path: root/drivers/spi
2011-08-02spi/pl022: remove function cannot exitLinus Walleij
The remove function in the PL022 driver cannot abort the remove function any way, so restructure the code so as not to make that assumption. Remove will now proceed no matter whether it can stop the transfer queue or not. Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-22Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/imx: add device tree probe support spi/imx: copy gpio number passed by platform data into driver private data spi/imx: use soc name in spi device type naming scheme spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4 spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macro spi/imx: do not make copy of spi_imx_devtype_data spi/dw: Add spi number into spi irq desc spi/tegra: Use engineering names in DT compatible property spi/fsl_spi: fix CPM spi driver mach-s3c2410: remove unused spi-gpio.h file spi: remove obsolete spi-s3c24xx-gpio driver mach-gta2: remove unused spi-gpio.h include mach-qt2410: convert to spi_gpio mach-jive: convert to spi_gpio spi/pxa2xx: Remove unavailable ssp_type from documentation spi/bfin_spi: uninline fat queue funcs spi/bfin_spi: constify pin array spi/bfin_spi: use structs for accessing hardware regs spi/topcliff-pch: Support new device ML7223 IOH ... Fix up trivial conflict in arch/arm/mach-ep93xx/Makefile
2011-07-14spi/imx: add device tree probe supportShawn Guo
It adds device tree probe support for spi-imx driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: copy gpio number passed by platform data into driver private dataShawn Guo
It copies gpio number passed via platform data embedded pointer into driver private data, so that we do not need to refer to this embedded pointer passed by platform data after probe function exits. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: use soc name in spi device type naming schemeShawn Guo
Software defined version number is not stable enough to be used in device type naming scheme. The patch changes it to use implicit soc name for spi device type definition. In this way, we can easily align the naming scheme with device tree binding, which comes later. It removes fifosize from spi_imx_data and adds devtype there, so that fifosize can be set in an inline function according to devtype. Also, cpu_is_mx can be replaced by inline functions checking devtype. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4Shawn Guo
The only difference between SPI_IMX_VER_0_7 and SPI_IMX_VER_0_4 is .config function. The patch uses cpu_is_mx35 (to be removed) as the temporary solution to consolidate functions spi_imx0_4_config and spi_imx0_7_config into mx31_config. As a result, type SPI_IMX_VER_0_7 can be merged into SPI_IMX_VER_0_4. It also renames function spi_imx0_4_reset to mx31_reset to keep consistency with other function naming. A couple of redundant macros, MX3_CSPISTAT and MX3_CSPISTAT_RR, together with the useless type SPI_IMX_VER_0_5 also get cleaned up. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macroShawn Guo
It's confusing to use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro, as it easily make people think of imx2 and imx3. It's better to use specific soc name just like what other SPI_IMX_VER do. For SPI_IMX_VER_2_3 case, it will be mx51. To distinguish it from CSPI on mx51, mx51_ecspi might be a good choice. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macroShawn Guo
SPI_IMX_VER_0_0 covers i.mx21 and i.mx27. It makes more sense to use mx21 rather than mx27 to name SPI_IMX_VER_0_0 function and macro, since i.mx21 comes out ealier than i.mx27. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: do not make copy of spi_imx_devtype_dataShawn Guo
spi_imx_devtype_data has already been driver private data. There is really no need to make a copy in spi_imx_data. Instead, a reference pointer works perfectly fine. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08spi/dw: Add spi number into spi irq descLiu, ShuoX
Signed-off-by: ShuoX Liu <shuox.liu@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-06spi/s3c64xx: Bug fix for SPI with different FIFO levelPadmavathi Venna
The existing macro fails for following scenarios. 1) S5P64X0 channel 1 2) S5PV210 channel 1 The FIFO data level supported in the above SoCs either 64 or 256 bytes depending on the channel. Because of this the TX_DONE is the 25 bit in the status register. The existing macro works for the following scenarios 1) S3C6410 all channels 2) S5PC100 all channels The FIFO data level supported in the above SoCs 64 bytes on all the channels. Because of this the TX_DONE is the 21 bit in the status register. So when we use the existing macro for the non-working SoCs it is not anding with the TX_DONE bit for transmission status check. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-05spi/tegra: Use engineering names in DT compatible propertyStephen Warren
Engineering names are more stable than marketing names. Hence, use them for Device Tree compatible properties instead. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-05spi/fsl_spi: fix CPM spi driverHolger Brunck
This patch fixes the freescale spi driver for CPM. Without this patch SPI on CPM failed because cpm_muram_alloc_fixed tries to allocate muram in an preserved area. The error reported was: mpc8xxx_spi f0011a80.spi: can't allocate spi parameter ram mpc8xxx_spi: probe of f0011a80.spi failed with error -12 Now the driver uses of_iomap to get access to this area similar to i2c driver driver in the i2c-cpm.c which has a similar device tree node. This is tested on a MPC8247 with CPM2. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-04spi: remove obsolete spi-s3c24xx-gpio driverPeter Korsgaard
It was equivalent to spi-gpio, and there's no longer any in-tree users of it, so get rid of it. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-17spi/bfin_spi: uninline fat queue funcsMike Frysinger
There's no need for these queue funcs to be inlined, so drop the markings. This shaves off a few hundred duplicated bytes. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-17spi/bfin_spi: constify pin arrayMike Frysinger
This array isn't written anywhere, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-17spi/bfin_spi: use structs for accessing hardware regsMike Frysinger
Rather than hardcoding the register sizes/offsets in this file, use the existing struct in the spi header for reading/writing the hardware. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-17Merge branch 'spi/merge' into spi/nextGrant Likely
2011-06-17spi/bfin_spi: fix handling of default bits per word settingMike Frysinger
The default bits per word setting should be 8 bits, but since most of our devices have been explicitly setting this up, we didn't notice when the default stopped working. At the moment, any default transfers without an explicit bit size setting error out with: bfin-spi bfin-spi.0: transfer: unsupported bits_per_word So in the transfer logic, have a bits_per_word setting of 0 fall into the 8 bit transfer logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16spi/topcliff-pch: Support new device ML7223 IOHTomoya MORINAGA
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub). The ML7223 IOH is for MP(Media Phone) use. The ML7223 is companion chip for Intel Atom E6xx series. The ML7223 is completely compatible for Intel EG20T PCH. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16spi/pl022: strengthen FIFO watermark level checksLinus Walleij
The platform configuration can select custom FIFO watermarks, but these may conflict the actual FIFO size of the PL022 variant if set too high. So strengthen the sanity checks to deny any conflicting settings. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16spi/pl022: support runtime PMRabin Vincent
Insert notifiers for the runtime PM API. With this the runtime PM layer kicks in to action where used. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Reviewed-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> [Rebased to Linux 3.0-rc3, edit description] Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16spi/pl022: initialize burstsize from FIFO trigger levelLinus Walleij
Configure the DMA burstsize from the FIFO trigger level supplied with the controller configuration data. This is based on a patch from Virupax, but I rewrote it differently. Reported-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-15gpio/tegra: Move Tegra gpio driver to drivers/gpioGrant Likely
As part of the gpio driver consolidation, this patch moves the Tegra driver into drivers/gpio Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-13spi-pl022: Add missing return value updateVirupax Sadashivpetimath
Return error on out of range cpsdvsr value. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-10spi: Convert uses of struct resource * to resource_size(ptr)Joe Perches
Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-09Merge branch 'ep93xx-dma' into spi/nextGrant Likely
2011-06-08spi/topcliff_pch: DMA supportTomoya MORINAGA
This patch enables this SPI driver works with DMA mode. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08spi/topcliff_pch: support new device ML7213 IOHTomoya MORINAGA
Support ML7213 device of OKI SEMICONDUCTOR. ML7213 is companion chip of Intel Atom E6xx series for IVI(In-Vehicle Infotainment). ML7213 is compatible for Intel EG20T PCH. v4: - Delete unrelated whitespace - Prevent device driver from accessing platform data - Add __devinit and __devexit - Save pdev->dev to pd_dev->dev.parent - Have own suspend/resume processing in platform_driver. - Care returned value in pch_spi_init - Change unregister order Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08spi/ep93xx: add DMA supportMika Westerberg
This patch adds DMA support for the EP93xx SPI driver. By default the DMA is not enabled but it can be enabled by setting ep93xx_spi_info.use_dma to true in board configuration file. Note that the SPI driver still uses PIO for small transfers (<= 8 bytes) for performance reasons. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2011-06-03spi/bitbang: initialize bits_per_word as specified by spi messageAnatolij Gustschin
SPI protocol drivers can submit messages specifying needed bits_per_word parameter for a message transfer. The bitbang driver currently ignores bits_per_word given by a singe message and always uses master's bits_per_word parameter. Only use master's bits_per_word when a message didn't specify needed bits_per_word for ongoing transfer. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-03spi/omap2: fix uninitialized variableGovindraj.R
fixes below compilation warning. The variable doesn't actual ever get used uninitialized, but that's no reason to be sloppy. drivers/spi/omap2_mcspi.c: In function 'omap2_mcspi_txrx_dma': drivers/spi/omap2_mcspi.c:301: warning: 'elements' may be used uninitialized in this function Signed-off-by: Govindraj.R <govindraj.raja@ti.com> [grant.likely: amended description] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-27spi/spi_bfin_sport: new driver for a SPI bus via the Blackfin SPORT peripheralCliff Cai
The Blackfin SPORT peripheral is a pretty flexible device. With enough coaching, we can make it generate SPI compatible waveforms. This is desirable as the SPORT can run at much higher clock frequencies than the dedicated on-chip SPI peripheral, and it can do full duplex DMA. It also opens up the possibility of multiple SPI buses in case someone wants to dedicate a whole bus to a specific part that does not play well with others. Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26spi/tle620x: add missing device_remove_file()Axel Lin
This patch includes below fixes: 1. Add missing device_remove_file for dev_attr_status_show in tle62x0_remove. 2. Fix tle62x0_probe error handling: Currently, if the error happens when ptr > 0, gpio_attrs[0] is not properly remove. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (57 commits) regulator: Fix 88pm8607.c printk format warning input: Add support for Qualcomm PMIC8XXX power key input: Add Qualcomm pm8xxx keypad controller driver mfd: Add omap-usbhs runtime PM support mfd: Fix ASIC3 SD Host Controller Configuration size mfd: Fix omap_usbhs_alloc_children error handling mfd: Fix omap usbhs crash when rmmoding ehci or ohci mfd: Add ASIC3 LED support leds: Add ASIC3 LED support mfd: Update twl4030-code maintainer e-mail address mfd: Correct the name and bitmask for ab8500-gpadc BTempPullUp mfd: Add manual ab8500-gpadc batt temp activation for AB8500 3.0 mfd: Provide ab8500-core enumerators for chip cuts mfd: Check twl4030-power remove script error condition after i2cwrite mfd: Fix twl6030 irq definitions mfd: Add phoenix lite (twl6025) support to twl6030 mfd: Avoid to use constraint name in 88pm860x regulator driver mfd: Remove checking on max8925 regulator[0] mfd: Remove unused parameter from 88pm860x API mfd: Avoid to allocate 88pm860x static platform data ...
2011-05-26Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe fails spi/spi_s3c24xx: Use spi_bitbang_stop instead of spi_unregister_master in s3c24xx_spi_remove spi/spi_nuc900: Use spi_bitbang_stop instead of spi_unregister_master in nuc900_spi_remove spi/spi_tegra: use spi_unregister_master() instead of spi_master_put() spi/spi_sh: use spi_unregister_master instead of spi_master_put in remove path spi: Use void pointers for data in simple SPI I/O operations spi/pl022: use cpu_relax in the busy loop spi/pl022: mark driver non-experimental spi/pl022: timeout on polled transfer v2 spi/dw_spi: improve the interrupt mode with the batch ops spi/dw_spi: change poll mode transfer from byte ops to batch ops spi/dw_spi: remove the un-necessary flush() spi/dw_spi: unify the low level read/write routines
2011-05-26mfd: Use mfd cell platform_data for timberdale cells platform bitsSamuel Ortiz
With the addition of a device platform mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-24coldfire_qspi compile fixSteven King
The m68k/m68knommu merge broke the qspi build. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-20spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe failsViresh Kumar
If pl022_dma_probe fails, we can try to transfer data in polling or interrupt mode. Also, set platform_info->enable_dma to 0, so that no other code tries to use dma. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_s3c24xx: Use spi_bitbang_stop instead of spi_unregister_master in ↵Axel Lin
s3c24xx_spi_remove Calling spi_bitbang_stop() will also destroy bitbang->workqueue, which is created by calling spi_bitbang_start() in s3c24xx_spi_probe(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_nuc900: Use spi_bitbang_stop instead of spi_unregister_master in ↵Axel Lin
nuc900_spi_remove Calling spi_bitbang_stop() will also destroy bitbang->workqueue, which is created by calling spi_bitbang_start() in nuc900_spi_probe(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_tegra: use spi_unregister_master() instead of spi_master_put()Axel Lin
spi_master_put() should only be used in error handling. Once spi_register_master() returns success, we should call spi_unregister_master() instead. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_sh: use spi_unregister_master instead of spi_master_put in remove pathAxel Lin
2011-05-20spi: Use void pointers for data in simple SPI I/O operationsMark Brown
Currently the simple SPI I/O operations all take pointers to u8 * buffers to operate on. This creates needless type compatibility issues and the underlying spi_transfer structure uses void pointers anyway so convert the API over to take void pointers too. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: use cpu_relax in the busy loopLinus Walleij
This relaxes the cpu in the polling busy-wait loop. Reported-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: mark driver non-experimentalLinus Walleij
This driver has no TODO, and is now used on several platforms: ARM, U300, Ux500, SPEAr and more. So drop the EXPERIMENTAL requirement. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: timeout on polled transfer v2Magnus Templing
This adds the missing handling of polling timeouts and deletes our last todo. Signed-off-by: Magnus Templing <magnus.templing@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> [Fixups from review by Wolfram Sang] Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20Merge commit 'v2.6.39' into spi/nextGrant Likely
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
