path: root/drivers/scsi
2011-07-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (71 commits) [SCSI] fcoe: cleanup cpu selection for incoming requests [SCSI] fcoe: add fip retry to avoid missing critical keep alive [SCSI] libfc: fix warn on in lport retry [SCSI] libfc: Remove the reference to FCP packet from scsi_cmnd in case of error [SCSI] libfc: cleanup sending SRR request [SCSI] libfc: two minor changes in comments [SCSI] libfc, fcoe: ignore rx frame with wrong xid info [SCSI] libfc: release exchg cache [SCSI] libfc: use FC_MAX_ERROR_CNT [SCSI] fcoe: remove unused ptype field in fcoe_rcv_info [SCSI] bnx2fc: Update copyright and bump version to 1.0.4 [SCSI] bnx2fc: Tx BDs cache in write tasks [SCSI] bnx2fc: Do not arm CQ when there are no CQEs [SCSI] bnx2fc: hold tgt lock when calling cmd_release [SCSI] bnx2fc: Enable support for sequence level error recovery [SCSI] bnx2fc: HSI changes for tape [SCSI] bnx2fc: Handle REC_TOV error code from firmware [SCSI] bnx2fc: REC/SRR link service request and response handling [SCSI] bnx2fc: Support 'sequence cleanup' task [SCSI] dh_rdac: Associate HBA and storage in rdac_controller to support partitions in storage ...
2011-07-28[SCSI] fcoe: cleanup cpu selection for incoming requestsVasu Dev
Cleanup to: - have selection for all types of frames, not just FCP. - remove redundant cpu_online check once fcoe_select_cpu called as this is not required since later code flow check for offlined cpu. - Simplify fcoe_select_cpu() by removing unnecessary checks to skip curr_cpu, this also fixes possibly infinite loop in case of curr_cpu is the only cpu while iterating in the loop. This cleanup mainly applies to target as incoming request are mostly for target, therefore Kiran has verified the patch with target also. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Tested-by: Kiran Patil <kiran.patil@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] fcoe: add fip retry to avoid missing critical keep aliveVasu Dev
Use pending queue to retry FIP frame in case its tx fails and use common pending queue for both fcoe and fip frames using fcoe_port_send. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc: fix warn on in lport retryVasu Dev
The lport retry timer hits warn on in case it has become ready in response from fip login from fcoe_ctlr_flogi_send(), this is possible but safe code path, therefore removing this warn on. Jun 22 03:16:30 10.0.16.6 [488198.316517] host3: Assigned Port ID 180f02 Jun 22 03:16:32 10.0.16.6 [488200.091561] ------------[ cut here ]------------ Jun 22 03:16:32 10.0.16.6 [488200.091586] WARNING: at drivers/scsi/libfc/fc_lport.c:1355 fc_lport_timeout+0xd9/0xe0 [libfc]() Signed-off-by: Vasu Dev <vasu.dev@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc: Remove the reference to FCP packet from scsi_cmnd in case of errorNeerav Parikh
fc_queuecommand() allocates an FCP packet for each SCSI command and sends it out on the wire. In the process it stores the reference to the FCP packet in the scsi_cmnd structure. Now, in case under stress testing the libfc exchange layer runs out of exchanges the fc_queuecommand() may not be able to send out commands out on the wire. In such a scenario if there is an error in sending the FCP packet out the wire; fc_queuecommand() deletes the FCP packet from internal queue, releases the FCP packet and returns a SCSI_MLQUEUE_HOST_BUSY status to the scsi-ml. But, the reference to the FCP packet set in the scsi_cmnd is not removed from the scsi_cmnd in this code path. This might lead to a crash under stress testing where the scsi_cmnd failed by fc_queuecommand() comes up to fc_eh_abort() via scsi eh thread. fc_eh_abort() will get reference to the FCP packet to be aborted from the scsi_cmnd for further FCP abort related processing and then try to release the FCP packet that has already been released. This patch removes the FCP packet reference from the scsi_cmnd before returning back from fc_queuecommand() in case of an error in sending out the FCP packet. Signed-off-by: Neerav Parikh <Neerav.Parikh@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc: cleanup sending SRR requestHillf Danton
The variable on stack, namely cdb_op, is not used but removed. [ Patch reworked by Robert Love due to invalid patch format ] Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc: two minor changes in commentsHillf Danton
One change is to cleanup typo in comment for fc_fcp_recv(), another corrects the misleading comment for fc_fcp_abts_resp(). [ Patch reworked by Robert Love due to invalid patch format ] Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc, fcoe: ignore rx frame with wrong xid infoVasu Dev
Drop the rx frame having xid with wrong cpu info or received with xid not matching to our xid. Not dropping such frame is causing panic as that causes accessing data struct beyond their bounds. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc: release exchg cacheHillf Danton
If fail to create workqueue, the newly created cache for exchg has to be released. Signed-off-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] libfc: use FC_MAX_ERROR_CNTHillf Danton
Though defined, FC_MAX_ERROR_CNT is not used. It is used now for CRC error in the path of receiving FCP frame. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] fcoe: remove unused ptype field in fcoe_rcv_infoYi Zou
There is no need to cache the ptype in fcoe_rcv_info struct as it is never used anywhere. Signed-off-by: Yi Zou <yi.zou@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] bnx2fc: Update copyright and bump version to 1.0.4Bhanu Prakash Gollapudi
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] bnx2fc: Tx BDs cache in write tasksBhanu Prakash Gollapudi
When there is a single BD for the entire data to be transmitted, use the BD inside the SGL context and set the cached SGE indication in the task context Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] bnx2fc: Do not arm CQ when there are no CQEsBhanu Prakash Gollapudi
2011-07-28[SCSI] bnx2fc: hold tgt lock when calling cmd_releaseBhanu Prakash Gollapudi
2011-07-28[SCSI] bnx2fc: Enable support for sequence level error recoveryBhanu Prakash Gollapudi
Driver advertises its support for 'retry' bit and 'conf completion' bit in PRLI params to enable support for 'sequence level error recovery' Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] bnx2fc: HSI changes for tapeBhanu Prakash Gollapudi
Program the firmware task structure with init_flags indicating the device is 'sequence level error recovery' capable. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] bnx2fc: Handle REC_TOV error code from firmwareBhanu Prakash Gollapudi
Driver decides to initiate REC on REC_TOV timer pop. The firmware maintains the REC timer and informs the driver as a firmware error message, which is an unsolicited event to the driver. Driver also issues REC on other unsolicited events from firmware that indicate data loss. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] bnx2fc: REC/SRR link service request and response handlingBhanu Prakash Gollapudi
2011-07-28[SCSI] bnx2fc: Support 'sequence cleanup' taskBhanu Prakash Gollapudi
For the devices that support sequence level error recovery, based on the REC response, the firmware has to be informed about the offset from which the retransmission should happen. Driver initiates sequence cleanup task to firmware so that the firmware can program the task. Upon the sequence cleanup completion, SRR is issued to retransmit the sequence. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-28[SCSI] dh_rdac: Associate HBA and storage in rdac_controller to support ↵Chandra Seetharaman
partitions in storage rdac hardware handler assumes that there is one-to-one relation ship between the host and the controller w.r.t lun. IOW, it does not support "multiple storage partitions" within a storage. Example: HBA1 and HBA2 see lun 0 and 1 in storage A (1) HBA3 and HBA4 see lun 0 and 1 in storage A (2) HBA5 and HBA6 see lun 0 and 1 in storage A (3) luns 0 and 1 in (1), (2) and (3) are totally different. But, rdac handler treats the lun 0s (and lun 1s) as the same when sending a mode select to the controller, which is wrong. This patch makes the rdac hardware handler associate HBA and the storage w.r.t lun (and not the host itself). Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Convert to DIV_ROUND_UP_SECTOR_T usage for sectors / dev_max_sectors kernel.h: Add DIV_ROUND_UP_ULL and DIV_ROUND_UP_SECTOR_T macro usage iscsi-target: Add iSCSI fabric support for target v4.1 iscsi: Add Serial Number Arithmetic LT and GT into iscsi_proto.h iscsi: Use struct scsi_lun in iscsi structs instead of u8[8] iscsi: Resolve iscsi_proto.h naming conflicts with drivers/target/iscsi
2011-07-27[SCSI] ipr: reorder error handling code to include iounmapJulia Lawall
The out_msi_disable label should be before cleanup_nomem to additionally benefit from the call to iounmap. Subsequent gotos are adjusted to go to out_msi_disable instead of cleanup_nomem, which now follows it. This is safe because pci_disable_msi does nothing if pci_enable_msi was not called. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ expression e1,e2; statement S; @@ e1 = pci_ioremap_bar(...); ... when != e1 = e2 when != iounmap(e1) when any ( if (<+...e1...+>) S | if(...) { ... return 0; } | if (...) { ... when != iounmap(e1) when != if (...) { ... iounmap(e1) ... } * return ...; } else S ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] pmcraid: reject negative request sizeDan Rosenberg
There's a code path in pmcraid that can be reached via device ioctl that causes all sorts of ugliness, including heap corruption or triggering the OOM killer due to consecutive allocation of large numbers of pages. First, the user can call pmcraid_chr_ioctl(), with a type PMCRAID_PASSTHROUGH_IOCTL. This calls through to pmcraid_ioctl_passthrough(). Next, a pmcraid_passthrough_ioctl_buffer is copied in, and the request_size variable is set to buffer->ioarcb.data_transfer_length, which is an arbitrary 32-bit signed value provided by the user. If a negative value is provided here, bad things can happen. For example, pmcraid_build_passthrough_ioadls() is called with this request_size, which immediately calls pmcraid_alloc_sglist() with a negative size. The resulting math on allocating a scatter list can result in an overflow in the kzalloc() call (if num_elem is 0, the sglist will be smaller than expected), or if num_elem is unexpectedly large the subsequent loop will call alloc_pages() repeatedly, a high number of pages will be allocated and the OOM killer might be invoked. It looks like preventing this value from being negative in pmcraid_ioctl_passthrough() would be sufficient. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] libsas: remove expander from dev list on errorLuben Tuikov
If expander discovery fails (sas_discover_expander()), remove the expander from the port device list (sas_ex_discover_expander()), before freeing it. Else the list is corrupted and, e.g., when we attempt to send SMP commands to other devices, the kernel oopses. Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Cc: stable@kernel.org Reviewed-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] megaraid_sas Version to 5.40-rc1 and Changelog updateadam radford
Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] megaraid_sas: Add .change_queue_depth supportadam radford
2011-07-27[SCSI] megaraid_sas: Fix FastPath I/O to work on degraded raid 1adam radford
2011-07-27[SCSI] bnx2fc: Enable REC & CONF support for the sessionBhanu Prakash Gollapudi
Based on PRLI response, identify if the target is FCP-2 (seq level error recovery) capable, and appropriately set the corresponding CONF, REC flags when offloading the session. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bnx2fc: Introduce interface structure for each vlan interfaceBhanu Prakash Gollapudi
Currently, bnx2fc has a hba structure that can work with only a single vlan interface. When there is a change in vlan id, it does not have the capability to switch to different vlan interface. To solve this problem, a new structure called 'interface' has been introduced, and each hba can now have multiple interfaces, one per vlan id. Most of the patch is a moving the interface specific fields from hba to the interface structure, and appropriately modifying the dereferences. A list of interfaces (if_list) is maintained along with adapter list. During a create call, the interface structure is allocated and added to if_list and deleted & freed on a destroy call. Link events are propagated to all interfaces belonging to the hba. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] hpsa: retry commands completing with status of UNSOLICITED_ABORTStephen M. Cameron
In a shared SAS setup, target devices may be reset by one of several hosts, and outstanding commands on that device will be completed to corresponding hosts with status of UNSOLICITED_ABORT. Such commands should be retried instead of being treated as i/o errors. Also fixed a nearby spelling error. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] hpsa: do not attempt to read from a write-only registerStephen M. Cameron
Most smartarrays tolerate it, but a few new ones don't. Without this change some newer Smart Arrays will lock up and i/o will grind to a halt. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: Change driver version to 8.3.25James Smart
Change driver version to 8.3.25 Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: Add FCF priority failover functionalityJames Smart
This patch implements a new FCF failover policy for the lpfc driver. It allows the driver to choose which FCF to failover to based on the FCF priority. This patch also introduces a new sysfs parameter (fcf_failover_policy) to allow the user to choose which FCF failover policy to use. Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: Enhancements to Debug infrastructureJames Smart
Enhancements to Debug infrastructure - debugfs additions for new hardware. - Correct stack overflow in lpfc_debugfs_dumpHBASlim_data() - Correct warning on uninitialized reg_val in lpfc_idiag_drbacc_write() - Separated the iDiag command for capturing mailbox commands for generic issue mailbox command entry point and for BSG multi-buffer handling. - Added capturing dumping capabiliy of mailbox command and external buffer for the completion of the mailbox command so that the outcome can be examined. - Changed all the iDiag command structure data array indexing introduced so far with properly defined macros. - Added SLI4 device PCI BAR memory mapped register read/browse, write-by- value, set-bit, and clear-bit methods for both interface type 0 and interface type 2. - Corrected warnings on mbxstatus being uninitialized in error paths in lpfc_bsg.c Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: PCI and SR-IOV FixesJames Smart
PCI and SR-IOV Fixes - Call pci_save_state after the pci_restore_state completes. - After calling pci_enable_pcie_error_reporting() and checking the return value for logging messages from rc, reset rc to 0 to it will not later be interpreted for error. - Read PCI config space SR-IOV capability to get the number of VFs supported. - Check for the PF's supported number of VFs before invoking PCI enable sriov API call and log error message that user requested number of VFs is beyond the PF capability if such request is passed in. - Added check for Physical function with Virtual Functions attached. If so, first disable all the VFs before proceeding to device reset. Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: Fabric and Target Discovery FixesJames Smart
Fabric and Target Discovery Fixes - Clear FC_VPORT_NEEDS_INIT_VPI flag during completion of REG_VFI mailbox command. - Prevent SLI3 Code from unregistering the physical VPI. - Add an else clause to the code that checks and sets sp->cmn.request_multiple_Nport to clear the bit. - Remove a redundant mbox free. - Modified lpfc_sli4_async_fip_evt to pass in physical VPI toi lpfc_find_vport_by_vpid function. - Modified lpfc_find_vport_by_vpid to translate physical VPI to logical VPI before comparing with vport VPI. Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: Adapter Interface fixes and changesJames Smart
Adapter Interface fixes and changes - Modify the macro field from lpfc_init_vpi_vpi to lpfc_init_vfi_vpi - Add the new CQE_CODE_RECEIVE_V1 CQE Code, add code in the driver to handle the new Code the same as the CQE_CODE_RECEIVE code except that there are two new checks for this code that will cause the driver to use the new V1 macros for rq_id and fcf_id. - Fix a bug in lpfc_prep_seq() where the size out of the first CQE was ONLY being used, even though multiple dmabufs make up the sequence, each have their own CQE with potentially different sizes. - Fix bug in lpfc_bsg_ct_unsol_event() where the ulpContext and ulpWord[3] fields of the XMIT_SEQUENCE64_CX IOCB were being calculated incorrectly. - Do physical to logical translation before indexing into the active XRI array. - Populate physical vpi in the iocb data structure. - Put the current accumulated total in each IOCB in the chain as we are walking thru then. The last IOCB in the chain should have the total length of the sequence. Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: Miscellaneous Bug fixes and code cleanupJames Smart
Miscellaneous Bug fixes and code cleanup - Fix 16G link speed reporting by adding check for 16G check. - Change the check and enforcement of MAILBOX_EXT_SIZE (2048B) to the check and enforcement of BSG_MBOX_SIZE - sizeof(MAILBOX_t) (3840B). - Instead of waiting for a fixed amount of time after performing firmware reset, the driver shall wait for the Lancer SLIPORT_STATUS register for the readiness of the firmware for bring up. - Add logging to indicate when dynamic parameters are changed. - Add revision and date to the firmware image format. - Use revision instead of rev_name to check firmware image version. - Update temporary offset after memcopy is complete for firmware update. - Consolidated the use of the macros to get rid of duplicated register offset definitions. - Removed the unused second parameter in routine lpfc_bsg_diag_mode_enter() - Enable debugfs when debugfs is enabled. - Update function comments for lpfc_sli4_alloc_xri and lpfc_sli4_init_rpi_hdrs. Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] lpfc 8.3.25: T10 DIF FixesJames Smart
T10 DIF Fixes - Fix the case where the SCSI Host supplies the CRC and driver to controller protection is on. - Only support T10 DIF type 1. LBA always goes in ref tag and app tag is not checked. - Change the format of the sense data passed up to the SCSI layer to match the Descriptor Format Sense Data found in SPC-4 sections 4.5.2.1 and 4.5.2.2. - Fix Slip PDE implementation. - Remove BUG() in else casein lpfc_sc_to_bg_opcodes. Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Update the driver version to 3.0.2.2Krishna Gudipati
Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Added support to configure lunmaskingKrishna Gudipati
- Added support to enable / disable lunmasking on Brocade adapter ports. - Added support to query / clear lunmasking configuration. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Introduced initiator based lun masking feature.Krishna Gudipati
- Added support to enable initiator based lun masking. - Initiator based Lun masking works similar to zoning where initiator port is allowed to see only those LUNs which are configured to be seen. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Add support to store driver configuration in flash.Krishna Gudipati
- Added dconf (Driver Config) BFA sub-module. - The dconf sub-module provides interfaces and manages flash writes to the flash DRV parition. - dconf sub-module also ensures that the whole 64K DRV partition is updated on a flash write. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Add support to collect / reset fabric stats.Krishna Gudipati
2011-07-27[SCSI] bfa: Added support to configure QOS and collect stats.Krishna Gudipati
- Added support to configure QOS on Brocade adapter ports. - Added support to collect / reset QOS statistics. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Add support to configure trunking on Brocade adapter ports.Krishna Gudipati
- Added logic to enable / disable trunking on Brocade adapter ports. - Added logic to query trunking info. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Add support to configure and query flash boot partitionKrishna Gudipati
2011-07-27[SCSI] bfa: Added support to collect and reset fcport statsKrishna Gudipati
- Added support to collect and reset fcport stats. - Modified design to allow multiple requests for fcport stats. - fcport will remember the stats request in its stats_pending queue and service each of the queued requests after receiving a firmware response for the prior request. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27[SCSI] bfa: Add support for IO profiling.Krishna Gudipati
- Made changes to support IO profiling. - Added support to configure and query IO profiling info. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
