path: root/drivers/ssb/sprom.c
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-19SSB: Change fallback sprom to callback mechanism.Hauke Mehrtens
Some embedded devices like the Netgear WNDR3300 have two SSB based cards without an own sprom on the pci bus. We have to provide two different fallback sproms for these and this was not possible with the old solution. In the bcm47xx architecture the sprom data is stored in the nvram in the main flash storage. The architecture code will be able to fill the sprom with the stored data based on the bus where the device was found. The bcm63xx code should do the same thing as before, just using the new API. Acked-by: Michael Buesch <mb@bu3sch.de> Cc: netdev@vger.kernel.org Cc: linux-wireless@vger.kernel.org Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2362/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-28ssb: fix NULL ptr deref when pcihost_wrapper is usedChristoph Fritz
Ethernet driver b44 does register ssb by it's pcihost_wrapper and doesn't set ssb_chipcommon. A check on this value introduced with commit d53cdbb94a52a920d5420ed64d986c3523a56743 and ea2db495f92ad2cf3301623e60cb95b4062bc484 triggers: BUG: unable to handle kernel NULL pointer dereference at 00000010 IP: [<c1266c36>] ssb_is_sprom_available+0x16/0x30 Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-04-26ssb: do not read SPROM if it does not existJohn W. Linville
Attempting to read registers that don't exist on the SSB bus can cause hangs on some boxes. At least some b43 devices are 'in the wild' that don't have SPROMs at all. When the SSB bus support loads, it attempts to read these (non-existant) SPROMs and causes hard hangs on the box -- no console output, etc. This patch adds some intelligence to determine whether or not the SPROM is present before attempting to read it. This avoids those hard hangs on those devices with no SPROM attached to their SSB bus. The SSB-attached devices (e.g. b43, et al.) won't work, but at least the box will survive to test further patches. :-) Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Michael Buesch <mb@bu3sch.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-23ssb: Fix range check in sprom writeMichael Buesch
The range check in the sprom image parser hex2sprom() is broken. One sprom word is 4 hex characters. This fixes the check and also adds much better sanity checks to the code. We better make sure the image is OK by doing some sanity checks to avoid bricking the device by accident. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-23ssb: Fix SPROM writingMichael Buesch
The SPROM writing routines were broken since we rewrote the suspend handling on wireless devices, because SPROM writing depended on suspend. This patch changes it and freezes devices with the driver remove(), probe() callbacks instead. This also simplifies the whole logics a lot. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-05ssb: Add SPROM fallback supportMichael Buesch
This adds SSB functionality to register a fallback SPROM image from the architecture setup code. Weird architectures exist that have half-assed SSB devices without SPROM attached to their PCI busses. The architecture can register a fallback SPROM image that is used if no SPROM is found on the SSB device. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13ssb: Add SPROM/invariants support for PCMCIA devicesMichael Buesch
This adds support for reading/writing the SPROM invariants for PCMCIA based devices. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
