IIO driver for Programmable High-g Digital Impact Sensor and Recorder.
Signed-off-by: Barry Song <barry.song@analog.com>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
IIO driver for Programmable 360 Degrees Inclinometer adis16203 parts.
IIO driver for dual Axis Accelerometer/inclinometer adis16201 parts.
Standardize the spacing/style across the IIO build files:
- comment block in Kconfigs
- newlines at ends of files
- trailing lines at ends of files
- indent with one tab, not spaces or mixed
Signed-off-by: Barry Song <Barry.Song@analog.com>
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Example of relatively common case of device sampling
based on internal clock and providing a data ready
signal to indicate that new data is available to be
read out.
Generic trigger approach used to allow other devices
to be sampled 'at the same time' as this the accelerometer.
This is very useful in various motion estimation algorithms.
Example of how a device with a hardware ring buffer is
handled within IIO.
Changes since V2:
* Moved to new registration functions giving much cleaner
interface.
This provides only very minimal support for this device.
Note that an alternate driver has been posted to the input
mailing list.
When the original LMKL discussion that led to the descision
to develop IIO occured, the question on whether the differing
requirements of IIO and input drivers made it a good idea
to have unified drivers was left as an open question.
It still is. All opinions on this question welcome.
A later patch in the series will add data ready triggering
and ring buffer support.
This core patch provides an event interface and sysfs
based reading of values.
