path: root/drivers/scsi/sun3x_esp.c
2008-10-23[SCSI] sun3x_esp: Convert && to ||Julia Lawall
The pattern !E && !E->fld is nonsensical. The patch below updates this according to the assumption that && should be ||. But perhaps another solution was intended. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @disable and_comm@ expression E; identifier fld; @@ - !E && !E->fld + !E || !E->fld // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-By: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] jazz_esp, sgiwd93, sni_53c710, sun3x_esp: fix platform driver ↵Kay Sievers
hotplug/coldplug Since commit 43cc71eed1250755986da4c0f9898f9a635cb3bf Author: Kay Sievers <kay.sievers@vrfy.org> Date: Sat Aug 18 04:40:39 2007 +0200 platform: prefix MODALIAS with "platform:" the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable SCSI platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] [akpm@linux-foundation.org: fix sgiwd93.c] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] sun3x_esp: convert to esp_scsiThomas Bogendoerfer
Converted sun3x_esp driver to use esp_scsi.c Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-24m68k: sg falloutGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2007-02-09[TC] dec_esp: Driver model for the PMAZ-AMaciej W. Rozycki
This is a set of changes that converts the PMAZ-A support to the driver model. The use of the driver model required switching to the hotplug SCSI initialization model, which in turn required a change to the core NCR53C9x driver. I decided not to break all the frontend drivers and introduced an additional parameter for esp_allocate() to select between the old and the new model. I hope this is OK, but I would be fine with converting NCR53C9x to the new model unconditionally as long as I do not have to fix all the other frontends (OK, perhaps I could do some of them ;-) ). Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-14[SCSI] More buffer->request_buffer changesChristoph Hellwig
Seem like quite a few splipped through the cracks. Here's a patch to update all references I could find: Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: Add the generic dma API functionsRoman Zippel
Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-05-20[SCSI] drivers/scsi/NCR53C9x.c: make a struct staticAdrian Bunk
This patch makes a needlessly global struct static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
