'spi/topic/mpc512x-psc', 'spi/topic/mpc52xx', 'spi/topic/mxs', 'spi/topic/nuc900', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/completion' and 'spi/topic/davinci' into spi-next
'spi/topic/au1550', 'spi/topic/bcm63xx', 'spi/topic/bcm63xx-hsspi', 'spi/topic/bfin5xx', 'spi/topic/bitbang' and 'spi/topic/bpw' into spi-next
Fix printk format warning by using %p extension 'ad' for dma_addr_t.
drivers/spi/spi-atmel.c:1228:3: warning: format '%x' expects argument of type 'unsigned int', but argument 7 has type 'dma_addr_t' [-Wformat]
drivers/spi/spi-atmel.c:1228:3: warning: format '%x' expects argument of type 'unsigned int', but argument 9 has type 'dma_addr_t' [-Wformat]
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
The PM callbacks implemented by the spi-atmel driver don't call
spi_master_{resume,suspend}, fix that.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Amend the spi atmel pin controller to optionally take a pin control
handle and set the state of the pins to:
- "default" on boot, resume and before performing an spitransfer
- "sleep" on suspend()
This should make it possible to optimize energy usage for the pins
both for the suspend/resume cycle
spi core will handle validating transfer length since commit 4d94bd21b333
"spi: core: Validate length of the transfers in message".
So remove the same checking in this driver.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This checking is already done in __spi_validate().
In spi_add_device(), we have the code to validate spi->chip_select.
So remove the duplicate code in various drivers.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Replace the deprecated master->transfer with transfer_one_message()
and allow the SPI subsystem handle all the queuing of messages.
Tested-by: Richard Genoud <richard.genoud@gmail.com>
The only speed available was max_speed (the maximum speed declared for a
device).
This patch adds the support for spi_tranfer->speed_hz parameter.
We can now set a different speed for each spi message.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Use devm_*() functions to make cleanup paths simpler.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
In case of error, the function devm_ioremap_resource() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check should be
replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This simplifies error handling.
Conflicts (trivial overlapping cleanups):
User-visible strings are more difficult to grep from sources if they are
separated to multiple source lines. This is worse than over 80 columns long
line code style violation.
Fix this by making those to single-line strings or by breaking them between
variables.
While at there, convert if (printk_ratelimit()) dev_warn() to use
dev_warn_ratelimited in spi-pxa2xx.c.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Fix the following checkpatch warning.
WARNING: quoted string split across lines
'irq' was not released when clk_prepare_enable failed.
Fix it.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Fixes the following types of checkpatch errors and warning:
ERROR: space required after that ',' (ctx:VxV)
WARNING: sizeof *as should be sizeof(*as)
Instead of using legacy suspend/resume methods, using newer
dev_pm_ops structure allows better control over power management.
Also, duplicated 'return' is removed from atmel_spi_resume().
This patch fixes the following sparse warnings.
dma_addr_t can be either u32 or u64 so we should cast to the
largest type and use the format specifier %llx.
drivers/spi/spi-atmel.c: In function ‘atmel_spi_next_xfer_dma_submit’:
drivers/spi/spi-atmel.c:631:2: warning:
format ‘%x’ expects argument of type ‘unsigned int’,
but argument 7 has type ‘dma_addr_t’ [-Wformat]
but argument 9 has type ‘dma_addr_t’ [-Wformat]
drivers/spi/spi-atmel.c: In function ‘atmel_spi_pdc_next_xfer’:
drivers/spi/spi-atmel.c:734:3: warning:
drivers/spi/spi-atmel.c:773:3: warning:
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Let checkers like sparse know that the locking imbalances are intentional
in these functions.
Replace clk_enable/disable with clk_prepare_enable/disable_unprepare to
avoid common clk framework warnings.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
Use generic DMA DT helper.
Platforms booting with or without DT populated are both supported.
Based on Ludovic Desroches <ludovic.desroches@atmel.com> patchset
"ARM: at91: move to generic DMA device tree binding"
Acked-by: Ludovic Desroches <ludovic.desroches@gmail.com>
Fill in the recently added spi_master.bits_per_word_mask field in as
many drivers as possible. Make related cleanups, such as removing any
redundant error-checking, or empty setup callbacks.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Fix using PIO transfer mode only support 8 bits transfer, doesn't support 16 bits.
[wenyou.yang@atmel.com: submit the patch]
Add dmaengine support.
Using "has_dma_support" member of struct is used to select
the transfer mode: dmaengine or pdc.
For the dmaengine transfer mode, it supports both 8 bits and 16 bits transfer.
For the dmaengine transfer mode, if it fails to config dmaengine,
or if the message length is less than 16 bytes, it will use the PIO transfer mode.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
[wenyou.yang@atmel.com: using "has_dma_support" to select dmaengine as the spi xfer mode]
[wenyou.yang@atmel.com: fix DMA: OOPS if buffer > 4096 bytes]
[richard.genoud@gmail.com: update with dmaengine interface]
[richard.genoud@gmail.com: fix __init/__devinit sections mismatch]
[richard.genoud@gmail.com: adapt to slave_config changes]
[richard.genoud@gmail.com: add support t0 16 bits transfer]
Will allow to drop the lock during DMA operations.
Replacing non-irqsave versions with irqsave versions of the lock
to make it correct in both pdc and dmaengine transfer mode
Needed for future use with dmaengine enabled driver.
atmel_spi_transfer() would check speed_hz and fail if
the speed was changed in the transfer. After commit
"spi: make sure all transfer has proper speed set"
this would happen on all transfers.
Change speed_hz check to only fail if a lower speed
than max is requested.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
The status of transfer is stored in controller data structure
so that it can be used not only by atmel_spi_msg_done() function.
This will be useful for upcoming dmaengine enabled driver.
register.
The "has_dma_support" needed for future use with dmaengine driver.
[Fixed some unneded ternery operators -- broonie]
Some of the spi driver module remove hooks were annotated with __exit
and referenced with __exit_p(). Presumably these were supposed to be
__devinit, __devexit and __devexit_p() since __init/__exit for a
probe/remove hook has never been correct. They also got missed during
the big __devinit/__devexit purge since they didn't match the pattern.
Remove then now to be rid of it.
v2: purge __init also
[Arnd set a patch cleaning up one, and then I found more]
Use the newly introduce cs-gpios dt support on atmel.
We do not use the hardware cs as it's wired and has bugs and limitations.
As the controller believes that only active-low devices/systems exists.
Pull SPI updates from Grant Likely:
"Primarily SPI device driver bug fixes, one removal of an old driver,
and some new tegra support. There is some core code change too, but
all in all pretty small stuff.
The new features to note are:
- Common code for describing GPIO CS lines in the device tree
- Remove the SPI_BUFSIZ limitation on spi_write_the_read()
- core spi ensures bits_per_word is set correctly
- SPARC can now use SPI"
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: (36 commits)
spi/sparc: Allow of_register_spi_devices for sparc
spi: Remove HOTPLUG section attributes
spi: Add support for specifying 3-wire mode via device tree
spi: Fix comparison of different integer types
spi/orion: Add SPI_CHPA and SPI_CPOL support to kirkwood driver.
spi/sh: Add SH Mobile series as dependency to MSIOF controller
spi/sh-msiof: Remove unneeded clock name
spi: Remove SPI_BUFSIZ restriction on spi_write_then_read()
spi/stmp: remove obsolete driver
spi/clps711x: New SPI master driver
spi: omap2-mcspi: remove duplicate inclusion of linux/err.h
spi: omap2-mcspi: Fix the redifine warning
spi/sh-hspi: add CS manual control support
of_spi: add generic binding support to specify cs gpio
spi: omap2-mcspi: remove duplicated include from spi-omap2-mcspi.c
spi/bitbang: (cosmetic) simplify list manipulation
spi/bitbang: avoid needless loop flow manipulations
spi/omap: fix D0/D1 direction confusion
spi: tegra: add spi driver for sflash controller
spi: Dont call master->setup if not populated
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Commit 940ab889 "drivercore: Add helper macro for platform_driver boilerplate"
converted this driver to use module_platform_driver, but due to the use
of platform_driver_probe(), this resulted in the call to atmel_spi_probe being
lost. Place the call to this function into the driver structure.
fix section missmatch
atmel_spi_probe is marked __init where it's supposed to be __devinit
atmel_spi_remove is marked __exit where it's supposed to be __devexit
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6:
spi: irq: Remove IRQF_DISABLED
OMAP: SPI: Fix the trying to free nonexistent resource error
spi/spi-ep93xx: add module.h include
spi/tegra: fix compilation error in spi-tegra.c
spi: spi-dw: fix all sparse warnings
spi/spi-pl022: Call pl022_dma_remove(pl022) only if enable_dma is true
spi/spi-pl022: calculate_effective_freq() must set rate <= requested rate
spi/spi-pl022: Don't allocate more sg than required.
spi/spi-pl022: Use GFP_ATOMIC for allocation from tasklet
spi/spi-pl022: Resolve formatting issues
For simple modules that contain a single platform_driver without any
additional setup code then ends up being a block of duplicated
boilerplate. This patch adds a new macro, module_platform_driver(),
which replaces the module_init()/module_exit() registrations with
template functions.
Reviewed-by: Magnus Damm <magnus.damm@gmail.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Sort the SPI makefile and enforce the naming convention spi_*.c for
spi drivers.
This change also rolls the contents of atmel_spi.h into the .c file
since there is only one user of that particular include file.
v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be
be the predominant pattern for subsystem prefixes.
- Clean up filenames in Kconfig and header comment blocks
