Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
This reverts commit 8fdf8dc5afdb02625084356ebd7c0d1c7494a00e.
Tegra spi driver was using devm_kzalloc before dev
was bound.
When setting transfer clock rate out of bounds
old clock rate was used without any notice.
Added support to use polling mode instead of interrupts
through a property in dt
Bug 1679083
Change-Id: Ic82ab592822cc96bacda05124d38ddd913e09af9
Reviewed-on: http://git-master/r/840233
(cherry picked from commit cd1c4db5adc8317572106099da37fa434245e699)
Reviewed-on: http://git-master/r/1009988
(cherry picked from commit b29ce03a6b7ebb306ff157640470dd5ab99c6f6b)
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1175213
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Reduce register accesses to SPI as it is dependent on
slow, variable SPI clock frequency.
Bug 1675619
Change-Id: I5d638b8f95d9207fbad1e30e21234fc7433e03b3
Reviewed-on: http://git-master/r/1009503
(cherry picked from commit 890a422a7b75507c33b53f1ca4c512f7911d61c4)
Reviewed-on: http://git-master/r/1174582
GVS: Gerrit_Virtual_Submit
SPI register access for T210 and earlier chips depend
on SPI clock frequency. Provided an option to set SPI
clock at max frequency for register access.
Bug 1675625
Change-Id: Ie52c83cd4602604822462d9f02ddf31ead83aafc
Reviewed-on: http://git-master/r/1009782
(cherry picked from commit a2ccd28f2850538064668568432fee5d70a22e82)
Reviewed-on: http://git-master/r/1174581
Remove IST(interrupt service thread) and move
that functionality to caller thread
Bug 1501764
Change-Id: Id310c75939be62a5121f2b2f68f14a146256b4aa
Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com>
Reviewed-on: http://git-master/r/399627
(cherry picked from commit f6366d4f846425bbfa0d8e919a974eff7429862f)
Reviewed-on: http://git-master/r/424075
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
By using dma_request_slave_channel_or_err(), the DMA slave ID can be
looked up from standard DT properties, and squirrelled away during
channel allocation. Hence, there's no need to use a custom DT property
to store the slave ID.
Change-Id: Id75c29442d39a7252eb591235a5b44511957afb7
Acked-by: Mark Brown <broonie@linaro.org>
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/389699
Bug 1454650
Enabling registration of spi1/2/3/5 in vcm30t124.
Change-Id: I42f1709e8551a4867864ace4b0bf576c9847d135
Signed-off-by: Yousuf A <yousufa@nvidia.com>
Reviewed-on: http://git-master/r/386683
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Tested-by: Sandeep Trasi <strasi@nvidia.com>
Bug 1454650
Change-Id: I579d36c0ae8203cc1e2119073718ecf206423fec
Reviewed-on: http://git-master/r/386682
Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com>
commit 61d1cf163c8653934cc8cd5d0b2a562d0990c265 upstream.
The 'ath79_spi_setup_cs' function initializes the chip
select line of a given SPI device in order to make sure
that the device is inactive.
If the SPI_CS_HIGH bit is set for a given device, it
means that the CS line of that device is active HIGH
so it must be set to LOW initially. In case of GPIO
CS lines, the 'ath79_spi_setup_cs' function does the
opposite of that due to the wrong GPIO flags.
Fix the code to use the correct GPIO flags.
Reported-by: Ronald Wahl <ronald.wahl@raritan.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Increasing transfer timeout from 1sec to 10sec as
timeout issue is happening during stress tests
sporadically, this timeout is root caused due to
delay in SPI ISR thread switch.
Bug 1451201
Change-Id: I1b500590875548b618139855cce8a9f4dcdac186
Reviewed-on: http://git-master/r/372903
commit 1f802f8249a0da536877842c43c7204064c4de8b upstream.
This reverts commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d.
It causes a NULL pointer dereference with drivers using the generic
spi_transfer_one_message(), which always calls
spi_finalize_current_message(), which zeroes master->cur_msg.
Drivers implementing transfer_one_message() theirselves must always call
spi_finalize_current_message(), even if the transfer failed:
* @transfer_one_message: the subsystem calls the driver to transfer a single
* message while queuing transfers that arrive in the meantime. When the
* driver is finished with this message, it must call
* spi_finalize_current_message() so the subsystem can issue the next
* transfer
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d upstream.
This corrects a problem in spi_pump_messages() that leads to an spi
message hanging forever when a call to transfer_one_message() fails.
This failure occurs in my MCP2210 driver when the cs_change bit is set
on the last transfer in a message, an operation which the hardware does
not support.
Rationale
Since the transfer_one_message() returns an int, we must presume that it
may fail. If transfer_one_message() should never fail, it should return
void. Thus, calls to transfer_one_message() should properly manage a
failure.
Fixes: ffbbdd21329f3 (spi: create a message queueing infrastructure)
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
commit 86b3bde003e6bf60ccb9c09b4115b8a2f533974c upstream.
The spi command must include the full message length including any
prepended writes, else transfers larger than 256 bytes will be
incomplete.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Acked-by: Florian Fainelli <florian@openwrt.org>
- Clear tx_status, rx_status variable for every
transfer
- Add log to check for any spurious interrutps
Bug 1445171
Change-Id: I48d7003ad0aa69b1d9275cddd1b060941489d556
Reviewed-on: http://git-master/r/361401
Terminate the dma when spi transaction times out.
Bug 1445171
Change-Id: If29c049ba37dcee9e5e1af213c47a0356f890961
Reviewed-on: http://git-master/r/360419
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Use PIO_EN bit to start the cpu based transfer
instead of DMA_EN bit
Bug 1445171
Change-Id: I7b28aa2066a71c4ffe02d0e61714e04cc54b03b5
Reviewed-on: http://git-master/r/360795
By default enable Little Endian byte format
Change-Id: I1fb3cc363aa708c34a5af3fe47b94ccf17590d40
Reviewed-on: http://git-master/r/351201
Get the controller data from child node (controller-data)
of spi client node.
spi client dt node should provide cdata entries as
below. Ex:
<spi-client>@<bus_num> {
controller-data {
nvidia,enable-hw-based-cs;
nvidia,cs-setup-clk-count = <10>;
nvidia,cs-hold-clk-count = <10>;
nvidia,rx-clk-tap-delay = <0>;
nvidia,tx-clk-tap-delay = <16>;
Change-Id: I3fc66d9131ebc70bda60c3d15a0b3fef532bc998
Reviewed-on: http://git-master/r/356941
Add DT support for spi controller data.
spi client dt node should add cdata entries
as below. Ex:
Bug 1422369
Change-Id: I8255643ef00fed486baf707edbf77b1b91586579
Reviewed-on: http://git-master/r/345354
Change-Id: Iaa3ecbf4877de835c8ca6b6b11948f4ad4772b5a
Signed-off-by: Edgardo Handal <ehandal@nvidia.com>
Reviewed-on: http://git-master/r/302956
added tegra_spi_cs_low() callback, called
from spi core for spi client users to set chip
select state(low/high).
Bug 1371286
Change-Id: Ifea4282a46f88c1744c44e6fd6dee7d98d72bc05
Reviewed-on: http://git-master/r/303904
spi_cs_low() callback is added for spi client
users to set chip select state(low/high).
prototype:
int spi_cs_low(struct spi_device *spi, bool state);
Bug 1371286
Change-Id: I4b2374202267338246262d902d6492d35dc755fb
Reviewed-on: http://git-master/r/303902
RX_TAP_DELAY should be set even if controller data(cdata)
as tap delay should be set depending on speed
Change-Id: Ia584be5c6bfd1e71166b4241ff127c22e1a7aeaf
Reviewed-on: http://git-master/r/301756
Set rx_tap_delay to 10 when speed > 35MHz and board
specific rx_clk_tap_delay data is zero.
Bug 1245131
Change-Id: Ie38469dac8d80737da5e45b9022ef1276b7fc883
Reviewed-on: http://git-master/r/273189
Instead on using rx_tap_delay value, tx_tap_delay value
is passed to SPI_RX_TAP_DELAY macro resulting in
undesired value in command2 reg.
Change-Id: I4592e98b240a7d23a81507bddf80e81008f73a7d
Reviewed-on: http://git-master/r/271475
So that the upstream common clk infrastructure can live side by side.
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: I0fe0ef8cd207d27b707821eed838c75b8ec04025
Removing old spi_tegra11.c driver and its instances
Change-Id: Id2302c484eeb780ae481e1edc9a25234a4fd77f2
Reviewed-on: http://git-master/r/251189
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
dev_info -> dev_dbg
Reviewed-on: http://git-master/r/199996
(cherry picked from commit 74d60d171164695d7bff372247bc2e2d4591ac02)
Change-Id: Ib5b57f09333810aab3dff1e6328b096a331d0722
Signed-off-by: Vijay Mali <vmali@nvidia.com>
Reviewed-on: http://git-master/r/214804
Reviewed-by: Scott Peterson <speterson@nvidia.com>
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
Add spi driver for NVIDIA's Tegra114 spi controller. This controller
is different than the older SoCs spi controller and there is a change
in register interface also.
This driver supports the:
- non DMA based transfer for smaller transfer i.e. less than FIFO depth.
- APB DMA based transfer for lager transfer i.e. more than FIFO depth.
- Runtime PM for clock gating.
- registration through DT and platform board files.
Change-Id: I30ab59a29d80b191843878994227945261ae8e17
Reviewed-on: http://git-master/r/202032
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
(cherry picked from commit 8b21af40fc68e280a1e7f0168928d1b97b61b6ba)
The clk_enable/clk_disable pair of APIs are replaced with
clk_prepare_enable and clk_disable_unprepare.
This is needed for the migration to common clk framework.
Bug 920915
Change-Id: Ieb05e10b35c6271c05f31a2651b7713b4722e236
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/172214
The function spi_tegra_resume has uninitialized variable "spi".
Initialized it to NULL to prevent build failure.
Bug 1179578
Change-Id: Iaf7b82438e473ca0a8792ce55571ce4baf1ef5fe
Signed-off-by: Kunal Agrawal <kunala@nvidia.com>
Reviewed-on: http://git-master/r/165857
Implemented change to set the MODE bits first and then
set CS and other bits of the command register.
Bug 1168218
Change-Id: I87bd94b8fac5821f11e575e53ee5694d6cad6d2c
Reviewed-on: http://git-master/r/161184
fix coverity issue.
Add Null check before dereferencing t->tx_buf and tspi->cur.
Bug 1046331
Change-Id: I2ff53b1945b4ee9a0d87e23816df7f2a3f1464fe
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/159542
Reviewed-by: Simone Willett <swillett@nvidia.com>
Rebase-Id: Rdfdd30e776c7196b41e28943b22d6a9b19a9d4b1
The value of SPI FIFO depth has been now set to
64.
Change-Id: I9c1ab1bddc4635d4ec1696f5763a5822d688ad71
Reviewed-on: http://git-master/r/146822
Rebase-Id: Rd3e4390529d444caf36124a7e5b0b08e0da2656b
Add support for HW based CS and add configuration
for CS setup time and hold time.
Reviewed-on: http://git-master/r/140617
(cherry picked from commit 90dcafb1414c8e3cb53bbdf518758210aa73f21b)
Change-Id: If746f74145d3cd0804bb8dccdd8f1d0e3c2ebf3b
Reviewed-on: http://git-master/r/143270
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R6cb1f9dbba6d78ca2cf4bc1917a1dad4b3b8b8ab
The spi tegra11 have the configuration for rx and tx
clock tap delay which need to be configure based on
the spi interface speed. It also depends on the platform
on which it is running.
Addign support for configuring this parameter through
platform file.
Reviewed-on: http://git-master/r/140615
(cherry picked from commit b7742640eb264677a47f9944b7711ddbf07bd723)
Change-Id: I4caa2a8405d56f9d85622f540fe6b36e49c2bf39
Reviewed-on: http://git-master/r/143269
Rebase-Id: R26ddc25bd03148f6d366f1e2e336eb91f40d619f
Change the clock source to reach the speed based on minimum power
and nearest require speed.
Reviewed-on: http://git-master/r/139733
(cherry picked from commit 28102ea1efe53fabf033a3ef31797923c2fed77c)
Change-Id: I4150e97fdccb140fbf5b401a68d2ca4e9802e1ac
Reviewed-on: http://git-master/r/143268
Rebase-Id: R28b87a14a2c9ff8a5b94b2cc438f3a4dc16982f5
Make sure that SCLK is enabled when spi trasnfer is in progress.
Reviewed-on: http://git-master/r/139732
(cherry picked from commit 4be79e0c084fb7b01a95fccb8d2144b7b9fc16d0)
Change-Id: Ie9f7d398c776d4b9d9e7cfb91bc0eec054183ce4
Reviewed-on: http://git-master/r/143267
Rebase-Id: R4e02d8fde5de9d45299afc41e7eda55e0ed44151
Tegra11 spi controller not require the Tx fifo
to be fill before enabling dma. Removing this checks.
Reviewed-on: http://git-master/r/135160
(cherry picked from commit c9f0787bd10a9dc17eeb6587a67493e0d042160a)
Change-Id: I366c191b9db6d713389307a1bc9904b2d8b0b064
Reviewed-on: http://git-master/r/143266
Rebase-Id: Re0d82749b714584d6ee14c567d37d91379dd133b
The speed was set for 12M. Now removing this fixed
speed and configuring based on client request.
Reviewed-on: http://git-master/r/135047
(cherry picked from commit d4b2de17c941d10c7d1297646c766bd261f82d0f)
Change-Id: I4977a85a0f0a7a9378406458b94f5d7d6f75e271
Reviewed-on: http://git-master/r/143265
Rebase-Id: Re7d5face4e1023f4493a45b05aacbbda53aa8b9f
Handling active HIGH CS propery as:
- Low in idle state.
- High during transfer.
Reviewed-on: http://git-master/r/134883
(cherry picked from commit 8a52f4b515e46f839bc4520c77db83b26cd6a7ca)
Change-Id: Ic90825031415f434bf5ebaf4c6d0aea4c3e932a2
Reviewed-on: http://git-master/r/143264
Rebase-Id: R16b990c93ad0ed51cb2302509142209bf6115444
Fix multiple issue in tegra11 driver which includes:
- Half duplex support.
- Proper selecting CS.
- Port fixes from T30 to T114 driver.
Reviewed-on: http://git-master/r/134607
Change-Id: Ica26924ebbf11c11307fc73ec3f8b2f607b2ff4a
Reviewed-on: http://git-master/r/143263
Rebase-Id: R3b4b9247edeb98b7618efa22f0bf535ec0719402
