The below patch fixes some comments and some typos that I have found
while reading drivers/staging/iio/*
The core must not modify available_scan_mask, because it causes problems
with drivers where multiple instances of the driver share the same mask set.
So make this explicit by marking available scan masks as const.
The max1363 driver needs some minor adjustment to accommodate this change.
Pull scan mask allocation into a separate function.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
We name this field "chan" throughout IIO with the exception of this one macro.
Rename it to be more consistent.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits)
net/hyperv: Add support for jumbo frame up to 64KB
net/hyperv: Add NETVSP protocol version negotiation
net/hyperv: Remove unnecessary kmap_atomic in netvsc driver
staging/rtl8192e: Register against lib80211
staging/rtl8192e: Convert to lib80211_crypt_info
staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops
staging/rtl8192e: Add lib80211.h to rtllib.h
staging/mei: add watchdog device registration wrappers
drm/omap: GEM, deal with cache
staging: vt6656: int.c, int.h: Change return of function to void
staging: usbip: removed unused definitions from header
staging: usbip: removed dead code from receive function
staging:iio: Drop {mark,unmark}_in_use callbacks
staging:iio: Drop buffer mark_param_change callback
staging:iio: Drop the unused buffer enable() and is_enabled() callbacks
staging:iio: Drop buffer busy flag
staging:iio: Make sure a device is only opened once at a time
staging:iio: Disallow modifying buffer size when buffer is enabled
staging:iio: Disallow changing scan elements in all buffered modes
staging:iio: Use iio_buffer_enabled instead of open coding it
Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of
module_init due to using module_i2c_driver() helper, next to removal of
MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
No known use case and makes in kernel interface work more complex.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Kind of obvious for this device but useful
for testing purposes.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Also, the differential channels should always have been signed.
Internally the fact that say scale is shared across channels is
actually of remarkably little interest. Hence lets not store it.
Numerous devices have weird combinations of channels sharing
scale anyway so it is not as though this was really telling
us much. Note however that we do still use the shared sysfs
attrs thus massively reducing the number of attrs in complex
drivers.
Side effect is that certain drivers that were abusing this
(mostly my work) needed to do a few more checks on what the
channel they are being queried on actually is.
This is also helpful for in kernel interfaces where we
just want to query the scale and don't care whether it
is shared with other channels or not.
Currently the iio framework uses bitmasks for the address field of channel info
attributes. This is for historical reasons and no longer required since it will
only ever query a single info attribute at once. This patch changes the code to
use the non-shifted iio_chan_info_enum values for the info attribute address.
Issue brought up by Lars-Peter Clausen. This is a varient of what
he suggested.
io/iio.h for driver stuff (has to include types.h)
Sub files for the bits drivers may or may not use
iio/sysfs.h
iio/buffer.h (contents of current buffer_generic.h)
(obviously anything offering events will need events.h as well)
iio/types.h for the enums that matter to both
iio_chan_type, iio_modifier
iio/events.h for the event code stuff
IIO_EVENT_CODE and friends. + everything in chrdev.h So this
is the stuff that userspace cares about.
Also include iio_event_type, iio_event_direction
Thus iio drivers include iio.h + as required
events.h
sysfs.h
buffer.h
in kernel users (once that interface is merged) will need inkern.h
which will pull in types.h
Userspace will need just events.h (which pulls in types.h) to get
everything they need to know about. Buffer userspace access doesn't
currently need any core defines. All information about the data
format is passed through sysfs.
Use the newly introduced module_i2c_driver macro for registering I2C drivers.
This allows us to remove a few lines of boilerplate code.
Longs are not known for being 8 bits.
Fix a dumb lack of consideration of the effect of combining
the iio_device_unregister and iio_free_device calls into
one. There is no valid place to free some of the sysfs
array elements.
This was originally there to avoid churn during a complex change.
Now everything is stable lets get rid of this as it is missleading
and confusing.
They aren't always ring buffers, so just use buffer for all naming.
Nothing in this file is specific to RING buffers so rename it.
types.
Straight forward change in the core, but required some drivers to not use
the IIO_CHAN macro as that doesn't allow setting this bit (and is
going away anyway). Hence the churn.
Tested on max1363 with a couple of supported parts.
V2: differential bit in code got 7 bits and direction 1. Reversed that.
Issue spotted by Michael - thanks!
Acked-by: Michael Hennerich <Michael.Hennerich@analog.com>
This set also includes quite a number of bug fixes of particularly
remove functions.
Necessary due to issue pointed out in Bart Van Assche's patch:
docs/driver-model: Document device.groups
V2: Rebase due to patch reordering.
V3: Pull various error fixes and cleanups out into their own patches.
This costs us nothing in event storage (as we are carrying a 64 bit
timestamp in the structure) and gives us lots more room to play with.
Also allows for more channels which some parts need.
V2: Cleanup some loose ends (such as the switch with only one option now).
channels.
This is as light as possible on changes to current drivers.
Some drivers make assumptions that their masks fit in a single
long. Given they were previously working this is clearly valid if
not tidy.
The max1363 is an example where there should be no such assumptions.
V2: Add the new ad5933
Now the old method is long gone, lets get rid of the _ex and whilst
here remove the unused id parameter.
Trivial mechanical change, but will break any out of tree drivers
using this.
V2: rebase
V3: rebase
We don't have a use case for these. Two drivers appeared to use them
but both report all events on the first.
V2: Remove now irrelevant comment.
V3: Include fixup for adc/ad7280a.c
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Sorry all, this one is very invasive, though the driver changes are
just trivial interface fixes. Not all done yet.
V2 - bring the sca3000 with us.
V3 - fix ade7758 bugs in conversion.
V4 - add ad5933
buffer.
Change suggested by Arnd Bergmann.
No real reason to have two chrdevs per device. This step merges them into one.
Currently this means that events will only work on devices with buffers. THat will
be remedied shortly.
V2: set name for event attribute groups. Otherwise they all sorts of fun occurs on
dynamic channel event attribute creation.
Lots of people expect module.h to just "be there" without
any #include effort. But we are crushing that. So fix those
files in staging relying on implicit module.h presence.
IIO_EV_CLASS_<TYPE> etc
The original definitions were duplicated to reduce tree churn during introduction of chan_spec
registration. Now there is no point in maintaining the two sets of definitions.
More headers now not needed after iio_chan_spec conversions.
A couple of drivers were using helpers from adc.h.
Given these were trivial, they are pushed down into the drivers.
indio_dev->channels was accidentally removed thus preventing any sysfs
registrations occuring for direct reading. That hid the other issue.
Unfortunately the incorrect handling leads to misspresentation of data
in sysfs reads.
In the error handling, it dereferences "st" before it has been
initialized. I also just tidied it up a bit to remove some extra
conditions.
event code spitting out.
elements out of iio_dev.
This was suggested by Arnd Bergmann, Other elements may well
move in here in future, but it definitely makes sense for these.
V2: IIO_CHAN macro usage update.
V2: Fixed missing free of pollfunc->name as pointed out by
Michael Hennerich.
This requires all drivers using the channel registration code and
events to change in one go.
V3: remove unwanted irq enable from event handler.
V2: rebase related fixes to move to new IIO_CHAN macro. All trivial.
V3: move to single chan registration macro. Also introduce some
local macros to greatly reduce code length when setting up the
chan_spec arrays for all the different devices.
V2: update read_raw for two value approach.
The only fiddly bit in here was ensuring the regulator was available until after
the free had occured.
Either name is fine, so went with the most common.
Not only was this not compliant with the abi, it was also missconfiguring
the buffer.
Suggested by Arnd Bergmann. Note this will break ALL drivers that
are out of mainline. The fix is trivial change of
iio_allocate_device() -> iio_allocate_device(0)
Sorry if this causes issues for any one!
V2: Include new drivers in the update
The device found passed to the attr functions is that of the ring
buffer, not the the iio_dev so we need to bounce through one more
hop to get the right address.
Reported-by: Michael Hennerich <michael.hennerich@analog.com>
Also fixes a missing NULL to terminate one of the attribute arrays.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
The job this was intended to do (never implemented) is now done
by explicit definition of _type attributes in all drivers
As both signed and unsigned in attributes exist, each element must
be fully specified.
tested with sca3000, adis16400
driver stubs
Acked-by: Barry Song <21cnbao@gmail.com>
