path: root/drivers/serial/atmel_serial.c
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10serial: general fixes in the serial_rs485 structureClaudio Scordino
Fix several issues related to the RS485 interface: - It adds the flag SER_RS485_RTS_BEFORE_SEND that was missing from the serial_rs485 structure (even if "delay_rts_before_send" was existing) - It adds a further "delay_rts_after_send" field for those drivers that can have a delay after send (e.g., atmel_serial) - It fixes the usage of the structure in the atmel_serial driver (where "delay_rts_before_send" should be used instead of "delay_rts_after_send"). Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Bernhard Roth <br@pwrnet.de> Cc: Philippe De Muyter <phdm@macqel.be> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26serial: fix rs485 for atmel_serial on avr32Peter Huewe
This patch fixes a build failure [1-4] in the atmel_serial code introduced by patch the patch ARM: 6092/1: atmel_serial: support for RS485 communications (e8faff7330a3501eafc9bfe5f4f15af444be29f5) The build failure was caused by missing struct field and missing defines for the avr32 board - the patch fixes this. [1] http://kisskb.ellerman.id.au/kisskb/buildresult/2575242/ - first failure in linux-next, may 11th [2] http://kisskb.ellerman.id.au/kisskb/buildresult/2816418/ - still exists as of today [3] http://kisskb.ellerman.id.au/kisskb/buildresult/2617511/ - first failure in Linus' tree - May 20th - did really no one notice this?! [4] http://kisskb.ellerman.id.au/kisskb/buildresult/2813956/ - still exists in Linus' tree as of today Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-04ARM: 6092/1: atmel_serial: support for RS485 communicationsClaudio Scordino
Final version of the patch that adds support for RS485 communications to the atmel_serial driver. The patch has been already sent and discussed on both linux-kernel and linux-arm-kernel mailing lists several times. Many people collaborated to improve and test the code: Tested-by: Sebastian Heutling <Sebastian.Heutling@who-ing.de> Tested-by: Bernhard Roth <br@pwrnet.de> Reviewed-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Michael Trimarchi <michael@evidence.eu.com> Signed-off-by: Rick Bronson <rick@efn.org> Signed-off-by: Sebastian Heutling <Sebastian.Heutling@who-ing.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-02serial: atmel_serial: add poll_get_char and poll_put_char uart_opsAlbin Tonnerre
Permits using KGDB over the console with the atmel_serial driver. [akpm@linux-foundation.org: s/barrier/cpu_relax/] Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Andrew Victor <linux@maxim.org.za> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-29atmel_serial: fix bad BUILD_BUG_ON() usageHaavard Skinnemoen
is_power_of_2() appears not to be constant enough for BUILD_BUG_ON() after the latest rework, so replace it with an open-coded test. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Jan Beulich <jbeulich@novell.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-19serial: move delta_msr_wait into the tty_portAlan Cox
This is used by various drivers not just serial and can be extracted as commonality Signed-off-by: Alan Cox <alan@linux.intel.com>
2009-09-19serial: kill off uart_infoAlan Cox
We moved this into uart_state, now move the fields out of the separate structure and kill it off. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-29drivers/serial/atmel_serial.c: fix compile when CONFIG_SERIAL_ATMEL=Y and ↵Albin Tonnerre
CONFIG_SERIAL_ATMEL_CONSOLE=N When SERIAL_ATMEL_CONSOLE is disabled, ATMEL_CONSOLE_DEVICE is set to NULL, and trying to access ATMEL_CONSOLE_DEVICE->flags in atmel_serial_probe makes the compile fail. This fixes the issue by only accessing it if CONFIG_SERIAL_ATMEL_CONSOLE is defined Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16atmel_serial: fix hang in set_termios when crtscts is enabledHaavard Skinnemoen
After enabling hardware flow control, any subsequent termios call may hang waiting for the transmitter to drain. This appears to be caused by a busy-loop in set_termios() waiting for the transmitter to become empty, which may take a very long time (or hang indefinitely) if the device at the other end is blocking us. A quick look through the tty and serial_core code indicates that any necessary flushing (which is optional) has already been done at this point, so there's no need for the driver to flush the transmitter on its own. Fix it by removing the busy-loop altogether. Tested-by: Eirik Aanonsen <eaa@wprmedical.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01avr32: add hardware handshake support to atmel_serialPeter Ma
Adds Hardware Handshake (aka RTS/CTS flow-control) support to atmel_serial driver, as a termios flag. For this to actually work, the platform code needs to configure the RTS and CTS pins for use by the USART. This has been done for AVR32 as a separate patch. Signed-off-by: Peter Ma <pma@mediamatech.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
2009-02-18atmel_serial might lose modem status changeAtsushi Nemoto
I found a problem of handling of modem status of atmel_serial driver. With the commit 1ecc26 ("atmel_serial: split the interrupt handler"), handling of modem status signal was splitted into two parts. The atmel_tasklet_func() compares new status with irq_status_prev, but irq_status_prev is not correct if signal status was changed while the port is closed. Here is a sequence to cause problem: 1. Remote side sets CTS (and DSR). 2. Local side close the port. 3. Local side clears RTS and DTR. 4. Remote side clears CTS and DSR. 5. Local side reopen the port. hw_stopped becomes 1. 6. Local side sets RTS and DTR. 7. Remote side sets CTS and DSR. Then CTS change interrupt can be received, but since CTS bit in irq_status_prev and new status is same, uart_handle_cts_change() will not be called (so hw_stopped will not be cleared, i.e. cannot send any data). I suppose irq_status_prev should be initialized at somewhere in open sequence. Itai Levi pointed out that we need to initialize atmel_port->irq_status as well here. His analysis is as follows: > Regarding the second part of the patch (which resets irq_status_prev), > it turns out that both versions of the patch (mine and Atsushi's) > still leave enough room for faulty behavior when opening the port. > > This is because we are not resetting both irq_status_prev and > irq_status in atmel_startup() to CSR, which leads faulty behavior in > the following sequences: > > First case: > 1. closing the port while CTS line = 1 (TX not allowed) > 2. setting CTS line = 0 (TX allowed) > 3. opening the port > 4. transmitting one char > 5. Cannot transmit more chars, although CTS line is 0 > > Second case: > 1. closing the port while CTS line = 0 (TX allowed) > 2. setting CTS line = 1 (TX not allowed) > 3. opening the port > 4. receiving some chars > 5. Now we can transmit, although CTS line is 1 > > This reason for this is that the tasklet is scheduled as a result of > TX or RX interrupts (not a status change!), in steps 4 above. Inside > the tasklet, the atmel_port->irq_status (which holds the value from > the previous session) is compared to atmel_port->irq_status_prev. > Hence, a status-change of the CTS line is faultily detected. > > Both cases were verified on 9260 hardware. [haavard.skinnemoen@atmel.com: folded with patch from Itai Levi] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Remy Bohmer <linux@bohmer.net> Cc: Marc Pignat <marc.pignat@hevs.ch> Cc: Itai Levi <itai.levi.devel@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15atmel_serial: fix flow control bugItai Levi
Fix the following problem, related to hardware flow control (CTS/RTS): Transmitting while CTS line is asserted in DMA mode, due to not checking for tx-stopped condition. We found these problems while testing the UARTs with hardware flow-control. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: "Andrew Victor" <avictor.za@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06atmel_serial: keep clock off when it's not neededDavid Brownell
The atmel_serial driver is mismanaging its clock by leaving it on at all times ... the whole point of clock management is to leave it off unless it's actively needed, which conserves power!! Although the kernel doesn't actually hang without my fix, it does discard quite a lot of early console output. The result still looks correct: usart users= 1 on 35000000 Hz, for atmel_usart.0 usart users= 0 off 35000000 Hz, for atmel_usart.2 when using ttyS0 as serial console. [haavard.skinnemoen@atmel.com: Make sure clock is enabled early for console] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23atmel_serial: update the powersave handler to match serial coreAnti Sullin
This problem seems to be unnoticed so far: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=b3b708fa2780cd2b5d8266a8f0c3a1cab364d4d2 has changed the serial core behavior to not to suspend the port if the device is enabled as a wakeup source. If the AT91 system goes to slow clock mode, the port should be suspended always and the clocks should be switched off. The patch attached updates the atmel_serial driver to match the changes in serial core. Also, the interrupts are disabled when the clock is disabled. If we disable the clock with interrupts enabled, an interrupt may get stuck. If this is the DBGU interrupt, this blocks the OR logic at system controller and thus all other sysc interrupts. Signed-off-by: Anti Sullin <anti.sullin@artecdesign.ee> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Michael Trimarchi <trimarchimichael@yahoo.it> Cc: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-20atmel_serial: Fix tty_port breakageHaavard Skinnemoen
The tty pointer has been moved into a tty_port field, so we need to use ->info->port.tty instead of just ->info->tty. Fixes these build errors: David Brownell <david-b@pacbell.net> wrote: > drivers/serial/atmel_serial.c: In function 'atmel_rx_from_ring': > drivers/serial/atmel_serial.c:665: error: 'struct uart_info' has no member named 'tty' > drivers/serial/atmel_serial.c: In function 'atmel_rx_from_dma': > drivers/serial/atmel_serial.c:672: error: 'struct uart_info' has no member named 'tty' > drivers/serial/atmel_serial.c: In function 'atmel_startup': > drivers/serial/atmel_serial.c:797: error: 'struct uart_info' has no member named 'tty' > make[2]: *** [drivers/serial/atmel_serial.o] Error 1 Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20Subject: [PATCH 2/2] atmel_serial: Implement flush_buffer() hookHaavard Skinnemoen
Avoid dumping garbage to the serial port when the tty is flushed. This tends to happen when rebooting from a serial console. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02atmel_serial: Drain console TX shifter before suspendingHaavard Skinnemoen
Funny things may happen if we stop the USART clock before the shifter is empty. Prevent this from happening by waiting until the shifter is completely drained before allowing suspend to continue. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za>
2008-07-02atmel_serial: Fix build on avr32 with CONFIG_PM enabledHaavard Skinnemoen
AVR32 doesn't have at91_suspend_entering_slow_clock(). Just assume the clock will keep running for now. David has a better solution for this, but this works for now. Leaving the USART clock running won't prevent the PM code from entering deep power-down modes anyway. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Cc: Andrew Victor <linux@maxim.org.za>
2008-06-06atmel_serial: filter out FP during baud rate detectionHaavard Skinnemoen
I made a change to u-boot that used the FP (Fractional Part) field of BRGR to achieve more accurate baud rate generation. Unfortunately, the atmel_serial driver looks at the whole BRGR register when trying to detect the baud rate that the port is currently running at, so setting FP to a nonzero value breaks the baud rate detection. I'll sit on the u-boot patch for a while longer, but this is clearly a bug in the atmel_serial driver which should be fixed. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_serial: remove duplicated macro definitionMichael Trimarchi
After commit 39d4c922b596633da86878b1a5cc881785b8e5fa (atmel_serial: fix uart/console concurrent access) the UART_GET_TCR macro got redefined. This patch removes the duplicated definition. Signed-off-by: michael trimarchi <trimarchimichael@evidence.eu.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15serial: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable serial platform drivers, to re-enable auto loading. NOTE that Kconfig for some of these drivers doesn't allow modular builds, and thus doesn't match the driver source's unload support. Presumably their unload code is buggy and/or weakly tested... [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-02atmel_serial: fix uart/console concurrent accessMarc Pignat
Strange chars appear on the serial port when a printk and a printf happens at the same time. This is caused by the pdc sending chars while atmel_console_write (called from printk) is executing Concurent access of uart and console to the same port leads to corrupted data to be transmitted, so disable tx dma (PDC) while writing to the console. Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-02atmel_serial: avoid stopping pdc during transmissionMichael Trimarchi
I found a problem related to losing data during pdc transmission in atmel_serial: connect ttyS1 with ttyS2 using a loopback cable, send 30 byte of packet from one to the other and waiting for 30 byte. On the other side just read and echo the data received. We always call atmel_tx_dma() from the tasklet regardless of what interrupt triggered it. Signed-off-by: michael <trimarchi@gandalf.sssup.it> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23atmel_serial: fix interrupt handler return valueHaavard Skinnemoen
We should only return IRQ_HANDLED when we actually found something to handle. This is important since the USART interrupt handler may be shared with the timer interrupt on some chips. Pointed-out-by: michael <trimarchi@gandalf.sssup.it> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: show tty name in /proc/interruptsHaavard Skinnemoen
When possible, pass the tty name to request_irq() so that the user can easily distinguish the different serial ports in /proc/interrupts. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: use container_of instead of direct castHaavard Skinnemoen
As pointed out by David Brownell, we really ought to be using container_of when converting from "struct uart_port *" to "struct atmel_uart_port *". Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: fix broken RX buffer allocationHaavard Skinnemoen
Introduced by atmel_serial-split-the-interrupt-handler.patch. Thanks to michael <trimarchi@gandalf.sssup.it> for spotting it. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: add DMA supportChip Coldwell
This patch is based on the DMA-patch by Chip Coldwell for the AT91/AT32 serial USARTS, with some tweaks to make it apply neatly on top of the other patches in this series. The RX and TX code has been moved to a tasklet and reworked a bit. Instead of depending on the ENDRX and TIMEOUT bits in CSR, we simply grab as much data as we can from the DMA buffers. I think this closes a race where the ENDRX bit is set after we read CSR but before we read RPR, although I haven't confirmed this. Similarly, the two TX handlers (ENDTX and TXBUFE) have been combined into one. Since the current code only uses a single TX buffer, there's no point in handling those interrupts separately. This also fixes a DMA sync bug in the original patch. [linux@bohmer.net: rebased onto irq-splitup patch] [hskinnemoen@atmel.com: moved to tasklet, fixed dma bug, misc cleanups] [hskinnemoen@atmel.com: atmel_serial dma: Misc fixes and cleanups] Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: split the interrupt handlerRemy Bohmer
Split up the interrupt handler of the serial port into a interrupt top-half and a tasklet. The goal is to get the interrupt top-half as short as possible to minimize latencies on interrupts. But the old code also does some calls in the interrupt handler that are not allowed on preempt-RT in IRQF_NODELAY context. This handler is executed in this context because of the interrupt sharing with the timer interrupt. The timer interrupt on Preempt-RT runs in IRQF_NODELAY context. The tasklet takes care of handling control status changes, pushing incoming characters to the tty layer, handling break and other errors. It also handles pushing TX data into the data register. Reading the complete receive queue is still done in the top-half because we never want to miss any incoming character. [hskinnemoen@atmel.com: misc cleanups and simplifications] Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: fix bugs in probe() error path and remove()Haavard Skinnemoen
When an error happens in probe(), the clocks should be disabled, but only if the port isn't already used as a console. In remove(), the port struct shouldn't be freed because it's defined statically. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: use existing console options only if BRG is runningHaavard Skinnemoen
If BRGR is zero, the baud rate generator isn't running, so the boot loader can't have initialized the port. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: use cpu_relax() when busy-waitingHaavard Skinnemoen
Replace two instances of barrier() with cpu_relax() since that's the right thing to do when busy-waiting. This does not actually change anything since cpu_relax() is defined as barrier() on both ARM and AVR32. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08atmel_serial: clean up the codeRemy Bohmer
Clean up the atmel_serial driver to conform the coding rules. It contains no functional change. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Tested-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04[ARM] 4660/3: at91: allow selecting UART for early kernel messagesGuennadi Liakhovetski
Currently early kernel messages, i.e., those from uncompression, go to the debugging UART. And if it is enabled in the platform configuration, but not initialized by the bootloader, the machine hangs, waiting for UART status change. Besides, having those messages on another UART - typically the console UART - may be preferrable. This patch allows selecting the UART in kernel configuration. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-14atmel_serial build warnings begoneDavid Brownell
Remove annoying build warnings about unused variables in atmel_serial, which afflict both AT91 and AVR32 builds. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16atmel_serial: fix break handlingHaavard Skinnemoen
The RXBRK field in the AT91/AT32 USART status register has the following definition according to e.g. the AT32AP7000 data sheet: RXBRK: Break Received/End of Break 0: No Break received or End of Break detected since the last RSTSTA. 1: Break Received or End of Break detected since the last RSTSTA. Thus, for each break, the USART sets the RXBRK bit twice. This patch modifies the driver to report the break event to the serial core only once by keeping track of whether a break condition is currently active. The break_active flag is reset as soon as a character is received, so even if we miss the start-of-break interrupt this should do the right thing. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ivan Kuten <ivan.kuten@promwad.com> Cc: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Cc: Patrice Vilchez <patrice.vilchez@rfo.atmel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03[ARM] 4357/1: AT91: Support slower serial baud-ratesAndrew Victor
Allow slower serial baud-rates by switching the UART clock from MCK to MCK/8. Based on patches by Mike Wolfram and Russell King. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-19Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (117 commits) [ARM] 4058/2: iop32x: set ->broken_parity_status on n2100 onboard r8169 ports [ARM] 4140/1: AACI stability add ac97 timeout and retries [ARM] 4139/1: AACI record support [ARM] 4138/1: AACI: multiple channel support for IRQ handling [ARM] 4211/1: Provide a defconfig for ns9xxx [ARM] 4210/1: base for new machine type "NetSilicon NS9360" [ARM] 4222/1: S3C2443: Remove reference to missing S3C2443_PM [ARM] 4221/1: S3C2443: DMA support [ARM] 4220/1: S3C24XX: DMA system initialised from sysdev [ARM] 4219/1: S3C2443: DMA source definitions [ARM] 4218/1: S3C2412: fix CONFIG_CPU_S3C2412_ONLY wrt to S3C2443 [ARM] 4217/1: S3C24XX: remove the dma channel show at startup [ARM] 4090/2: avoid clash between PXA and SA1111 defines [ARM] 4216/1: add .gitignore entries for ARM specific files [ARM] 4214/2: S3C2410: Add Armzone QT2410 [ARM] 4215/1: s3c2410 usb device: per-platform vbus_draw [ARM] 4213/1: S3C2410 - Update definition of ADCTSC_XY_PST [ARM] 4098/1: ARM: rtc_lock only used with rtc_cmos [ARM] 4137/1: Add kexec support [ARM] 4201/1: SMP barriers pair needed for the secondary boot process ... Fix up conflict due to typedef removal in sound/arm/aaci.h
2007-02-12[PATCH] atmel_serial: Use __raw I/O register accessHaavard Skinnemoen
Access to chip-internal registers should always be native-endian. This is especially important for AVR32 since it's a big-endian architecture and the non-raw readl() and writel() macros are defined to do little-endian accesses. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[ARM] 4151/1: AT91 / AVR32: Move at91_pdc.h to linux/atmel_pdc.hAndrew Victor
The Atmel AT91 and AVR32 processor architectures share many of the same peripherals. The PDC (Peripheral Data Controller) registers are also implemented within in a number of the on-chip peripherals (eg, USART, MMC, SPI, SSC, etc). In a attempt not to duplicate the register definitions in each peripheral, or in each architecture, the at91_pdc.h header in asm-arm/arch-at91 and asm-avr32/arch-at32ap has been replaced with linux/atmel_pdc.h. The definitions have also been renamed from AT91_PDC_* to ATMEL_PDC_*, and the drivers updated accordingly. Original patch from Nicolas Ferre. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4088/1: AT91: Unbalanced IRQ in serial driver suspend/resumeAndrew Victor
This patch fixes the unbalanced calls to enable_irq_wake() and disable_irq_wake() in the AT91 (and AVR32) serial driver. It should resolve these kernel messages: Unbalanced IRQ x wake disable BUG: warning at kernel/irq/manage.c:167/set_irq_wake() Original patch from Marc Pignat. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4086/1: AT91: Whitespace cleanupAndrew Victor
A couple of whitespace cleanups, mainly in the AT91 header files. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[ARM] 3973/1: AT91: Serial driver compile fixAndrew Victor
1. The CPU identification has moved from <system.h> to <cpu.h>. 2. AT91RM9200_BASE_US0 is only defined if we are compiling in support for the AT91RM9200. Therefore we need to replace the CONFIG_ARM ifdef with CONFIG_ARCH_AT91RM9200 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] 3954/1: AT91: Update drivers for new headersAndrew Victor
This patch updates the drivers (and other files) which include the hardware headers. This fixes the breakage introduced in patches 3950/1 and 3951/1 (those patches were getting big). The AVR32 architecture uses the same serial driver and had its own copy of at91rm9200_pdc.h. Renamed it to at91_pdc.h Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] 3947/1: AT91: cpu_is_XXX macro'sAndrew Victor
This patch replaces the arch_identify() in system.h with a set of cpu_is_XXX() macro's. This allows for compile-time checking of the target AT91 processor. Original patch from David Brownell. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04[PATCH] atmel_serial: Fix roundoff error in atmel_console_get_optionsHaavard Skinnemoen
The atmel_console_get_options() function initializes the baud, parity and bits settings from the actual hardware setup, in case it has been initialized by a e.g. boot loader. The baud rate, however, is not necessarily exactly equal to one of the standard baud rates (115200, etc.) This means that the baud rate calculated by this function may be slightly higher or slightly lower than one of the standard baud rates. If the baud rate is slightly lower than the target, this causes problems when uart_set_option() tries to match the detected baud rate against the standard baud rate, as it will always select a baud rate that is lower or equal to the target rate. For example if the detected baud rate is slightly lower than 115200, usart_set_options() will select 57600. This patch fixes the problem by subtracting 1 from the value in BRGR when calculating the baud rate. The detected baud rate will thus always be higher than the nearest standard baud rate, and uart_set_options() will end up doing the right thing. Tested on ATSTK1000 and AT91RM9200-EK boards. Both are broken without this patch. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
