path: root/drivers/sn/Makefile
2006-10-17[PATCH] ioc4: Enable build on non-SN2Brent Casavant
The SGI PCI-RT card, based on the SGI IOC4 chip, will be made available on Altix XE (x86_64) platforms in the near future. As such it is now a misnomer for the IOC4 base device driver to live under drivers/sn, and would complicate builds for non-SN2. This patch moves the IOC4 base driver code from drivers/sn to drivers/misc, and updates the associated Makefiles and Kconfig files to allow building on non-SN2 configs. Due to the resulting change in link order, it is now necessary to use late_initcall() for IOC4 subdriver initialization. [akpm@osdl.org: __udivdi3 fix] [akpm@osdl.org: fix default in Kconfig] Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Altix: ioc3 serial supportPatrick Gefre
Add driver support for a 2 port PCI IOC3-based serial card on Altix boxes: This is a re-submission. On the original submission I was asked to organize the code so that the MIPS ioc3 ethernet and serial parts could be used with this driver. Stanislaw Skowronek was kind enough to provide the shim layer for this - thanks Stanislaw. This patch includes the shim layer and the Altix PCI ioc3 serial driver. The MIPS merged ioc3 ethernet and serial support is forthcoming. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ioc4: CONFIG splitBrent Casavant
The SGI IOC4 I/O controller chip drivers are currently all configured by CONFIG_BLK_DEV_SGIIOC4. This is undesirable as not all IOC4 hardware features are needed by all systems. This patch adds two configuration variables, CONFIG_SGI_IOC4 for core IOC4 driver support (see patch 1/3 in this series for further explanation) and CONFIG_SERIAL_SGI_IOC4 to independently enable serial port support. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
