Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
The interrupt handler should only ever return one of the three irqreturn_t
constants and not an error code. Also make sure to always call
iio_trigger_notify_done before leaving the trigger handler.
When calling __lis3l02dq_write_data_ready_config we pass the device struct of
embedded in the IIO device only to look up the IIO device from the device struct
again right away. This patch changes the code to pass the IIO device directly.
Acked-by: Jonathan Cameron <jic23@kernel.org>
Currently we use two different naming schemes in the IIO API, iio_verb_object
and iio_object_verb. E.g iio_device_register and iio_allocate_device. This
patches renames instances of the later to the former. The patch also renames allocate to
alloc as this seems to be the preferred form throughout the kernel.
In particular the following renames are performed by the patch:
iio_put_device -> iio_device_put
iio_allocate_device -> iio_device_alloc
iio_free_device -> iio_device_free
iio_get_trigger -> iio_trigger_get
iio_put_trigger -> iio_trigger_put
iio_allocate_trigger -> iio_trigger_alloc
iio_free_trigger -> iio_trigger_free
The conversion was done with the following coccinelle patch with manual fixes to
comments and documentation.
<smpl>
-iio_put_device
+iio_device_put
-iio_allocate_device
+iio_device_alloc
-iio_free_device
+iio_device_free
-iio_get_trigger
+iio_trigger_get
-iio_put_trigger
+iio_trigger_put
-iio_allocate_trigger
+iio_trigger_alloc
-iio_free_trigger
+iio_trigger_free
</smpl>
Step 1 in moving the IIO core out of staging.
This will be needed when multiple buffer support is added.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
The below patch fixes some comments and some typos that I have found
while reading drivers/staging/iio/*
Setup the buffer access functions in the buffer allocate function. There is no
need to let each driver handle this on its own.
No obvious usecase and complicates in kernel interface work.
Legacy of having multiple chrdevs that never got cleaned up.
Obviously drivers should only use this for pushing to buffers.
They need buffer->scan_mask for pulling from them post demux.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
These callbacks should not be buffer instance specific.
Hence move them out of the buffer.
Has no remaining users.
The advantage of kcalloc is, that will prevent integer overflows which could
result from the multiplication of number of elements and size and it is also
a bit nicer to read.
The semantic patch that makes this change is available
in https://lkml.org/lkml/2011/11/25/107
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Lots of drivers have in the past expected the presence of basic things
like THIS_MODULE and EXPORT_SYMBOL. With the header cleanup, they wont
have these. Call out the include explicitly.
This driver already supports kfifo usage, so the term ring is
misleading and hence replaced.
They aren't always ring buffers, so just use buffer for all naming.
also, IIO_RING_HARDWARE_BUFFER -> IIO_BUFFER_HARDWARE
These aren't always rings so the naming should not imply that.
Not always a ring so naming is missleading.
Also, kfifo_buf is probably first buffer to take out of staging and it
definitely isn't a ring.
channels.
This is as light as possible on changes to current drivers.
Some drivers make assumptions that their masks fit in a single
long. Given they were previously working this is clearly valid if
not tidy.
The max1363 is an example where there should be no such assumptions.
V2: Add the new ad5933
Acked-by: Michael Hennerich <Michael.Hennerich@analog.com>
The scan mask will be dynamically assigned in register, so don't
use it before that.
In adis16260 I've moved it as I know this driver has userspace code.
Same for sca3000 where it is cost free due to hardware buffer.
Can do that for the others, but in theory userspace code should always
have been checking these and setting them appropriately anyway!
V2: Clear default mask out of adis16400 as reported by Michael
Reported-by: Michael Hennerich <michael.hennerich@analog.com>
struct iio_dev.
This is always true, so lets make it explicit.
Missing from the iio_chan_spec conversion patches.
iio_trig_structure.
Right now this results in increased code, but I still think it is worth doing to avoid
replication across instances of drivers etc and move as much stuff as possible to constant.
Ops structure is optional for the occasional driver that uses none of it (currently
only the ad7793).
Some didn't get converted the first time around.
Silliness that has been there a long time.
It seemed like a good idea at the time, it wasn't.
The code with this in place is larger and more complex for
no real gain. Basically we've cleaned up the core around
it so much that this no longer makes sense.
Only really effects the lis3l02dq driver.
Signed-off-by: Jonathan Cameron <jic23@cam.acuk>
1) move a generic helper function out of ring_sw. It applies to other buffers as well.
2) Get rid of a lot of left over function definitions.
3) Move all the access functions into static structures.
4) Introduce and use a static structure for the setup functions, preenable etc.
Some driver conversions thanks to Michael Hennerich (pulled out of patches
that would otherwise sit after this).
any control_attrs via struct device
As the majority of triggers don't actually have any other control_attrs lets use the fact
that struct device has a groups element when we do need to have these attributes registered.
A vargs function is used to cut down on lots of building strings in every single driver
just in order to pass them into the allocate.
Also iio_allocate_trigger_named -> iio_allocate_trigger as there is no
unamed version any more, so that is now just confusing.
Blackfin tested and fixed by Michael Hennerich.
V2: Elements from Michael Hennerich's patches for the ade7758
Does add a small burden to both handlers, but the gain is somewhat
simpler code.
V2: Cleaned up handling of name string.
from that for the datardy signal.
This removes the one and only real user of the rather complex event list management.
V3: More trivial rebase fixups.
V2: Trivial rebase fixup.
As Arnd observed, things are clearner if we pass iio_dev into read and write fucntions.
Now uses st for lis3l02dq_state everywhere.
Other bits of trivial tidying.
V3: Move to single IIO_CHAN macro.
V2: Update to two part read_raw value.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
The job this was intended to do (never implemented) is now done
by explicit definition of _type attributes in all drivers
Also, adds a macro to make defining such attributes simple.
Acked-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
tested with sca3000, adis16400
Now fits other driver's structure for easier modification.
bps -> bytes_per_datum
ring_enable -> enable
Acked-by: Barry Song <21cnbao@gmail.com>
