Done via perl script:
$ cat remove_semi_switch.pl
my $match_balanced_parentheses = qr/(\((?:[^\(\)]++|(?-1))*\))/;
my $match_balanced_braces = qr/(\{(?:[^\{\}]++|(?-1))*\})/;
foreach my $file (@ARGV) {
my $f;
my $text;
my $oldtext;
next if ((-d $file));
open($f, '<', $file)
or die "$P: Can't open $file for read\n";
$oldtext = do { local($/) ; <$f> };
close($f);
next if ($oldtext eq "");
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(switch\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
} while ($count > 0);
if ($text ne $oldtext) {
my $newfile = $file;
open($f, '>', $newfile)
or die "$P: Can't open $newfile for write\n";
print $f $text;
close($f);
Remove unused typedef bc_bool_t.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
Free resources before exit.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
pinfo->name is a 32 char buffer. In the original code, the last char
wasn't fully utilized.
These two allocations are only called from the probe() path and there
aren't any locks held for probe().
This merges the staging-next tree to Linus's tree and resolves
some conflicts that were present due to changes in other trees that were
affected by files here.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Changed <module>-objs to <module>-y in Makefile.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
chd_dec_major is unsigned, so check chd_dec_major < 0 doesn't make sense.
Since it is used as signed, declare it as int.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Driver should call disable_pci_device() if it returns from pci_probe()
with error.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Acked-by: Jarod Wilson <jarod@redhat.com>
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
Remove unnesessary casts from void*.
Removed kfree(NULL checks) that were not necessary
Signed-off-by: Scott Kidder <scott.kidder11@gmail.com>
Remove typedefs from driver
Signed-of-by: Lior Dotan <liodot@gmail.com>
Drop cast on the result of kmalloc and similar functions.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
- (T *)
(\(kmalloc\|kzalloc\|kcalloc\|kmem_cache_alloc\|kmem_cache_zalloc\|
kmem_cache_alloc_node\|kmalloc_node\|kzalloc_node\)(...))
// </smpl>
A semicolon is missing at the end of a statement, but it does compile
fine without it as the macro BCMLOG_ERR expands to a do {...} while (0);
Signed-off-by: Charles Clément <caratorn@gmail.com>
Remove unused #include <linux/version.h>('s) in
drivers/staging/crystalhd/crystalhd_lnx.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
These patches fixes some whitspace and indentation warnings from
checkpatch.pl
Also these changed #includes:
bc_dts_glob_lnx.h:43: WARNING: Use #include <linux/param.h> instead of <asm/param.h>
rystalhd_lnx.h:45: WARNING: Use #include <linux/io.h> instead of <asm/io.h>
crystalhd_lnx.h:49: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
It all compiles fine, but I don't have the hardware to test with..
Signed-off-by: Lars Lindley <lindley@coyote.org>
Cc: Jarod Wilson <jarod@redhat.com>
Use IS_ERR() instead of comparing to NULL.
Signed-off-by: Jani Nikula <ext-jani.1.nikula@nokia.com>
This is a patch to the crystalhd_hw.c file that fixes up a white space
and brace warnings found by the checkpatch.pl tool
Signed-off-by: Tomas Dabasinskas <tomas.it@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch does following improvements:
1. Follow kernel style for comments
2. Reorganize code for readability improvement
3. Use PCI helper macros
4. Use __devinit, __devexit, __devexit_p at necessary places
5. Mark functions and data as static when it is not exported
Signed-off-by: Ameya Palande <2ameya@gmail.com>
Cc: Naren Sankar <nsankar@broadcom.com>
Cc: Jarod Wilson <jarod@wilsonet.com>
Cc: Scott Davilla <davilla@4pi.com>
Cc: Manu Abraham <abraham.manu@gmail.com>
Add necessary include to fix build on PowerPC
Signed-off-by: Jarod Wilson <jarod@redhat.com>
We don't actually need most of the register defines to build,
and most of the ones we don't need aren't currently interesting.
We'll leave a full copy of all of them in libcrystalhd's source,
and only include what we need and/or think might be interesting
in the driver.
I somehow managed to not actually include these two fixes in the submission
that was committed to the staging tree. libcrystalhd should eventually be
built against the kernel-provided header, and needs the stdint.h include. The
VOID bit is to keep things in sync with the Mac OS X driver and library that
Scott Davilla is also working on.
Signed-off-by: Scott Davilla <davilla@4pi.com>
This patch supersedes the earlier ones sent by Manu Abraham to add
the Broadcom Crystal HD driver to the staging tree, per discussion
with him about it. I've been working with Broadcom's Naren Sankar
on this driver for a number of months, and had already talked Naren
about submitting this on Broadcom's behalf, didn't expect anyone
else to jump on submitting it as quickly as Manu did. ;)
This version is a one-shot deal, incorporating the original driver,
Manu's coding style clean-ups, udev device creation support from
Edgar 'gimli' Hucek, and a number of other small tweaks from myself
and Scott Davilla, the other individual who has been working closely
on this code with Naren and I.
I've tested this iteration of the code lightly on a mini pci-e board
in a ThinkPad T61p running x86_64 Fedora 12, with the expected results,
and will test further on other systems with other variants of the card
(I have three varieties of this device currently in hand). Scott has
also tested on assorted primarily i686 varieties of Ubuntu, and Naren
has tested with both Fedora and Ubuntu, iirc.
Note: only the 70012 is currently supported by this driver, 70015
support will follow later. Also note that Blu-Ray support isn't
enabled (at the firmware level), due to misc fun related to the
BD encryption scheme, DRM, etc. :\
I *do* have a git tree containing the driver, lib, gst plugin and
firmware that I'm working from at the moment[*], as there are inter-
dependencies between the driver and lib, and the driver can be used
with kernels going a ways back (I've only tested back to 2.6.18 as
it exists in Red Hat Enterprise Linux 5). I'm exporting from there,
into a linux-next tree, then generating patches from there. The goal
is to feed everything upstream as quickly as possible, but there are
users who want this code for earlier kernels too...
The firmware will be submitted for inclusion in dwmw2's linux-firmware
tree once there is a suitable redistribution-no-modification type of
license on it (I believe Naren is working with Broadcom legal to get
that in place).
Changelog from initial Broadcom release to here:
commit d20475d444610c5683d09e63f707f5bb22359062
Author: Jarod Wilson <jarod@redhat.com>
Date: Mon Jan 4 13:55:16 2010 -0500
include: lib doesn't build w/o the removed stdint include
So add it back...
commit c181070a330530b792d2b80e3ec6ab12a5a57394
Author: Scott Davilla <davilla@4pi.com>
Date: Mon Jan 4 13:38:37 2010 -0500
include: don't define VOID if its already defined
commit 33d8a2b691e81212e398f53770578d79650bf0bc
Date: Mon Jan 4 13:12:10 2010 -0500
driver: create crystalhd device using udev
Based on:
http://sourceforge.net/apps/trac/archvdr/browser/trunk/archvdr/crystalhd/use_udev.patch
Signed-off-by: Edgar ( gimli ) Hucek <ebsi4711 at gmail dot com>
Formatting tweaks, error-handling path fixups and any bugs added by Jarod.
commit c44c64dea5537814796fcbe2d9db0209383c78b9
Author: Manu Abraham <abraham.manu@gmail.com>
Date: Mon Jan 4 10:32:47 2010 -0500
crystalhd: coding style cleanups
Signed-off-by: Manu Abraham <abraham.manu@gmail.com>
commit cffa6da7467ff697a656d1dfff54bb0513a053dc
Date: Mon Jan 4 10:17:27 2010 -0500
crystalhd: run dos2unix over everything, this is linux source...
commit 7fa38a282db7af5a5746055f7c6cef8a9b8ee138
Date: Mon Jan 4 10:02:33 2010 -0500
crystalhd: initial import of released Broadcom code
Straight import of:
http://www.broadcom.com/docs/support/crystalhd/crystalhd_linux_20091229.zip
Unfortunately, we're unable to publicly publish all the history that got
us from the initial internal code to what was released here, but such is
life, we can just be happy we've got this open-sourced now. :)
Signed-off-by: Naren Sankar <nsankar@broadcom.com>
