queue and be placed some place where the dm-multipath hw_handler can use them if that failover code is going to stay in the kernel. That conversion patch will be sent in another mail though. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] correct some dropped const compiler warningsJames Bottomley
Make the vendor, model and rev fields in scsi_device pointers to const and update a few prototypes of functions using them. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] use a completion in scsi_send_eh_cmndChristoph Hellwig
scsi_send_eh_cmnd currently uses a semaphore and an overload of eh_timer to either get a completion for a command for a timeout. Switch to using a completion and wait_for_completion_timeout to simply the code and not having to deal with the races ourselves. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-09[SCSI] fix callers of scsi_remove_device() who already hold the scan mutedAlan Stern
This patch (as544) adds a private entry point to scsi_remove_device, for use when callers already own the scan_mutex. The appropriate callers are modified to use the new entry point. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-06[SCSI] unexport scsi_add_timer/scsi_delete_timerChristoph Hellwig
2005-06-26[SCSI] remove scsi_eh_eflags_ macrosChristoph Hellwig
Just opencoded access to eh_eflags, it's much more readable anyway. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-26[SCSI] remove scsi_cmnd->ownerChristoph Hellwig
never checked anywhere Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] scsi: remove unused scsi_cmnd->internal_timeout field
scsi_cmnd->internal_timeout field doesn't have any meaning anymore. Kill the field. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
