This is the 4.4.59 stable release
commit 7243e0b20729d372e97763617a7a9c89f29b33e1 upstream.
The calculation of SPR and SPPR doesn't round correctly at several
places which might result in baud rates that are too big. For example
with tclk_hz = 250000001 and target rate 25000000 it determined a
divider of 10 which is wrong.
Instead of fixing all the corner cases replace the calculation by an
algorithm without a loop which should even be quicker to execute apart
from being correct.
Fixes: df59fa7f4bca ("spi: orion: support armada extended baud rates")
Signed-off-by: Mark Brown <broonie@kernel.org>
This is the 4.4.39 stable release
Currently the DMA transfer path switches to EOQ mode for transfers
less than or equal to the DSPI FIFO size. Remove this and rely on
DMA mode alone.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Buffers allocated with a call to dma_alloc_coherent should be
freed with dma_free_coherent instead of the currently used
devm_kfree.
Current DMA implementation was not handling the continuous selection
format viz. SPI chip select would be deasserted even between sequential
serial transfers.
Use existing dspi_data_to_pushr function to restructure the transmit
code path and set or reset the CONT bit on same lines as code path
in EOQ mode does. This correctly implements continuous selection format
while also correcting and cleaning up the transmit code path.
Currently dmaengine_prep_slave_single was being called with length
set to the complete DMA buffer size. This resulted in unwanted bytes
being transferred to the SPI register leading to clock and MOSI lines
having unwanted data even after chip select got deasserted and the
required bytes having been transferred.
While at it also clean up the use of curr_xfer_len which is central
to the DMA setup, from bytes to DMA transfers for every use.
Current DMA implementation had a bug where the DMA transfer would
exit the loop in dspi_transfer_one_message after the completion of
a single transfer. This results in a multi message transfer submitted
with SPI_IOC_MESSAGE to terminate incorrectly without an error.
This patch fixes the above issue.
Data register is 4 bytes but only 2 bytes of it are really used
for data and rest of it is for configuration. We should split the
transfers at 1K boundary instead of 4K which is DMA buffer size
as it is only possible to accomodate one byte in PUSHR for 8 bit
transfer mode and two bytes for 16 bit transfer mode.
In dspi_next_xfer_dma_submit we spread out the individual items
to align well with the FIFO width (4 bytes, see the for loop).
So when using 8 bits per word, we go from
0x12 0x23 0xab 0xcd
To
0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x23
0x00 0x00 0x00 0xab
0x00 0x00 0x00 0xcd
And when using 16 bits per word we go from:
0x12 0x23 0xab 0xcd
To
0x00 0x00 0x12 0x23
0x00 0x00 0xab 0xcd
So we require a DMA buffer size of 4 * bytes to transfer or the
data has to be split in chunks of DSPI_DMA_BUFSIZE / 4.
commit 6999aeabbb703a81a204cb6f9f8f151759a99ac4 upstream.
The call sequence spi_alloc_master/spi_register_master/spi_unregister_master
is complete; it reduces the device reference count to zero, which and results
in device memory being freed. The subsequent call to spi_master_put is
unnecessary and results in an access to free memory. Drop it.
Fixes: 9298bc727385 ("spi: spi-fsl-dspi: Remove spi-bitbang")
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
commit c3ccf357c3d75bd2924e049b6a991f7c0c111068 upstream.
The conversion from a look-up table to a calculation for clock generator
parameters forgot to take into account that BRDV x 1/1 is valid only if
BRPS is x 1/1 or x 1/2, leading to undefined behavior (e.g. arbitrary
clock rates).
This limitation is documented for the MSIOF module in all supported
SH/R-Mobile and R-Car Gen2/Gen3 ARM SoCs.
Tested on r8a7791/koelsch and r8a7795/salvator-x.
Fixes: 65d5665bb260b034 ("spi: sh-msiof: Update calculation of frequency dividing")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
This is the 4.4.21 stable release
Add DMA support for Vybrid.
Upstream discussions would like to get rid of spidev in device
trees since it is a Linux software artifact. However, we would like
to provide a spidev interface for our standard SPI port available
to tinker with on our Toradex Colibri Evaluation Board. Invent a
new device called evalspi...
This reverts commit 88c66ffd8ed6cd50e436ce0d5830cd27f93259a2.
This reverts commit b84a7643279332aca39d4be85d47c0734802c91e.
commit 152bc19e2fc2b7fce7ffbc2a9cea94b147223702 upstream.
It seems the commit e5262d0568dc ("spi: spi-pxa2xx: SPI support for Intel Quark
X1000") misses one place to be adapted for Intel Quark, i.e. in reset_sccr1().
Clear all RFT bits when call reset_sccr1() on Intel Quark.
Fixes: e5262d0568dc ("spi: spi-pxa2xx: SPI support for Intel Quark X1000")
commit 6d9fe44bd73d567d04d3a68a2d2fa521ab9532f2 upstream.
When testing SPI without DMA I noticed that filling the FIFO on the
spi controller causes timeout.
Always leave room for one byte in the FIFO.
Signed-off-by: Michal Suchanek <hramrach@gmail.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 719bd6542044efd9b338a53dba1bef45f40ca169 upstream.
The trasfer timeout is fixed at 1000 ms. Reading a 4Mbyte flash over
1MHz SPI bus takes way longer than that. Calculate the timeout from the
actual time the transfer is supposed to take and multiply by 2 for good
measure.
This is the 4.4.12 stable release
commit 1ff7760ff66b98ef244bf0e5e2bd5310651205ad upstream.
We clamp frame_len_words to a maximum of 4096, but do not actually
limit the number of words written or read through the DATA registers
or the length added to spi_message::actual_length. This results in
silent data corruption for commands longer than this maximum.
Recalculate the length of each transfer, taking frame_len_words into
account. Use this length in qspi_{read,write}_msg(), and to increment
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit ea1b60fb085839a9544cb3a0069992991beabb7f upstream.
Each transfer can specify 8, 16 or 32 bits per word independently of
the default for the device being addressed. However, currently we
calculate the number of words in the frame assuming that the word size
is the device default.
If multiple transfers in the same message have differing
bits_per_word, we bitwise-or the different values in the WLEN register
field.
Fix both of these. Also rename 'frame_length' to 'frame_len_words' to
make clear that it's not a byte count like spi_message::frame_length.
commit 66ec246eb9982e7eb8e15e1fc55f543230310dd0 upstream.
Certain Intel Sunrisepoint PCH variants report zero chip selects in SPI
capabilities register even they have one per port. Detection in
pxa2xx_spi_probe() sets master->num_chipselect to 0 leading to -EINVAL
from spi_register_master() where chip select count is validated.
Fix this by not using SPI capabilities register on Sunrisepoint. They don't
have more than one chip select so use the default value 1 instead of
detection.
Fixes: 8b136baa5892 ("spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals")
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
commit b920cc3191d7612f26f36ee494e05b5ffd9044c0 upstream.
Rockchip_spi_set_cs could be called by spi_setup, but
spi_setup may be called by device driver after runtime suspend.
Then the spi clock is closed, rockchip_spi_set_cs may access the
spi registers, which causes cpu block in some socs.
Fixes: 64e36824b32 ("spi/rockchip: add driver for Rockchip RK3xxx")
Signed-off-by: Huibin Hong <huibin.hong@rock-chips.com>
Add new sysfs 'num_chipselect' file to expose the maximum number
of chipselects a SPI master can support.
This allows to create a script in user space which automatically
creates a new spidev instance for every chipselect on a bus.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Use sysfs new_id file to enable spidev at runtime. new_id file accepts
bus number and chip select in 'B.C' format.
With reference to the last ML discussion here[1] regarding the solution
for spidev with device trees. This patch adds support to load spidevB.C
via sysfs new_id file as suggested by Greg.
[1] http://thread.gmane.org/gmane.linux.kernel.spi.devel/20331/focus=20369
Suggested-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[fixed error handling]
This is the 4.4.5 stable release
Calculate and update max speed from bus clock for SoCs
using DSPI IP.
The bus clock factor's are taken from the data sheets
of respective SoCs.
Acked-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit 9419b2006cf47c75985ea51d36ddc51346d29efd)
commit 70f340df24518d36eeaefb6652d492f250115c19 upstream.
The non-DT platform that uses this driver (actually the AVR32) was taking a bad
branch for determining if the IP would use gpio for CS.
Adding the presence of DT as a condition fixes this issue.
Fixes: 4820303480a1 ("spi: atmel: add support for the internal chip-select of the spi controller")
Reported-by: Mans Rullgard <mans@mansr.com>
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
[nicolas.ferre@atmel.com: extract from ml discussion]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Tested-by: Mans Rullgard <mans@mansr.com>
commit 2f538c017e1a8620d19553931199c6d6a6d31bb2 upstream.
Occasionally the setup function will be called multiple times. Only request
the gpio the first time otherwise -EBUSY will occur on subsequent calls to
setup.
Reported-by: Joseph Bell <joe@iachieved.it>
Signed-off-by: Michael Welling <mwelling@ieee.org>
spi-linus
Fix parent-device reference leak due to SPI-core taking an unnecessary
reference to the parent when allocating the master structure, a
reference that was never released.
Note that driver core takes its own reference to the parent when the
master device is registered.
Fixes: 49dce689ad4e ("spi doesn't need class_device")
Signed-off-by: Johan Hovold <johan@kernel.org>
Cc: stable@vger.kernel.org
We use the spi_lock spinlock to protect against races between the device
being removed and file operations on the spidev. This means that in the
removal path all references to the device need to be done under lock as
in removal we dropping references to the device.
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
DSPI instances in Vybrid have a different amount of chip selects
and CTARs (Clock and transfer Attributes Register). In case of
DSPI1 we only have 2 CTAR registers and 4 CS. In present driver
implementation CTAR offset is derived from CS instance which will
lead to out of bound access if chip select instance is greater than
CTAR register instance, hence use single CTAR0 register for all CS
instances. Since we write the CTAR register anyway before each access,
there is no value in using the additional CTAR registers. Also one
should not program a value in CTAS for a CTAR register that is not
present, hence configure CTAS to use CTAR0.
'spi/fix/mediatek' and 'spi/fix/pl022' into spi-linus
When submitting an identical spi_message multiple times via spi_sync
the spi_message.frame_length does not get reset to 0 in __spi_validate
before adding up all spi_transfer.len resulting in
frame_length > actual_length on all but the first spi_sync call.
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
Handle EPROBE_DEFER explicitly so that we ensure that we get the DMA
channel specified in the device tree, instead of depending on the DMA
controller getting probed before us.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
With a 64-bit resource_size_t, we get a build warning on bcm63xx_spi_probe:
drivers/spi/spi-bcm63xx.c:565:16: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'resource_size_t {aka long long unsigned int}' [-Wformat=]
As we are printing a resource, we can just use the %pr format
specifier that pretty-prints the address and avoids the warning.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
When only one device is present, it is not necessary to specify
cs_gpios, as the CS line can be controlled by the hardware
module.
Without this patch, older device tree bindings used before
37457607 "spi: mediatek: mt8173 spi multiple devices support"
would cause a panic on boot. This fixes the crash, and
re-introduces backward compatibility.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Acked-by: Leilk Liu <leilk.liu@mediatek.com>
Commit ca5d24854210 ("spi: Add THIS_MODULE to spi_driver in SPI core")
adds the new __spi_register_driver() function, but keeps the kerneldoc
for the spi_register_driver() function in place and forgets to add the
description for the new owner parameter.
Signed-off-by: Thierry Reding <treding@nvidia.com>
'spi/topic/txx9' into spi-next
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
'spi/topic/mtk', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
spi-next
'spi/topic/bfin-sport', 'spi/topic/bfin5xx' and 'spi/topic/bitbang' into spi-next
'spi/topic/au1550', 'spi/topic/bcm2835' and 'spi/topic/bcm2835aux' into spi-next
