Fixed coding style issues as flagged by checkpatch.pl
Signed-off-by: Chris Forbes <chrisf@ijw.co.nz>
--bcaec50161b317392804a33628dd
Content-Type: text/plain; charset=ISO-8859-1
Hi Greg,
Please find patch attached .
Thanks,
Rahul
Hi Greg,<br><br> Please find patch attached .<br><br>Thanks,<br> Rahul<br>
From ba1dbafaef1a87c1338c5bb0e6bba3be06071c90 Mon Sep 17 00:00:00 2001
Date: Sat, 14 May 2011 11:28:25 +0530
Subject: [PATCH] Trivial indentation cleanup
Signed-off-by: Rahul Tank <rahul.tank@gmail.com>
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
s/seperate/separate
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Jiri Kosina <trivial@kernel.org>
Some remaining coding style cleanups to the header files
and the echo.c file.
Cc: David Rowe <david@rowetel.com>
This define is never set in the kernel, so remove the code
using it.
using it. This lets us drop the mmx.h file as well.
This file is no longer needed, thanks to the work done by David.
This patch removes the need for the bit_operations.h include file which
can now be deleted. It also contains some minor corrections to comments
(typos and alignment of ASCII formulas). I have also removed some #if
lines that were not necessary.
I have tested the patch using a unit test module that runs in kernel
mode and have verified that the patched code gives identical results to
the previous version using a 8000 sample input sequence. Let me know if
you want this unit test, it runs automatically when the module is
insmod-ed and outputs a go/no go result:
# insmod oslec.ko
# dmesg
[17191803.480000] oslec_test installed
[17191803.480000] Testing OSLEC with 128 taps (16 ms tail)
[17191803.496000] Oslec Unit Test PASSED! pass: 8000 fail: 0
Signed-off-by: David Rowe <david@rowetel.com>
The proc interface is no longer in the echo code, so remove the TODO
item.
Cc: Steve Underwood <steveu@coppice.org>
It's all just minor comment spacing issues. This patch fixes
up the remaining ones and now the code is checkpatch.pl clean.
I have just had a bug fix submitted for Oslec which I have applied to
Oslec SVN. The bug can potentially stops the echo canceller adapting
after a few seconds, although it hasn't caused many problems in
practice.
before:
errors lines of code errors/KLOC
drivers/staging/echo/ 213 1701 125.2
after:
drivers/staging/echo/ 8 1685 4.7
Compile tested.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Lindent drivers/staging/echo
Signed-off by: J.R. Mauro <jrm8005@gmail.com>
Remove typedefs in drivers/staging/echo
Signed-off-by: Jianjun Kong <jianjun@zeuux.org>
Lindent drivers/staging/echo*
This patch removes the very noisy "end of function" markers that are
very annoying when reading the driver code.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
The kernel is written in C, so remove the __cplusplus macro magic from the
driver.
This patch removes dead code that is wrapped in #ifndef __KERNEL__.
This patch removes the malloc()/free() macro wrappers and converts
call-sites to use kcalloc() and kzalloc() where appropriate. I also
fixed up out-of-memory error handling in couple of places where it was
broken.
Signed-off-by: Tzafrir Cohen <tzafrir@cohens.org.il>
Split out the external interface to a separate file called oslec.h .
Give the struct a name while we're at it.
This is used by mISDN and Zaptel drivers.
Cc: Tzafrir Cohen <tzafrir.cohen@xorcom.com>
