Replace obsolete strict_strto with more appropriate kstrto calls
Signed-off-by: Daniel Walter <dwalter@google.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
This patch adds support for an alternate I/O path in the scsi midlayer
which uses the blk-mq infrastructure instead of the legacy request code.
Use of blk-mq is fully transparent to drivers, although for now a host
template field is provided to opt out of blk-mq usage in case any unforseen
incompatibilities arise.
In general replacing the legacy request code with blk-mq is a simple and
mostly mechanical transformation. The biggest exception is the new code
that deals with the fact the I/O submissions in blk-mq must happen from
process context, which slightly complicates the I/O completion handler.
The second biggest differences is that blk-mq is build around the concept
of preallocated requests that also include driver specific data, which
in SCSI context means the scsi_cmnd structure. This completely avoids
dynamic memory allocations for the fast path through I/O submission.
Due the preallocated requests the MQ code path exclusively uses the
host-wide shared tag allocator instead of a per-LUN one. This only
affects drivers actually using the block layer provided tag allocator
instead of their own. Unlike the old path blk-mq always provides a tag,
although drivers don't have to use it.
For now the blk-mq path is disable by defauly and must be enabled using
the "use_blk_mq" module parameter. Once the remaining work in the block
layer to make blk-mq more suitable for slow devices is complete I hope
to make it the default and eventually even remove the old code path.
Based on the earlier scsi-mq prototype by Nicholas Bellinger.
Thanks to Bart Van Assche and Robert Elliot for testing, benchmarking and
various sugestions and code contributions.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Webb Scales <webbnh@hp.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
Tested-by: Bart Van Assche <bvanassche@acm.org>
Tested-by: Robert Elliott <elliott@hp.com>
Seems like these counters are missing any sort of synchronization for
updates, as a over 10 year old comment from me noted. Fix this by
using atomic counters, and while we're at it also make sure they are
in the same cacheline as the _busy counters and not needlessly stored
to in every I/O completion.
With the new model the _busy counters can temporarily go negative,
so all the readers are updated to check for > 0 values. Longer
term every successful I/O completion will reset the counters to zero,
so the temporarily negative values will not cause any harm.
Avoid taking the queue_lock to check the per-device queue limit. Instead
we do an atomic_inc_return early on to grab our slot in the queue,
and if necessary decrement it after finishing all checks.
Unlike the host and target busy counters this doesn't allow us to avoid the
queue_lock in the request_fn due to the way the interface works, but it'll
allow us to prepare for using the blk-mq code, which doesn't use the
queue_lock at all, and it at least avoids a queue_lock round trip in
scsi_device_unbusy, which is still important given how busy the queue_lock
is.
Avoid taking the host-wide host_lock to check the per-host queue limit.
Instead we do an atomic_inc_return early on to grab our slot in the queue,
The SCSI standard defines 64-bit values for LUNs, and large arrays
employing large or hierarchical LUN numbers become more and more
common.
So update the linux SCSI stack to use 64-bit LUN numbers.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
Pull first round of SCSI updates from James Bottomley:
"This patch consists of the usual driver updates (megaraid_sas,
scsi_debug, qla2xxx, qla4xxx, lpfc, bnx2fc, be2iscsi, hpsa, ipr) plus
an assortment of minor fixes and the first precursors of SCSI-MQ (the
code path simplifications) and the bug fix for the USB oops on remove
(which involves an infrastructure change, so is sent via the main tree
with a delayed backport after a cycle in which it is shown to
introduce no new bugs)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (196 commits)
[SCSI] sd: Quiesce mode sense error messages
[SCSI] add support for per-host cmd pools
[SCSI] simplify command allocation and freeing a bit
[SCSI] megaraid: simplify internal command handling
[SCSI] ses: Use vpd information from scsi_device
[SCSI] Add EVPD page 0x83 and 0x80 to sysfs
[SCSI] Return VPD page length in scsi_vpd_inquiry()
[SCSI] scsi_sysfs: Implement 'is_visible' callback
[SCSI] hpsa: update driver version to 3.4.4-1
[SCSI] hpsa: fix bad endif placement in RAID 5 mapper code
[SCSI] qla2xxx: Fix build errors related to invalid print fields on some architectures.
[SCSI] bfa: Replace large udelay() with mdelay()
[SCSI] vmw_pvscsi: Some improvements in pvscsi driver.
[SCSI] vmw_pvscsi: Add support for I/O requests coalescing.
[SCSI] vmw_pvscsi: Fix pvscsi_abort() function.
[SCSI] remove deprecated IRQF_DISABLED from SCSI
[SCSI] bfa: Updating Maintainers email ids
[SCSI] ipr: Add new CCIN definition for Grand Canyon support
[SCSI] ipr: Format HCAM overlay ID 0x21
[SCSI] ipr: Use pci_enable_msi_range() and pci_enable_msix_range()
EVPD page 0x83 is used to uniquely identify the device.
So instead of having each and every program issue a separate
SG_IO call to retrieve this information it does make far more
sense to display it in sysfs.
Some older devices (most notably tapes) will only report reliable
information in page 0x80 (Unit Serial Number). So export this
in the sysfs attribute 'vpd_pg80'.
[jejb: checkpatch fix]
[hare: attach after transport configure]
[fengguang.wu@intel.com: spotted problems with the original now fixed]
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Instead of modifying attributes after the device has been created
we should be using the 'is_visible' callback to avoid races.
When the host template doesn't declare an eh_host_reset_handler
the eh_deadline mechanism is pointless and will set the
device to offline. So disable eh_deadline if no
eh_host_reset_handler is present.
This patch eliminates the reap_ref and replaces it with a proper kref.
On last put of this kref, the target is removed from visibility in
sysfs. The final call to scsi_target_reap() for the device is done from
__scsi_remove_device() and only if the device was made visible. This
ensures that the target disappears as soon as the last device is gone
rather than waiting until final release of the device (which is often
too long).
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: stable@vger.kernel.org # delay backport by 2 months for field testing
driver-core now supports synchrnous self-deletion of attributes and
the asynchrnous removal mechanism is scheduled for removal. Use it
instead of device_schedule_callback(). This makes "delete" behave
synchronously.
Cc: linux-scsi@vger.kernel.org
The former minimum valid value of 'eh_deadline' is 1s, which means
the earliest occasion to shorten EH is 1 second later since a
command is failed or timed out. But if we want to skip EH steps
ASAP, we have to wait until the first EH step is finished. If the
duration of the first EH step is long, this waiting time is
excruciating. So, it is necessary to accept 0 as the minimum valid
value for 'eh_deadline'.
According to my test, with Hannes' patchset 'New EH command timeout
handler' as well, the minimum IO time is improved from 73s
(eh_deadline = 1) to 43s(eh_deadline = 0) when commands are timed
out by disabling RSCN and target port.
Signed-off-by: Ren Mingxin <renmx@cn.fujitsu.com>
This patchs adds an 'eh_deadline' sysfs attribute to the scsi
host which limits the overall runtime of the SCSI EH.
The 'eh_deadline' value is stored in the now obsolete field
'resetting'.
When a command is failed the start time of the EH is stored
in 'last_reset'. If the overall runtime of the SCSI EH is longer
than last_reset + eh_deadline, the EH is short-circuited and
falls through to issue a host reset only.
[jejb: add comments in Scsi_Host about new fields]
If you mutiple devices connect to a host, we might be interested in
have an intensive I/O workload on one disk, and notice starvation on others.
This give the user more hint about current infight io for scsi device.
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
Generate a uevent when the following Unit Attention ASC/ASCQ
codes are received:
2A/01 MODE PARAMETERS CHANGED
2A/09 CAPACITY DATA HAS CHANGED
38/07 THIN PROVISIONING SOFT THRESHOLD REACHED
3F/03 INQUIRY DATA HAS CHANGED
3F/0E REPORTED LUNS DATA HAS CHANGED
Log kernel messages when the following Unit Attention ASC/ASCQ
codes are received that are not as specific as those above:
2A/xx PARAMETERS CHANGED
3F/xx TARGET OPERATING CONDITIONS HAVE CHANGED
Added logic to set expecting_lun_change for other LUNs on the target
after REPORTED LUNS DATA HAS CHANGED is received, so that duplicate
uevents are not generated, and clear expecting_lun_change when a
REPORT LUNS command completes, in accordance with the SPC-3
specification regarding reporting of the 3F 0E ASC/ASCQ UA.
[jejb: remove SPC3 test in scsi_report_lun_change and some docbook fixes and
unused variable fix, both reported by Fengguang Wu]
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
Introduce eh_timeout which can be used for error handling purposes. This
was previously hardcoded to 10 seconds in the SCSI error handling
code. However, for some fast-fail scenarios it is necessary to be able
to tune this as it can take several iterations (bus device, target, bus,
controller) before we give up.
store_host_reset() has tried to re-invent the wheel to compare sysfs strings.
Unfortunately it did so poorly and never bothered to check the input from
userspace before overwriting stack with it, so something simple as:
echo "WoopsieWoopsie" >
/sys/devices/pseudo_0/adapter0/host0/scsi_host/host0/host_reset
would result in:
[ 316.310101] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81f5bac7
[ 316.310101]
[ 316.320051] Pid: 6655, comm: sh Tainted: G W 3.7.0-rc5-next-20121114-sasha-00016-g5c9d68d-dirty #129
[ 316.320051] Call Trace:
[ 316.340058] pps pps0: PPS event at 1352918752.620355751
[ 316.340062] pps pps0: capture assert seq #303
[ 316.320051] [<ffffffff83b3856b>] panic+0xcd/0x1f4
[ 316.320051] [<ffffffff81f5bac7>] ? store_host_reset+0xd7/0x100
[ 316.320051] [<ffffffff8110b996>] __stack_chk_fail+0x16/0x20
[ 316.320051] [<ffffffff81f5bac7>] store_host_reset+0xd7/0x100
[ 316.320051] [<ffffffff81e55bb3>] dev_attr_store+0x13/0x30
[ 316.320051] [<ffffffff812f7db1>] sysfs_write_file+0x101/0x170
[ 316.320051] [<ffffffff8127acc8>] vfs_write+0xb8/0x180
[ 316.320051] [<ffffffff8127ae80>] sys_write+0x50/0xa0
[ 316.320051] [<ffffffff83c03418>] tracesys+0xe1/0xe6
Fix this by uninventing whatever was going on there and just use sysfs_streq.
Bug introduced by 29443691 ("[SCSI] scsi: Added support for adapter and
firmware reset").
[jejb: added necessary const to prevent compile warnings]
Cc: <stable@vger.kernel.org> #3.2+
John reports:
BUG: soft lockup - CPU#2 stuck for 23s! [kworker/u:8:2202]
Call Trace:
[<ffffffff8141782a>] scsi_remove_target+0xda/0x1f0
[<ffffffff81421de5>] sas_rphy_remove+0x55/0x60
[<ffffffff81421e01>] sas_rphy_delete+0x11/0x20
[<ffffffff81421e35>] sas_port_delete+0x25/0x160
[<ffffffff814549a3>] mptsas_del_end_device+0x183/0x270
...introduced by commit 3b661a9 "[SCSI] fix hot unplug vs async scan race".
Don't restart lookup of more stargets in the multi-target case, just
arrange to traverse the list once, on the assumption that new targets
are always added at the end. There is no guarantee that the target will
change state in scsi_target_reap() so we can end up spinning if we
restart.
Acked-by: Jack Wang <jack_wang@usish.com>
LKML-Reference: <CAEhu1-6wq1YsNiscGMwP4ud0Q+MrViRzv=kcWCQSBNc8c68N5Q@mail.gmail.com>
Reported-by: John Drescher <drescherjm@gmail.com>
Tested-by: John Drescher <drescherjm@gmail.com>
Signed-off-by: Dan Williams <djbw@fb.com>
The following crash results from cases where the end_device has been
removed before scsi_sysfs_add_sdev has had a chance to run.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000098
IP: [<ffffffff8115e100>] sysfs_create_dir+0x32/0xb6
Call Trace:
[<ffffffff8125e4a8>] kobject_add_internal+0x120/0x1e3
[<ffffffff81075149>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff8125e641>] kobject_add_varg+0x41/0x50
[<ffffffff8125e70b>] kobject_add+0x64/0x66
[<ffffffff8131122b>] device_add+0x12d/0x63a
[<ffffffff814b65ea>] ? _raw_spin_unlock_irqrestore+0x47/0x56
[<ffffffff8107de15>] ? module_refcount+0x89/0xa0
[<ffffffff8132f348>] scsi_sysfs_add_sdev+0x4e/0x28a
[<ffffffff8132dcbb>] do_scan_async+0x9c/0x145
...teach scsi_sysfs_add_devices() to check for deleted devices() before
trying to add them, and teach scsi_remove_target() how to remove targets
that have not been added via device_add().
Reported-by: Dariusz Majchrzak <dariusz.majchrzak@intel.com>
Avoid that the code for requeueing SCSI requests triggers a
crash by making sure that that code isn't scheduled anymore
after a device has been removed.
Also, source code inspection of __scsi_remove_device() revealed
a race condition in this function: no new SCSI requests must be
accepted for a SCSI device after device removal started.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Acked-by: Tejun Heo <tj@kernel.org>
Use blk_queue_dead() to test whether the queue is dead instead
of !sdev. Since scsi_prep_fn() may be invoked concurrently with
__scsi_remove_device(), keep the queuedata (sdev) pointer in
__scsi_remove_device(). This patch fixes a kernel oops that
can be triggered by USB device removal. See also
http://www.spinics.net/lists/linux-scsi/msg56254.html.
Other changes included in this patch:
- Swap the blk_cleanup_queue() and kfree() calls in
scsi_host_dev_release() to make that code easier to grasp.
- Remove the queue dead check from scsi_run_queue() since the
queue state can change anyway at any point in that function
where the queue lock is not held.
- Remove the queue dead check from the start of scsi_request_fn()
since it is redundant with the scsi_device_online() check.
Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: <stable@kernel.org>
This patch adds a new state SDEV_TRANSPORT_OFFLINE. It will
be used by transport classes to offline devices for cases like
when the fast_io_fail/recovery_tmo fires. In those cases we
want all IO to fail, and we have not yet escalated to dev_loss_tmo
behavior where we are removing the devices.
Currently to handle this state, transport classes are setting
the scsi_device's state to running, setting their internal
session/port structs state to something that indicates failed,
and then failing IO from some transport check in the queuecommand.
The reason for the new value is so that users can distinguish
between a device failure that is a result of a transport problem
vs the wide range of errors that devices get offlined for
when a scsi command times out and we offline the devices there.
It also fixes the confusion as to why the transport class is
failing IO, but has set the device state from blocked to running.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Added new sysfs attr 'host_reset' in scsi_sysfs.c to
perform adapter or firmware reset as suggested by
Mike Christie here:
http://marc.info/?l=linux-scsi&m=127359347111167&w=2
user/application can write "adapter" or "firmware" on
this attr and it will call newly added function hook
in scsi_host_template to call LDD adapter or firmware
reset implementation.
Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com>
In certain circumstances, we can get an oops from a torn down device.
Most notably this is from CD roms trying to call scsi_ioctl. The root
cause of the problem is the fact that after scsi_remove_device() has
been called, the queue is fully torn down. This is actually wrong
since the queue can be used until the sdev release function is called.
Therefore, we add an extra reference to the queue which is released in
sdev->release, so the queue always exists.
Reported-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: stable@kernel.org
Signed-off-by: James Bottomley <jbottomley@parallels.com>
SCSI uses request_queue->queuedata == NULL as a signal that the queue
is dying. We set this state in the sdev release function. However,
this allows a small window where we release the last reference but
haven't quite got to this stage yet and so something will try to take
a reference in scsi_request_fn and oops. It's very rare, but we had a
report here, so we're pushing this as a bug fix
The actual fix is to set request_queue->queuedata to NULL in
scsi_remove_device() before we drop the reference. This causes
correct automatic rejects from scsi_request_fn as people who hold
additional references try to submit work and prevents anything from
getting a new reference to the sdev that way.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP ||
CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be
replaced with CONFIG_PM.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
This trivial patch (as1338) makes two uninformative error messages in
scsi_sysfs_add_sdev() more explicit.
Removing SCSI devices through
echo 1 > /sys/bus/scsi/devices/ ... /delete
while the FC transport class removes the SCSI target can lead to an
oops:
Unable to handle kernel pointer dereference at virtual kernel address 00000000b6815000
Oops: 0011 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: sunrpc qeth_l3 binfmt_misc dm_multipath scsi_dh dm_mod ipv6 qeth ccwgroup [last unloaded: scsi_wait_scan]
CPU: 1 Not tainted 2.6.35.5-45.x.20100924-s390xdefault #1
Process fc_wq_0 (pid: 861, task: 00000000b7331240, ksp: 00000000b735bac0)
Krnl PSW : 0704200180000000 00000000003ff6e4 (__scsi_remove_device+0x24/0xd0)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:2 PM:0 EA:3
Krnl GPRS: 0000000000000001 0000000000000000 00000000b6815000 00000000bc24a8c0
00000000003ff7c8 000000000056dbb8 0000000000000002 0000000000835d80
ffffffff00000000 0000000000001000 00000000b6815000 00000000bc24a7f0
00000000b68151a0 00000000b6815000 00000000b735bc20 00000000b735bbf8
Krnl Code: 00000000003ff6d6: a7840001 brc 8,3ff6d8
00000000003ff6da: a7fbffd8 aghi %r15,-40
00000000003ff6de: e3e0f0980024 stg %r14,152(%r15)
>00000000003ff6e4: e31021200004 lg %r1,288(%r2)
00000000003ff6ea: a71f0000 cghi %r1,0
00000000003ff6ee: a7a40011 brc 10,3ff710
00000000003ff6f2: a7390003 lghi %r3,3
00000000003ff6f6: c0e5ffffc8b1 brasl %r14,3f8858
Call Trace:
([<0000000000001000>] 0x1000)
[<00000000003ff7d2>] scsi_remove_device+0x42/0x54
[<00000000003ff8ba>] __scsi_remove_target+0xca/0xfc
[<00000000003ff99a>] __remove_child+0x3a/0x48
[<00000000003e3246>] device_for_each_child+0x72/0xbc
[<00000000003ff93a>] scsi_remove_target+0x4e/0x74
[<0000000000406586>] fc_rport_final_delete+0xb2/0x23c
[<000000000015d080>] worker_thread+0x200/0x344
[<000000000016330c>] kthread+0xa0/0xa8
[<0000000000106c1a>] kernel_thread_starter+0x6/0xc
[<0000000000106c14>] kernel_thread_starter+0x0/0xc
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<00000000003ff7cc>] scsi_remove_device+0x3c/0x54
The function __scsi_remove_target iterates through the SCSI devices on
the host, but it drops the host_lock before calling
scsi_remove_device. When the SCSI device is deleted from another
thread, the pointer to the SCSI device in scsi_remove_device can
become invalid. Fix this by getting a reference to the SCSI device
before dropping the host_lock to keep the SCSI device alive for the
call to scsi_remove_device.
Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com>
Cc: Stable Tree <stable@kernel.org>
Some controllers have a hardware limit on the number of protection
information scatter-gather list segments they can handle.
Introduce a max_integrity_segments limit in the block layer and provide
a new scsi_host_template setting that allows HBA drivers to provide a
value suitable for the hardware.
Add support for honoring the integrity segment limit when merging both
bios and requests.
Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
Fake "address-of" expressions that evaluate to NULL generally confuse
readers and can provoke compiler warnings. This patch (as1411) removes
one such fake expression, using an "#ifdef" in its place.
This patch (as1398b) adds runtime PM support to the SCSI layer. Only
the machanism is provided; use of it is up to the various high-level
drivers, and the patch doesn't change any of them. Except for sg --
the patch expicitly prevents a device from being runtime-suspended
while its sg device file is open.
The implementation is simplistic. In general, hosts and targets are
automatically suspended when all their children are asleep, but for
them the runtime-suspend code doesn't actually do anything. (A host's
runtime PM status is propagated up the device tree, though, so a
runtime-PM-aware lower-level driver could power down the host adapter
hardware at the appropriate times.) There are comments indicating
where a transport class might be notified or some other hooks added.
LUNs are runtime-suspended by calling the drivers' existing suspend
handlers (and likewise for runtime-resume). Somewhat arbitrarily, the
implementation delays for 100 ms before suspending an eligible LUN.
This is because there typically are occasions during bootup when the
same device file is opened and closed several times in quick
succession.
The way this all works is that the SCSI core increments a device's
PM-usage count when it is registered. If a high-level driver does
nothing then the device will not be eligible for runtime-suspend
because of the elevated usage count. If a high-level driver wants to
use runtime PM then it can call scsi_autopm_put_device() in its probe
routine to decrement the usage count and scsi_autopm_get_device() in
its remove routine to restore the original count.
Hosts, targets, and LUNs are not suspended while they are being probed
or removed, or while the error handler is running. In fact, a fairly
large part of the patch consists of code to make sure that things
aren't suspended at such times.
[jejb: fix up compile issues in PM config variations]
This patch (as1397b) converts the SCSI midlayer to use the new PM
callbacks (struct dev_pm_ops). A new source file, scsi_pm.c, is
created to hold the new callback routines, and the existing
suspend/resume code is moved there.
This patch fixes sdev_rw_attr() macro for scsi device sysfs entries.
It seems there is no such function snscanf in the current linux kernel,
so it fails to compile scsi driver when someone try to add a new rw entry.
This has been unfixed for a long time probably because current scsi device
has no rw entries.
# grep snscanf . -rn
./drivers/scsi/scsi_sysfs.c:489: snscanf (buf, 20, format_string, &sdev->field); \
Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com>
This patch (as1358) fixes a bug in the error pathway of
scsi_target_add(). If registration fails, the target should not be
reaped. The reaping occurs later, when scanning is finished and all
the child devices are removed. The current code leaves an unbalanced
value in starget->reap_ref.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Hibernate: Fix preallocating of memory
PM / Hibernate: Remove swsusp.c finally
PM / Hibernate: Remove trailing space in message
PM: Allow SCSI devices to suspend/resume asynchronously
PM: Allow USB devices to suspend/resume asynchronously
USB: implement non-tree resume ordering constraints for PCI host controllers
PM: Allow PCI devices to suspend/resume asynchronously
PM / Hibernate: Swap, remove useless check from swsusp_read()
PM / Hibernate: Really deprecate deprecated user ioctls
PM: Allow device drivers to use dpm_wait()
PM: Start asynchronous resume threads upfront
PM: Add facility for advanced testing of async suspend/resume
PM: Add a switch for disabling/enabling asynchronous suspend/resume
PM: Asynchronous suspend and resume of devices
PM: Add parent information to timing messages
PM: Document device power attributes in sysfs
PM / Runtime: Add sysfs switch for disabling device run-time PM
Set power.async_suspend for all SCSI devices, targets and hosts, so
that they can be suspended and resumed in parallel with the main
suspend/resume thread and possibly with other devices they don't
depend on in a known way (i.e. devices which are not their parents or
children).
The power.async_suspend flag is also set for devices that don't have
suspend or resume callbacks, because otherwise they would make the
main suspend/resume thread wait for their "asynchronous" children
(during suspend) or parents (during resume), effectively negating the
possible gains from executing these devices' suspend and resume
callbacks asynchronously.
This patch (as1335) fixes a bug in scsi_sysfs_add_sdev(). Its callers
always remove the device if anything goes wrong, so it should never
remove the device.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits)
[SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP
[SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class
[SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED
[SCSI] zfcp: Update FSF error reporting
[SCSI] zfcp: Improve ELS ADISC handling
[SCSI] zfcp: Simplify handling of ct and els requests
[SCSI] zfcp: Remove ZFCP_DID_MASK
[SCSI] zfcp: Move WKA port to zfcp FC code
[SCSI] zfcp: Use common code definitions for FC CT structs
[SCSI] zfcp: Use common code definitions for FC ELS structs
[SCSI] zfcp: Update FCP protocol related code
[SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport
[SCSI] zfcp: Assign scheduled work to driver queue
[SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore
[SCSI] zfcp: Implement module unloading
[SCSI] zfcp: Merge trace code for fsf requests in one function
[SCSI] zfcp: Access ports and units with container_of in sysfs code
[SCSI] zfcp: Remove suspend callback
[SCSI] zfcp: Remove global config_mutex
[SCSI] zfcp: Replace local reference counting with common kref
Current FC HBA queue_depth ramp up code depends on last queue
full time. The sdev already has last_queue_full_time field to
track last queue full time but stored value is truncated by
last four bits.
So this patch updates last_queue_full_time without truncating
last 4 bits to store full value and then updates its only
current usages in scsi_track_queue_full to ignore last four bits
to keep current usages same while also use this field
in added ramp up code.
Adds scsi_handle_queue_ramp_up to ramp up queue_depth on
successful completion of IO. The scsi_handle_queue_ramp_up will
do ramp up on all luns of a target, just same as ramp down done
on all luns on a target.
The ramp up is skipped in case the change_queue_depth is not
supported by LLD or already reached to added max_queue_depth.
Updates added max_queue_depth on every new update to default
queue_depth value.
The ramp up is also skipped if lapsed time since either last
queue ramp up or down is less than LLD specified
queue_ramp_up_period.
Adds queue_ramp_up_period to sysfs but only if change_queue_depth
is supported since ramp up and queue_ramp_up_period is needed only
in case change_queue_depth is supported first.
Initializes queue_ramp_up_period to 120HZ jiffies as initial
default value, it is same as used in existing lpfc and qla2xxx.
-v2
Combined all ramp code into this single patch.
-v3
Moves max_queue_depth initialization after slave_configure is
called from after slave_alloc calling done. Also adjusted
max_queue_depth check to skip ramp up if current queue_depth
is >= max_queue_depth.
-v4
Changes sdev->queue_ramp_up_period unit to ms when using sysfs i/f
to store or show its value.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
Tested-by: Christof Schmitt <christof.schmitt@de.ibm.com>
Tested-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
This patch modifies scsi_host_template->change_queue_depth so that
it takes an argument indicating why it is being called. This will be
used so that if a LLD needs to do some extra processing when
handling queue fulls or later ramp ups, it can do so.
This is a simple port of the drivers setting a change_queue_depth
callback. In the patch I just have these LLDs adjust the queue depth
if the user was requesting it.
[Vasu.Dev: v2
Also converted pmcraid_change_queue_depth and then verified
all modules compile using "make allmodconfig" for any new build
warnings on X86_64.
Updated original description after combing two original
patches from Mike to make this patch git bisectable.]
[jejb: fixed up 53c700]
Async scanning introduced a very wide window where the SCSI device is
up and running but has not yet been added to sysfs. We delay the
adding until all scans have completed to retain the same ordering as
sync scanning.
This delay in visibility causes an oops if a device is removed before
we make it visible because the SCSI removal routines have an inbuilt
assumption that if a device is in SDEV_RUNNING state, it must be
visible (which is not necessarily true in the async scanning case).
Fix this by introducing an additional is_visible flag which we can use
to condition the tear down so we do the right thing for running but
not yet made visible.
Reported-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
The root cause of the problem is the fact that dev_set_name() now
allocates storage instead of using the original array within the kobj.
That means that the SCSI assumption that if you haven't made the
containing object or any sub objects visible, you can just destroy it
(and its component devices) lock stock and barrel becomes false.
Fix this by doing the get of sdev_dev at parent time and thus do an
extra put of it in scsi_destroy_sdev() (and all other destruction
without add paths).
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it
up itself on remove(), and not from the bus callbacks. This
removes the need to hook into bus->remove(), which should not
be used at the same time as driver->remove().
[jejb: fix sdkp initialisation problem due to mismerge]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Warning(linux-2.6.28-git13//drivers/scsi/scsi_sysfs.c:1049): Excess function parameter 'dev' description in 'scsi_sysfs_add_host'
