This is the 4.9.166 stable release
commit 83dc7e3dea76b77b6bcc289eb86c5b5c145e8dff upstream.
Since the command type of UTRD in UFS 2.1 specification is the same with
UFS 2.0. And it assumes the future UFS specification will follow the
same definition.
Signed-off-by: kehuanlin <kehuanlin@pinecone.net>
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
commit a83da8a4509d3ebfe03bb7fffce022e4d5d4764f upstream.
It was reported that some devices report an OPTIMAL TRANSFER LENGTH of
0xFFFF blocks. That looks bogus, especially for a device with a
4096-byte physical block size.
Ignore OPTIMAL TRANSFER LENGTH if it is not a multiple of the device's
reported physical block size.
To make the sanity checking conditionals more readable--and to
facilitate printing warnings--relocate the checking to a helper
function. No functional change aside from the printks.
Cc: <stable@vger.kernel.org>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199759
Reported-by: Christoph Anton Mitterer <calestyo@scientia.net>
commit 3722e6a52174d7c3a00e6f5efd006ca093f346c1 upstream.
The virtio scsi spec defines struct virtio_scsi_ctrl_tmf as a set of
device-readable records and a single device-writable response entry:
// Device-readable part
le32 type;
le32 subtype;
u8 lun[8];
le64 id;
// Device-writable part
u8 response;
The above should be organised as two descriptor entries (or potentially
more if using VIRTIO_F_ANY_LAYOUT), but without any extra data after "le64
id" or after "u8 response".
The Linux driver doesn't respect that, with virtscsi_abort() and
virtscsi_device_reset() setting cmd->sc before calling virtscsi_tmf(). It
results in the original scsi command payload (or writable buffers) added to
the tmf.
This fixes the problem by leaving cmd->sc zeroed out, which makes
virtscsi_kick_cmd() add the tmf to the control vq without any payload.
Cc: stable@vger.kernel.org
Signed-off-by: Felipe Franciosi <felipe@nutanix.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
[ Upstream commit 79edd00dc6a96644d76b4a1cb97d94d49e026768 ]
When a target sends Check Condition, whilst initiator is busy xmiting
re-queued data, could lead to race between iscsi_complete_task() and
iscsi_xmit_task() and eventually crashing with the following kernel
backtrace.
[3326150.987523] ALERT: BUG: unable to handle kernel NULL pointer dereference at 0000000000000078
[3326150.987549] ALERT: IP: [<ffffffffa05ce70d>] iscsi_xmit_task+0x2d/0xc0 [libiscsi]
[3326150.987571] WARN: PGD 569c8067 PUD 569c9067 PMD 0
[3326150.987582] WARN: Oops: 0002 [#1] SMP
[3326150.987593] WARN: Modules linked in: tun nfsv3 nfs fscache dm_round_robin
[3326150.987762] WARN: CPU: 2 PID: 8399 Comm: kworker/u32:1 Tainted: G O 4.4.0+2 #1
[3326150.987774] WARN: Hardware name: Dell Inc. PowerEdge R720/0W7JN5, BIOS 2.5.4 01/22/2016
[3326150.987790] WARN: Workqueue: iscsi_q_13 iscsi_xmitworker [libiscsi]
[3326150.987799] WARN: task: ffff8801d50f3800 ti: ffff8801f5458000 task.ti: ffff8801f5458000
[3326150.987810] WARN: RIP: e030:[<ffffffffa05ce70d>] [<ffffffffa05ce70d>] iscsi_xmit_task+0x2d/0xc0 [libiscsi]
[3326150.987825] WARN: RSP: e02b:ffff8801f545bdb0 EFLAGS: 00010246
[3326150.987831] WARN: RAX: 00000000ffffffc3 RBX: ffff880282d2ab20 RCX: ffff88026b6ac480
[3326150.987842] WARN: RDX: 0000000000000000 RSI: 00000000fffffe01 RDI: ffff880282d2ab20
[3326150.987852] WARN: RBP: ffff8801f545bdc8 R08: 0000000000000000 R09: 0000000000000008
[3326150.987862] WARN: R10: 0000000000000000 R11: 000000000000fe88 R12: 0000000000000000
[3326150.987872] WARN: R13: ffff880282d2abe8 R14: ffff880282d2abd8 R15: ffff880282d2ac08
[3326150.987890] WARN: FS: 00007f5a866b4840(0000) GS:ffff88028a640000(0000) knlGS:0000000000000000
[3326150.987900] WARN: CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
[3326150.987907] WARN: CR2: 0000000000000078 CR3: 0000000070244000 CR4: 0000000000042660
[3326150.987918] WARN: Stack:
[3326150.987924] WARN: ffff880282d2ad58 ffff880282d2ab20 ffff880282d2abe8 ffff8801f545be18
[3326150.987938] WARN: ffffffffa05cea90 ffff880282d2abf8 ffff88026b59cc80 ffff88026b59cc00
[3326150.987951] WARN: ffff88022acf32c0 ffff880289491800 ffff880255a80800 0000000000000400
[3326150.987964] WARN: Call Trace:
[3326150.987975] WARN: [<ffffffffa05cea90>] iscsi_xmitworker+0x2f0/0x360 [libiscsi]
[3326150.987988] WARN: [<ffffffff8108862c>] process_one_work+0x1fc/0x3b0
[3326150.987997] WARN: [<ffffffff81088f95>] worker_thread+0x2a5/0x470
[3326150.988006] WARN: [<ffffffff8159cad8>] ? __schedule+0x648/0x870
[3326150.988015] WARN: [<ffffffff81088cf0>] ? rescuer_thread+0x300/0x300
[3326150.988023] WARN: [<ffffffff8108ddf5>] kthread+0xd5/0xe0
[3326150.988031] WARN: [<ffffffff8108dd20>] ? kthread_stop+0x110/0x110
[3326150.988040] WARN: [<ffffffff815a0bcf>] ret_from_fork+0x3f/0x70
[3326150.988048] WARN: [<ffffffff8108dd20>] ? kthread_stop+0x110/0x110
[3326150.988127] ALERT: RIP [<ffffffffa05ce70d>] iscsi_xmit_task+0x2d/0xc0 [libiscsi]
[3326150.988138] WARN: RSP <ffff8801f545bdb0>
[3326150.988144] WARN: CR2: 0000000000000078
[3326151.020366] WARN: ---[ end trace 1c60974d4678d81b ]---
Commit 6f8830f5bbab ("scsi: libiscsi: add lock around task lists to fix
list corruption regression") introduced "taskqueuelock" to fix list
corruption during the race, but this wasn't enough.
Re-setting of conn->task to NULL, could race with iscsi_xmit_task().
if (conn->task == task)
conn->task = NULL;
conn->task in iscsi_xmit_task() could be NULL and so will be task.
__iscsi_get_task(task) will crash (NullPtr de-ref), trying to access
refcount.
iscsi_xmit_task()
struct iscsi_task *task = conn->task;
__iscsi_get_task(task);
This commit will take extra conn->session->back_lock in iscsi_xmit_task()
to ensure iscsi_xmit_task() waits for iscsi_complete_task(), if
iscsi_complete_task() wins the race. If iscsi_xmit_task() wins the race,
iscsi_xmit_task() increments task->refcount
(__iscsi_get_task) ensuring iscsi_complete_task() will not iscsi_free_task().
Signed-off-by: Anoob Soman <anoob.soman@citrix.com>
Signed-off-by: Bob Liu <bob.liu@oracle.com>
Acked-by: Lee Duncan <lduncan@suse.com>
commit 5e420fe635813e5746b296cfc8fff4853ae205a2 upstream.
Add missing break statement and fix identation issue.
This bug was found thanks to the ongoing efforts to enable
-Wimplicit-fallthrough.
Fixes: 9cb62fa24e0d ("aacraid: Log firmware AIF messages")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[ Upstream commit 5d8fc4a9f0eec20b6c07895022a6bea3fb6dfb38 ]
The issue to be fixed in this commit is when libfc found it received a
invalid FLOGI response from FC switch, it would return without freeing the
fc frame, which is just the skb data. This would cause memory leak if FC
switch keeps sending invalid FLOGI responses.
This fix is just to make it execute `fc_frame_free(fp)` before returning
from function `fc_lport_flogi_resp`.
Signed-off-by: Ming Lu <ming.lu@citrix.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
[ Upstream commit fe35a40e675473eb65f2f5462b82770f324b5689 ]
Assign fc_vport to ln->fc_vport before calling csio_fcoe_alloc_vnp() to
avoid a NULL pointer dereference in csio_vport_set_state().
ln->fc_vport is dereferenced in csio_vport_set_state().
Signed-off-by: Varun Prakash <varun@chelsio.com>
commit ffeafdd2bf0b280d67ec1a47ea6287910d271f3f upstream.
The sysfs phy_identifier attribute for a sas_end_device comes from the rphy
phy_identifier value.
Currently this is not being set for rphys with an end device attached, so
we see incorrect symlinks from systemd disk/by-path:
root@localhost:~# ls -l /dev/disk/by-path/
total 0
lrwxrwxrwx 1 root root 9 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 10 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0-part3 -> ../../sdc3
Indeed, each sas_end_device phy_identifier value is 0:
root@localhost:/# more sys/class/sas_device/end_device-0\:0\:2/phy_identifier
0
root@localhost:/# more sys/class/sas_device/end_device-0\:0\:10/phy_identifier
0
This patch fixes the discovery code to set the phy_identifier. With this,
we now get proper symlinks:
total 0
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy10-lun-0 -> ../../sdg
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy11-lun-0 -> ../../sdh
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy2-lun-0 -> ../../sda
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy2-lun-0-part1 -> ../../sda1
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy3-lun-0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy3-lun-0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy3-lun-0-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0 -> ../../sdc
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0-part1 -> ../../sdc1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0-part2 -> ../../sdc2
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0-part3 -> ../../sdc3
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy5-lun-0 -> ../../sdd
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0 -> ../../sde
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0-part1 -> ../../sde1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0-part2 -> ../../sde2
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0-part3 -> ../../sde3
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0 -> ../../sdf
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0-part1 -> ../../sdf1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0-part2 -> ../../sdf2
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0-part3 -> ../../sdf3
Fixes: 2908d778ab3e ("[SCSI] aic94xx: new driver")
Reported-by: dann frazier <dann.frazier@canonical.com>
Signed-off-by: John Garry <john.garry@huawei.com>
Reviewed-by: Jason Yan <yanaijie@huawei.com>
Tested-by: dann frazier <dann.frazier@canonical.com>
[ Upstream commit cc29a1b0a3f2597ce887d339222fa85b9307706d ]
scsi_mq_setup_tags(), which is called by scsi_add_host(), calculates the
command size to allocate based on the prot_capabilities. In the isci
driver, scsi_host_set_prot() is called after scsi_add_host() so the command
size gets calculated to be smaller than it needs to be. Eventually,
scsi_mq_init_request() locates the 'prot_sdb' after the command assuming it
was sized correctly and a buffer overrun may occur.
However, seeing blk_mq_alloc_rqs() rounds up to the nearest cache line
size, the mistake can go unnoticed.
The bug was noticed after the struct request size was reduced by commit
9d037ad707ed ("block: remove req->timeout_list")
Which likely reduced the allocated space for the request by an entire cache
line, enough that the overflow could be hit and it caused a panic, on boot,
at:
RIP: 0010:t10_pi_complete+0x77/0x1c0
Call Trace:
<IRQ>
sd_done+0xf5/0x340
scsi_finish_command+0xc3/0x120
blk_done_softirq+0x83/0xb0
__do_softirq+0xa1/0x2e6
irq_exit+0xbc/0xd0
call_function_single_interrupt+0xf/0x20
</IRQ>
sd_done() would call scsi_prot_sg_count() which reads the number of
entities in 'prot_sdb', but seeing 'prot_sdb' is located after the end of
the allocated space it reads a garbage number and erroneously calls
t10_pi_complete().
To prevent this, the calls to scsi_host_set_prot() are moved into
isci_host_alloc() before the call to scsi_add_host(). Out of caution, also
move the similar call to scsi_host_set_guard().
Fixes: 3d2d75254915 ("[SCSI] isci: T10 DIF support")
Link: http://lkml.kernel.org/r/da851333-eadd-163a-8c78-e1f4ec5ec857@deltatee.com
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Intel SCU Linux support <intel-linux-scu@intel.com>
Cc: Artur Paszkiewicz <artur.paszkiewicz@intel.com>
Cc: "James E.J. Bottomley" <jejb@linux.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Reviewed-by: Jens Axboe <axboe@kernel.dk>
[ Upstream commit 72b4a0465f995175a2e22cf4a636bf781f1f28a7 ]
The return code should be check while qla4xxx_copy_from_fwddb_param fails.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Acked-by: Manish Rangankar <mrangankar@marvell.com>
This reverts commit d26358590bb2be063453412cfeec5afefe55d030 which is
commit 42caa0edabd6a0a392ec36a5f0943924e4954311 upstream.
It's not needed in the 4.9.y tree, my fault for backporting it that far.
Reported-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
The aic94xx driver is currently failing to load with errors like
sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:03.0/0000:02:00.3/0000:07:02.0/revision'
Because the PCI code had recently added a file named 'revision' to every
PCI device. Fix this by renaming the aic94xx revision file to
aic_revision. This is safe to do for us because as far as I can tell,
there's nothing in userspace relying on the current aic94xx revision file
so it can be renamed without breaking anything.
Fixes: 702ed3be1b1b (PCI: Create revision file in sysfs)
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
[ Upstream commit 7ff44499bafbd376115f0bb6b578d980f56ee13b ]
- fix race condition when a unit is deleted after an RLL,
and before we have gotten the LV_STATUS page of the unit.
- In this case we will get a standard inquiry, rather than
the desired page. This will result in a unit presented
which no longer exists.
- If we ask for LV_STATUS, insure we get LV_STATUS
Reviewed-by: Murthy Bhat <murthy.bhat@microsemi.com>
Reviewed-by: Mahesh Rajashekhara <mahesh.rajashekhara@microsemi.com>
Reviewed-by: Scott Teel <scott.teel@microsemi.com>
Reviewed-by: Kevin Barnett <kevin.barnett@microsemi.com>
Signed-off-by: Dave Carroll <david.carroll@microsemi.com>
Signed-off-by: Don Brace <don.brace@microsemi.com>
[ Upstream commit b2346b5030cf9458f30a84028d9fe904b8c942a7 ]
Reviewed-by: Scott Benesh <scott.benesh@microsemi.com>
Reviewed-by: Ajish Koshy <ajish.koshy@microsemi.com>
Reviewed-by: Dave Carroll <david.carroll@microsemi.com>
Signed-off-by: Mahesh Rajashekhara <mahesh.rajashekhara@microsemi.com>
[ Upstream commit b114d9009d386276bfc3352289fc235781ae3353 ]
When LCB's are rejected, if beaconing was already in progress, the
Reason Code Explanation was not being set. Should have been set to
command in progress.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <jsmart2021@gmail.com>
[ Upstream commit c7a082e4242fd8cd21a441071e622f87c16bdacc ]
UBSAN reported those with MegaRAID SAS-3 3108,
[ 77.467308] UBSAN: Undefined behaviour in drivers/scsi/megaraid/megaraid_sas_fp.c:117:32
[ 77.475402] index 255 is out of range for type 'MR_LD_SPAN_MAP [1]'
[ 77.481677] CPU: 16 PID: 333 Comm: kworker/16:1 Not tainted 4.20.0-rc5+ #1
[ 77.488556] Hardware name: Huawei TaiShan 2280 /BC11SPCD, BIOS 1.50 06/01/2018
[ 77.495791] Workqueue: events work_for_cpu_fn
[ 77.500154] Call trace:
[ 77.502610] dump_backtrace+0x0/0x2c8
[ 77.506279] show_stack+0x24/0x30
[ 77.509604] dump_stack+0x118/0x19c
[ 77.513098] ubsan_epilogue+0x14/0x60
[ 77.516765] __ubsan_handle_out_of_bounds+0xfc/0x13c
[ 77.521767] mr_update_load_balance_params+0x150/0x158 [megaraid_sas]
[ 77.528230] MR_ValidateMapInfo+0x2cc/0x10d0 [megaraid_sas]
[ 77.533825] megasas_get_map_info+0x244/0x2f0 [megaraid_sas]
[ 77.539505] megasas_init_adapter_fusion+0x9b0/0xf48 [megaraid_sas]
[ 77.545794] megasas_init_fw+0x1ab4/0x3518 [megaraid_sas]
[ 77.551212] megasas_probe_one+0x2c4/0xbe0 [megaraid_sas]
[ 77.556614] local_pci_probe+0x7c/0xf0
[ 77.560365] work_for_cpu_fn+0x34/0x50
[ 77.564118] process_one_work+0x61c/0xf08
[ 77.568129] worker_thread+0x534/0xa70
[ 77.571882] kthread+0x1c8/0x1d0
[ 77.575114] ret_from_fork+0x10/0x1c
[ 89.240332] UBSAN: Undefined behaviour in drivers/scsi/megaraid/megaraid_sas_fp.c:117:32
[ 89.248426] index 255 is out of range for type 'MR_LD_SPAN_MAP [1]'
[ 89.254700] CPU: 16 PID: 95 Comm: kworker/u130:0 Not tainted 4.20.0-rc5+ #1
[ 89.261665] Hardware name: Huawei TaiShan 2280 /BC11SPCD, BIOS 1.50 06/01/2018
[ 89.268903] Workqueue: events_unbound async_run_entry_fn
[ 89.274222] Call trace:
[ 89.276680] dump_backtrace+0x0/0x2c8
[ 89.280348] show_stack+0x24/0x30
[ 89.283671] dump_stack+0x118/0x19c
[ 89.287167] ubsan_epilogue+0x14/0x60
[ 89.290835] __ubsan_handle_out_of_bounds+0xfc/0x13c
[ 89.295828] MR_LdRaidGet+0x50/0x58 [megaraid_sas]
[ 89.300638] megasas_build_io_fusion+0xbb8/0xd90 [megaraid_sas]
[ 89.306576] megasas_build_and_issue_cmd_fusion+0x138/0x460 [megaraid_sas]
[ 89.313468] megasas_queue_command+0x398/0x3d0 [megaraid_sas]
[ 89.319222] scsi_dispatch_cmd+0x1dc/0x8a8
[ 89.323321] scsi_request_fn+0x8e8/0xdd0
[ 89.327249] __blk_run_queue+0xc4/0x158
[ 89.331090] blk_execute_rq_nowait+0xf4/0x158
[ 89.335449] blk_execute_rq+0xdc/0x158
[ 89.339202] __scsi_execute+0x130/0x258
[ 89.343041] scsi_probe_and_add_lun+0x2fc/0x1488
[ 89.347661] __scsi_scan_target+0x1cc/0x8c8
[ 89.351848] scsi_scan_channel.part.3+0x8c/0xc0
[ 89.356382] scsi_scan_host_selected+0x130/0x1f0
[ 89.361002] do_scsi_scan_host+0xd8/0xf0
[ 89.364927] do_scan_async+0x9c/0x320
[ 89.368594] async_run_entry_fn+0x138/0x420
[ 89.372780] process_one_work+0x61c/0xf08
[ 89.376793] worker_thread+0x13c/0xa70
[ 89.380546] kthread+0x1c8/0x1d0
[ 89.383778] ret_from_fork+0x10/0x1c
This is because when populating Driver Map using firmware raid map, all
non-existing VDs set their ldTgtIdToLd to 0xff, so it can be skipped later.
From drivers/scsi/megaraid/megaraid_sas_base.c ,
memset(instance->ld_ids, 0xff, MEGASAS_MAX_LD_IDS);
From drivers/scsi/megaraid/megaraid_sas_fp.c ,
/* For non existing VDs, iterate to next VD*/
if (ld >= (MAX_LOGICAL_DRIVES_EXT - 1))
continue;
However, there are a few places that failed to skip those non-existing VDs
due to off-by-one errors. Then, those 0xff leaked into MR_LdRaidGet(0xff,
map) and triggered the out-of-bound accesses.
Fixes: 51087a8617fe ("megaraid_sas : Extended VD support")
Signed-off-by: Qian Cai <cai@lca.pw>
Acked-by: Sumit Saxena <sumit.saxena@broadcom.com>
[ Upstream commit 2ba55c9851d74eb015a554ef69ddf2ef061d5780 ]
Problem:
The Linux kernel takes a logical volume offline after a LUN reset. This is
generally accompanied by this message in the dmesg output:
Device offlined - not ready after error recovery
Root Cause:
The root cause is a "quirk" in the timeout handling in the Linux SCSI
layer. The Linux kernel places a 30-second timeout on most media access
commands (reads and writes) that it send to device drivers. When a media
access command times out, the Linux kernel goes into error recovery mode
for the LUN that was the target of the command that timed out. Every
command that timed out is kept on a list inside of the Linux kernel to be
retried later. The kernel attempts to recover the command(s) that timed out
by issuing a LUN reset followed by a TEST UNIT READY. If the LUN reset and
TEST UNIT READY commands are successful, the kernel retries the command(s)
that timed out.
Each SCSI command issued by the kernel has a result field associated with
it. This field indicates the final result of the command (success or
error). When a command times out, the kernel places a value in this result
field indicating that the command timed out.
The "quirk" is that after the LUN reset and TEST UNIT READY commands are
completed, the kernel checks each command on the timed-out command list
before retrying it. If the result field is still "timed out", the kernel
treats that command as not having been successfully recovered for a
retry. If the number of commands that are in this state are greater than
two, the kernel takes the LUN offline.
Fix:
When our RAIDStack receives a LUN reset, it simply waits until all
outstanding commands complete. Generally, all of these outstanding commands
complete successfully. Therefore, the fix in the smartpqi driver is to
always set the command result field to indicate success when a request
completes successfully. This normally isn’t necessary because the result
field is always initialized to success when the command is submitted to the
driver. So when the command completes successfully, the result field is
left untouched. But in this case, the kernel changes the result field
behind the driver’s back and then expects the field to be changed by the
driver as the commands that timed-out complete.
Signed-off-by: Kevin Barnett <kevin.barnett@microsemi.com>
commit 44759979a49bfd2d20d789add7fa81a21eb1a4ab upstream.
Changing of caching mode via /sys/devices/.../scsi_disk/.../cache_type may
fail if device responds to MODE SENSE command with DPOFUA flag set, and
then checks this flag to be not set on MODE SELECT command.
In this scenario, when trying to change cache_type, write always fails:
# echo "none" >cache_type
bash: echo: write error: Invalid argument
And following appears in dmesg:
[13007.865745] sd 1:0:1:0: [sda] Sense Key : Illegal Request [current]
[13007.865753] sd 1:0:1:0: [sda] Add. Sense: Invalid field in parameter list
From SBC-4 r15, 6.5.1 "Mode pages overview", description of DEVICE-SPECIFIC
PARAMETER field in the mode parameter header:
The write protect (WP) bit for mode data sent with a MODE SELECT
command shall be ignored by the device server.
The DPOFUA bit is reserved for mode data sent with a MODE SELECT
command.
The remaining bits in the DEVICE-SPECIFIC PARAMETER byte are also reserved
and shall be set to zero.
[mkp: shuffled commentary to commit description]
Signed-off-by: Ivan Mironov <mironov.ivan@gmail.com>
commit 3f7e62bba0003f9c68f599f5997c4647ef5b4f4e upstream.
The commit 356fd2663cff ("scsi: Set request queue runtime PM status back to
active on resume") fixed up the inconsistent RPM status between request
queue and device. However changing request queue RPM status shall be done
only on successful resume, otherwise status may be still inconsistent as
below,
Request queue: RPM_ACTIVE
Device: RPM_SUSPENDED
This ends up soft lockup because requests can be submitted to underlying
devices but those devices and their required resource are not resumed.
For example,
After above inconsistent status happens, IO request can be submitted to UFS
device driver but required resource (like clock) is not resumed yet thus
lead to warning as below call stack,
WARN_ON(hba->clk_gating.state != CLKS_ON);
ufshcd_queuecommand
scsi_dispatch_cmd
scsi_request_fn
__blk_run_queue
cfq_insert_request
__elv_add_request
blk_flush_plug_list
blk_finish_plug
jbd2_journal_commit_transaction
kjournald2
We may see all behind IO requests hang because of no response from storage
host or device and then soft lockup happens in system. In the end, system
may crash in many ways.
Fixes: 356fd2663cff (scsi: Set request queue runtime PM status back to active on resume)
Signed-off-by: Stanley Chu <stanley.chu@mediatek.com>
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit 9ae4f8420ed7be4b13c96600e3568c144d101a23 ]
If "interface" is NULL then we can't release it and trying to will only
lead to an Oops.
Fixes: aea71a024914 ("[SCSI] bnx2fc: Introduce interface structure for each vlan interface")
unload
[ Upstream commit 02f425f811cefcc4d325d7a72272651e622dc97e ]
Currently pvscsi_remove calls free_irq more than once as
pvscsi_release_resources and __pvscsi_shutdown both call
pvscsi_shutdown_intr. This results in a 'Trying to free already-free IRQ'
warning and stack trace. To solve the problem pvscsi_shutdown_intr has been
moved out of pvscsi_release_resources.
Signed-off-by: Cathy Avery <cavery@redhat.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 5db6dd14b31397e8cccaaddab2ff44ebec1acf25 ]
This commit addresses NULL pointer dereference in iscsi_eh_session_reset.
Reference should not be made to session->leadconn when session->state is
set to ISCSI_STATE_TERMINATE.
Signed-off-by: Fred Herard <fred.herard@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Lee Duncan <lduncan@suse.com>
commit f7068114d45ec55996b9040e98111afa56e010fe upstream.
We're casting the CDROM layer request_sense to the SCSI sense
buffer, but the former is 64 bytes and the latter is 96 bytes.
As we generally allocate these on the stack, we end up blowing
up the stack.
Fix this by wrapping the scsi_execute() call with a properly
sized sense buffer, and copying back the bits for the CDROM
layer.
Reported-by: Piotr Gabriel Kosinski <pg.kosinski@gmail.com>
Reported-by: Daniel Shapira <daniel@twistlock.com>
Tested-by: Kees Cook <keescook@chromium.org>
Fixes: 82ed4db499b8 ("block: split scsi_request out of struct request")
[bwh: Despite what the "Fixes" field says, a buffer overrun was already
possible if the sense data was really > 64 bytes long.
Backported to 4.9:
- We always need to allocate a sense buffer in order to call
scsi_normalize_sense()
- Remove the existing conditional heap-allocation of the sense buffer]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
This is the 4.9.144 stable release
commit 42c335f7e67029d2e01711f2f2bc6252277c8993 upstream.
When copying attributes, the len argument was padded out and the
resulting memcpy() would copy beyond the end of the source buffer.
Avoid this, and use size_t for val_len to avoid all the casts.
Similarly, avoid source buffer casts and use void *.
Additionally enforces val_len can be represented by u16 and that the DMA
buffer was not overflowed. Fixes the size of mfa, which is not
FC_FDMI_PORT_ATTR_MAXFRAMESIZE_LEN (but it will be padded up to 4). This
was noticed by the future CONFIG_FORTIFY_SOURCE checks.
Cc: Daniel Micay <danielmicay@gmail.com>
Acked-by: Varun Prakash <varun@chelsio.com>
commit 81df022b688d43d2a3667518b2f755d384397910 upstream.
Cleanly fill memory for "vendor" and "model" with 0-bytes for the
"compatible" case rather than adding only a single 0 byte. This
simplifies the devinfo code a a bit, and avoids mistakes in other places
of the code (not in current upstream, but we had one such mistake in the
SUSE kernel).
[mkp: applied by hand and added braces]
Signed-off-by: Martin Wilck <mwilck@suse.com>
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
commit 8c5a50e8e7ad812a62f7ccf28d9a5e74fddf3000 upstream.
The bfa driver has a number of real issues with string termination
that gcc-8 now points out:
drivers/scsi/bfa/bfad_bsg.c: In function 'bfad_iocmd_port_get_attr':
drivers/scsi/bfa/bfad_bsg.c:320:9: error: argument to 'sizeof' in 'strncpy' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c: In function 'bfa_fcs_fabric_psymb_init':
drivers/scsi/bfa/bfa_fcs.c:775:9: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:781:9: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:788:9: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:801:10: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:808:10: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c: In function 'bfa_fcs_fabric_nsymb_init':
drivers/scsi/bfa/bfa_fcs.c:837:10: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:844:10: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:852:10: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs.c:778:2: error: 'strncat' output may be truncated copying 10 bytes from a string of length 63 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs.c:784:2: error: 'strncat' output may be truncated copying 30 bytes from a string of length 63 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs.c:803:3: error: 'strncat' output may be truncated copying 44 bytes from a string of length 63 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs.c:811:3: error: 'strncat' output may be truncated copying 16 bytes from a string of length 63 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs.c:840:2: error: 'strncat' output may be truncated copying 10 bytes from a string of length 63 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs.c:847:2: error: 'strncat' output may be truncated copying 30 bytes from a string of length 63 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs_lport.c: In function 'bfa_fcs_fdmi_get_hbaattr':
drivers/scsi/bfa/bfa_fcs_lport.c:2657:10: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs_lport.c:2659:11: error: argument to 'sizeof' in 'strncat' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
drivers/scsi/bfa/bfa_fcs_lport.c: In function 'bfa_fcs_lport_ms_gmal_response':
drivers/scsi/bfa/bfa_fcs_lport.c:3232:5: error: 'strncpy' output may be truncated copying 16 bytes from a string of length 247 [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs_lport.c: In function 'bfa_fcs_lport_ns_send_rspn_id':
drivers/scsi/bfa/bfa_fcs_lport.c:4670:3: error: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs_lport.c:4682:3: error: 'strncat' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs_lport.c: In function 'bfa_fcs_lport_ns_util_send_rspn_id':
drivers/scsi/bfa/bfa_fcs_lport.c:5206:3: error: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs_lport.c:5215:3: error: 'strncat' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcs_lport.c: In function 'bfa_fcs_fdmi_get_portattr':
drivers/scsi/bfa/bfa_fcs_lport.c:2751:2: error: 'strncpy' specified bound 128 equals destination size [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcbuild.c: In function 'fc_rspnid_build':
drivers/scsi/bfa/bfa_fcbuild.c:1254:2: error: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
drivers/scsi/bfa/bfa_fcbuild.c:1253:25: note: length computed here
drivers/scsi/bfa/bfa_fcbuild.c: In function 'fc_rsnn_nn_build':
drivers/scsi/bfa/bfa_fcbuild.c:1275:2: error: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
In most cases, this can be addressed by correctly calling strlcpy and
strlcat instead of strncpy/strncat, with the size of the destination
buffer as the last argument.
For consistency, I'm changing the other callers of strncpy() in this
driver the same way.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Sudarsana Kalluru <Sudarsana.Kalluru@cavium.com>
commit afa3dfd42d205b106787476647735aa1de1a5d02 upstream.
If ufshcd pltfrm/pci driver's probe fails for some reason then ensure
that scsi host is released to avoid memory leak but managed memory
allocations (via devm_* calls) need not to be freed explicitly on probe
failure as memory allocated with these functions is automatically freed
on driver detach.
Reviewed-by: Sahitya Tummala <stummala@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 30fc33f1ef475480dc5bea4fe1bda84b003b992c upstream.
UFS devfreq clock scaling work may require clocks to be ON if it need to
execute some UFS commands hence it may request for clock hold before
issuing the command. But if UFS clock gating work is already running in
parallel, ungate work would end up waiting for the clock gating work to
finish and as clock gating work would also wait for the clock scaling
work to finish, we would enter in deadlock state. Here is the call trace
during this deadlock state:
Workqueue: devfreq_wq devfreq_monitor
__switch_to
__schedule
schedule
schedule_timeout
wait_for_common
wait_for_completion
flush_work
ufshcd_hold
ufshcd_send_uic_cmd
ufshcd_dme_get_attr
ufs_qcom_set_dme_vs_core_clk_ctrl_clear_div
ufs_qcom_clk_scale_notify
ufshcd_scale_clks
ufshcd_devfreq_target
update_devfreq
devfreq_monitor
process_one_work
worker_thread
kthread
ret_from_fork
Workqueue: events ufshcd_gate_work
__switch_to
__schedule
schedule
schedule_preempt_disabled
__mutex_lock_slowpath
mutex_lock
devfreq_monitor_suspend
devfreq_simple_ondemand_handler
devfreq_suspend_device
ufshcd_gate_work
process_one_work
worker_thread
kthread
ret_from_fork
Workqueue: events ufshcd_ungate_work
__switch_to
__schedule
schedule
schedule_timeout
wait_for_common
wait_for_completion
flush_work
__cancel_work_timer
cancel_delayed_work_sync
ufshcd_ungate_work
process_one_work
worker_thread
kthread
ret_from_fork
This change fixes this deadlock by doing this in devfreq work (devfreq_wq):
Try cancelling clock gating work. If we are able to cancel gating work
or it wasn't scheduled, hold the clock reference count until scaling is
in progress. If gate work is already running in parallel, let's skip
the frequecy scaling at this time and it will be retried once next scaling
window expires.
commit f2a785ac23125fa0774327d39e837e45cf28fe92 upstream.
The ungate work turns on the clock before it exits hibern8, if the link
was put in hibern8 during clock gating work. There occurs a race
condition when clock scaling work calls ufshcd_hold() to make sure low
power states cannot be entered, but that returns by checking only
whether the clocks are on. This causes the clock scaling work to issue
UIC commands when the link is in hibern8 causing failures. Make sure we
exit hibern8 state before returning from ufshcd_hold().
Callstacks for race condition:
ufshcd_scale_gear
ufshcd_devfreq_scale
update_devfreq
devfreq_monitor
process_one_work
worker_thread
kthread
ret_from_fork
ufshcd_uic_hibern8_exit
ufshcd_ungate_work
process_one_work
worker_thread
kthread
ret_from_fork
Signed-off-by: Venkat Gopalakrishnan <venkatg@codeaurora.org>
commit e3ce73d69aff44421d7899b235fec5ac2c306ff4 upstream.
In this change there are a few fixes of possible NULL pointer access and
possible access to index that exceeds array boundaries.
Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org>
commit 1e4ac5d6fe0a4af17e4b6251b884485832bf75a3 upstream.
If chip unable to fully initialize, use full shutdown sequence to clear out
any stale FW state.
Fixes: e315cd28b9ef ("[SCSI] qla2xxx: Code changes for qla data structure refactoring")
Cc: stable@vger.kernel.org #4.10
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
commit 4c1458df9635c7e3ced155f594d2e7dfd7254e21 upstream.
Fixes: 6246b8a1d26c7c ("[SCSI] qla2xxx: Enhancements to support ISP83xx.")
Fixes: 1bb395485160d2 ("qla2xxx: Correct iiDMA-update calling conventions.")
[ Upstream commit 0ef01a2d95fd62bb4f536e7ce4d5e8e74b97a244 ]
When running an mds diagnostic that passes frames with the switch, soft
lockups are detected. The driver is in a CQE processing loop and has
sufficient amount of traffic that it never exits the ring processing routine,
thus the "lockup".
Cap the number of elements in the work processing routine to 64 elements. This
ensures that the cpu will be given up and the handler reschedule to process
additional items.
Signed-off-by: James Smart <james.smart@broadcom.com>
[ Upstream commit 47db7873136a9c57c45390a53b57019cf73c8259 ]
In megasas_mgmt_compat_ioctl_fw(), to handle the structure
compat_megasas_iocpacket 'cioc', a user-space structure megasas_iocpacket
'ioc' is allocated before megasas_mgmt_ioctl_fw() is invoked to handle
the packet. Since the two data structures have different fields, the data
is copied from 'cioc' to 'ioc' field by field. In the copy process,
'sense_ptr' is prepared if the field 'sense_len' is not null, because it
will be used in megasas_mgmt_ioctl_fw(). To prepare 'sense_ptr', the
user-space data 'ioc->sense_off' and 'cioc->sense_off' are copied and
saved to kernel-space variables 'local_sense_off' and 'user_sense_off'
respectively. Given that 'ioc->sense_off' is also copied from
'cioc->sense_off', 'local_sense_off' and 'user_sense_off' should have the
same value. However, 'cioc' is in the user space and a malicious user can
race to change the value of 'cioc->sense_off' after it is copied to
'ioc->sense_off' but before it is copied to 'user_sense_off'. By doing
so, the attacker can inject different values into 'local_sense_off' and
'user_sense_off'. This can cause undefined behavior in the following
execution, because the two variables are supposed to be same.
This patch enforces a check on the two kernel variables 'local_sense_off'
and 'user_sense_off' to make sure they are the same after the copy. In
case they are not, an error code EINVAL will be returned.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
[ Upstream commit fd47d919d0c336e7c22862b51ee94927ffea227a ]
If a target disconnects during a PIO data transfer the command may fail
when the target reconnects:
scsi host1: DMA length is zero!
scsi host1: cur adr[04380000] len[00000000]
The scsi bus is then reset. This happens because the residual reached
zero before the transfer was completed.
The usual residual calculation relies on the Transfer Count registers.
That works for DMA transfers but not for PIO transfers. Fix the problem
by storing the PIO transfer residual and using that to correctly
calculate bytes_sent.
Fixes: 6fe07aaffbf0 ("[SCSI] m68k: new mac_esp scsi driver")
Tested-by: Stan Johnson <userm57@yahoo.com>
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Tested-by: Michael Schmitz <schmitzmic@gmail.com>
[ Upstream commit 3a9910d7b686546dcc9986e790af17e148f1c888 ]
qla2x00_tmf_sp_done() now deletes the timer that will run
qla2x00_tmf_iocb_timeout(), but doesn't check whether the timer already
expired. Check the return value from del_timer() to avoid calling
complete() a second time.
Fixes: 4440e46d5db7 ("[SCSI] qla2xxx: Add IOCB Abort command asynchronous ...")
Fixes: 1514839b3664 ("scsi: qla2xxx: Fix NULL pointer crash due to active ...")
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ Upstream commit 934767c56b0d9dbb95a40e9e6e4d9dcdc3a165ad ]
The return status of the adapter check on KERNEL_PANIC is supposed to be
the upper 16 bits of the OMR status register.
Fixes: c421530bf848604e (scsi: aacraid: Reorder Adpater status check)
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Raghava Aditya Renukunta <RaghavaAditya.Renukunta@microsemi.com>
[ Upstream commit f1f1fadacaf08b7cf11714c0c29f8fa4d4ef68a9 ]
When sd_init_command() get's a command with a unknown req_op() it crashes the
system via BUG().
This makes debugging the actual reason for the broken request cmd_flags pretty
hard as the system is down before it's able to write out debugging data on the
serial console or the trace buffer.
Change the BUG() to a WARN_ON() and return BLKPREP_KILL to fail gracefully and
return an I/O error to the producer of the request.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit adad633af7b970bfa5dd1b624a4afc83cac9b235 ]
While reviewing another part of the code, Kees noticed that the strncpy of the
partition name might not always be NUL terminated. Switch to using strscpy
which does this safely.
Reported-by: Kees Cook <keescook@chromium.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
[ Upstream commit d792d4c4fc866ae224b0b0ca2aabd87d23b4d6cc ]
There's currently a warning about string overflow with strncat:
drivers/scsi/ibmvscsi_tgt/ibmvscsi_tgt.c: In function 'ibmvscsis_probe':
drivers/scsi/ibmvscsi_tgt/ibmvscsi_tgt.c:3479:2: error: 'strncat' specified
bound 64 equals destination size [-Werror=stringop-overflow=]
strncat(vscsi->eye, vdev->name, MAX_EYE);
Switch to a single snprintf instead of a strcpy + strcat to handle this
cleanly.
Suggested-by: Kees Cook <keescook@chromium.org>
[ Upstream commit cbe3fd39d223f14b1c60c80fe9347a3dd08c2edb ]
We should first do the le16_to_cpu endian conversion and then apply the
FCP_CMD_LENGTH_MASK mask.
Fixes: 5f35509db179 ("qla2xxx: Terminate exchange if corrupted")
Acked-by: Quinn Tran <Quinn.Tran@cavium.com>
[ Upstream commit c3b10a55abc943a526aaecd7e860b15671beb906 ]
There is a possibility that firmware on the controller was upgraded before
system was suspended. During resume, driver needs to read updated
controller properties.
Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com>
[ Upstream commit aa154ea885eb0c2407457ce9c1538d78c95456fa ]
When ioremap_nocache fails, the lack of error-handling code may cause
unexpected results.
This patch adds error-handling code after calling ioremap_nocache.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
Acked-by: Manish Rangankar <Manish.Rangankar@cavium.com>
[ Upstream commit 1262dc09dc9ae7bf4ad00b6a2c5ed6a6936bcd10 ]
Currently an open firmware property is copied into partition_name variable
without keeping a room for \0.
Later one, this variable (partition_name), which is 97 bytes long, is
strncpyed into ibmvcsci_host_data->madapter_info->partition_name, which is
96 bytes long, possibly truncating it 'again' and removing the \0.
This patch simply decreases the partition name to 96 and just copy using
strlcpy() which guarantees that the string is \0 terminated. I think there
is no issue if this there is a truncation in this very first copy, i.e,
when the open firmware property is read and copied into the driver for the
very first time;
This issue also causes the following warning on GCC 8:
drivers/scsi/ibmvscsi/ibmvscsi.c:281:2: warning: strncpy output may be truncated copying 96 bytes from a string of length 96 [-Wstringop-truncation]
inlined from ibmvscsi_probe at drivers/scsi/ibmvscsi/ibmvscsi.c:2221:7:
drivers/scsi/ibmvscsi/ibmvscsi.c:265:3: warning: strncpy specified bound 97 equals destination size [-Wstringop-truncation]
CC: Bart Van Assche <bart.vanassche@wdc.com>
CC: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Signed-off-by: Breno Leitao <leitao@debian.org>
Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
This is the 4.9.128 stable release
[ Upstream commit 4dc98c1995482262e70e83ef029135247fafe0f2 ]
tw_probe() returns 0 in case of fail of tw_initialize_device_extension(),
pci_resource_start() or tw_reset_sequence() and releases resources.
twl_probe() returns 0 in case of fail of twl_initialize_device_extension(),
pci_iomap() and twl_reset_sequence(). twa_probe() returns 0 in case of
fail of tw_initialize_device_extension(), ioremap() and
twa_reset_sequence().
The patch adds retval initialization for these cases.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
Acked-by: Adam Radford <aradford@gmail.com>
This is the 4.9.127 stable release
drivers/gpu/drm/imx/imx-ldb.c
drivers/staging/android/ion/ion_priv.h
[ Upstream commit 0756c57bce3d26da2592d834d8910b6887021701 ]
We accidentally return success instead of -ENOMEM on this error path.
Reviewed-by: John Garry <john.garry@huawei.com>
