Now that the SPDX tag is in all comedi files, that identifies the
license in a specific and legally-defined manner. So the extra GPL text
wording can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/staging/comedi files files with the correct SPDX
license identifier based on the license text in the file itself. The
SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Change the MODULE_DESCRIPTION to something more usefull than the
generic "Comedi low-level driver".
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
The external pin TGIN can be used to start and/or stop the analog input
command. Currently the driver only supports negative edge polarity for
this signal.
Add support to allow the user to select positive edge polarity using
the CR_INVERT flag.
Clarify the documentation in the comedi driver comment block to
better explain the cmd triggert.
Add a comment to step 2b of the (*do_cmdtest) to clarify the
trigger check.
The waveform analog outputs on the 'ao' boards are not currently
supported. Modify the comment about the analog output range on
these boards so that the information is saved but fixes the
checkpatch.pl issues:
WARNING: Block comments use a trailing */ on a separate line
Move the comment so it's grouped with the comedi_lrange info.
These comments are just extra cruft. Remove them to fix the
WARNING: line over 80 characters
Fix the checkpatch.pl issues:
These comments are just added cruft. Remove them.
This step of the (*do_cmdtest) fixes the timing arguments when the
cmd->convert_src is TRIG_TIMER. The code is compact but it's a bit
hard to understand the "burst mode" vs. "non burst mode" (i.e. paced)
timing.
Clarify the fixup by splitting it into separate functions to check
the arguments based on if the command is doing 'paced' or 'burst'
timing. Add some comments to clarify the fixups.
This also fixes a minor issue with the 'burst' timing. When the
cmd->scan_begin_src is also TRIG_TIMER the pacer clock is used to
start each scan. The cmd->scan_begin_arg specifies the scan time.
The minimum (not maximum) value for this time must be large enough
for the 'burst' conversion time to sample all the channels.
The current 'max' check limits the scan time to the minimum time
(i.e. the max conversion speed).
The comments about the members of the private data are not really
necessary and removing them fixes a couple checkpatch.pl issues.
For aesthetics, move this information into the comedi comment block.
Fix the checkpatch.pl issue:
CHECK: Prefer kernel type 'u16' over 'uint16_t'
Change the type to 'unsigned short' as that is more typical in comedi
drivers.
Use sizeof(*p) instead of sizeof(type) when allocation the buffer.
Also fix the checkpatch.pl issue:
Tidy up these multi-line comments to fix the checkpatch.pl issues:
WARNING: Block comments use * on subsequent lines
The comedi_device spinlock is used to protect the indirect addressing
selected by the DAS1800_SELECT register. It also prevents races between
the interrupt handler and the analog input (*poll).
Update the comments to make this clear.
Absorb this helper function into the analog input (*do_cmd).
For aesthetics, convert the switch code into if/else.
Use the helper function to handle the busywaiting for the analog
input conversion to complete.
Refactor this function so it can be used to program the chanlist for
the analog input (*do_cmd) and (*insn_read).
Rename the function so it has namespace associated with the driver.
Introduce a helper function for the common code needed to set the
control c register bits for a channel specification.
Use the core provided readback support to allow reading back the last
value written to the analog output channels.
This value is compared against the unsigned int cmd->convert_arg to
check the minimum value (max speed) for the analog input conversion
timing.
For aesthetics, change the type to match the cmd->convert_arg type.
The "hc" type boards have 64 analog input channels with a 64
entry queue. All the others have 16 channels and a 256 entry
queue.
EXP-1800 expansion boards can be used to increase the number
of analog inputs on the 16 channel boards, 16 channels per
EXP-1800, for a total of 256 channels.
Remove the 'qram_len' member of the boardinfo and use the
'id' member to determine the number of channels.
Add a comment about the number of channels and the unclear
mapping of the channels when EXP-1800 boards are used.
The boards supported by this driver have analog inputs with gains
of 1, 10, 50, and 250 ("01" type) or 1, 2, 4, and 8 ("02" type).
Unfortunately, the "01"/"02" type cannot be determined from the
boards id or by probing.
Replace the 'range_ai' member of the boardinfo with a bit-field flag,
'is_01_series' and only set it for the "01" type boards. Remove the
unnecessary initialization for the "02" type boards.
For aesthetics, rename the comedi_lrange arrays and document the gain.
The "da" and "hc" type boards have normal analog outputs. The
"ao" type boards have move advanced analog outputs with waveform
generation capability.
Remove the 'ao_ability' member of the boardinfo and use the
'id' member to determine if the subdevice should be initialized.
The "ao" waveform analog outputs are not currently supported.
For aesthetics, add an else if for the initialization of the
subdevice for these boards.
The "st-da" board types have 4 analog output channels. All other
board types, with analog outputs, only have 2 channels.
Remove the 'ao_n_chan' member of the boardinfo and use the
'id' member to determine the subdevice 'n_chan'.
The (*insn_write) functions are supposed to write insn->n values to the
specified channel. Tidy up this function and make it work like the core
expects.
The current code used to initialize the analog outputs only sets the
last channel. The other channels will be reloaded with the last value
that was written to them.
Move the code into the subdevice init and properly initialize all the
channels to 0V.
The "hc" type boards have 8 digtial outputs. All other board
types have 4.
Remove the 'do_n_chan' member of the boardinfo and use the
The "hr" type boards have 16-bit analog inputs and outputs.
All other board types have 12-bit.
Remove the 'resolution' member of the boardinfo and use the
'id' member to determine the subdevices 'maxdata'.
The analog outputs expect 2's complement data. For aesthetics, use
the helper function to handle the munging instead of depending on
the boardinfo 'resolution'.
The "hc" type boards do not support common mode analog inputs
all the other board types do.
Remove the unnecessary member from the boardinfo and use the
'id' member to determine if the SDF_COMMON flag should be set
for the subdevice.
Refactor das1800_probe() to return an errno instead of the boardinfo
pointer.
Add the board 'id' to the boardinfo to tidy up this function to clarify
the sanity check when the user provided a board name when trying to
attach to the driver.
Currently when this function probes for a boardinfo based on the board
id it returns the wrong boardinfo for the "st-da" and "hr-da" types.
This causes the analog input subdevice for those boards to not be
available. Fix the probe so that a proper boardinfo is used.
For aesthetics, add some whitespace to the boardinfo array.
For aesthetics, add some whitespace to the subdevice init and rename
the subdevice support functions.
the (*insn_write) function.
the (*insn_bits) function.
The "da" type boards all have 4 analog outputs. Fix the boardinfo
for the das-1801st-da.
The analog input samples are 2's complement when the inputs are configured
for bipolar ranges and offset binary when they are unipolar ranges. For
bipolar ranges the sample needs to be munged to the offset binary format
that comedi uses.
The (*insn_read) does the munging correctly but the async command support
incorrectly munges the data for both bipolar and unipolar ranges when
reading the remaining samples from the fifo in das1800_handle_fifo_not_empty().
Add a (*munge) function to the analog input subdevice so that the samples
are correctly munged when they are added to the async buffer by
comedi_buf_write_samples(). Add a flag to the private data and set it in
the (*do_cmd) so that the munging is only done for bipolar ranges.
Clarify the code by using the core helper functions to check the range and
do the munging.
DMA is optional with this driver. If it was not enabled the devpriv->dma
pointer will be NULL.
Fix the possible NULL pointer dereference when trying to disable the DMA
channels in das1800_ai_cancel() and tidy up the comments to fix the
It's probably harmless in das1800_ai_setup_dma() because the 'desc' pointer
will not be used if DMA is disabled but fix it there also.
Fixes: 99dfc3357e98 ("staging: comedi: das1800: remove depends on ISA_DMA_API limitation")
Cc: <stable@vger.kernel.org> # 4.0+
Commit 06ad6bd8 "staging: comedi: das1800: cleanup das1800_probe()"
Accidently removed the 'break' statement for case 0x8 of the switch.
Add it back.
Reported-by: coverity (CID 1309550)
For aesthetics, rename the 'thisboard' variables to 'board'. That name
is more commonly used for the boardinfo pointer in comedi drivers.
Make this function return a pointer to the boardinfo instead of an index.
Since it's not typical, add a comment to clarify why this legacy driver
does a probe.
As preparation for removal of "comedi_fc.h", replace calls to the
`cfc_check_trigger_...` functions from "comedi_fc.h" with the
replacement `comedi_check_trigger_...` functions from "../comedidev.h"
and remove the inclusion of "comedi_fc.h".
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Blank lines are not needed before a close brace '}' or after an
open brace '{'. Also remove any multiple blank lines.
This patch removes a if condition which has a semicolon
after it. As the conditional check is redundant, the comment
before it is also changed. The following
coccinelle script was used to detect the pattern of a
semicolon after if.
@r1@
position p;
if (...);@p
@script:python@
p0 << r1.p;
// Emacs org-mode output
cocci.print_main("", p0)
cocci.print_secs("", p0)
Signed-off-by: Navya Sri Nizamkari <navyasri.tech@gmail.com>
This driver uses an 8254 timer to generate the pacer clock used for analog
input data conversion. Convert it to use the comedi_8254 module to provide
support for the 8254 timer.
Tidy up the (*do_cmdtest) validation of the timer arguments.
Absorb the converted das1800_setup_counters() code into the (*do_cmd).
Hardware errors should be reported with the COMEDI_CB_ERROR event. This event
will cause the async command to cancel. It's not necessary to also set the
COMEDI_CB_EOA event. Remove these events.
