* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Signed-off-by: Michael Buesch <m@bues.ch>
warning message
drivers/ssb/driver_chipcommon_pmu.c: In function ssb_pmu_resources_init
drivers/ssb/driver_chipcommon_pmu.c:420:15: warning: updown_tab_size may
be used uninitilized in this function.
updown_tab_size and depend_tab_size may not be set in the bus->chip_id
switch statement, so set to 0 by default to avoid using uninitialized
stack space.
Signed-off-by: Connor Hansen <cmdkhh@gmail.com>
Default min_msk on my 0x4312 is 0x80000CBB, not 0xCBB. Now we follow
specs and wl (noticed in MMIO dumps).
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Some of the N PHYs need a revision in the handling of the PMU.
Implement the "PMU LDO set voltage" and "PMU LDO PA ref enable"
functions, and use them during LP-PHY baseband init in b43.
Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com>
This adds support for the SSB PMU.
A PMU is found on Low-Power devices.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
