path: root/drivers/ssb/b43_pci_bridge.c
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-22ssb: b43-pci-bridge: Add new vendor for BCM4318Daniel Klaffenbach
Add new vendor for Broadcom 4318. Signed-off-by: Daniel Klaffenbach <danielklaffenbach@gmail.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27b43: Add BCM4307 PCI-IDMichael Buesch
00:09.0 Network controller [0280]: Broadcom Corporation BCM4307 Ethernet Controller [14e4:4306] (rev 03) Subsystem: Broadcom Corporation BCM4307 Ethernet Controller [14e4:4306] Flags: bus master, fast devsel, latency 32, IRQ 10 Memory at d7000000 (32-bit, non-prefetchable) [size=8K] Kernel driver in use: b43-pci-bridge Kernel modules: ssb Reported-by: yoann <yoann71@msn.com> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29b43/ssb: Add SPROM8 extraction and LP-PHY detectionMichael Buesch
This adds detection code for the LP-PHY and SPROM extraction code for version 8, which is needed by the LP-PHY and newer N-PHY. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29ssb/b43: add new N PHY deviceJohannes Berg
This is used on my macbook. N PHY, obviously nothing works yet, but we can detect the chip with this patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-03drivers/ssb/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28b43-ssb-bridge: Add PCI ID for BCM43XGMichael Buesch
This adds the PCI ID 0x4329 for the BCM43XG. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28ssb: Convert to use of the new SPROM structureLarry Finger
In disagreement with the SPROM specs, revision 3 devices appear to have moved the MAC address. Change ssb to handle the revision 4 SPROM, which is a different size. This change in size is handled by adding a new variable to the ssb_sprom struct and using it whenever possible. For those routines that do not have access to this structure, a 'u16 size' argument is added. The new PCI_ID for the BCM4328 is also added. Testing of the Revision 4 SPROM, which is used on the BCM4328, was done by Michael Gerdau <mgerdau@tiscali.de>. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[SSB]: Sparse fixes.Michael Buesch
This fixes all Sparse warnings in SSB. No semantics change. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
