commit b8336be66dec06bef518030a0df9847122053ec5 upstream.
The interrupt handler `dt282x_interrupt()` causes a null pointer
dereference for those supported boards that have no analog output
support. For these boards, `dev->write_subdev` will be `NULL` and
therefore the `s_ao` subdevice pointer variable will be `NULL`. In that
case, the following call near the end of the interrupt handler results
in a null pointer dereference:
comedi_handle_events(dev, s_ao);
Fix it by only calling the above function if `s_ao` is valid.
(There are other uses of `s_ao` by the interrupt handler that may or may
not be reached depending on values of hardware registers. Trust that
they are reliable for now.)
Note:
commit 4f6f009b204f ("staging: comedi: dt282x: use comedi_handle_events()")
propagates an earlier error from
commit f21c74fa4cfe ("staging: comedi: dt282x: use cfc_handle_events()").
Fixes: 4f6f009b204f ("staging: comedi: dt282x: use comedi_handle_events()")
Cc: <stable@vger.kernel.org> # v3.19+
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Now that the SPDX tag is in all comedi files, that identifies the
license in a specific and legally-defined manner. So the extra GPL text
wording can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/staging/comedi files files with the correct SPDX
license identifier based on the license text in the file itself. The
SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Here, dev->irq is not assigned with irq. comedi_legacy_detach()
is using dev->irq for release irq and dt282x_attach() is using dev->irq
for initialize comedi_subdevice.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
The "Configuration options" are documented in the comedi driver comment
block. Remove the redundant comment before the drivers (*attach) function.
The 'convert_arg' sets the acquisition timing of the analog input command.
The maximum speed (the minimum timing) depends on the board 'ai_speed' which
if always >= 4000. Remove the redundant 'min' check,
Define the pacer clock limits and remove the magic numbers. Refactor
the code to use a common path to return the actual 'ns' timing and
the timer divisor value.
Arnd Bergmann pointed out that gcc-6 warns about passing negative signed
integer into swab16() due to the macro expansion of 'outw'.
It appears that the register map constants are causing the warnings.
Actually, it might just be the (1 << 15) ones...
Convert all the constants as suggested by checkpatch.pl:
CHECK: Prefer using the BIT macro
The BIT() macro will make all the constants explicitly 'unsigned', which
helps to avoid the warning.
Fix the, unsused, DT2821_CHANCSR_PRESLA() macro. The "Present List
Address" (PRESLA) bits in the CHANCSR register are read only. This
define was meant to extract the bits from the read value.
Tested-by: Arnd Bergmann <arnd@arndb.de>
The macro DIV_ROUND_UP performs the computation
(((n) + (d) - 1) /(d)). It clarifies the divisor calculations.
This was done using the coccinelle script:
expression e1;
expression e2;
- ((e1) + e2 - 1) / (e2)
+ DIV_ROUND_UP(e1,e2)
- ((e1) + (e2 - 1)) / (e2)
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
The kernel.h macro DIV_ROUND_CLOSEST performs the computation
`(x +d/2)/d` but is perhaps more readable.
The Coccinelle script used is as follows:
// <smpl>
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
// </smpl>
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
As preparation for removal of "comedi_fc.h", replace calls to the
`cfc_check_trigger_...` functions from "comedi_fc.h" with the
replacement `comedi_check_trigger_...` functions from "../comedidev.h"
and remove the inclusion of "comedi_fc.h".
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Blank lines are not needed before a close brace '}' or after an
open brace '{'. Also remove any multiple blank lines.
Fix the alignment issues in all the comedi drivers.
The if and the else branch code are identical - so the condition has no
effect on the effective code - this patch removes the condition and the
duplicated code.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Use the new comedi_isadma module to provide the ISA DMA support. This removes
all the ISA_DMA_API code from this driver and allows the driver to be used on
platforms that don't support the ISA_DMA_API.
According to Documentation/DMA-ISA-LPC.txt, the DMA lock needs to be
claimed before using any of the ISA DMA routines. Introduce a helper
function to disable the ISA DMA controller and add the necessary
locking calls.
Introduce a helper function to program the ISA DMA controller. Program
the ISA DMA as described in Documentation/DMA-ISA-LPC.txt.
Use dma_{alloc,free}_coherent() to allocate and free the DMA buffers.
This removes the dependancy on VIRT_TO_BUS.
For aesthetics, introduce a struct to hold the DMA descriptor data.
The IRA and DMA are optional with this driver but both are required to
support async commands. Introduce a helper function to request the IRQ
and DMA channel and allocate the buffers. Don't fail the driver attach
if the user passed an invalid IRQ or DMA channel or they cannot be
requested.
Rewrite the "Devices:" line in the comedi "driver" comment to conform to
the usual comedi format for this line. The line should be a
comma-separated list where the first item is in the following format:
[Manufacturer] BOARD-NAME (comedi-board-name)
The "[Manufacturer]" and/or "(comedi-board-name)" parts may be omitted
from following items, in which case the parts from the preceding item
are used. The "Devices:" line may be continued continued over several
lines by using one or more spaces at the start of each continuation line
(not counting the space after the "*" in the block comment).
Most of the comedi drivers that provide readback for write only subdevices now
use the comedi core comedi_alloc_subdev_readback() helper to allocate the subdevice
'reaback' member instead of using some member in their private data. These drivers
also hook up the (*insn_read) callback to the comedi_readback_insn_read() helper to
provide the readback.
Have the core automatically hook up the (*insn_read) callback after allocating the
memory if the driver has not already hooked it up to a private function.
This inline helper function has been replaced with comedi_bytes_per_sample().
The same commit (bf33eb4b4f57) introduced a couple other related helper
functions a manipulate the sample size.
Use the new helper functions to remove the use of 'bytes_per_sample()' and
remove it.
Use comedi_buf_write_samples() to add the samples to the async buffer.
That function will determining the number of bytes to add based on the
bytes_per_sample().
Introduce a helper function to read the analog output samples from the
async buffer and prep the DMA.
Use comedi_buf_read_samples() to read the analog output samples from
the async buffer.
cfc_handle_events() is just a wrapper around comedi_handle_events().
This driver currently allows a cmd->stop_src == TRIG_COUNT with a cmd->stop_arg
of 0 for both the analog input and output async commands. The (*do_cmd) for
both subdevices sets up and starts the command without handling the "empty
acquisition". This results in the interrupt functions trying to transfer 0 data
samples.
Validate that the cmd->stop_arg is >= 1 in the (*do_cmdtest) to prevent the
"empty acquisition".
The `comedi_board(dev)` inline function calls just return
`dev->board_ptr`. Expand the inline function calls.
Replace use of the `TRIG_ROUND_...` macros with the new names
`CMDF_ROUND_...`. The numeric values are unchanged.
Use the new comedi_subdevice 'readback' member and the core provided
(*insn_read) for the readback of the analog output subdevice channels.
The comedi_error() function is just a wrapper around dev_err() that adds
the dev->driver->driver_name prefix to the message and a terminating
new-line character. The addition of the driver_name is just added noise
and some of the users of comedi_error() add unnecessary additional new-line
characters.
Use dev_err() directly instead of comedi_error() to avoid any confusion
and so that all the comedi generated kernel messages have the same format.
Fix checkpatch.pl warning:
WARNING: else is not generally useful after a break or return
The DT2821 series board have jumpers that set the output range for
the two Analog Output channels. The range_table for the Analog Output
subdevice provides all possible ranges to the user. When a unipolar
range is selected the board expects the data to be in a straight
binary format. When a bipolar range is select the data should be in
two's complement format.
Currently, the user passes some configuration options when attaching
to the driver to select the data format for each channel. If the
user does not pass the config options, the data format is assumed to
be straight binary.
The Analog Output subdevice now has a range_table that provides the
user will all possible ranges. Use the range information to determine
if the data values need to be munged into two's complememnt values
and deprecate the config options.
The direction of the 16 DIO channels is controlled with two bits in the
DACSR register. The HBOE bit controls the direction of channels 15-8 and
the LBOE bit channels 7-0.
The DACSR register is also used to control the Analog Output async command
support. Currently, starting or canceling an Analog Output command would
also reset the DIO directions so that all channels were inputs.
Fix the driver so that the DIO direction is not changed when starting or
canceling an Analog Output async command.
For aesthetics, rename the register map defines so that the bit defines
are associated with the registers. Also, convert all the bit defines into
bit-shifts to make them clear.
Remove all the verbose comments. All the registers and bits are named
according to the User Manual for the DT2821 Series, Document UM-05073-G.
That manual can be checked if necessary for the verbose information.
A common timer is used for analog input and output async commands. The
(*do_cmdtest) for both subdevices calculates the divisor as part of
Step 4 when validating the trigger arguments. The divisor is calculated
again in the (*do_cmd) for both subdevices in order to set the timer.
The comedi core only calls the (*do_cmd) is called after a successful
(*do_cmdtest). Save the divisor from the (*do_cmdtest) in the private
data and use that value in the (*do_cmd).
The extra check of the cmd->convert_arg in dt282x_ai_cmd() is not necessary.
The convert_arg was already checked in the (*do_cmdtest), and it's not used
in the (*do_cmd).
Tidy up dt282x_ns_to_timer(), the parameters are all unsigned int's and the
mask of the 'flags' can be moved here to simplify the callers.
Change the MODULE_DESCRIPTION to something more useful than the
generic "Comedi low-level driver".
Tidy up the multi-line comments at the beginning of the file to follow
the CodingStyle.
The DT2821 series boards do not have programmable analog output ranges.
The range is set, per-channel, with jumpers on the board.
Currently the user has to pass some configuration options when attaching
to the driver in order to set the range for each channel. If they do not
pass the range options they will default to 0. If they pass an invalid
range option they will also default to 0. The 0 range option is bipolar
10V. If the user passes a range option that does not match the hardware
setting it doesn't cause any problems in the driver it just causes the
user space comedilib library to incorrectly convert the hardware values
to physical values.
Make the attach a bit simpler by deprecating these options and providing
a range table with all the valid ranges for the analog outputs. The user
can then select the correct range when they use the comedilib functions.
Most of the boards supported by this driver can do either single-ended or
differential Analog Input but there are a couple that can only do one or
the other. On the boards that can do both the type of input is set with
The 'it->options[4]' passed by the user during the board (*attach) is used
to determine how the Analog Inputs are configured. This is used to set
the subdevice flags and number of channels correctly.
Fix the check of this option so that it only applies when the board can
actually do differential input. Also, default to differential inputs if
that is the only mode the board supports.
For aesthetics, add some whitespace to the Analog Input subdevice init.
For aesthetics, add some whitespace to the Analog Output subdevice init.
This enum is used to index the 'options' values that are passed
by the user attaches to the driver. These options are identified
in the comedi comment block.
For aesthetics, remove the enum and just open code the index values.
Refactor the Analog Input subdevice init so that the it->options[4],
indicating differential inputs, does not have to be checked multiple
times.
For aesthetics, factor the code that initializes the then checks to see
if it is actually a DT2821 series board out of the (*attach).
For clarity, remove the MASK and VAL defines used to check the board and
jsut open code the values.
The comedi core expects the (*insn_read) functions to return 'insn->n'
samples. Fix this function to work like the core expects.
For aesthetics, rename the private data 'ao' member to clarify its
use. Also, remove the unnecessary comment.
The main interrupt handler already has the comedi_subdevice pointer
needed in this function. Pass that subdevice pointer so that it does
not need to be fetched as a local variable.
Tidy up the function a bit.
The comedi core sanity checks that the subdevice has a buffer allocated
before allowing an async command to start. The helper functions in comedi_buf
will also sanity check the buffer as a side effect of the 'alloc' helpers
with reading or writing data for the buffer.
Remove the unnecessary sanity checks in the ai/ao dma interrupt handlers.
This will allow the handlers to disable the dma and then fail when they
try to read/write the buffer. Currently dma is left enabled due to the
sanity checks.
For aesthetics, add some whitespace to the Digital I/O subdevice init.
Rename these functions so they have namespace associated with the driver.
