A number of these register indexes were not set or actually wrong.
This only effects sysfs reads.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
elements out of iio_dev.
This was suggested by Arnd Bergmann, Other elements may well
move in here in future, but it definitely makes sense for these.
iio_dev.
Uses the iio_allocate_device parameter to set aside space for adis16400_state and
____cacheline_aligned buffers for tx and rx to avoid separatel allocating them.
Next patch will remove original driver.
Note this leaves holes in the scan indexing.
Untested - except via adis16350...
V3: rebase fixup.
V2: move to single IIO_CHAN macro.
Next patch will remove the current adis16350 driver.
These should have been merged a long time ago, but there we are.
V3: rebase fixup + add missing extend_name for supply on adis16350
V2: Move to single IIO_CHAN macro + use the new extend_name
to make the naming of the temperature sensors contain x, y, z
rather than messing with modifiers. This a very weird case
and I don't want temperature to use axial modifiers.
channel registration.
V2: rebase fixup.
Whilst the adis16400 does indeed support events, currently the driver
does not. The trigger code should never use that infrastructure.
Tested indirectly via the IMU driver merge to follow.
Suggested by Arnd Bergmann. Note this will break ALL drivers that
are out of mainline. The fix is trivial change of
iio_allocate_device() -> iio_allocate_device(0)
Sorry if this causes issues for any one!
V2: Include new drivers in the update
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
number
CC: stable <stable@kernel.org>
Add delay after self test to satisfy timing requirements.
Increase start-up delay.
cs_change must not be set in the last transfer of a spi message
associate events with them.
Given event codes are associated by number not name, all adc channels
including those with names need to have numbers.
g -> ms/s^2
deg -> rad
deg/s -> rad/s
some temperatures still broken
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
driver stubs
Acked-by: Barry Song <21cnbao@gmail.com>
1. move adis16400_spi_read_burst() to adis16400_ring.c since it is only
called there
2. add the lost calling to adis16400_self_test()
3. codes cleanup
Signed-off-by: Barry Song <21cnbao@gmail.com>
These drivers use kzalloc() but don't include slab.h. They currently
build though because the spi.h header will pull in slab.h for us. But
rather than rely on that behavior forever, include slab.h explicitly.
Signed-off-by: Barry Song <Barry.Song@analog.com>
