path: root/drivers/sfi
2009-10-03SFI: remove __init from sfi_verify_tableArjan van de Ven
sfi_verify_table() is called at runtime, and thus cannot be __init Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03SFI: fix section mismatch warnings in sfi_core.cRakib Mullick
The function sfi_map_memory/sfi_unmap_memory uses early_ioremap/early_iounmap respectively, which refers to a __init function. And function sfi_check_table also refers to a __init function sfi_verify_table. Since the references are valid, so use __ref to get rid of the warnings. We were warned by the following warnings: LD vmlinux.o MODPOST vmlinux.o WARNING: vmlinux.o(.text+0xb6ba3a): Section mismatch in reference from the function sfi_map_memory() to the function .init.text:early_ioremap() The function sfi_map_memory() references the function __init early_ioremap(). This is often because sfi_map_memory lacks a __init annotation or the annotation of early_ioremap is wrong. WARNING: vmlinux.o(.text+0xb6bab6): Section mismatch in reference from the function sfi_unmap_memory() to the function .init.text:early_iounmap() The function sfi_unmap_memory() references the function __init early_iounmap(). This is often because sfi_unmap_memory lacks a __init annotation or the annotation of early_iounmap is wrong. WARNING: vmlinux.o(.text+0xb6be30): Section mismatch in reference from the function sfi_check_table() to the function .init.text:sfi_verify_table() The function sfi_check_table() references the function __init sfi_verify_table(). This is often because sfi_check_table lacks a __init annotation or the annotation of sfi_verify_table is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-15SFI: remove unneeded includesFeng Tang
Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28SFI: add capability to parse ACPI tablesFeng Tang
Extend SFI to access standard ACPI tables. (eg. the PCI MCFG) using sfi_acpi_table_parse(). Note that this is _not_ a hybrid ACPI + SFI mode. The platform boots in either ACPI mode or SFI mode. SFI runs only with acpi_disabled=1, which can be set at build-time via CONFIG_ACPI=n, or at boot time by the failure to find ACPI platform support. So this extension simply allows SFI-platforms to re-use existing standard table formats that happen to be defined to live in ACPI envelopes. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28SFI: add platform-independent core supportFeng Tang
drivers/sfi/sfi_core.c contains the generic SFI implementation. It has a private header, sfi_core.h, for its own use and the private use of future files in drivers/sfi/ Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28SFI: Simple Firmware Interface - MAINTAINERS, KconfigLen Brown
CONFIG_SFI=y enables the kernel to boot and run optimally on platforms that support the Simple Firmware Interface. Thanks to Jacob Pan for prototyping the initial Linux SFI support, and to Feng Tang for Linux bring-up and debug both in emulation and on Moorestown hardware. See http://simplefirmware.org for more information on SFI. Signed-off-by: Len Brown <len.brown@intel.com>
