path: root/drivers/sn
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] IOC3/IOC4: PCI mem space resourcesBrent Casavant
The SGI IOC3 and IOC4 PCI devices implement memory space apertures, not I/O space apertures. Use the appropriate region management functions. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Cc: Stanislaw Skowronek <skylark@linux-mips.org> Cc: Brent Casavant <bcasavan@sgi.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-17[PATCH] ioc4: Enable build on non-SN2Brent Casavant
The SGI PCI-RT card, based on the SGI IOC4 chip, will be made available on Altix XE (x86_64) platforms in the near future. As such it is now a misnomer for the IOC4 base device driver to live under drivers/sn, and would complicate builds for non-SN2. This patch moves the IOC4 base driver code from drivers/sn to drivers/misc, and updates the associated Makefiles and Kconfig files to allow building on non-SN2 configs. Due to the resulting change in link order, it is now necessary to use late_initcall() for IOC4 subdriver initialization. [akpm@osdl.org: __udivdi3 fix] [akpm@osdl.org: fix default in Kconfig] Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] ioc4: Remove SN2 feature and config dependenciesBrent Casavant
The SGI PCI-RT card, based on the SGI IOC4 chip, will be made available on Altix XE (x86_64) platforms in the near future. As such dependencies on SN2-specific features and config dependencies need to be removed. This patch updates the Kconfig files to remove the config dependency, and updates the IOC4 bus speed detection routine to use universally available time interfaces instead of mmtimer. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06Various drivers' irq handlers: kill dead code, needless castsJeff Garzik
- Eliminate casts to/from void* - Eliminate checks for conditions that never occur. These typically fall into two classes: 1) Checking for 'dev_id == NULL', then it is never called with NULL as an argument. 2) Checking for invalid irq number, when the only caller (the system) guarantees the irq handler is called with the proper 'irq' number argument. Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] remove devinit from ioc4 pci_driverDave Jones
Documention/pci.txt states.. "The struct pci_driver shouldn't be marked with any of these tags." (Referring to __devinit and friends). (akpm: good documentation, that. Link this driver into vmlinux with hotplug CPU disabled and it'll crash). Signed-off-by: Dave Jones <davej@redhat.com> Cc: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] SGI IOC4: Detect IO card variantBrent Casavant
There are three different IO cards which an SGI IOC4 controller may find itself on. One of these variants does not bring out the IDE and serial signals, so we need to disable attaching the corresponding IOC4 subdrivers to such cards. Cleans up message clutter emitted during device probing. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-03[PATCH] Altix: correct ioc4 port orderBrent Casavant
Currently loading the ioc3 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] Altix: correct ioc3 port orderPat Gefre
Currently loading the ioc3 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Last DMA_xBIT_MASK cleanupsTobias Klauser
These are the last conversions of pci_set_dma_mask(), pci_set_consistent_dma_mask() and pci_dma_supported() to use DMA_xBIT_MASK constants from linux/dma-mapping.h Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21Pull sem2mutex-ioc4 into release branchTony Luck
2006-02-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
2006-02-28[PATCH] Altix: more ioc3 cleanups and locking fixesPat Gefre
Some "inline" removing that Andrew suggested, removed some locking on add/remove at this level - we'll let the callees decide. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-27[IA64] show "SN Devices" menu only if CONFIG_SGI_SNJes Sorensen
Adrian> On architectures like i386, the "Multimedia Capabilities Port Adrian> drivers" menu is visible, but it can't be visited since it Adrian> contains nothing usable for CONFIG_SGI_SN=n. Jes> Thats only a third of the patch, if you want to do that, you should Jes> remove the redundant SGI_SN checks below. Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-08[PATCH] sn3 iomem annotations and fixesAl Viro
2006-02-01[PATCH] Altix ioc3: correct export callPat Gefre
Use EXPORT_SYMBOL_GPL in ioc3 shim layer. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-26[IA64-SGI] sem2mutex ioc4.cJes Sorensen
Convert to use a single mutex instead of two rwsems as this isn't performance critical. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-14[PATCH] Altix: ioc3 serial supportPatrick Gefre
Add driver support for a 2 port PCI IOC3-based serial card on Altix boxes: This is a re-submission. On the original submission I was asked to organize the code so that the MIPS ioc3 ethernet and serial parts could be used with this driver. Stanislaw Skowronek was kind enough to provide the shim layer for this - thanks Stanislaw. This patch includes the shim layer and the Altix PCI ioc3 serial driver. The MIPS merged ioc3 ethernet and serial support is forthcoming. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ioc4: PCI bus speed detectionBrent Casavant
Several hardware features of SGI's IOC4 I/O controller chip require timing-related driver calculations dependent upon the PCI bus speed. This patch enables the core IOC4 driver code to detect the actual bus speed and store a value that can later be used by the IOC4 subdrivers as needed. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Pat Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ioc4: CONFIG splitBrent Casavant
The SGI IOC4 I/O controller chip drivers are currently all configured by CONFIG_BLK_DEV_SGIIOC4. This is undesirable as not all IOC4 hardware features are needed by all systems. This patch adds two configuration variables, CONFIG_SGI_IOC4 for core IOC4 driver support (see patch 1/3 in this series for further explanation) and CONFIG_SERIAL_SGI_IOC4 to independently enable serial port support. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ioc4: Core driver rewriteBrent Casavant
This series of patches reworks the configuration and internal structure of the SGI IOC4 I/O controller device drivers. These changes are motivated by several factors: - The IOC4 chip PCI resources are of mixed use between functions (i.e. multiple functions are handled in the same address range, sometimes within the same register), muddling resource ownership and initialization issues. Centralizing this ownership in a core driver is desirable. - The IOC4 chip implements multiple functions (serial, IDE, others not yet implemented in the mainline kernel) but is not a multifunction PCI device. In order to properly handle device addition and removal as well as module insertion and deletion, an intermediary IOC4-specific driver layer is needed to handle these operations cleanly. - All IOC4 drivers are currently enabled by a single CONFIG value. As not all systems need all IOC4 functions, it is desireable to enable these drivers independently. - The current IOC4 core driver will trigger loading of all function-level drivers, as it makes direct calls to them. This situation should be reversed (i.e. function-level drivers cause loading of core driver) in order to maintain a clear and least-surprise driver loading model. - IOC4 hardware design necessitates some driver-level dependency on the PCI bus clock speed. Current code assumes a 66MHz bus, but the speed should be autodetected and appropriate compensation taken. This patch series effects the above changes by a newly and better designed IOC4 core driver with which the function-level drivers can register and deregister themselves upon module insertion/removal. By tracking these modules, device addition/removal is also handled properly. PCI resource management and ownership issues are centralized in this core driver, and IOC4-wide configuration actions such as bus speed detection are also handled in this core driver. This patch: The SGI IOC4 I/O controller chip implements multiple functions, though it is not a multi-function PCI device. Additionally, various PCI resources of the IOC4 are shared by multiple hardware functions, and thus resource ownership by driver is not clearly delineated. Due to the current driver design, all core and subordinate drivers must be loaded, or none, which is undesirable if not all IOC4 hardware features are being used. This patch reorganizes the IOC4 drivers so that the core driver provides a subdriver registration service. Through appropriate callbacks the subdrivers can now handle device addition and removal, as well as module insertion and deletion (though the IOC4 IDE driver requires further work before module deletion will work). The core driver now takes care of allocating PCI resources and data which must be shared between subdrivers, to clearly delineate module ownership of these items. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Pat Gefre <pfg@sgi.com Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
