path: root/drivers/scsi/st.c
2011-11-11st: fix race in st_scsi_execute_endPetr Uzel
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream. The call to complete() in st_scsi_execute_end() wakes up sleeping thread in write_behind_check(), which frees the st_request, thus invalidating the pointer to the associated bio structure, which is then passed to the blk_rq_unmap_user(). Fix by storing pointer to bio structure into temporary local variable. This bug is present since at least linux-2.6.32. Signed-off-by: Petr Uzel <petr.uzel@suse.cz> Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-22[SCSI] st: Increase success probability in driver buffer allocationFUJITA Tomonori
Modify allocation to try the minimum possible page order allowed by the HBA scatter/gather segment limit in allocation of the driver's internal buffer. This increases the probability of successful allocation. The allocation may still fail if this minimum order is > 0. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Reported-by: Lukas Kolbe <lkolbe@techfak.uni-bielefeld.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-22[SCSI] st: Store page order before driver buffer allocationKai Makisara
The order of the pages allocated for the driver buffer must be stored before allocation because it is used in freeing already allocated pages if allocation fails. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Reported-by: Lukas Kolbe <lkolbe@techfak.uni-bielefeld.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (84 commits) [SCSI] be2iscsi: SGE Len == 64K [SCSI] be2iscsi: Remove premature free of cid [SCSI] be2iscsi: More time for FW [SCSI] libsas: fix bug for vacant phy [SCSI] sd: Fix overflow with big physical blocks [SCSI] st: add MTWEOFI to write filemarks without flushing drive buffer [SCSI] libsas: Don't issue commands to devices that have been hot-removed [SCSI] megaraid_sas: Add Online Controller Reset to MegaRAID SAS drive [SCSI] lpfc 8.3.17: Update lpfc driver version to 8.3.17 [SCSI] lpfc 8.3.17: Replace function reset methodology [SCSI] lpfc 8.3.17: SCSI fixes [SCSI] lpfc 8.3.17: BSG fixes [SCSI] lpfc 8.3.17: SLI Additions and Fixes [SCSI] lpfc 8.3.17: Code Cleanup and Locking fixes [SCSI] zfcp: Remove scsi_cmnd->serial_number from debug traces [SCSI] ipr: fix array error logging [SCSI] aha152x: enable PCMCIA on 64bit [SCSI] scsi_dh_alua: Handle all states correctly [SCSI] cxgb4i: connection and ddp setting update [SCSI] cxgb3i: fixed connection over vlan ...
2010-10-08[SCSI] st: add MTWEOFI to write filemarks without flushing drive bufferKai Makisara
This patch adds a new MTIOCTOP operation MTWEOFI that writes filemarks with immediate bit set. This means that the drive does not flush its buffer and the next file can be started immediately. This speeds up writing in applications that have to write multiple small files. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-05-27st: use noop_llseek() instead of default_llseek()Jan Blunck
st_open() suggests that llseek() doesn't work: "We really want to do nonseekable_open(inode, filp); here, but some versions of tar incorrectly call lseek on tapes and bail out if that fails. So we disallow pread() and pwrite(), but permit lseeks." Instead of using the fallback default_llseek() the driver should use noop_llseek() which leaves the file->f_pos untouched but succeeds. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Kai Makisara <Kai.Makisara@kolumbus.fi> Cc: Willem Riede <osst@riede.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-10[SCSI] st: fix mdata->page_order handlingFUJITA Tomonori
dio transfer always resets mdata->page_order to zero. It breaks high-order pages previously allocated for non-dio transfer. This patches adds reserved_page_order to st_buffer structure to save page order for non-dio transfer. http://bugzilla.kernel.org/show_bug.cgi?id=14563 When enlarge_buffer() allocates 524288 from 0, st uses six-order page allocation. So mdata->page_order is 6 and frp_seg is 2. After that, if st uses dio, sgl_map_user_pages() sets mdata->page_order to 0 for st_do_scsi(). After that, when we call normalize_buffer(), it frees only free frp_seg * PAGE_SIZE (2 * 4096) though we should free frp_seg * PAGE_SIZE << 6 (2 * 4096 << 6). So we see buffer_size is set to 516096 (524288 - 8192). Reported-by: Joachim Breuer <linux-kernel@jmbreuer.net> Tested-by: Joachim Breuer <linux-kernel@jmbreuer.net> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: stable@kernel.org Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] st: fix test of value range in st_set_options()Roel Kluin
value cannot logically be less than START and greater than BUFFERSIZE. #define EXTENDED_SENSE_START 18 // vi include/scsi/scsi_cmnd.h +105 #define SCSI_SENSE_BUFFERSIZE 96 [akpm@linux-foundation.org: fix warning] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] st: fix possible memory use after free after MTSETBLK ioctlDavid Jeffery
A memory use after free bug can manifest if the MTSETBLK or SET_DENS_AND_BLK ioctl features are used to set the tape's blocksize from 0 to non-zero. After the driver sets the new block size, in this one case it calls normalize_buffer() to free the device's internal data buffers. However, the ioctl code assumes there is always a buffer and does not check or allocate a buffer if there isn't one. So any following ioctl calls can corrupt a part of memory by writing data to memory that the st driver had freed. This patch removes the normalize_buffer() call and the specialness of changing from a 0 to non-zero blocksize to fix the possible use of memory after it has been freed by the st driver. signed-off-by: David Jeffery <djeffery@redhat.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-12[SCSI] Merge branch 'linus'James Bottomley
Conflicts: drivers/message/fusion/mptsas.c fixed up conflict between req->data_len accessors and mptsas driver updates. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] st: fix gcc 4.4 warningKai Makisara
This patch fixes the GCC 4.4 warning reported by David Binderman and Sergey Senozhatsky. The old version was working correctly but was not easy to read. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: add rq->resid_lenTejun Heo
rq->data_len served two purposes - the length of data buffer on issue and the residual count on completion. This duality creates some headaches. First of all, block layer and low level drivers can't really determine what rq->data_len contains while a request is executing. It could be the total request length or it coulde be anything else one of the lower layers is using to keep track of residual count. This complicates things because blk_rq_bytes() and thus [__]blk_end_request_all() relies on rq->data_len for PC commands. Drivers which want to report residual count should first cache the total request length, update rq->data_len and then complete the request with the cached data length. Secondly, it makes requests default to reporting full residual count, ie. reporting that no data transfer occurred. The residual count is an exception not the norm; however, the driver should clear rq->data_len to zero to signify the normal cases while leaving it alone means no data transfer occurred at all. This reverse default behavior complicates code unnecessarily and renders block PC on some drivers (ide-tape/floppy) unuseable. This patch adds rq->resid_len which is used only for residual count. While at it, remove now unnecessasry blk_rq_bytes() caching in ide_pc_intr() as rq->data_len is not changed anymore. Boaz : spotted missing conversion in osd Sergei : spotted too early conversion to blk_rq_bytes() in ide-tape [ Impact: cleanup residual count handling, report 0 resid by default ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-12[SCSI] Remove SUGGEST flagsMartin K. Petersen
The SUGGEST_* flags in the SCSI command result have been out of fashion for a while and we don't actually use them in the error handling. Remove the remaining occurrences. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: retry enlarge_buffer allocationKai Makisara
Make enlarge_buffer() retry allocation if the previously chosen page order was too small. Really limit the page order to 6. Return error if the maximum order is not large enough for the request. Signed-off-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: integrate st_scsi_kern_execute and st_do_scsiKai Makisara
This integrates st_scsi_kern_execute and st_do_scsi. IOW, it removes st_scsi_kern_execute. Then st has a single function, st_do_scsi, to perform SCSI commands. Signed-off-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: remove unused frp_sg_currentFUJITA Tomonori
frp_sg_current in struct st_buffer is always zero. We don't need it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: remove unused orig_frp_segsFUJITA Tomonori
orig_frp_segs in struct st_buffer is always zero. We don't need it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: simplify new_tape_bufferFUJITA Tomonori
- remove the from_initialization argument, which is always 1. We always need to use GFP_ATOMIC. - 'got' valuable is initialized to zero and doesn't change. We don't need it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: remove struct scatterlistFUJITA Tomonori
This removes the usage of struct scatterlist completely. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: kill struct st_buff_fragmentFUJITA Tomonori
This removes struct st_buff_fragment and use reserved_pages array to store fragment buffer. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: remove buf_to_sgFUJITA Tomonori
This removes unused buf_to_sg() that the non-dio path used. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: convert dio path to use st_scsi_executeFUJITA Tomonori
This patch converts the dio path (mmap) to use st_scsi_execute. IOW, it removes scsi_execute_async in the non dio path. scsi_execute_async has gone! This also remove unused st_sleep_done. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: convert non-dio path to use st_scsi_executeFUJITA Tomonori
This patch converts the non-dio path (fragment buffer path) to use st_scsi_execute. IOW, it removes scsi_execute_async in the non-dio path. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: add st_scsi_execute helper functionFUJITA Tomonori
st_scsi_execute is a helper function to perform SCSI commands involving data transfer between user and kernel space (st_read and st_write). It's the future plan to combine this with st_scsi_kern_execute helper function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: add struct rq_map_data supportFUJITA Tomonori
This adds struct rq_map_data and the array of pointers to store fragment buffers to struct st_buffer. This patch doesn't remove st_buf_fragment but the latter patch does. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] st: make all the fragment buffers the same sizeFUJITA Tomonori
This patch simiplifies the fragment buffer management a bit, all the buffers in the fragment list become the same size. This is necessary to use the block layer API (sg driver was modified in the same way) since the block layer API takes the same size page frames instead of scatter gatter. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert st_int_ioctl to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in st_int_ioctl with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert get_location to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in get_location (READ_POSITION) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert write_mode_page to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in write_mode_page (MODE_SELECT) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert read_mode_page to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in read_mode_page (MODE_SENSE) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert check_tape to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in check_tape (READ_BLOCK_LIMITS and MODE_SENSE) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert st_flush to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in st_flush (WRITE FILEMARKS) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert cross_eof to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in cross_eof (SPACE) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert do_load_unload to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in do_load_unload (START STOP) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert set_location to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in set_location (LOCATE 10) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: convert test_ready to use st_scsi_kern_executeFUJITA Tomonori
This replaces st_do_scsi in test_ready (TEST_UNIT_READY) with st_scsi_kern_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: add st_scsi_kern_execute helper functionFUJITA Tomonori
st_scsi_kern_execute is a helper function to perform SCSI commands synchronously. It supports data transfer with a liner in-kernel buffer (not scatter gather). st_scsi_kern_execute internally uses scsi_execute(). The majority of st_do_scsi can be replaced with st_scsi_kern_execute. This is a preparation for rewriting st_do_scsi to remove obsolete scsi_execute_async(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: move st_request initialization to st_allocate_request form st_do_scsiFUJITA Tomonori
This moves st_request initialization code to st_allocate_request() form st_do_scsi(). This is a preparation for making st_allocate_request() usable for everyone, not only st_do_scsi(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] st: update to use block timeoutJames Bottomley
Since we're trying to eliminate struct scsi_device timeout, the tape driver has to be updated to use the block queue timeout instead. The tape use of scsi_device timeout looks to be self consistent, so I don't think this necessarily fixes any bug, but it has to be done to allow me to remove the timeout parameter from struct scsi_device. Acked-by: Kai Makisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-21[PATCH] don't mess with file in scsi_nonblockable_ioctl()Al Viro
2008-10-21[PATCH] switch scsi_cmd_ioctl() to passing fmode_tAl Viro
2008-10-16device create: scsi: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26[SCSI] st: Remove bogus memsetKai Makisara
Mike Christie noticed a bogus memset. It can be removed as dead code since the number of bytes in the driver buffer in fixed block mode is always a multiple of the tape block size. Signed-off-by: Kai Mäkisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26[SCSI] st: Move buffer pointer back when data could not be written.Kai Makisara
Move buffer pointer back when data could not be written. Bug found by Mike Christie. Signed-off-by: Kai Mäkisara <Kai.Makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-06-20st: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
