path: root/drivers/scsi/sym53c8xx_2
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-02[SCSI] sd, sym53c8xx: Remove warnings after vsprintf %pV introducation.David Miller
GCC warns about empty printf format strings, and after the addition of %pV these existing such cases in the scsi driver layer were exposed enough for the compiler to start seeing them. Based almost entirely upon a patch by Joe Perches. [jejb: fix up sym53c8xx msg] Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-15drivers/scsi/sym53c8xx_2/sym_glue.c: rename skip_spaces() to sym_skip_spaces()Andrew Morton
To avoid a collision with the newly-added kernel-wide skip_spaces(). Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-21sym53c8xx: ratelimit parity errorsJohn Stoffel
This makes a huge difference when you have a serial console on bootup to limit these messages to a sane number. Signed-off-by: John Stoffel <john@stoffel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-20[SCSI] sym53c8xx_2: slave_alloc/destroy safety (2.6.27.5)Aaro Koskinen
Make the sym53c8xx_2 driver slave_alloc/destroy less unsafe. References to the destroyed LCB are cleared from the target structure (instead of leaving a dangling pointer), and when the last LCB for the target is destroyed the reference to the upper layer target data is cleared. The host lock is used to prevent a race with the interrupt handler. Also user commands are prevented for targets with all LCBs destroyed. Signed-off-by: Aaro Koskinen <Aaro.Koskinen@nokia.com> Tested-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-20[SCSI] sym53c8xx_2: lun to_clear flag not re-initialized (2.6.27.5)Aaro Koskinen
(Resent with proper formatting) Fix for the sym53c8xx_2 driver to initialize lun's to_clear flag after a bus reset (a failed clear can trigger a bus reset and it should not be attemped again after that). Signed-off-by: Aaro Koskinen <Aaro.Koskinen@nokia.com> Tested-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_40BIT_MASK macro with DMA_BIT_MASK(40)Yang Hongyang
Replace all DMA_40BIT_MASK macro with DMA_BIT_MASK(40) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03[SCSI] replace __inline with inlineHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: don't flood syslog with negotiation messagesTony Battersby
sym53c8xx prints a negotiation message after every check condition. This can add up to a lot of messages for removable-medium devices (CD-ROM, tape drives, etc.) that are being polled, since they return check condition when no medium is present. This patch suppresses the negotiation message if it would be the same as the last one printed. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: use a queue depth of 1 for untagged devicesTony Battersby
sym53c8xx uses a command queue depth of 2 for untagged devices, without good reason. This _mostly_ seems to work ok, but it has caused me some subtle problems. For example, I have an application where one thread sends write commands to a tape drive, and another thread sends log sense polling commands. With a queue depth of 2, the polling commands end up being starved for long periods of time while multiple write commands are serviced (this may also be related to the fact the the sg driver queues commands in LIFO order). This problem is fixed by changing the queue depth to 1 for untagged devices. I have tested this change extensively with many different tape drives, medium changers, and disk drives (disk drives of course use tagged commands and are therefore unaffected by this patch). Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: handle pci_iomap() failuresTony Battersby
sym_init_device() doesn't check if pci_iomap() fails. It also tries to map device RAM without first checking FE_RAM. 1) Move some initialization from sym_init_device() to the top of sym2_probe(). 2) Rename sym_init_device() to sym_iomap_device(). 3) Call sym_iomap_device() after sym_check_supported() instead of before so that device->chip.features will be set. 4) Check FE_RAM in sym_iomap_device() before mapping RAM. 5) If sym_iomap_device() cannot map registers, then abort. 6) If sym_iomap_device() cannot map RAM, then fall back to not using RAM and continue. 7) Remove the check for FE_RAM in sym_attach() since dev->ram_base is now always set correctly. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: unmap pci memory after probe errorsTony Battersby
During sym2_probe(), sym_init_device() does pci_iomap(), but there is no corresponding pci_iounmap() if an error occurs before sym_attach() copies sym_device::s.{ioaddr,ramaddr} to np. 1) Add the sym_iounmap_device() function. 2) Call sym_iounmap_device() if an error occurs between sym_init_device() and the time sym_attach() allocates np. 3) Make sym_attach() copy sym_device::s.{ioaddr,ramaddr} to np before calling any function that can fail so that sym_free_resources() will do the unmap instead of sym_iounmap_device(). Also fixed by this patch: During sym2_probe(), if sym_check_raid() returns nonzero, then pci_release_regions() is never called. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: fix bogus free_irq() on error pathTony Battersby
If sym_attach() gets an error at or before request_irq(), then sym_free_resources() will call free_irq() for an unregistered interrupt handler. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: fix NULL deref on error pathTony Battersby
If sym_attach() fails to allocate np, the error path will dereference a NULL pointer for printk. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: fix shost use-after-free and memory leakTony Battersby
This patch fixes two bugs: 1) rmmod sym53c8xx uses shost after freeing it with scsi_put_host(shost). 2) insmod sym53c8xx doesn't call scsi_put_host(shost) if scsi_add_host() fails, causing a memory leak on the error path. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: Keep transfer negotiations validAaro Koskinen
(The patch updated based on testing and comments from Tony Battersby.) Change the sym53c8xx_2 driver negotiation logic so that the driver will tolerate better device removals. Negotiation message(s) will be sent with every INQUIRY and REQUEST SENSE command, and whenever there is a change in goals or when the device reports check condition. The patch was made specifically to address the case where you hotswap the disk using remove-single-device/add-single-device commands through /proc/scsi/scsi. Without the patch the driver keeps using old transfer parameters even though the target is reset and reports check condition, so the data transfer of the very first INQUIRY will fail. Signed-off-by: Aaro Koskinen <Aaro.Koskinen@nokia.com> Tested-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-26[SCSI] sym53c8xx: free luntbl in sym_hcb_freeMike Anderson
This patch frees the luntbl dma area in sym_hcb_free if allocated. Since the luntbl is part of a larger dma coherent area not freeing the luntbl kept a 64k dma coherent area previous allocated through dma_alloc_coherent allocated. This prevented a DLPAR remove IO operation from completing successfully. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_ofBenjamin Herrenschmidt
The sym53c8xx driver, for some reason, seems to mostly re-implement linux/list.h with added bogosity. The main one is it's implementation of sym_que_entry which spits warnings with recent gcc's on some 64 bits architectures. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-28scsi: fix integer as NULL pointer warningsHarvey Harrison
drivers/scsi/aic7xxx/aic7770_osm.c:53:58: warning: Using plain integer as NULL pointer drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:355:47: warning: Using plain integer as NULL pointer drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:372:55: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:997:28: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:1003:28: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:1165:46: warning: Using plain integer as NULL pointer drivers/scsi/fdomain.c:1446:40: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:1650:51: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:3171:42: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:5732:52: warning: Using plain integer as NULL pointer drivers/scsi/ncr53c8xx.c:8189:31: warning: Using plain integer as NULL pointer drivers/scsi/ncr53c8xx.c:8225:34: warning: Using plain integer as NULL pointer drivers/scsi/dpt_i2o.c:156:32: warning: Using plain integer as NULL pointer drivers/scsi/ultrastor.c:954:42: warning: Using plain integer as NULL pointer drivers/scsi/ultrastor.c:1104:18: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[SCSI] sym53c8xx: fix resid calculationTony Battersby
This patch fixes the calculation of the data transfer residual for the case of a command that is supposed to transfer an odd number of bytes on a wide bus but transfers nothing instead. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] sym53c8xx: fix bad memset argument in sym_set_cam_result_errorNathan Lynch
On a big powerpc box I got the following oops with 2.6.24-git2: sym0: <1010-66> rev 0x1 at pci 0000:d0:01.0 irq 215 sym0: No NVRAM, ID 7, Fast-80, LVD, parity checking sym0: SCSI BUS has been reset. scsi0 : sym-2.2.3 target0:0:8: FAST-40 WIDE SCSI 80.0 MB/s ST (25 ns, offset 31) scsi 0:0:8:0: Direct-Access IBM ST318305LC C509 PQ: 0 ANSI: 3 target0:0:8: tagged command queuing enabled, command queue depth 16. target0:0:8: Beginning Domain Validation target0:0:8: asynchronous target0:0:8: wide asynchronous target0:0:8: FAST-80 WIDE SCSI 160.0 MB/s DT (12.5 ns, offset 31) target0:0:8: FAST-80 WIDE SCSI 160.0 MB/s DT (12.5 ns, offset 31) Unable to handle kernel paging request for data at address 0x00000000 Faulting instruction address: 0xc000000000038460 cpu 0x25: Vector: 300 (Data Access) at [c00000000f567840] pc: c000000000038460: .memcpy+0x60/0x280 lr: d000000000050280: .sym_set_cam_result_error+0xfc/0x1e0 [sym53c8xx] sp: c00000000f567ac0 msr: 8000000000009032 dar: 0 dsisr: 42000000 current = 0xc000006d1e0af0a0 paca = 0xc0000000004afc00 pid = 0, comm = swapper enter ? for help [link register ] d000000000050280 .sym_set_cam_result_error+0xfc/0x1e0 [sym53c8xx] [c00000000f567ac0] c00000000f567b80 (unreliable) [c00000000f567b80] d0000000000552b8 .sym_complete_error+0x12c/0x1bc [sym53c8xx] [c00000000f567c20] d0000000000561a4 .sym_int_sir+0xaa4/0x1718 [sym53c8xx] [c00000000f567d00] d000000000057e8c .sym_interrupt+0x4e4/0x6ec [sym53c8xx] [c00000000f567dc0] d00000000004fdf4 .sym53c8xx_intr+0x6c/0xdc [sym53c8xx] [c00000000f567e50] c0000000000a83e0 .handle_IRQ_event+0x7c/0xec [c00000000f567ef0] c0000000000aa344 .handle_fasteoi_irq+0x130/0x1f0 [c00000000f567f90] c00000000002a538 .call_handle_irq+0x1c/0x2c [c000004d5e0b3a90] c00000000000c320 .do_IRQ+0x108/0x1d0 [c000004d5e0b3b20] c000000000004790 hardware_interrupt_entry+0x18/0x1c The memset() in sym_set_cam_result_error() would appear to be trashing the scsi_cmnd struct instead of clearing sense_buffer. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sym53c8xx: fixes two bugs related to chip resetKrzysztof Helt
This patch fixes two bugs pointed by James Bottomley: 1. the if (!sym_data->io_reset). That variable is only ever filled by a stack based completion. If we find it non empty it means this code has been entered twice and we have a severe problem, so that should just become a BUG_ON(sym_data->io_reset). 2. sym_data->io_reset should be set to NULL before the routine is exited otherwise the PCI recovery code could end up completing what will be a bogus pointer into the stack. Big thanks to James Bottomley for help with the patch. Signed-off-by: Krzysztof Helt <krzysztof.h1@w.pl> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sym2: fix section mismatch warningRandy Dunlap
Fix section mismatch warning: WARNING: vmlinux.o(.text+0x1ff3a2): Section mismatch: reference to .exit.text:sym2_remove (between 'sym2_io_error_detected' and 'sym_xpt_done') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-12-18[SCSI] sym53c8xx: fix "irq X: nobody cared" regressionTony Battersby
The patch described by the following excerpt from ChangeLog-2.6.24-rc1 eventually causes a "irq X: nobody cared" error after a while: commit 99c9e0a1d6cfe1ba1169a7a81435ee85bc00e4a1 Author: Matthew Wilcox <matthew@wil.cx> Date: Fri Oct 5 15:55:12 2007 -0400 [SCSI] sym53c8xx: Make interrupt handler capable of returning IRQ_NONE After this happens, the kernel disables the IRQ, causing the SCSI card to stop working until the next reboot. The problem is caused by the interrupt handler returning IRQ_NONE instead of IRQ_HANDLED after handling an interrupt-on-the-fly (INTF) condition. The following patch fixes the problem. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-12-18[SCSI] sym53c8xx: fix free_irq() regressionTony Battersby
The following commit changed the pointer passed to request_irq(), but failed to change the pointer passed to free_irq(): commit 99c9e0a1d6cfe1ba1169a7a81435ee85bc00e4a1 Author: Matthew Wilcox <matthew@wil.cx> Date: Fri Oct 5 15:55:12 2007 -0400 [SCSI] sym53c8xx: Make interrupt handler capable of returning IRQ_NONE ... The result is that free_irq() doesn't actually take any action. This patch fixes it. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-23Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (39 commits) [SCSI] qla2xxx: Update version number to 8.02.00-k5. [SCSI] qla2xxx: Correct display of ISP serial-number. [SCSI] qla2xxx: Correct residual-count handling discrepancies during UNDERRUN handling. [SCSI] qla2xxx: Make driver (mostly) legacy I/O port free. [SCSI] qla2xxx: Fix issue where final flash-segment updates were falling into the slow-path write handler. [SCSI] qla2xxx: Handle unaligned sector writes during NVRAM/VPD updates. [SCSI] qla2xxx: Defer explicit interrupt-polling processing to init-time scenarios. [SCSI] qla2xxx: Resync with latest HBA SSID specification -- 2.2u. [SCSI] sym53c8xx: Remove sym_xpt_async_sent_bdr [SCSI] sym53c8xx: Remove pci_dev pointer from sym_shcb [SCSI] sym53c8xx: Make interrupt handler capable of returning IRQ_NONE [SCSI] sym53c8xx: Get rid of IRQ_FMT and IRQ_PRM [SCSI] sym53c8xx: Use scmd_printk where appropriate [SCSI] sym53c8xx: Simplify DAC DMA handling [SCSI] sym53c8xx: Remove tag_ctrl module parameter [SCSI] sym53c8xx: Remove io_ws, mmio_ws and ram_ws elements [SCSI] sym53c8xx: Remove ->device_id [SCSI] sym53c8xx: Use pdev->revision [SCSI] sym53c8xx: PCI Error Recovery support [SCSI] sym53c8xx: Stop overriding scsi_done ...
2007-10-23[SCSI] sym53c8xx: Remove sym_xpt_async_sent_bdrMatthew Wilcox
This function just printed a message to the user; move the print to its only caller, and turn it into an starget_printk. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Remove pci_dev pointer from sym_shcbMatthew Wilcox
This structure is accessed by the device; the fewer Linux things in it, the better. Using the pci_dev pointer from the hostdata requires a lot of changes: - Pass Scsi_Host to a lot of routines which currently take a sym_hcb. - Set the Scsi_Host as the pci drvdata (instead of the sym_hcb) Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Make interrupt handler capable of returning IRQ_NONEMatthew Wilcox
Make sym_interrupt return an irqreturn_t instead of void, and take a Scsi_Host instead of a sym_hcb. Pass the Scsi_Host to the interrupt handler instead of the sym_hcb. Rename the host_data to sym_data. Keep a pci_dev pointer in the sym_data. Rename the Scsi_Host from instance to shost. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Get rid of IRQ_FMT and IRQ_PRMMatthew Wilcox
These macros aren't needed any more. They used to be used for SPARC. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Use scmd_printk where appropriateMatthew Wilcox
If we have a scsi_cmnd, it gives the user more information than the sym_name, and maybe the target. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Simplify DAC DMA handlingMatthew Wilcox
By introducing the use_dac(), set_dac() and DMA_DAC_MASK macros, we can eliminate a lot of ifdefs from the code. We now rely on the compiler to optimise away a few things that we'd formerly relied on the preprocessor to do. This makes sym_setup_bus_dma_mask() small enough to inline into its only caller. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Remove tag_ctrl module parameterMatthew Wilcox
With sysfs making these options tunable at runtime, there's no justification for keeping this horrendously complex specification string around. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Remove io_ws, mmio_ws and ram_ws elementsMatthew Wilcox
These struct elements record info that is never needed Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Remove ->device_idMatthew Wilcox
Following the same path as ->revision_id, remove ->device_id Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Use pdev->revisionMatthew Wilcox
Auke missed the sym2 driver in his initial sweep. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: PCI Error Recovery supportLinas Vepstas
This patch adds the PCI error recovery callbacks to the Symbios SCSI device driver. It includes support for First Failure Data Capture. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Assorted changes to initial patches, including returning IRQ_NONE from the interrupt handler if the device is offline and re-using the eh_done completion in the scsi error handler. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Stop overriding scsi_doneMatthew Wilcox
Instead of telling the reset routine that the command completed from sym_eh_done, do it from sym_xpt_done. The 'to_do' element of the ucmd is redundant -- it serves only to tell whether eh_done is valid or not, and we can tell this by checking to see if it's NULL. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Don't disable interrupts in the interrupt handlerMatthew Wilcox
Interrupts can't be re-entered, so it's sufficient to call spin_lock, not spin_lock_irqsave(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Remove unnecessary check in queuecommandMatthew Wilcox
The midlayer won't scan the host ID, so we don't need to check. This is the only caller of sym_xpt_done2, so remove that too. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-23[SCSI] sym53c8xx: Remove data_mapping and data_mappedMatthew Wilcox
Before all commands used sg, data_mapping and data_mapped were used to distinguish whether the command had used map_single or map_sg. Now all commands are sg, so we can delete data_mapping, data_mapped and the wrapper functions __unmap_scsi_data, __map_scsi_sg_data, unmap_scsi_data and map_scsi_sg_data. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
