path: root/drivers/serial/8250_pci.c
2008-07-24serial: add support for a no-name 4 ports multiserial cardCatalin(ux) M BOIE
It is a no-name PCI card. I found no reference to a producer so I used "UNKNOWN_0x1584" as the name. Full lspci: 01:07.0 0780: 10b5:9050 (rev 01) Subsystem: 10b5:1584 Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- \ ParErr- Stepping- SERR+ FastB2B- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- \ DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- Interrupt: pin A routed to IRQ 10 Region 1: I/O ports at ec00 [size=128] Region 2: I/O ports at e480 [size=32] Region 3: I/O ports at e400 [size=8] Capabilities: [40] Power Management version 1 Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA \ PME(D0+,D1-,D2-,D3hot+,D3cold-) Status: D0 PME-Enable- DSel=0 DScale=0 PME- Capabilities: [48] #06 [0080] Capabilities: [4c] Vital Product Data After: 0000:01:07.0: ttyS4 at I/O 0xe480 (irq = 10) is a 16550A 0000:01:07.0: ttyS5 at I/O 0xe488 (irq = 10) is a 16550A 0000:01:07.0: ttyS6 at I/O 0xe490 (irq = 10) is a 16550A 0000:01:07.0: ttyS7 at I/O 0xe498 (irq = 10) is a 16550A Signed-off-by: Catalin(ux) M BOIE <catab@embedromix.ro> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20drivers/serial/: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time in comments, printk's and MODULE_DESCRIPTION's (no printk's or MODULE_DESCRIPTION's are completely removed). While doing this I also found and fixed a missing \n in a printk in m32r_sio.c Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24serial: support for InstaShield IS-400 four port RS-232 PCI cardIgnacio García Pérez
Add support for the InstaShield IS-400 four port RS-232 PCI card. Signed-off-by: Ignacio García Pérez <iggarpe@t2i.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-018250: switch 8250 drivers to use _nocache ioremapsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28serial: silence section mismatch warnings in 8250_pciSam Ravnborg
Fix following warnings: WARNING: drivers/serial/built-in.o(.data+0x5b8): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_ite887x_exit() WARNING: drivers/serial/built-in.o(.data+0x5e0): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() WARNING: drivers/serial/built-in.o(.data+0x608): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() WARNING: drivers/serial/built-in.o(.data+0x658): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() WARNING: drivers/serial/built-in.o(.data+0x680): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() WARNING: drivers/serial/built-in.o(.data+0x6a8): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() WARNING: drivers/serial/built-in.o(.data+0x6d0): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:sbs_exit() WARNING: drivers/serial/built-in.o(.data+0x6f8): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:sbs_exit() WARNING: drivers/serial/built-in.o(.data+0x720): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:sbs_exit() WARNING: drivers/serial/built-in.o(.data+0x748): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:sbs_exit() pci_serial_quirks contains a number of function pointers where the referenced function is annotated __devexit. This is OK so we annotate pci_serial_quirks with __refdata to ignore the __devexit references Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-308250_pci: duplicate initializer in array ([pbn_b0_8_115200])Al Viro
2008-02-088250_pci: coding styleAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05serial: add ADDI-DATA GmbH Communication cardsin8250_pci.c and pci_ids.hKrauth.Julien
Add ADDI-DATA GmbH communication cards to 8250_pci driver. Supported cards are: APCI-7300, APCI-7420, APCI-7500, APCI-7800 APCI-7300-2, APCI-7420-2, APCI-7500-2 APCI-7300-3, APCI-7420-3, APCI-7500-3, APCI-7800-3 [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Krauth J. <krauth.julien@addi-data.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-05PCI: pciserial_resume_one ignored return value of pci_enable_deviceDirk Hohndel
[PATCH] pciserial_resume_one ignored return value of pci_enable_device Signed-off-by: Dirk Hohndel <hohndel@linux.intel.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-168250_pci: Autodetect mainpine cardsAlan Cox
Add support for a whole range of boards. Some are partly autodetected but not fully correctly others (PCI Express notably) not at all. Stick all the right entries in. Thanks to Mainpine for information and testing. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31Fix modpost warning in serial driverRalf Baechle
This is triggered if PCI && !HOTPLUG. MODPOST vmlinux.o WARNING: vmlinux.o(.data+0xc910): Section mismatch: reference to .init.text:pci_ite887x_init (between 'pci_serial_quirks' and 'serial_pci_tbl') Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22serial: add pci ids for PA Semi PWRficient onchip uartsOlof Johansson
Add PCI IDs for the onchip UARTs on PA Semi PWRficient. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22Add blacklisting capability to serial_pci to avoid misdetection of serial portsChristian Schmidt
The serial_pci driver tries to guess serial ports on unknown devices based on the PCI class (modem or serial). On certain softmodems (AC'97 modems) this can lead to the recognition of non-existing serial ports. This patch adds a blacklist of PCI IDs that are to be ignored by the driver. [akpm@linux-foundation.org: cleanups] Signed-off-by: Christian Schmidt <schmidt@digadd.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: Yinghai Lu <yinghai.lu@sun.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22serial: add support for ITE 887x chipsNiels de Vos
Add support for the it887x-chips (PCI) manufactured by ITE. Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31DDB5477: remove driver bits of supportYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] serial: replace kmalloc+memset with kzallocBurman Yan
2007-02-11[PATCH] serial: support for new boardMatthias Fuchs
Add support for the CPCI-ASIO4 quad port CompactPCI UART board from electronic system design gmbh. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Perle multimodem card (PCI-RAS) detectionThomas Hoehn
Get the Perle quad-modem PCI card (PCI-RAS4) detected by serial driver. It may also get the PCI-RAS8 running, but can't guarantee as I didn't had one for testing. Signed-off-by: Thomas Hoehn <thomas.hoehn@avocent.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] Add support for Korenix 16C950-based PCI cardsRussell King
This adds initial support to 8250-pci for the Korenix Jetcard PCI serial cards. The JC12xx cards are standard RS232-based serial cards utilising the Oxford 16C950 device. The JC14xx are RS422/RS485-based cards, but in order for these to be supported natively, we will need additional tweaks to the 8250 layers so we can specify some values for the 950's registers. Hence, these two entries are commented out. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[SERIAL] CONFIG_PM=n slim: drivers/serial/8250_pci.cAlexey Dobriyan
Remove some code which is unneeded if CONFIG_PM=n. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-30[SERIAL] 8250: constify some serial structsHelge Deller
- some const- ification and usage of ARRAY_SIZE() in serial drivers Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-27[SERIAL] Support for Intashield 2 port PCI serial cardPeter Horton
Here is a patch that adds support for the Instashield IS-200 2 port PCI serial card. Signed-off-by: Peter Horton <pdh@colonel-panic.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-serial: [SERIAL] Ensure 8250_pci quirks are not marked __devinit [SERIAL] Convert fifosize to an unsigned int
2006-07-03[SERIAL] Ensure 8250_pci quirks are not marked __devinitRussell King
The 8250_pci quirks must not be marked __devinit since they may be used from parport_serial. We only really need to mark those which might be used by cards recognised by parport_serial, but that wouldn't allow static checking. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-27[PATCH] 64bit Resource: convert a few remaining drivers to use ↵Greg Kroah-Hartman
resource_size_t where needed Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-08[SERIAL] 8250_pci: add new PCI serial card supportYoichi Yuasa
This patch adds new PCI serial card support. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-02[SERIAL] SIIG 8-port serial boards supportAndrey Panin
This patch adds support for SIIG 8-port boards. These boards have 4 ports in separate bars and another 4 ports in the single bar. Because of this strange port arrangement these cards need special setup function. Fortunately no other SIIG cards have more than 4 port, so this setup function could be used for them too. Signed-off-by: Andrey Panin <pazke@donpac.ru> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-18[SERIAL] Add 8250 support for Decision Computer International Co. PCCOM2Alon Bar-Lev
There is a new device which is look like: Serial controller: Decision Computer International Co. PCCOM2 (rev 02) (prog-if 02 [16550]) 0700: 6666:0004 (rev 02) (prog-if 02) Flags: medium devsel, IRQ 177 Memory at fe000000 (32-bit, non-prefetchable) [size=128] I/O ports at e880 [size=128] I/O ports at e400 [size=256] It has two 16550A, and is not listed in kernel, although the manufacturer clams that it is supported... I've created the following patch, it only add the new PCI id and the card to the repository, it seems to work. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[SERIAL] 8520_pci: build fixAndrew Morton
_INLINE_ went away. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[SERIAL] Add support for more Connect Tech PCI serial boardsGareth Howlett
I've also fixed the sort-ordering comments on this naming convention. Signed-off-by: Stuart MacDonald <stuartm@connecttech.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-07[SERIAL] 8250_pci: Remove redundant assignment, and mark fallthrough.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-28[SERIAL] mark several serial tables constArjan van de Ven
This patch marks a few serial data structures const, moving them to .rodata where they won't false-share cachelines with things that get written to. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-24[SERIAL] new hp diva console portJustin Chen
Add the new ID 0x132a and configure the new PCI Diva console port. This device supports only 1 single console UART. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-24[SERIAL] support the Exsys EX-4055 4S four-port cardBjorn Helgaas
Tested by Wolfgang Denk with this device: 00:0f.0 Network controller: PLX Technology, Inc. PCI <-> IOBus Bridge (rev 01) Subsystem: Exsys EX-4055 4S(16C550) RS-232 Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- Status: Cap- 66Mhz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- Interrupt: pin A routed to IRQ 10 Region 0: Memory at 80100000 (32-bit, non-prefetchable) [size=128] Region 1: I/O ports at 7080 [size=128] Region 2: I/O ports at 7400 [size=32] 00:0f.0 Class 0280: 10b5:9050 (rev 01) Subsystem: d84d:4055 Results with this patch: Serial: 8250/16550 driver $Revision: 1.90 $ 32 ports, IRQ sharing enabled ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A PCI: Found IRQ 10 for device 0000:00:0f.0 ttyS4 at I/O 0x7400 (irq = 10) is a 16550A ttyS5 at I/O 0x7408 (irq = 10) is a 16550A ttyS6 at I/O 0x7410 (irq = 10) is a 16550A ttyS7 at I/O 0x7418 (irq = 10) is a 16550A Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-28Merge with Linus' 2.6 treeRussell King
2005-07-27[PATCH] serial: MRi MRI-PCIDS1 dual port serial cardDavid Ranson
Add support for the MRi PCIDS1 dual port serial card. This card is a little controversial since it is the subject of a PCI vendor/device ID clash. (See http://www.ussg.iu.edu/hypermail/linux/kernel/0303.1/0516.html). I have for now just used the hex ID 0x950a. The divisor was part calculated part iterated, so may not be exactly correct (but works for me at all settings between 300 - 115300 bps). Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[SERIAL] Convert parport_serial to use new 8250_pci interfacesRussell King
Convert parport_serial to use the new 8250_pci interface, converting the table to a pciserial_board table. This also unuses the SPCI_* definitions in serialP.h, which can now be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-27[SERIAL] Expose 8250_pci setup/removal/suspend/resume functionsRussell King
Re-jig the setup/removal/suspend/resume of 8250 pci ports so that they know slightly less about how they're attached to a PCI device. Expose this as the new interface for registering PCI serial ports, as well as the pciserial_board structure and associated flag definitions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-27[SERIAL] Pass around serial_private instead of pci_devRussell King
Pass the serial_private structure via the setup method instead of the pci_dev. We don't want to assume that the pci_dev's driver data is a pointer to serial_private. Instead, put the pci_dev inside serial_private. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-27[SERIAL] Collapse the SIIG quirk entriesRussell King
Collapse all the SIIG quirk entries into one. SIIG10x cards all have PCI device IDs of 0x10xx, SIIG20x cards all have PCI device IDs of 0x20xx. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-27[SERIAL] Factor out the common setup from the per-serial port loop.Russell King
2005-07-27[SERIAL] Rename pci_board to pciserial_board.Russell King
2005-07-22[PATCH] Serial: No need to check for priv != NULL in remove_oneRussell King
2005-07-18[PATCH] Serial: Add support for SIIG Quartet serial cardAndrey Panin
Add support for SIIG Quartet Serial card. This card has Oxford Semiconducor 16954 quad UART which is clocked by 10x faster (18.432 MHz) quartz. Signed-off-by: Andrey Panin <pazke@donpac.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-06[PATCH] 8250_pci.c: add comment about enum sorting orderRussell King
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
