path: root/drivers/scsi/sd.c
2008-04-29block: no need to initialize rq->cmd in prepare_flush_fn hookFUJITA Tomonori
The block layer initializes rq->cmd (queue_flush calls rq_init) so prepare_flush_fn hooks don't need to do that. The purpose of this patch is to remove sizeof(rq->cmd), as a preparation for large command support, which changes rq->cmd from the static array to a pointer. sizeof(rq->cmd) will not make sense. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-19[SCSI] sd, sr: do not emit change event at device addKay Sievers
Initialize the "state changed" flag, so we do not send a change event immediately after registering a new device. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[SCSI] sd: handle bad lba in sense informationJames Bottomley
Some devices report medium error locations incorrectly. Add guards to make sure the reported bad lba is actually in the request that caused it. Additionally remove the large case statment for sector sizes and replace it with the proper u64 divisions. Tested-by: Mike Snitzer <snitzer@gmail.com> Cc: Stable Tree <stable@kernel.org> Cc: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] implement scsi_data_bufferBoaz Harrosh
In preparation for bidi we abstract all IO members of scsi_cmnd, that will need to duplicate, into a substructure. - Group all IO members of scsi_cmnd into a scsi_data_buffer structure. - Adjust accessors to new members. - scsi_{alloc,free}_sgtable receive a scsi_data_buffer instead of scsi_cmnd. And work on it. - Adjust scsi_init_io() and scsi_release_buffers() for above change. - Fix other parts of scsi_lib/scsi.c to members migration. Use accessors where appropriate. - fix Documentation about scsi_cmnd in scsi_host.h - scsi_error.c * Changed needed members of struct scsi_eh_save. * Careful considerations in scsi_eh_prep/restore_cmnd. - sd.c and sr.c * sd and sr would adjust IO size to align on device's block size so code needs to change once we move to scsi_data_buff implementation. * Convert code to use scsi_for_each_sg * Use data accessors where appropriate. - tgt: convert libsrp to use scsi_data_buffer - isd200: This driver still bangs on scsi_cmnd IO members, so need changing [jejb: rebased on top of sg_table patches fixed up conflicts and used the synergy to eliminate use_sg and sg_count] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sd: add fix for devices with last sector access problemsHans de Goede
This patch adds a new scsi_device flag (last_sector_bug) for devices which contain a bug where the device crashes when the last sector is read in a larger then 1 sector read. This is for example the case with sdcards in the HP PSC1350 printer cardreader and in the HP PSC1610 printer cardreader. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sd,sr: add early detection of medium not presentJames Bottomley
The current scsi_test_unit_ready() is updated to return sense code information (in struct scsi_sense_hdr). The sd and sr drivers are changed to interpret the sense code return asc 0x3a as no media and adjust the device status accordingly. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sr,sd: send media state change modification eventsKay Sievers
This will send for a card reader slot (remove/add media): UEVENT[1187091572.155884] change /devices/pci0000:00/0000:00:1d.7/usb5/5-2/5-2:1.0/host7/target7:0:0/7:0:0:0 (scsi) UEVENT[1187091572.162314] remove /block/sdb/sdb1 (block) UEVENT[1187091572.172464] add /block/sdb/sdb1 (block) UEVENT[1187091572.175408] change /devices/pci0000:00/0000:00:1d.7/usb5/5-2/5-2:1.0/host7/target7:0:0/7:0:0:0 (scsi) and for a DVD drive (add/eject media): UEVENT[1187091590.189159] change /devices/pci0000:00/0000:00:1f.1/host4/target4:0:0/4:0:0:0 (scsi) UEVENT[1187091590.957124] add /module/isofs (module) UEVENT[1187091604.468207] change /devices/pci0000:00/0000:00:1f.1/host4/target4:0:0/4:0:0:0 (scsi) Userspace gets events, even for unpartitioned media. This unifies the event handling for asynchronoous events (AN) and events caused by perodical polling the device from userspace. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> [jejb: modified for new event API] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-06Revert "scsi: revert "[SCSI] Get rid of scsi_cmnd->done""Linus Torvalds
This reverts commit ac40532ef0b8649e6f7f83859ea0de1c4ed08a19, which gets us back the original cleanup of 6f5391c283d7fdcf24bf40786ea79061919d1e1d. It turns out that the bug that was triggered by that commit was apparently not actually triggered by that commit at all, and just the testing conditions had changed enough to make it appear to be due to it. The real problem seems to have been found by Peter Osterlund: "pktcdvd sets it [block device size] when opening the /dev/pktcdvd device, but when the drive is later opened as /dev/scd0, there is nothing that sets it back. (Btw, 40944 is possible if the disk is a CDRW that was formatted with "cdrwtool -m 10236".) The problem is that pktcdvd opens the cd device in non-blocking mode when pktsetup is run, and doesn't close it again until pktsetup -d is run. The effect is that if you meanwhile open the cd device, blkdev.c:do_open() doesn't call bd_set_size() because bdev->bd_openers is non-zero." In particular, to repeat the bug (regardless of whether commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d is applied or not): " 1. Start with an empty drive. 2. pktsetup 0 /dev/scd0 3. Insert a CD containing an isofs filesystem. 4. mount /dev/pktcdvd/0 /mnt/tmp 5. umount /mnt/tmp 6. Press the eject button. 7. Insert a DVD containing a non-writable filesystem. 8. mount /dev/scd0 /mnt/tmp 9. find /mnt/tmp -type f -print0 | xargs -0 sha1sum >/dev/null 10. If the DVD contains data beyond the physical size of a CD, you get I/O errors in the terminal, and dmesg reports lots of "attempt to access beyond end of device" errors." which in turn is because the nested open after the media change won't cause the size to be set properly (because the original open still holds the block device, and we only do the bd_set_size() when we don't have other people holding the device open). The proper fix for that is probably to just do something like bdev->bd_inode->i_size = (loff_t)get_capacity(disk)<<9; in fs/block_dev.c:do_open() even for the cases where we're not the original opener (but *not* call bd_set_size(), since that will also change the block size of the device). Cc: Peter Osterlund <petero2@telia.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-02scsi: revert "[SCSI] Get rid of scsi_cmnd->done"Ingo Molnar
This reverts commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d ("[SCSI] Get rid of scsi_cmnd->done") that was supposed to be a cleanup commit, but apparently it causes regressions: Bug 9370 - v2.6.24-rc2-409-g9418d5d: attempt to access beyond end of device http://bugzilla.kernel.org/show_bug.cgi?id=9370 this patch should be reintroduced in a more split-up form to make testing of it easier. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Matthew Wilcox <matthew@wil.cx> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16block: convert blkdev_issue_flush() to use empty barriersJens Axboe
Then we can get rid of ->issue_flush_fn() and all the driver private implementations of that. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] Get rid of scsi_cmnd->doneMatthew Wilcox
The ULD ->done callback moves into the scsi_driver. By moving the call to scsi_io_completion() from scsi_blk_pc_done() to scsi_finish_command(), we can eliminate the latter entirely. By returning 'good_bytes' from the ->done callback (rather than invoking scsi_io_completion()), we can stop exporting scsi_io_completion(). Also move the prototypes from sd.h to sd.c as they're all internal anyway. Rename sd_rw_intr to sd_done and rw_intr to sr_done. Inspired-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] move ULD attachment into the prep functionJames Bottomley
One of the intents of the block prep function was to allow ULDs to use it for preprocessing. The original SCSI model was to have a single prep function and add a pointer indirect filter to build the necessary commands. This patch reverses that, does away with the init_command field of the scsi_driver structure and makes ULDs attach directly to the prep function instead. The value is really that it allows us to begin to separate the ULDs from the SCSI mid layer (as long as they don't use any core functions---which is hard at the moment---a ULD doesn't even need SCSI to bind). Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-08-04[SCSI] sd: disentangle barriers in SCSIJames Bottomley
Our current implementation has a generic set of barrier functions that go through the SCSI driver model. Realistically, this is unnecessary, because the only device that can use barriers (sd) can set the flush functions up at probe or revalidate time. This patch pulls the barrier functions out of the mid layer and scsi driver model and relocates them directly in sd. Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-16bsg: add a request_queue argument to scsi_cmd_ioctl()FUJITA Tomonori
bsg uses scsi_cmd_ioctl() for some SCSI/sg ioctl commands. scsi_cmd_ioctl() gets a request queue from a gendisk arguement. This prevents bsg being bound to SCSI devices that don't have a gendisk (like OSD). This adds a request_queue argument to scsi_cmd_ioctl(). The SCSI/sg ioctl commands doesn't use a gendisk so it's safe for any SCSI devices to use scsi_cmd_ioctl(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-30[SCSI] Merge up to linux-2.6 headJames Bottomley
Conflicts: drivers/scsi/jazz_esp.c Same changes made by both SCSI and SPARC trees: problem with UTF-8 conversion in the copyright. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-24[SCSI] sd: remove __GFP_DMABernhard Walle
After 821de3a27bf33f11ec878562577c586cd5f83c64, it's not necessary to alloate a DMA buffer any more in sd.c. Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-22[SCSI] sd: fix refcounting regression in suspend/resume routinesAlan Stern
This patch (as909) fixes a couple of refcounting errors in the sd driver's suspend and resume methods. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-17[SCSI] modalias for scsi devicesMichael Tokarev
The following patch adds support for sysfs/uevent modalias attribute for scsi devices (like disks, tapes, cdroms etc), based on whatever current sd.c, sr.c, st.c and osst.c drivers supports. The modalias format is like this: scsi:type-0x04 (for TYPE_WORM, handled by sr.c now). Several comments. o This hexadecimal type value is because all TYPE_XXX constants in include/scsi/scsi.h are given in hex, but __stringify() will not convert them to decimal (so it will NOT be scsi:type-4). Since it does not really matter in which format it is, while both modalias in module and modalias attribute match each other, I descided to go for that 0x%02x format (and added a comment in include/scsi/scsi.h to keep them that way), instead of changing them all to decimal. o There was no .uevent routine for SCSI bus. It might be a good idea to add some more ueven environment variables in there. o osst.c driver handles tapes too, like st.c, but only SOME tapes. With this setup, hotplug scripts (or whatever is used by the user) will try to load both st and osst modules for all SCSI tapes found, because both modules have scsi:type-0x01 alias). It is not harmful, but one extra module is no good either. It is possible to solve this, by exporting more info in modalias attribute, including vendor and device identification strings, so that modalias becomes something like scsi:type-0x12:vendor-Adaptec LTD:device-OnStream Tape Drive and having that, match for all 3 attributes, not only device type. But oh well, vendor and device strings may be large, and they do contain spaces and whatnot. So I left them for now, awaiting for comments first. Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] sd: fix up start/stop messages for new sd_printk() APIJames Bottomley
2007-03-20[SCSI] sd: implement START/STOP managementTejun Heo
Implement SBC START/STOP management. sdev->mange_start_stop is added. When it's set to one, sd STOPs the device on suspend and shutdown and STARTs it on resume. sdev->manage_start_stop defaults is in sdev instead of scsi_disk cdev to allow ->slave_config() override the default configuration but is exported under scsi_disk sysfs node as sdev->allow_restart is. When manage_start_stop is zero (the default value), this patch doesn't introduce any behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] sd: fix return value of sd_sync_cache()Tejun Heo
sd_sync_cache() should return -errno on error, fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] sd: typo fix: sdkp_printk should be sd_printkJames Bottomley
2007-03-11[SCSI] sd: convert logging to new printk helpersMartin K. Petersen
Convert the sd.c SCSI logging calls to scmd_printk()/sd_printk() instead of plain printk(). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] sd: make printing use a common prefixMartin K. Petersen
Make SCSI disk printing more consistent: - Define sd_printk(), sd_print_sense_hdr() and sd_print_result() - Move relevant header bits into sd.h - Remove all the legacy disk_name passing and use scsi_disk pointers where possible - Switch printk() lines to the new sd_ functions so that output is consistent Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-16USB Storage: indistinguishable devices with broken and unbroken firmwareOliver Neukum
there's a USB mass storage device which exists in two version. One reports the correct size and the other does not. Apart from that they are identical and cannot be told apart. Here's a heuristic based on the empirical finding that drives have even sizes. Signed-off-by: Oliver Neukum <oneukum@suse.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-02[SCSI] sd: udev accessing an uninitialized scsi_disk field results in a crashNagendra Singh Tomar
sd_probe() calls class_device_add() even before initializing the sdkp->device variable. class_device_add() eventually results in the user mode udev program to be called. udev program can read the the allow_restart attribute of the newly created scsi device. This is resulting in a crash as the show function for allow_restart (i.e sd_show_allow_restart) returns the attribute value by reading the sdkp->device->allow_restart variable. As the sdkp->device is not initialized before calling the user mode hotplug helper, this results in a crash. The patch below solves it by calling class_device_add() only after the necessary fields in the scsi_disk structure are initialized properly. Signed-off-by: Nagendra Singh Tomar <nagendra_tomar@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-08[PATCH] struct path: convert scsiJosef Sipek
2006-11-15[SCSI] sd: clearer output of disk cache stateLuben Tuikov
Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-15[SCSI] Reduce polling in sd.cAlan Stern
If a drive reports that no media is present, there's no point in continuing to ask it about media status. This patch (as696) cuts the TUR polling short as soon as the drive reports no media instead of going a full 3 iterations. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits) [SCSI] Initial Commit of qla4xxx [SCSI] raid class: handle component-add errors [SCSI] SCSI megaraid_sas: handle thrown errors [SCSI] SCSI aic94xx: handle sysfs errors [SCSI] SCSI st: fix error handling in module init, sysfs [SCSI] SCSI sd: fix module init/exit error handling [SCSI] SCSI osst: add error handling to module init, sysfs [SCSI] scsi: remove hosts.h [SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c [SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog [SCSI] megaraid_sas: adds tasklet for cmd completion [SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error [SCSI] megaraid_sas: function pointer for disable interrupt [SCSI] megaraid_sas: frame count optimization [SCSI] megaraid_sas: FW transition and q size changes [SCSI] qla2xxx: Update version number to 8.01.07-k2. [SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked. [SCSI] qla2xxx: Add MODULE_FIRMWARE tags. [SCSI] qla2xxx: Add support for host port state FC transport attribute. [SCSI] qla2xxx: Add support for fabric name FC transport attribute. ...
2006-10-04[SCSI] SCSI sd: fix module init/exit error handlingJeff Garzik
- Properly handle and unwind errors in init_sd(). Fixes leaks on error, if class_register() or scsi_register_driver() failed. - Ensure that exit_sd() execution order is the perfect inverse of initialization order. FIXME: If some-but-not-all register_blkdev() calls fail, we wind up calling unregister_blkdev() for block devices we did not register. This was a pre-existing bug. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-02[SCSI] Wrong size information for devices with disabled read accessHannes Reinecke
When accessing a device with disabled read access the capacity is set randomly to 1GB. This makes it impossible to userspace tools to detect invalid device capacities. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Acked-by: Chris Mason <mason@suse.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-09[SCSI] hide EH backup data outside the scsi_cmndChristoph Hellwig
Currently struct scsi_cmnd has various fields that are used to backup original data after the corresponding fields have been overridden for EH commands. This means drivers can easily get at it and misuse it. Due to the old_ naming this doesn't happen for most of them, but two that have different names have been used wrong a lot (see previous patch). Another downside is that they unessecarily bloat the scsi_cmnd size. This patch moves them onstack in scsi_send_eh_cmnd to fix those two issues aswell as allowing future EH fixes like moving the EH command submissions to use SG lists like everything else. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-28[SCSI] scsi: Add allow_restart sysfs class attributeBrian King
This is a resend of a patch I generated in response to an email sent by Ruben Faelens <parasietje@gmail.com>. His original email to linux-scsi requested a method in which he could spin down a scsi disk when not in use and have the kernel automatically spin it back up when an I/O was generated to the disk. The infrastructure to automatically spin a disk up has been in the scsi error handler for some time now, but it is not enabled by default. This patch adds an sd sysfs attribute which allows userspace to enable this behavior. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26[SCSI] sd/scsi_lib simplify sd_rw_intr and scsi_io_completionLuben Tuikov
This patch simplifies "good_bytes" computation in sd_rw_intr(). sd: "good_bytes" computation is always done in terms of the resolution of the device's medium, since after that it is the number of good bytes we pass around and other layers/contexts (as opposed ot sd) can translate that to their own resolution (block layer:512). It also makes scsi_io_completion() processing more straightforward, eliminating the 3rd argument to the function. It also fixes a couple of bugs like not checking return value, using "break" instead of "return;", etc. I've been running with this patch for some time now on a test (do-it-all) system. Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-25[PATCH] git-scsi-misc: min() warning fixAndrew Morton
drivers/scsi/sd.c: In function `sd_store_cache_type': drivers/scsi/sd.c:193: warning: comparison of distinct pointer types lacks a cast Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-19[SCSI] allow displaying and setting of cache type via sysfsJames Bottomley
I think I promised to do this two years ago This patch adds a scsi_disk class with the cache type and FUA parameters, so user land application can easily obtain them without having to parse dmesg. It also allows setting the cache type (use with care...) This patch is a bit dangerous because I've replaced the disk kref with a class device reference ... Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] MODULE_ALIAS_{BLOCK,CHAR}DEV_MAJOR for drivers/scsiRene Herman
Add device-major aliases in drivers/scsi, allowing kmod autoload: MODULE_ALIAS_CHARDEV_MAJOR(SCSI_CHANGER_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(OSST_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(SCSI_TAPE_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_CDROM_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_DISKN_MAJOR) Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] scsi_lib: fix recognition of cache type of Initio SBP-2 bridgesAl Viro
Regardless what mode page was asked for, Initio INIC-14x0 and INIC-2430 always return page 6 without mode page headers. Try to recognise this as a special case in scsi_mode_sense and setting the mode sense headers accordingly. Signed-off-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Remove devfs support from the SCSI subsystemGreg KH
As devfs has been disabled from the kernel tree for a number of months now (5 to be exact), here's a patch against 2.6.16-rc1-git1 that removes support for it from the SCSI subsystem. The patch also removes the scsi_disk devfs_name field as it's no longer needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
