commit f20fbaad7620af2df36a1f9d1c9ecf48ead5b747 upstream.
`spidev_message()` sums the lengths of the individual SPI transfers to
determine the overall SPI message length. It restricts the total
length, returning an error if too long, but it does not check for
arithmetic overflow. For example, if the SPI message consisted of two
transfers and the first has a length of 10 and the second has a length
of (__u32)(-1), the total length would be seen as 9, even though the
second transfer is actually very long. If the second transfer specifies
a null `rx_buf` and a non-null `tx_buf`, the `copy_from_user()` could
overrun the spidev's pre-allocated tx buffer before it reaches an
invalid user memory address. Fix it by checking that neither the total
nor the individual transfer lengths exceed the maximum allowed value.
Thanks to Dan Carpenter for reporting the potential integer overflow.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Signed-off-by: Mark Brown <broonie@kernel.org>
[Ian Abbott: Note: original commit compares the lengths to INT_MAX instead
of bufsiz due to changes in earlier commits.]
Signed-off-by: Zefan Li <lizefan@huawei.com>
commit 9d239d353c319f9ff884c287ce47feb7cdf60ddc upstream.
The commit d297933cc7fc (spi: dw: Fix detecting FIFO depth) tries to fix the
logic of the FIFO detection based on the description on the comments. However,
there is a slight difference between numbers in TX Level and TX FIFO size.
So, by specification the FIFO size would be in a range 2-256 bytes. From TX
Level prospective it means we can set threshold in the range 0-(FIFO size - 1)
bytes. Hence there are currently two issues:
a) FIFO size 2 bytes is actually skipped since TX Level is 1 bit and could be
either 0 or 1 byte;
b) FIFO size is incorrectly decreased by 1 which already done by meaning of
TX Level register.
This patch fixes it eventually right.
Fixes: d297933cc7fc (spi: dw: Fix detecting FIFO depth)
Reviewed-by: Axel Lin <axel.lin@ingics.com>
commit 67bf9cda4b498b8cea4a40be67a470afe57d2e88 upstream.
The FIFO size is 40 accordingly to the specifications, but this means 0x40,
i.e. 64 bytes. This patch fixes the typo and enables FIFO size autodetection
for Intel MID devices.
Fixes: 7063c0d942a1 (spi/dw_spi: add DMA support)
commit d297933cc7fcfbaaf2d37570baac73287bf0357d upstream.
Current code tries to find the highest valid fifo depth by checking the value
it wrote to DW_SPI_TXFLTR. There are a few problems in current code:
1) There is an off-by-one in dws->fifo_len setting because it assumes the latest
register write fails so the latest valid value should be fifo - 1.
2) We know the depth could be from 2 to 256 from HW spec, so it is not necessary
to test fifo == 257. In the case fifo is 257, it means the latest valid
setting is fifo = 256. So after the for loop iteration, we should check
fifo == 2 case instead of fifo == 257 if detecting the FIFO depth fails.
This patch fixes above issues.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-and-tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[lizf: Backported to 3.4: adjust context]
commit 0a8727e69778683495058852f783eeda141a754e upstream.
An IOCTL call that calls spi_setup() and then dw_spi_setup() will
overwrite the persisted last transfer speed. On each transfer, the
SPI speed is compared to the last transfer speed to determine if the
clock divider registers need to be updated (did the speed change?).
This bug was observed with the spidev driver using spi-config to
update the max transfer speed.
This fix: Don't overwrite the persisted last transaction clock speed
when updating the SPI parameters in dw_spi_setup(). On the next
transaction, the new speed won't match the persisted last speed
and the hardware registers will be updated.
On initialization, the persisted last transaction clock
speed will be 0 but will be updated after the first SPI
transaction.
Move zeroed clock divider check into clock change test because
chip->clk_div is zero on startup and would cause a divide-by-zero
error. The calculation was wrong as well (can't support odd #).
Reported-by: Vlastimil Setka <setka@vsis.cz>
Signed-off-by: Vlastimil Setka <setka@vsis.cz>
Signed-off-by: Thor Thayer <tthayer@opensource.altera.com>
commit 3ffa6158f002e096d28ede71be4e0ee8ab20baa2 upstream.
When mapped RX DMA entries are unmapped in an error condition when DMA
is firstly configured in the driver, the number of TX DMA entries was
passed in, which is incorrect
Signed-off-by: Ray Jui <rjui@broadcom.com>
commit 8e45ef682cb31fda62ed4eeede5d9745a0a1b1e2 upstream.
Do full clean up at exit, means terminate all ongoing DMA transfers.
commit b41583e7299046abdc578c33f25ed83ee95b9b31 upstream.
In case of 8 bit mode and DMA usage we end up with every second byte written as
0. We have to respect bits_per_word settings what this patch actually does.
commit 1f802f8249a0da536877842c43c7204064c4de8b upstream.
This reverts commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d.
It causes a NULL pointer dereference with drivers using the generic
spi_transfer_one_message(), which always calls
spi_finalize_current_message(), which zeroes master->cur_msg.
Drivers implementing transfer_one_message() theirselves must always call
spi_finalize_current_message(), even if the transfer failed:
* @transfer_one_message: the subsystem calls the driver to transfer a single
* message while queuing transfers that arrive in the meantime. When the
* driver is finished with this message, it must call
* spi_finalize_current_message() so the subsystem can issue the next
* transfer
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d upstream.
This corrects a problem in spi_pump_messages() that leads to an spi
message hanging forever when a call to transfer_one_message() fails.
This failure occurs in my MCP2210 driver when the cs_change bit is set
on the last transfer in a message, an operation which the hardware does
not support.
Rationale
Since the transfer_one_message() returns an int, we must presume that it
may fail. If transfer_one_message() should never fail, it should return
void. Thus, calls to transfer_one_message() should properly manage a
failure.
Fixes: ffbbdd21329f3 (spi: create a message queueing infrastructure)
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
commit 1ad849aee5f53353ed88d9cd3d68a51b03a7d44f upstream.
Some SPI slave devices require asserted chip select signal across
multiple transfer segments of an SPI message. Currently the driver
always de-asserts the internal SS signal for every single transfer
segment of the message and ignores the 'cs_change' flag of the
transfer description. Disable the internal chip select (SS) only
if this is needed and indicated by the 'cs_change' flag.
Without this change, each partial transfer of a surrounding
multi-part SPI transaction might erroneously change the SS
signal, which might prevent slaves from answering the request
that was sent in a previous transfer segment because the
transaction could be considered aborted (SS was de-asserted
before reading the response).
Reported-by: Gerhard Sittig <gerhard.sittig@ifm.com>
commit 375981f2e14868be16cafbffd34a4f16a6ee01c6 upstream.
The status of the interrupt is available in the status register,
so reading the clear pending register and writing back the same
value will not actually clear the pending interrupts. This patch
modifies the interrupt handler to read the status register and
clear the corresponding pending bit in the clear pending register.
Modified the hwInit function to clear all the pending interrupts.
Signed-off-by: Girish K S <ks.giri@samsung.com>
commit fd316941cfee1fbd12746afea83720fb7823888a upstream.
Commit ffbbdd21329f3e15eeca6df2d4bc11c04d9d91c0
"spi: create a message queueing infrastructure"
Accidentally deleted the logic to disable the port
when unused leading to higher power consumption.
Fix this up.
Cc: Vinit Shenoy <vinit.shenoy@st.com>
Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com>
commit 067aa4815a9bc12a569d8a06afef50ba5773afbf upstream.
Commit 178db7d3, "spi: Fix device unregistration when unregistering
the bus master", changed spi device initialization of dev.parent pointer
to be the master's device pointer instead of his parent.
This introduced a bug in spi-fsl-spi, since its usage of spi device
pointer was not updated accordingly. This was later fixed by commit
5039a86, "spi/mpc83xx: fix NULL pdata dereference bug", but it missed
another spot on fsl_spi_cs_control function where we also need to update
usage of spi device pointer. This change address that.
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
This patch ensures that the last bit of a transfer gets correctly
flushed out of the register.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
This condition is used to determine 8 bits or 16 and 32 bits transfer.
Obviously it is reversed.
Since the member was dropped from the common Blackfin header, we need
to stop using it in the SPORT driver too.
No other SPI controller has this field, and SPI clients should be setting
this up in their own drivers. So drop it from the Blackfin controller to
keep people from using it.
Each transfer may have its own bits per word.
This controller is only for blackfin 5xx soc, so rename it to BFIN5XX
Currently, if we request for frequency greater than maximum possible, spi driver
returns error.
For example, if the spi block src frequency is 333/4 MHz, i.e. 83.33.. MHz,
maximum frequency programmable would be src/2. Which would come around 41.6...
It is difficult to pass frequency in these figures. We normally try to program
in round figures, like 42 MHz and it should get programmed to <=
requested_frequency, i.e. 41.6...
For this to happen, we must not return error even if requested freq is higher
than max possible. But should program it to max possible.
Reported-by: Vinit Kamalaksha Shenoy <vinit.shenoy@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
We were not properly advertising the MODE bits supported by this driver, fix
that.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
We do not need to use a flag to indicate if the master driver is stopping
it is sufficient to perform spi master unregistering in the platform
driver's remove function.
This patch converts the bcm63xx SPI driver to use the SPI infrastructure
pump message queue. Since we were previously sleeping in the SPI
driver's transfer() function (which is not allowed) this is now fixed as well.
To complete that conversion a certain number of changes have been made:
- the transfer len is split into multiple hardware transfers in case its
size is bigger than the hardware FIFO size
- the FIFO refill is no longer done in the interrupt context, which was a
bad idea leading to quick interrupt handler re-entrancy
Tested-by: Tanguy Bouzeloc <tanguy.bouzeloc@efixo.com>
A new enum indicating the dma channel direction was introduced by:
commit 49920bc66984a512f4bcc7735a61642cd0e4d6f2
dmaengine: add new enum dma_transfer_direction
The following commit changed spi-ep93xx to use the new enum:
commit a485df4b4404379786c4bdd258bc528b2617449d
spi, serial: move to dma_transfer_direction
In doing so a sparse warning was introduced:
warning: mixing different enum types
int enum dma_data_direction versus
int enum dma_transfer_direction
This is produced because the 'dir' passed in ep93xx_spi_dma_prepare
is an enum dma_data_direction and is being used to set the
dma_slave_config 'direction' which is now an enum dma_transfer_direction.
Fix this by converting spi-ep93xx to use the new enum type in all
places.
Acked-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Vinod Koul <vinod.koul@intel.com>
calculate_effective_freq() was still not optimized and there were cases when it
returned without error and with values of cpsr and scr as zero.
Also, the variable named found is not used well.
This patch targets to optimize and correct this routine. Tested for SPEAr.
Tested-by: Vinit Kamalaksha Shenoy <vinit.shenoy@st.com>
pl022 ssp controller supports word lengths from 4 to 16 (or 32) bits.
Currently implemented checks were incorrect. It has following check
if (pl022->vendor->max_bpw >= 32)
which must be checking for <=.
Also error print message is incorrect, that prints "range is from 1 to
16".
Fix both these issues.
Signed-off-by: Vinit Shenoy <vinit.shenoy@st.com>
Pull ARM fixes from Russell King:
"Nothing too disasterous, the biggest thing being the removal of the
regulator support for vcore in the AMBA driver; only one SoC was using
this and it got broken during the last merge window, which then
started causing problems for other people. Mutual agreement was
reached for it to be removed."
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7386/1: jump_label: fixup for rename to static_key
ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEE
ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMU
ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus
ARM: 7383/1: nommu: populate vectors page from paging_init
ARM: 7381/1: nommu: fix typo in mm/Kconfig
ARM: 7380/1: DT: do not add a zero-sized memory property
ARM: 7379/1: DT: fix atags_to_fdt() second call site
ARM: 7366/3: amba: Remove AMBA level regulator support
ARM: 7377/1: vic: re-read status register before dispatching each IRQ handler
ARM: 7368/1: fault.c: correct how the tsk->[maj|min]_flt gets incremented
Pull SPI bug fixes from Grant Likely:
"Miscellaneous driver bug fixes. No major changes in this branch."
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6:
spi/imx: prevent NULL pointer dereference in spi_imx_probe()
spi/imx: mark base member in spi_imx_data as __iomem
spi/davinci: Fix DMA API usage in davinci
spi/pL022: include types.h to remove compilation warnings
The AMBA bus regulator support is being used to model on/off switches
for power domains which isn't terribly idiomatic for modern kernels with
the generic power domain code and creates integration problems on platforms
which don't use regulators for their power domains as it's hard to tell
the difference between a regulator that is needed but failed to be provided
and one that isn't supposed to be there (though DT does make that easier).
Platforms that wish to use the regulator API to manage their power domains
can indirect via the power domain interface.
This feature is only used with the vape supply of the db8500 PRCMU
driver which supplies the UARTs and MMC controllers, none of which have
support for managing vcore at runtime in mainline (only pl022 SPI
controller does). Update that supply to have an always_on constraint
until the power domain support for the system is updated so that it is
enabled for these users, this is likely to have no impact on practical
systems as probably at least one of these devices will be active and
cause AMBA to hold the supply on anyway.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
When no platform_data is present and either 'spi-num-chipselects' is
not defined in the DT or 'cs-gpios' has less entries than
'spi-num-chipselects' specifies, the NULL platform_data pointer is
being dereferenced.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Merge batch of fixes from Andrew Morton:
"The simple_open() cleanup was held back while I wanted for laggards to
merge things.
I still need to send a few checkpoint/restore patches. I've been
wobbly about merging them because I'm wobbly about the overall
prospects for success of the project. But after speaking with Pavel
at the LSF conference, it sounds like they're further toward
completion than I feared - apparently davem is at the "has stopped
complaining" stage regarding the net changes. So I need to go back
and re-review those patchs and their (lengthy) discussion."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches)
memcg swap: use mem_cgroup_uncharge_swap fix
backlight: add driver for DA9052/53 PMIC v1
C6X: use set_current_blocked() and block_sigmask()
MAINTAINERS: add entry for sparse checker
MAINTAINERS: fix REMOTEPROC F: typo
alpha: use set_current_blocked() and block_sigmask()
simple_open: automatically convert to simple_open()
scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()
libfs: add simple_open()
hugetlbfs: remove unregister_filesystem() when initializing module
drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback
fs/xattr.c:setxattr(): improve handling of allocation failures
fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed
fs/xattr.c: suppress page allocation failure warnings from sys_listxattr()
sysrq: use SEND_SIG_FORCED instead of force_sig()
proc: fix mount -t proc -o AAA
Many users of debugfs copy the implementation of default_open() when
they want to support a custom read/write function op. This leads to a
proliferation of the default_open() implementation across the entire
tree.
Now that the common implementation has been consolidated into libfs we
can replace all the users of this function with simple_open().
This replacement was done with the following semantic patch:
<smpl>
@ open @
identifier open_f != simple_open;
identifier i, f;
-int open_f(struct inode *i, struct file *f)
-if (i->i_private)
-f->private_data = i->i_private;
-return 0;
@ has_open depends on open @
identifier fops;
identifier open.open_f;
struct file_operations fops = {
-.open = open_f,
+.open = simple_open,
</smpl>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
This fixes 36 sparse warnings like:
drivers/spi/spi-imx.c:143:1: warning: incorrect type in argument 1 (different address spaces)
drivers/spi/spi-imx.c:143:1: expected void const volatile [noderef] <asn:2>*<noident>
drivers/spi/spi-imx.c:143:1: got void *
the bus master", changed device initialization to be children of the
bus master, not children of the bus masters parent device. The pdata
pointer used in fsl_spi_chipselect must updated to reflect the changed
initialization.
Signed-off-by: Kenth Eriksson <kenth.eriksson@transmode.com>
The driver uses NULL for dma_unmap_single instead of
the struct device that the API expects.
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
Tested-by: Akshay Shankarmurthy <akshay.s@ti.com>
Pull slave-dmaengine update from Vinod Koul:
"This includes the cookie cleanup by Russell, the addition of context
parameter for dmaengine APIs, more arm dmaengine driver cleanup by
moving code to dmaengine, this time for imx by Javier and pl330 by
Boojin along with the usual driver fixes."
Fix up some fairly trivial conflicts with various other cleanups.
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (67 commits)
dmaengine: imx: fix the build failure on x86_64
dmaengine: i.MX: Fix merge of cookie branch.
dmaengine: i.MX: Add support for interleaved transfers.
dmaengine: imx-dma: use 'dev_dbg' and 'dev_warn' for messages.
dmaengine: imx-dma: remove 'imx_dmav1_baseaddr' and 'dma_clk'.
dmaengine: imx-dma: remove unused arg of imxdma_sg_next.
dmaengine: imx-dma: remove internal structure.
dmaengine: imx-dma: remove 'resbytes' field of 'internal' structure.
dmaengine: imx-dma: remove 'in_use' field of 'internal' structure.
dmaengine: imx-dma: remove sg member from internal structure.
dmaengine: imx-dma: remove 'imxdma_setup_sg_hw' function.
dmaengine: imx-dma: remove 'imxdma_config_channel_hw' function.
dmaengine: imx-dma: remove 'imxdma_setup_mem2mem_hw' function.
dmaengine: imx-dma: remove dma_mode member of internal structure.
dmaengine: imx-dma: remove data member from internal structure.
dmaengine: imx-dma: merge old dma-v1.c with imx-dma.c
dmaengine: at_hdmac: add slave config operation
dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic
dmaengine/dma_slave: introduce inline wrappers
dma: imx-sdma: Treat firmware messages as warnings instead of erros
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Pull "ARM: More device tree support updates" from Olof Johansson:
"This branch contains a number of updates for device tree support on
several ARM platforms, in particular:
* AT91 continues the device tree conversion adding support for a
number of on-chip drivers and other functionality
* ux500 adds probing of some of the core SoC blocks through device
tree
* Initial device tree support for ST SPEAr600 platforms
* kirkwood continues the conversion to device-tree probing"
Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and
drivers/usb/gadget/at91_udc.c due to header file include cleanups.
Also do an "evil merge" for the MACH_U8500 config option rename that the
affected RMI4 touchscreen driver in staging. It's called MACH_MOP500
now, and it was missed during previous merges.
* tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
ARM: SPEAr600: Add device-tree support to SPEAr600 boards
ARM: ux500: Provide local timer support for Device Tree
ARM: ux500: Enable PL022 SSP Controller in Device Tree
ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree
ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree
ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree
ARM: ux500: db8500: list most devices in the snowball device tree
ARM: ux500: split dts file for snowball into generic part
ARM: ux500: combine the board init functions for DT boot
ARM: ux500: Initial Device Tree support for Snowball
ARM: ux500: CONFIG: Enable Device Tree support for future endeavours
ARM: kirkwood: use devicetree for rtc-mv
ARM: kirkwood: rtc-mv devicetree bindings
ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0
ARM: kirkwood: fdt: facilitate new boards during fdt migration
ARM: kirkwood: fdt: absorb kirkwood_init()
ARM: kirkwood: fdt: use mrvl ticker symbol
ARM: orion: wdt: use resource vice direct access
ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data.
ARM: orion: spi: remove enable_clock_fix which is not used
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
Pull SPI changes for v3.4 from Grant Likely:
"Mostly a bunch of new drivers and driver bug fixes; but this also
includes a few patches that create a core message queue infrastructure
for the spi subsystem instead of making each driver open code it."
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits)
spi/fsl-espi: Make sure pm is within 2..32
spi/fsl-espi: make the clock computation easier to read
spi: sh-hspi: modify write/read method
spi: sh-hspi: control spi clock more correctly
spi: sh-hspi: convert to using core message queue
spi: s3c64xx: Fix build
spi: s3c64xx: remove unnecessary callback msg->complete
spi: remove redundant variable assignment
spi: release lock on error path in spi_pump_messages()
spi: Compatibility with direction which is used in samsung DMA operation
spi-topcliff-pch: add recovery processing in case wait-event timeout
spi-topcliff-pch: supports a spi mode setup and bit order setup by IO control
spi-topcliff-pch: Fix issue for transmitting over 4KByte
spi-topcliff-pch: Modify pci-bus number dynamically to get DMA device info
spi/imx: simplify error handling to free gpios
spi: Convert to DEFINE_PCI_DEVICE_TABLE
spi: add Broadcom BCM63xx SPI controller driver
SPI: add CSR SiRFprimaII SPI controller driver
spi-topcliff-pch: fix -Wuninitialized warning
spi: Mark spi_register_board_info() __devinit
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
git://git.infradead.org/users/jcooper/linux-kirkwood into kirkwood/dt
* 'kirkwood_dt_for_3.4_v3' of git://git.infradead.org/users/jcooper/linux-kirkwood:
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The reference manual says that pm has to stay within 2 and 32. So the
lowest frequency is 32 and DIV16 set, the highest is 2 and DIV16 unset.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The -1 +1 thingy should probably do what DIV_ROUND_UP does. The 4 is 2
the "platform_clock => sysclock" and 2 from the computation part. The 64
is the same 4 times 16.
into next/cleanup
* 'ep93xx-for-arm-soc' of git://github.com/RyanMallon/linux-2.6:
(update to v3.3-rc7)
arch/arm/mach-s3c2440/common.h
Current sh-hspi had wrong write/read method which was not linux standard.
If spi_transfer requests tx[2], rx[2] len=2,
then, driver should run tx[0], rx[0], tx[1], rx[1].
But current sh-hspi runs tx[0], tx[1], rx[0], rx[1].
This patch fixes it up.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Current sh-hspi had used platform-specific speed.
This patch remove it, and use spi_transfer specific speed.
It removes unnecessary flags from struct sh_hspi_info,
but struct sh_hspi_info is still exist, since sh-hspi needs
platform info in the future.
