A lot of the intel_display stuff is duplicated, but we will add it first,
clean it up and then investigate the best way to merge stuff.
This first block integrates the various basic chunks of the CDV display setup.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Start the style cleanup
Remove all sorts of bits we can get rid of. We are now a very simple KMS
driver relying on the stolen memory for our framebuffer base (which is for
the moment hardcoded).
To support multiple frame buffers and some accel bits we will need some kind
of memory allocator, possibly a minimal use of GEM.
Lots of little ones all through the driver, mostly
all in a cut-and-paste header comment.
Cc: Alan Cox <alan@linux.intel.com>
This is an initial staging driver for the GMA500. It's been stripped out
of the PVR drivers and crunched together from various bits of code and
different kernels.
Currently it's unaccelerated but still pretty snappy even compositing with
the frame buffer X server.
Lots of work is needed to rework the ttm and bo interfaces from being
ripped out and then 2D acceleration wants putting back for framebuffer and
somehow eventually via DRM.
There is no support for the parts without open source userspace (video
accelerators, 3D) as per kernel policy.
