commit 563a53f3906a6b43692498e5b3ae891fac93a4af upstream.
On non-OF systems spi->controlled_data may be NULL. This causes a NULL
pointer derefence on dm365-evm.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
commit aabb797b4c1204b2e8518538b2616e476f2bac92, which is commit
c5a2a394835f473ae23931eda5066d3771d7b2f8 upstream had an error in it.
Ben writes:
The '!' needs to be deleted. This appears to have been fixed upstream
by:
commit 8aedbf580d21121d2a032e4c8ea12d8d2d85e275
Author: Fabien Parent <fparent@baylibre.com>
Date: Thu Feb 23 19:01:56 2017 +0100
spi: davinci: Use SPI framework to handle DMA mapping
which is not suitable for stable.
So I'm just fixing this up directly.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Kevin Hilman <khilman@baylibre.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Sasha Levin <alexander.levin@verizon.com>
[ Upstream commit c5a2a394835f473ae23931eda5066d3771d7b2f8 ]
The correct error checking for dma_map_single() is to use
dma_mapping_error().
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
With the new dma_request_chan() the client driver does not need to look for
the DMA resource and it does not need to pass filter_fn anymore.
By switching to the new API the driver can now support deferred probing
against DMA.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Use dev_err() for reporting errors rather than
dev_dbg().
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
davinci_spi_bufs() uses wait_for_completion_interruptible()
without bothering to handle -ERESTARTSYS. Due to this,
sometime, it returns prematurely when a signal is received.
Since the return value is never checked, userspace eventually
receives a spurious -EIO.
To fix this, use un-interruptible wait_for_completion_timeout().
Use spi->cs_gpio directly to remove the following build warning:
drivers/spi/spi-davinci.c:219:6: warning: 'gpio' may be used uninitialized in this function
Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Currently the pre-scaler limit is incorrect. The value differs slightly
for various devices so a single value can't be used. Using the compatible
field select the correct pre-scaler limit.
Add new compatible field value for Keystone devices to support their
unique pre-scaler limit value.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Within davinci_spi_get_prescale() the prescale has two meanings. First one
being the calculated prescale value and then at the end translates it to the
prescale value that will be written to the SPI register.
At first glance this can be confusing especially when comparing the minimum
prescale value against what is seen in the TRM.
To simplify things make it clear that the calculated prescale value will always
be based on the value that will be written into the SPI register.
SPI hardware spec for Keystone specify a lower value of 0 for pre-scale
divider which determine what max value of spi clock (spi-max-frequency)
the device can support. This translates to a clock divider of 2. So fix
the lower limit value used for the boundary check in
davinci_spi_get_prescale() function to 1 so that a maximum of spi device
clock rate / 2 is possible to be set for spi-max-frequency.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
'spi/topic/dw' and 'spi/topic/fsl' into spi-next
'spi/topic/checkpatch' and 'spi/topic/clps711x' into spi-next
'spi/fix/fsl', 'spi/fix/pl022', 'spi/fix/rockchip' and 'spi/fix/sirf' into spi-linus
This patch adds ability to configure delay between transmission of
words over SPI bus if it's required by SPI slave devices.
New optional SPI slave property:
- ti,spi-word-delay : delay between transmission of words
(SPIFMTn.WDELAY, SPIDAT1.WDEL)
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Remove empty function davinci_spi_cleanup().
Now CS GPIOs are requested from struct spi_master.setup() callback
and that causes failures when Client SPI device is getting accessed
through SPIDEV driver. The failure happens, because .setup() callback
may be called many times from IOCTL handler and when it's called
second time gpio_request() will fail and return -EBUSY.
Hence, fix it by moving CS GPIOs requesting code in .probe().
Reported-by: Murali Karicheri <m-karicheri2@ti.com>
Fix the following checkpatch warnings.
WARNING: Missing a blank line after declarations
WARNING: quoted string split across lines
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The driver should not touch CS lines if SPI_NO_CS flag is set.
This patch fixes it as this functionality was broken accidentally
by
commit a88e34ea213e1b ("spi: davinci: add support to configure gpio cs through dt").
Fixes: a88e34ea213e1b ("spi: davinci: add support to configure gpio cs through dt")
Signed-off-by: Mark Brown <broonie@linaro.org>
Rework Davinci SPI driver to store GPIO CS number in cs_gpio field
of SPI device structure (spi_device) for both DT and non-DT cases.
This will make Davinci SPI driver code simpler and allows to reuse
more SPI core functionality.
Currently driver supports only configuration of GPIO CS through
platform data. This patch enhances the driver to configure GPIO
CS through DT. Also update the DT binding documentation to
reflect the availability of cs-gpios.
Currently, the driver defines SPI_MAX_CHIPSELECT as 2 and
use per device array bytes_per_word based on this. This breaks
if num_chipselect per device is greater than 2. This patch
fix this and allocate memory for this array based on
num_chipselect.
It's preparation patch to enable GPIO CS feature for
Davinci SPI.
It's pointless to use of_match_ptr within CONFIG_OF guard.
Use of_match_ptr around davinci_spi_of_match when setting .of_match_table.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
spi_master_get_devdata() never returns NULL when spi_alloc_master() success,
so remove NULL test for dspi.
We have ensured master is not NULL before assigning it to dspi->bitbang.master.
So also remove NULL test for dspi->bitbang.master.
'spi/topic/bcm63xx-hsspi', 'spi/topic/bitbang', 'spi/topic/bpw', 'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/davinci', 'spi/topic/dw' and 'spi/topic/falcon' into spi-linus
The implementation in spi_setup() already set spi->bits_per_word = 8 when
spi->bits_per_word is 0 before calling spi->master->setup.
So we don't need to do it again in setup() callback.
Acked-by: Barry Song <Baohua.Song@csr.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Use devm_*() functions to make cleanup paths simpler.
With CONFIG_ARM_LPAE=y spi driver throws below warning
drivers/spi/spi-davinci.c: In function ‘davinci_spi_probe’:
drivers/spi/spi-davinci.c:965:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘resource_size_t’ [-Wformat]
drivers/spi/spi-davinci.c:965:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘resource_size_t’ [-Wformat]
Lets use '%pa' to properly print 'resource_size_t' type variables.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
Many drivers that use bitbang library have a leak on probe error paths.
This is because once a spi_master_get() call succeeds, we need an additional
spi_master_put() call to free the memory.
Fix this issue by moving the code taking a reference to master to
spi_bitbang_start(), so spi_bitbang_start() will take a reference to master on
success. With this change, the caller is responsible for calling
spi_bitbang_stop() to decrement the reference and spi_master_put() as
counterpart of spi_alloc_master() to prevent a memory leak.
So now we have below patten for drivers using bitbang library:
probe:
spi_alloc_master -> Init reference count to 1
spi_bitbang_start -> Increment reference count
remove:
spi_bitbang_stop -> Decrement reference count
spi_master_put -> Decrement reference count (reference count reaches 0)
Fixup all users accordingly.
Suggested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Acked-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
'prescale' contains the return value of davinci_spi_get_prescale()
which is a signed integer. Convert 'prescale' to integer to silence
the following warning:
drivers/spi/spi-davinci.c:318 davinci_spi_setup_transfer() warn:
unsigned 'prescale' is never less than zero.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Commit 048177ce3b3962852fd34a7e04938959271c7e70 (spi: spi-davinci:
convert to DMA engine API) introduced a regression: dma_map_single()
is called with direction DMA_FROM_DEVICE for rx and for tx.
Signed-off-by: Christian Eggers <ceggers@gmx.de>
Acked-by: Matt Porter <mporter@ti.com>
Cc: stable@vger.kernel.org # v3.7.x+
Fill in the recently added spi_master.bits_per_word_mask field in as
many drivers as possible. Make related cleanups, such as removing any
redundant error-checking, or empty setup callbacks.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Follow DT naming convention for compatible property of the blob.
Use first chip name that introduced the specific version of the
device.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
Fix below module build error:
CC [M] drivers/spi/spi-davinci.o
drivers/spi/spi-davinci.c:774:1: error: '__mod_of_device_table' aliased
to undefined symbol 'davini_spi_of_match'
make[2]: *** [drivers/spi/spi-davinci.o] Error 1
make[1]: *** [drivers/spi] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [drivers] Error 2
With RT pre-empt patch applied to Linux kernel, the irq handler will be
force converted to an irq thread. spi driver can get back to back messages
from the slave device. In such cases, IRQ thread doesn't get a chance to
run to read the slave data. Hence the irq handler must be run in hard irq
context to read/write data from slave device. Otherwise, the kernel goes
into a deadlock. This patch fixes this issue when PREEMPT_RT_FULL is
enabled in the kernel. A dummy thread function is provided to satisfy the
request_threaded_irq() API. Passing a NULL for function also causes the
irq handler to be executed in the thread context.
This adds OF support to DaVinci SPI controller to configure platform
data through device bindings. Also replaces clk_enable() with
of clk_prepare_enable() as well as clk_disable() with
clk_disable_unprepare().
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
Pull slave-dmaengine updates from Vinod Koul:
"This time we have Andy updates on dw_dmac which is attempting to make
this IP block available as PCI and platform device though not fully
complete this time.
We also have TI EDMA moving the dma driver to use dmaengine APIs, also
have a new driver for mmp-tdma, along with bunch of small updates.
Now for your excitement the merge is little unusual here, while
merging the auto merge on linux-next picks wrong choice for pl330
(drivers/dma/pl330.c) and this causes build failure. The correct
resolution is in linux-next. (DMA: PL330: Fix build error) I didn't
back merge your tree this time as you are better than me so no point
in doing that for me :)"
Fixed the pl330 conflict as in linux-next, along with trivial header
file conflicts due to changed includes.
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (29 commits)
dma: tegra: fix interrupt name issue with apb dma.
dw_dmac: fix a regression in dwc_prep_dma_memcpy
dw_dmac: introduce software emulation of LLP transfers
dw_dmac: autoconfigure data_width or get it via platform data
dw_dmac: autoconfigure block_size or use platform data
dw_dmac: get number of channels from hardware if possible
dw_dmac: fill optional encoded parameters in register structure
dw_dmac: mark dwc_dump_chan_regs as inline
DMA: PL330: return ENOMEM instead of 0 from pl330_alloc_chan_resources
DMA: PL330: Remove redundant runtime_suspend/resume functions
DMA: PL330: Remove controller clock enable/disable
dmaengine: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
DMA: PL330: Set the capability of pdm0 and pdm1 as DMA_PRIVATE
ARM: EXYNOS: Set the capability of pdm0 and pdm1 as DMA_PRIVATE
dma: tegra: use list_move_tail instead of list_del/list_add_tail
mxs/dma: Enlarge the CCW descriptor area to 4 pages
dw_dmac: utilize slave_id to pass request line
dmaengine: mmp_tdma: add dt support
dmaengine: mmp-pdma support
spi: davici - make davinci select edma
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the davinci include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Ben Dooks" <ben-linux@fluff.org>
Cc: "Wolfram Sang" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Liam Girdwood <lrg@ti.com>
Cc: davinci-linux-open-source@linux.davincidsp.com
Removes use of the DaVinci EDMA private DMA API and replaces
it with use of the DMA engine API.
Signed-off-by: Matt Porter <mporter@ti.com>
Tested-by: Tom Rini <trini@ti.com>
Tested-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
