It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/staging/comedi files files with the correct SPDX
license identifier based on the license text in the file itself. The
SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Rewrite the "Devices:" line in the comedi "driver" comment to conform to
the usual comedi format for this line. The line should be a
comma-separated list where the first item is in the following format:
[Manufacturer] BOARD-NAME (comedi-board-name)
The "[Manufacturer]" and/or "(comedi-board-name)" parts may be omitted
from following items, in which case the parts from the preceding item
are used. The "Devices:" line may be continued continued over several
lines by using one or more spaces at the start of each continuation line
(not counting the space after the "*" in the block comment).
Group boards from the same manufacturer together on the "Devices:" line
to avoid repeating the "[Manufacturer]" tag unnecessarily.
Also fix a couple of typos in the board names on the "Devices:" line:
"p16r16dio" was used twice, but one of them should be "p8r8dio";
"prearl-mm-p" should be "pearl-mm-p".
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
The `comedi_board(dev)` inline function calls just return
`dev->board_ptr`. Expand the inline function calls.
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Fix the checkpatch.pl error:
ERROR: "(foo*)" should be "(foo *)"
The Diamond Systems IR104-PBF board is a PC/104 module with 20
optoisolated inputs and 20 relay outputs.
This board can be supported by the pcl730 driver.
Cc: Greg Kroah-Hartman <gregk@linuxfoundation.org>
The Diamond Systems OPMM-1616-XT board is a PC/104 module with 16
optoisolated inputs and 16 relay outputs.
The PEARL-MM-P board is a PC/104 module with 16 relay outputs.
Both of these boards can be supported by the pcl730 driver.
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
These conditions are never true because they use bitwise AND instead of
logical ands.
Fixes: b3ff824a81e8 ('staging: comedi: drivers: use comedi_dio_update_state() for complex cases')
Acked-by: Ian Abbott <abbotti@mev.co.uk>
Use comedi_dio_update_state() to handle the boilerplate code to update
the subdevice s->state for more complex cases where the hardware is only
updated based on the 'mask' of the channels that are modified.
All the ioport resources are managed by the comedi core. None of
the drivers depend on <linux/ioport.h>. Remove the includes.
comedidev.h is the main kernel header for comedi. Every comedi
driver includes this header which then includes a number of
<linux/*> headers. All the drivers need <linux/module.h> and some
of them need <linux/delay.h>. The rest are not needed by any of
the drivers.
Remove all the includes in comedidev.h except for <linux/dma-mapping.h>,
which is needed to pick up the enum dma_data_direction for the
comedi_subdevice definition, and "comedi.h", which is the uapi
header for comedi.
Add <linux/module.h> to all the comedi drivers and <linux/delay.h>
to the couple that need it.
This driver supports a number of simple digital i/o boards with
slight variations in the register map. Clean up the comment about
the register map to better document the driver.
Remove the #define's used for the registers since thet don't apply
to all the board variations supported by the driver.
The ICP P8R8-DIO ISA boards can be supported by this driver. This board
has 8 isolated digital outputs and 8 isolated digital outputs.
Add support for this board to the pcl730 driver.
The ACL-7225b and P16R16R-DIO ISA boards can be supported by this driver.
These board have 16 isolated digital outputs and 16 isolated digital
outputs.
Add support for these boards to the pcl730 driver and remove the
standalone acl7225b driver.
The PCL-734 ISA board can be supported by this driver. This board has
32 isolated digital outputs.
Add support for the PCL-734 board to the pcl730 driver and remove it
from the poc driver.
The PCL-733 ISA board can be supported by this driver. This board has
32 isolated digital inputs.
Add support for the PCL-733 board to the pcl730 driver and remove it
The PCL-725 ISA board can be supported by this driver. This board has
8 isolated digital inputs and 8 isolated digital outputs.
Add support for the PCL-725 board to the pcl730 driver and remove the
standalone pcl725 driver.
The PCM-3730 PC/104 board has the same register i/o map as the PCL-730
ISA board. The only difference is the number of isolated digital input
and output channels.
Add support for the PCM-3770 board to the pcl730 driver and remove the
standalone pcm3730 driver.
Tidy up the multi-line comment at the beginning of the file to
follow the CodingStyle.
Rename the boardinfo table so it has namespace associated with the
driver.
For aesthetic reasons, add some whitespace to the subdevice init
and reorder it a bit.
Remove the blank line printk at the end of the attach.
For aesthetic reasons, rename the function.
Use a local variable for the 'reg' offset that is stored in the
comedi_subdevice 'private' pointer to minimize the number of casts.
Also, add local variables for the 'mask' and 'bits'.
The outputs only need to be updated if the 'mask' indicates that the
'bits' are changing. Move the update code into the main 'if (mask)'
block.
Convert the boardinfo declaration to C99 format and move it near the
struct definition.
Since the *_SIZE defines are only used in the boardinfo, remove them
and just open code the values in the boardinfo.
Use the new comedi_legacy_detach() helper in the (*detach) to release
the I/O region requested by these drivers.
Since the (*detach) for these drivers only releases the region, remove
the private (*detach) functions and use comedi_legacy_detach() directly
for the (*detach).
Use comedi_request_region() to request the I/O region used by this
driver.
Remove the noise when the board is first attached as well as the
error message when the request_region() fails, comedi_request_reqion()
will output the error message if necessary.
Also, remove the unnecessary 'dev->irq = 0'. This driver does not
use interrupts and the comedi core has already cleared this variable.
This legacy driver does no additional probing so the dev->board_name
will already be properly initialized by the comedi core before calling
the (*attach) function.
Remove the unnecessary initialization of dev->board_name and use it
when requesting the resources instead of the open-coded strings.
Convert the comedi_subdevice access from pointer math to array
access.
The comedi_subdevice 'insn_bits' functions return the number of data
elements used to perform the command. Most of the insn_bits functions
return an open coded '2' to indicate this. The same value is available
as 'insn->n'. Return that instead to better indicate what the return
means.
Cc: Frank Mori Hess <fmhess@users.sourceforge.net>
The comedi core does the sanity check to make sure that the data length
the INSN_BITS instruction is 2. There is no need for the drivers to do
this check. Remove all the sanity checks in the drivers.
comedi_alloc_subdevices can fail with -EINVAL or -ENOMEM. When it
does fail make sure to pass the proper error code back.
Cc: Ian Abbott <abbott@mev.co.uk>
Move the inline alloc_subdevices() function from comedidev.h
to drivers.c and rename it to comedi_alloc_subdevices(). The
function is large enough to warrant being an exported symbol
rather than being an inline in every driver.
The 'this_board' macro depends on having a local variable with
a magic name. The CodingStyle document suggests not doing this
to avoid confusion. Remove the macro and use the comedi_board()
inline helper to get the dev->board_ptr information.
Cc: Mori Hess <fmhess@users.sourceforge.net>
1. Change the return type from int to void
All the detach functions, except for the comedi usb drivers, simply
return success (0). Plus, the return code is never checked in the
comedi core.
The comedi usb drivers do return error codes but the conditions can
never happen.
The first check is:
if (!dev)
return -EFAULT;
This checks that the passed comedi_device pointer is valid. The detach
function itself is called using this pointer so it MUST always be valid
or there is a bug in the core:
if (dev->driver)
dev->driver->detach(dev);
And the second check:
usb = dev->private;
if (!usb)
return -EFAULT;
The dev->private pointer is setup in the attach function to point to the
probed usb device. This value could be NULL if the attach fails. But,
since the comedi core is going to unload the driver anyway and does not
check for errors there is no gain by returning one.
After removing these checks from the comedi usb drivers the detach
functions required a bit of cleanup.
2. Remove all the printk noise in the detach functions
All of the printk output is really just noise. The user did a rmmod to
unload the driver, we really don't need to tell them about it.
Also, some of the messages are output using:
dev_dbg(dev->hw_dev, ...
or
dev_info(dev->hw_dev, ...
Unfortunately the hw_dev value is only used by drivers that are doing
DMA. For most drivers this variable is going to be NULL so the output
is not going to work as expected.
3. Refactor a couple static 'free_resource' functions into the detach
functions.
The 'free_resource' function is only being called by the detach and it
makes more sense to just absorb the code.
4. Remove a couple unnecessary braces for single statements.
5. Remove unnecessary comments.
Most of the comedi drivers appear to be based on the comedi skel driver
and have the comments from that driver included. These comments make
sense in the skel driver for reference but they don't need to be in any
of the actual drivers.
6. Remove all the extra whitespace.
It's not needed to make the functions any more readable.
7. Remove the now unused 'attached_successfully' variable in the
cb_pcimdda driver.
This variable was only used to conditionally output some driver noise
during the detach. Since all the printk's have been removed this
variable is no longer necessary.
Convert the refactored comedi drivers to use the module_comedi_driver()
macro which makes the code smaller and a bit simpler.
In the process, rename the driver variables from driver_* to *_driver,
as is more typical with other subsystems, and make sure they are all
static.
Move the module_init/module_exit routines and the associated
struct comedi_driver and other variables to the end of the source.
This is more typical of how other drivers are written and removes
the need for the forward declarations.
The n_boardtypes macros are simply open-coded versions of the kernels
ARRAY_SIZE macro. Use the kernel provided macro.
Move the init/exit routines to the respective C source files
instead of calling COMEDI_INITCLEANUP
Signed-off-by: Arun Thomas <arun.thomas@gmail.com>
Add MODULE_AUTHOR, MODULE_LICENSE, and MODULE_DESCRIPTION calls
to the respective C source files instead of calling COMEDI_MODULES_MACRO
This fixes all checkpatch issues in the pcl730 comedi driver.
Signed-off-by: Benjamin Adolphi <b.adolphi@gmail.com>
Lindent changes to comdi driver in staging tree.
This patch is followed by the checkpatch.pl error fixes.
Did not make them part of this patch as the patch size is already huge.
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Change from the foo: bar format to the .foo = bar format.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
