Now that the SPDX tag is in all comedi files, that identifies the
license in a specific and legally-defined manner. So the extra GPL text
wording can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/staging/comedi files files with the correct SPDX
license identifier based on the license text in the file itself. The
SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Format the multi-line comments in the kernel CodingStyle.
Move the comment about the I/O ports in dnp_attach() to the start
of the function. This is typically where the resources are reserved.
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
Blank lines are not needed before a close brace '}' or after an
open brace '{'. Also remove any multiple blank lines.
These messages are just added noise. Remove them.
Use comedi_dio_update_state() to handle the boilerplate code to update
the subdevice s->state.
Also, fix a bug where the state of the channels is returned in data[0].
The comedi core expects it to be returned in data[1].
Convert the drivers with simple, per channel programmable i/o, to use the
comedi_dio_insn_config() helper function.
All of these pass a 'mask' of '0' to comedi_dio_insn_config() this causes
the per channel mask to be used to configure the i/o direction.
comedidev.h is the main kernel header for comedi. Every comedi
driver includes this header which then includes a number of
<linux/*> headers. All the drivers need <linux/module.h> and some
of them need <linux/delay.h>. The rest are not needed by any of
the drivers.
Remove all the includes in comedidev.h except for <linux/dma-mapping.h>,
which is needed to pick up the enum dma_data_direction for the
comedi_subdevice definition, and "comedi.h", which is the uapi
header for comedi.
Add <linux/module.h> to all the comedi drivers and <linux/delay.h>
to the couple that need it.
Addresses change...
Remove the paragraph with the FSF address from all the comedi source
files.
Also, remove the paragraph about the finding the complete GPL in the
COPYING file since it's unnecessary.
The dev->board_name is now initialized by the comedi core before calling
the(*attach) or (*auto_attach) function in a driver. As long as the driver
does no additional probing, it's no longer necessary initialize the board_name.
This driver only supports a single "boardtype". Remove the unneeded
boardinfo struct and its use in the driver. Change the "driver_name"
to match what the boardinfo supplied.
Convert the comedi_subdevice access from pointer math to array
access.
Fix checkpatch.pl warning about printk issue by merging two printk
calls into one dev_info call.
Signed-off-by: Güngör Erseymen <gelurine@gmail.com>
The private data struct 'dnp_private_data' contains no information.
Remove it and the alloc_private() call.
Cc: Frank Mori Hess <fmhess@users.sourceforge.net>
The comedi_subdevice 'insn_bits' functions return the number of data
elements used to perform the command. Most of the insn_bits functions
return an open coded '2' to indicate this. The same value is available
as 'insn->n'. Return that instead to better indicate what the return
means.
The comedi core does the sanity check to make sure that the data length
the INSN_BITS instruction is 2. There is no need for the drivers to do
this check. Remove all the sanity checks in the drivers.
comedi_alloc_subdevices can fail with -EINVAL or -ENOMEM. When it
does fail make sure to pass the proper error code back.
Cc: Ian Abbott <abbott@mev.co.uk>
These comments are redundant. The function name 'comedi_alloc_subdevices'
provides this information.
Cc: Ian Abbott <ian@mev.co.uk>
Move the inline alloc_subdevices() function from comedidev.h
to drivers.c and rename it to comedi_alloc_subdevices(). The
function is large enough to warrant being an exported symbol
rather than being an inline in every driver.
The 'thisboard' macro depends on having a local variable with
a magic name. The CodingStyle document suggests not doing this
to avoid confusion. Remove the macro and use the comedi_board()
inline helper to get the dev->board_ptr information.
Cc: Mori Hess <fmhess@users.sourceforge.net>
1. Change the return type from int to void
All the detach functions, except for the comedi usb drivers, simply
return success (0). Plus, the return code is never checked in the
comedi core.
The comedi usb drivers do return error codes but the conditions can
never happen.
The first check is:
if (!dev)
return -EFAULT;
This checks that the passed comedi_device pointer is valid. The detach
function itself is called using this pointer so it MUST always be valid
or there is a bug in the core:
if (dev->driver)
dev->driver->detach(dev);
And the second check:
usb = dev->private;
if (!usb)
return -EFAULT;
The dev->private pointer is setup in the attach function to point to the
probed usb device. This value could be NULL if the attach fails. But,
since the comedi core is going to unload the driver anyway and does not
check for errors there is no gain by returning one.
After removing these checks from the comedi usb drivers the detach
functions required a bit of cleanup.
2. Remove all the printk noise in the detach functions
All of the printk output is really just noise. The user did a rmmod to
unload the driver, we really don't need to tell them about it.
Also, some of the messages are output using:
dev_dbg(dev->hw_dev, ...
or
dev_info(dev->hw_dev, ...
Unfortunately the hw_dev value is only used by drivers that are doing
DMA. For most drivers this variable is going to be NULL so the output
is not going to work as expected.
3. Refactor a couple static 'free_resource' functions into the detach
functions.
The 'free_resource' function is only being called by the detach and it
makes more sense to just absorb the code.
4. Remove a couple unnecessary braces for single statements.
5. Remove unnecessary comments.
Most of the comedi drivers appear to be based on the comedi skel driver
and have the comments from that driver included. These comments make
sense in the skel driver for reference but they don't need to be in any
of the actual drivers.
6. Remove all the extra whitespace.
It's not needed to make the functions any more readable.
7. Remove the now unused 'attached_successfully' variable in the
cb_pcimdda driver.
This variable was only used to conditionally output some driver noise
during the detach. Since all the printk's have been removed this
variable is no longer necessary.
Move the module_init/module_exit routines and the associated
struct comedi_driver and other variables to the end of the source.
This is more typical of how other drivers are written and removes
the need for the forward declarations.
Convert the driver to use the module_comedi_driver() macro which
makes the code smaller and a bit simpler.
Move the init/exit routines to the respective C source files
instead of calling COMEDI_INITCLEANUP
Signed-off-by: Arun Thomas <arun.thomas@gmail.com>
Add MODULE_AUTHOR, MODULE_LICENSE, and MODULE_DESCRIPTION calls
to the respective C source files instead of calling COMEDI_MODULES_MACRO
Fixed coding style issues: 80-char width limit, KERN_ facility level
Signed-off-by: Darren Armstrong <darren.armstrong85@gmail.com>
Fixed a coding style issue.
Created during the keynote presentation at FOSDEM 2010
Lindent changes to comdi driver in staging tree.
This patch is followed by the checkpatch.pl error fixes.
Did not make them part of this patch as the patch size is already huge.
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Replace instances of computing number of elements in an array with
sizeof(foo)/sizeof(struct footype) with the ARRAY_SIZE macro.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Change from the foo: bar format to the .foo = bar format.
driver for SSV Embedded Systems' DIL/Net-PCs
Cc: David Schleef <ds@schleef.org>
