Now that the SPDX tag is in all comedi files, that identifies the
license in a specific and legally-defined manner. So the extra GPL text
wording can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/staging/comedi files files with the correct SPDX
license identifier based on the license text in the file itself. The
SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Use a local variable for the 'devpriv->ai_bounce_buffer' to shorten
the lines in pci9111_handle_fifo_half_full() and gix the checkpath.pl
issue about:
CHECK: Alignment should match open parenthesis
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
Rename the CamelCase parameters of plx9050_interrupt_control().
Reformat the multi-line comments in the kernel CodingStyle.
Remove the unnecessary CHANGELOG information, git provided this
better.
For aesthetics, define a macro to set the analog input range bits.
As suggested by checkpatch.pl, use the BIT macro to define the
register bits.
As preparation for removal of "comedi_fc.h", replace calls to the
`cfc_check_trigger_...` functions from "comedi_fc.h" with the
replacement `comedi_check_trigger_...` functions from "../comedidev.h"
and remove the inclusion of "comedi_fc.h".
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Include the new "../comedi_pci.h" header instead of <linux/pci.h> and
"../comedidev.h", which will now get included indirectly.
Blank lines are not needed before a close brace '}' or after an
open brace '{'. Also remove any multiple blank lines.
Fix the alignment issues in all the comedi drivers.
This driver uses an 8254 timer to generate the pacer clock used for analog
input data acquisition. Convert it to use the comedi_8254 module to provide
support for the 8254 timer.
Hardware errors should be reported with the COMEDI_CB_ERROR event. This event
will cause the async command to cancel. It's not necessary to also set the
COMEDI_CB_EOA event. Remove these events.
Most of the comedi drivers that provide readback for write only subdevices now
use the comedi core comedi_alloc_subdev_readback() helper to allocate the subdevice
'reaback' member instead of using some member in their private data. These drivers
also hook up the (*insn_read) callback to the comedi_readback_insn_read() helper to
provide the readback.
Have the core automatically hook up the (*insn_read) callback after allocating the
memory if the driver has not already hooked it up to a private function.
The comedi core now counts the number of samples added to the async buffer and
detects the end-of-scan and increments the comedi_async 'scans_done' counter.
Remove the private data member 'stop_counter' and use the 'scans_done' member
to detect the end-of-acquisition.
This fixes a possible interger overflow when calculating the value of the
'stop_counter' and removes the need to accumulate the 'total' number of
samples added to the async buffer in pci9111_handle_fifo_half_full().
Use the recently added sample manipulation helpers to remove the hardcoded
assumption of the sample size.
The SDF_READABLE flag is not necessary for digital output subdevices. For
consistency, remove this flag from the comedi drivers that set it.
Use comedi_buf_write_samples() to add the samples to the async buffer.
The number of bytes to add is determined automatically based on the
number of samples and the bytes_per_sample().
cfc_handle_events() is just a wrapper around comedi_handle_events().
Introduce a generic (*detach) function for comedi PCI drivers to handle
the boilerplate code needed to detach a PCI driver.
This function works similar to comedi_legacy_detach() where it will:
* free the dev->irq if it has been requested
* iounmap the dev->mmio addres if it has been ioremap'ed
The helper then calls comedi_pci_disable() to release the regions and
disable the PCI device.
Use the new helper directly for the (*detach) in the following cases:
* where comedi_pci_disable() is used directly for the (*detach)
* where the detach function is just boilerplate
Use the new helper in the (*detach) of the simpler PCI drivers. Call
the helper after disabling interrupts (reset) and before any additional
cleanup (kfree) to avoid any race conditions with the interrupt handler.
Use the new comedi_subdevice 'readback' member and the core provided
(*insn_read) for the readback of the analog output subdevice channels.
The functions pci9111_trigger_source_set(), pci9111_pretrigger_set(),
and pci9111_autoscan_set() are all used to select the A/D trigger type.
They all do a read/mask/set/write of the A/D Trigger Mode Control register.
Simplify the code by removing these helper functions and combining all
the trigger bits so that a single write can be used to set the register.
This define is only used in the pci_device_id table and doesn't add
any additional clarity to the code. Remove the define and just open
code the value.
This define is only used in a comedi_error() message. The addition of
the driver name to the message is not necessary. Remove the define.
For aesthetics, convert the comedi_error() into a dev_dbg().
Factor the fifo half-full handling out of the interrupt function to reduce
the indent level of the code.
Tidy up the factored out code.
Use the comedi_fc helper, cfc_check_trigger_arg_is(), to validate
the cmd->convert_arg for the convert_src TRIG_TIMER. Pass the local
variable to i8253_cascade_ns_to_timer() instead of the cmd argument.
This value is modified by that function to return the actual time
(in nanoseconds) that the timer will be programmed with based on the
calculated divisors. The cfc_check_trigger_arg_is() helper will then
validate that the cmd->convert_arg is that value and modify it if not.
Also use cfc_check_trigger_arg_is() to validate that the
cmd->scan_begin_arg is the calculate value and modify it if not.
This member of the private data is a copy of the cmd->chanlist_len. Use
that instead.
The comedi_cmd pointer is typically just called 'cmd'. Rename the local
variable in pci9111_ai_do_cmd().
This member of the private data can be determined by checking the
cmd->stop_src. Do that instead.
This step in the (*do_cmdtest) fixes the comedi_cmd arguments, usually
for TRIG_TIMER sources.
Tidy up this step to clarify the code and remove the extra local
variables. All the arguments are unsigned long so change the 'tmp'
local variable type and rename it for aesthetics.
This step of the (*do_cmdtest) verifies that the selected trigger sources
are mutually compatible.
For this driver the scan_begin_src must be TRIG_FOLLOW or the same source
as the convert_src.
Simplify the logic to clarify this.
For aesthetics, rename the local variable 'error' to 'err'. This is the
normal name for this local variable in (*do_cmdtest) functions.
Step 5 of the (*do_cmdtest) validates that the cmd->chanlist is compatible
with the hardware.
For aesthetics, factor out the step 5 code for the analog input async command
support. Tidy up the factored out code.
To minimize the noise, change the comedi_err(), which is a wrapper around
dev_err(), to dev_dbg().
Use the comedi_fc helper function to automatically call the subdevice
(*cancel) function when needed and call comedi_event().
In the Kconfig, COMEDI_ADL_PCI9111 already selects COMEDI_FC.
The trigger sources were already validataed in the (*do_cmdtest) before the
(*do_cmd) is called. Refactor the code in pci9111_ai_do_cmd() to use if/else
instead of the switch since the default cases can never be reached.
It's not necessary to clear the returned data pointer when an (*insn_read)
times out. For aesthetics, remove all of these in the drivers.
Have the comedi core display a standard dev_dbg() message when a timeout
occurs and remove all the driver specific messages.
Use comedi_timeout() to wait for the analog input end-of-conversion.
These messages are just added noise. Remove them.
Tidy up the format of the comedi_lrange table.
An irq is only needed for async command support, modify the attach of
the subdevices so that the command support is only hooked up if the irq
request was successful. Remove the then unnecessary sanity check in
The dev->irq passed to request_irq() will always be 0 when the auto_attach
function is called. The pcidev->irq should be used instead to get the correct
irq number.
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro
is not preferred.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Sample values in comedi are generally represented as unsigned values.
Change the element type of the `ai_bounce_buffer[]` member of `struct
pci9111_private_data` from `short` to `unsigned short` for consistency.
Also change the type of the `array` variable in `pci9111_ai_munge()`
from `short *` to `unsigned short *`.
Introduce a couple defines for the common 8254 oscillator base values
used in the comedi drivers and remove the custom defines and open
coded values.
Change the i8253_cascade_ns_to_timer_2div() calls in the drivers to
the more generic i8253_cascade_ns_to_timer(). They are identical due
to the #define in the 8253.h header.
Remove the extra mask by TRIG_ROUND_MASK of the 'round_mode' parameter
to i8253_cascade_ns_to_timer(). That function already handles the mask.
Tidy up all the calls to i8253_cascade_ns_to_timer().
Use comedi_dio_update_state() to handle the boilerplate code to update
the subdevice s->state for simple cases where the hardware is updated
when any channel is modified.
Also, fix a bug in the amplc_pc263 and amplc_pci263 drivers where the
current state is not returned in data[1].
comedidev.h is the main kernel header for comedi. Every comedi
driver includes this header which then includes a number of
<linux/*> headers. All the drivers need <linux/module.h> and some
of them need <linux/delay.h>. The rest are not needed by any of
the drivers.
Remove all the includes in comedidev.h except for <linux/dma-mapping.h>,
which is needed to pick up the enum dma_data_direction for the
comedi_subdevice definition, and "comedi.h", which is the uapi
header for comedi.
Add <linux/module.h> to all the comedi drivers and <linux/delay.h>
to the couple that need it.
Use the helper function to allocate memory and set the comedi_device
private data pointer.
This removes the dependency on slab.h from most of the drivers so
remove the global #include in comedidev.h and the local #include
in some of the drivers.
Addresses change...
Remove the paragraph with the FSF address from all the comedi source
files.
Also, remove the paragraph about the finding the complete GPL in the
COPYING file since it's unnecessary.
Use the PLX 9052 register defines in plx9052.h instead of duplicating
the defines locally in this driver.
