[ Upstream commit 329101244f214952606359d254ae883b7109e1a5 ]
The problem is in gb_lights_request_handler(). If we get a request to
change the config then we release the light with gb_lights_light_release()
and re-allocated it. However, if the allocation fails part way through
then we call gb_lights_light_release() again. This can lead to a couple
different double frees where we haven't cleared out the original values:
gb_lights_light_v4l2_unregister(light);
kfree(light->channels);
kfree(light->name);
I also made a small change to how we set "light->channels_count = 0;".
The original code handled this part fine and did not cause a use after
free but it was sort of complicated to read.
Fixes: 2870b52bae4c ("greybus: lights: add lights implementation")
Acked-by: Rui Miguel Silva <rmfrfs@gmail.com>
Link: https://lore.kernel.org/r/20190829122839.GA20116@mwanda
[ Upstream commit 04820da21050b35eed68aa046115d810163ead0c ]
Free memory region, if gb_lights_channel_config is not successful.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Reviewed-by: Rui Miguel Silva <rmfrfs@gmail.com>
When checking the value of delay_on to set the channel as active, it was
checked the pointer and not the value, as it should be.
Fixes: cc43368a3c ("greybus: lights: Control runtime pm suspend/resume on AP side")
Signed-off-by: Rui Miguel Silva <rmfrfs@gmail.com>
Even though we trust leds core that the pointers should be valid, we are
safer to check delay_{on|off} before use.
Also, this avoid a smatch warning:
drivers/staging/greybus/light.c:484 gb_blink_set()
warn: variable dereferenced before check 'delay_on' (see line 476)
Fix allocation of attributes with the correct size, this also fix smatch
warning:
drivers/staging/greybus/light.c:293 channel_attr_groups_set()
warn: double check that we're allocating correct size: 8 vs 16
No need to support older kernel versions in the Greybus Light driver, so
remove the checks as needed, we can now rely on all of the correct LED
core apis being present. And compile only if flash and v4l2 flash is
reachable.
Signed-off-by: Rui Miguel Silva <rui.silva@linaro.org>
Signed-off-by: Greg Kroah-Hartman <gregkh@google.com>
According to runtime pm architecture, the kernel side driver should be
as smart as needed to know when the module is idle or active, so that it can
issue the suspend/resume operations to the firmware side at the right time.
To add logics prevents AP from issuing the suspend request to the firmware
when a channel turning to active state, and put it to suspend if the state
is going to inactive with still holding a reference.
Testing Done: Compiled and verified on EVT2 and gpbridge-test module
with device class daughter board.
Signed-off-by: Kris Huang <huang_kris@projectara.com>
Reviewed-by: Rui Miguel Silva <rui.silva@linaro.org>
Fix incorrect attribute size when the channel supports fader, as well as
fixing the issue that the attribute list is not null terminated.
Testing Done:
- Verified by setting brightness and color on red/green/blue leds
of the device class test board.
Signed-off-by: David Lin <dtwlin@google.com>
A backport (commit 79c4de08c0e5a26b04a4ac9e6543dad6379f0b40) was
applied in kernel which adding attribute-group support in led-class.
Remove the LED_HAVE_GROUPS flag check entirely that allow led
drivers to create custom attributes like color/fade_in/fade_out.
Modify Lights greybus driver to support runtime PM framework.
The suspend and resume function have been tested with gpbridge-test
image by sysfs. Lights functions work well on suspend/resume.
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Light protocol driver is suffering from the same issue that was fixed in
camera driver earlier (commit a7c3b0c3c8da).
Big cleanup function is used instead of fine grained control in the
error path, and in one of the cases the mutex was found uninitialized
and so the oops seen in SW-6752.
Initialize the mutex before any code can access it.
Compile tested only.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Coccinelle points out that a call in gb_lights_channel_free() to
flush_work() is passed which is always non-null. Prior to the
call, there is an unnecessary check to see if that address is null.
Get rid of the test.
Signed-off-by: Alex Elder <elder@linaro.org>
This converts all drivers to use the gb_connection_get_data() and
gb_connection_set_data() functions to make it a bit more explicit as to
what is going on.
Reviewed-by: Alex Elder <elder@linaro.org>
lights can never be NULL at that point since lights_count must be different than
zero, and we need only to validate the light_id.
Reported-by: Johan Hovold <johan@hovoldconsulting.com>
The validation for a complete configured light is wrong and it is
reworked to make sure that only when the light is ready, will handle
request events.
If register to v4l2 fails just mark the light as not having flash so in
release we do not try to unregister.
We do not need to check for channels and lights as they can never be
NULL as a big memory array elements.
Convert the legacy lights protocol driver to a bundle driver.
This also fixes a potential crash should a (malicious) module have sent
an early request before the private data had been initialised.
Reviewed-by: Johan Hovold <johan@hovoldconsulting.com>
This breaks the light setup routine into two parts, the first one
allocates all the necessary resources and the second on registers lights
to the required frameworks.
This is required to enable only TX on the connection, until we have
allocated all the resources, otherwise the request handler might get
called for partially initialized structures.
In kernel v4.5 there is a change in LED api, which remove the need for
individual work queue and rename the set_sync operation to set_blocking.
This patch add the handling of this case and avoid compilation failure
for this kernel versions.
V4l2 flash will return erro ERANGE if val(which is the default value)
is not defined. Just set it to the max value reported by the module.
When attaching torch to a flash we release the channel torch resources,
but afterwards we do it again when releasing all the channels.
Just free all the resource at channel release.
We do not implement any of the v4l2 flash operations, as the default
ones are ok for now, however the init needs anything define, if not it
will return an error. So, just define it and have an error free v4l2
flash init.
Greybus bundle drivers should register their class devices as children
to the bundle device that they bind to.
Signed-off-by: Johan Hovold <johan@hovoldconsulting.com>
We are removing struct device from the gb_connection structure in the
near future. The gb_bundle structure's struct device should be used as
a replacement.
This patch moves the light driver to use the bundle pointer instead of
the connection pointer.
This patch adds lights implementation for Greybus Lights class, it
allows multiplexing of lights devices using the same connection. Also
adds two sysfs entries to led class (color, fade) which are commonly
used in several existing LED devices.
It support 2 major class of devices (normal LED and flash type), for
the first it registers to led_classdev, for the latest it registers in
the led_classdev_flash and v4l2_flash, depending on the support of the
kernel version.
Each Module can have N light devices attach and each light can have
multiple channel associated:
glights
|->light0
| |->channel0
| |->channel1
| |->channeln
|->lightn
|->channel0
|->channel1
|->channeln
