path: root/drivers/scsi/sr_ioctl.c
2006-03-06Allocate 96 bytes for SCSI sense data replyLinus Torvalds
The SCSI layer uses SCSI_SENSE_BUFFERSIZE (96) for the sense buffer size, even though some other code uses "sizeof(struct request_sense)" (which is 64 bytes). Allocate the buffer using the bigger of the two for safety. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] sr: split sr_audio_ioctl into specific helpersChristoph Hellwig
split each ioctl handled in sr_audio_ioctl into a function of it's own. This cleans the code up nicely, and allows various places in sr_ioctl to call these helpers directly instead of going through the multiplexer. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28[SCSI] convert sr to scsi_execute_reqJames Bottomley
This follows almost the identical model to sd, except that there's one ioctl which returns raw sense data, so it had to use scsi_execute() instead. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-21[SCSI] drivers/scsi/sr_ioctl.c: check for failed allocationNate Dailey
I noticed a case in sr_ioctl.c's sr_get_mcn where a buffer is allocated, but the pointer isn't checked for null. Signed-off-by: Nate Dailey <nate.dailey@stratus.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
