Use the new spi_sync_transfer() helper function instead of open-coding it.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Replace open-coded instances of getting a iio_dev struct from a device struct
with dev_to_iio_dev().
Acked-by: Jonathan Cameron <jic23@kernel.org>
Step 1 in moving the IIO core out of staging.
In all existing cases, the calls are coming from a location where
the indio_dev is already available.
These callbacks should not be buffer instance specific.
Hence move them out of the buffer.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Has no remaining users.
Issue brought up by Lars-Peter Clausen. This is a varient of what
he suggested.
io/iio.h for driver stuff (has to include types.h)
Sub files for the bits drivers may or may not use
iio/sysfs.h
iio/buffer.h (contents of current buffer_generic.h)
(obviously anything offering events will need events.h as well)
iio/types.h for the enums that matter to both
iio_chan_type, iio_modifier
iio/events.h for the event code stuff
IIO_EVENT_CODE and friends. + everything in chrdev.h So this
is the stuff that userspace cares about.
Also include iio_event_type, iio_event_direction
Thus iio drivers include iio.h + as required
events.h
sysfs.h
buffer.h
in kernel users (once that interface is merged) will need inkern.h
which will pull in types.h
Userspace will need just events.h (which pulls in types.h) to get
everything they need to know about. Buffer userspace access doesn't
currently need any core defines. All information about the data
format is passed through sysfs.
They aren't always ring buffers, so just use buffer for all naming.
Nothing in this file is specific to RING buffers so rename it.
also, IIO_RING_HARDWARE_BUFFER -> IIO_BUFFER_HARDWARE
These aren't always rings so the naming should not imply that.
This patch set should bring all the attributes created outside
of chan_spec registration inline with the new abi.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
The scan mask will be dynamically assigned in register, so don't
use it before that.
In adis16260 I've moved it as I know this driver has userspace code.
Same for sca3000 where it is cost free due to hardware buffer.
Can do that for the others, but in theory userspace code should always
have been checking these and setting them appropriately anyway!
V2: Clear default mask out of adis16400 as reported by Michael
Reported-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Michael Hennerich <Michael.Hennerich@analog.com>
Sorry all, this one is very invasive, though the driver changes are
just trivial interface fixes. Not all done yet.
V2 - bring the sca3000 with us.
V3 - fix ade7758 bugs in conversion.
V4 - add ad5933
Missing from the iio_chan_spec conversion patches.
Getting rid of messages that make it harder to spot important issues.
Some code removed that will be useful one day. Can put it back then.
Mechanical change.
1) move a generic helper function out of ring_sw. It applies to other buffers as well.
2) Get rid of a lot of left over function definitions.
3) Move all the access functions into static structures.
4) Introduce and use a static structure for the setup functions, preenable etc.
Some driver conversions thanks to Michael Hennerich (pulled out of patches
that would otherwise sit after this).
in all buffer implementations.
This element has been usused by the core for quite some time. sca3000 set it none the less
until the rewrite in the previous patch (and hence didn't work).
from buffer
Fairly substantial rewrite as the code had bitrotted.
A rethink is needed for how to handle variable types in the new chan_spec world.
This patch restores sca3000 buffer usage to a working state.
V3: Rebase fixups.
V2: Move to new version of IIO_CHAN macro
part of sca3000 driver temporarily disabled (buffer won't run
anyway). This section is replaced later in this patch set.
Whilst it is possible to output events to say buffers have passed
a particular level there are no obvious reasons to actually do so.
The upshot of this patch is that buffers will only ever have
one threshold turned on at a time.
For now sca3000 has it's ring buffer effectively disabled.
Fixed later in series.
Change suggested by Arnd Bergmann, Related patch to remove
pointless (now) dead_offset parameter will have await
proper fix for the sca3000 driver. That depends on
some intermediate patches so may be a little while.
The device found passed to the attr functions is that of the ring
buffer, not the the iio_dev so we need to bounce through one more
hop to get the right address.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
The job this was intended to do (never implemented) is now done
by explicit definition of _type attributes in all drivers
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
tested with sca3000, adis16400
bps -> bytes_per_datum
ring_enable -> enable
Minor stuff (static, NULL, etc.)
Cc: Jonathan Cameron <jic23@cam.ac.uk>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Example of how a device with a hardware ring buffer is
handled within IIO.
Changes since V2:
* Moved to new registration functions giving much cleaner
interface.
