path: root/drivers/spi/spi-tegra.c
2011-10-25drivercore: Add helper macro for platform_driver boilerplateGrant Likely
For simple modules that contain a single platform_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_platform_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Magnus Damm <magnus.damm@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2011-10-14spi/tegra: fix compilation error in spi-tegra.cMarc Dietrich
Add #include <linux/module.h> to spi-tegra.c to fix a compilation error after the removal of module.h from device.h (in patch: "include: replace linux/module.h with "struct module" wherever possible"). Signed-off-by: Marc Dietrich <marvin24@gmx.de> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-05spi/tegra: Use engineering names in DT compatible propertyStephen Warren
Engineering names are more stable than marketing names. Hence, use them for Device Tree compatible properties instead. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-15gpio/tegra: Move Tegra gpio driver to drivers/gpioGrant Likely
As part of the gpio driver consolidation, this patch moves the Tegra driver into drivers/gpio Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-10spi: Convert uses of struct resource * to resource_size(ptr)Joe Perches
Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
