commit 62d2feb9803f18c4e3c8a1a2c7e30a54df8a1d72 upstream.
Fix crash after issuing:
echo hmc5843 0x1e > /sys/class/i2c-dev/i2c-2/device/new_device
[ 37.180999] device: '2-001e': device_add
[ 37.188293] bus: 'i2c': add device 2-001e
[ 37.194549] PM: Adding info for i2c:2-001e
[ 37.200958] bus: 'i2c': driver_probe_device: matched device 2-001e with driver hmc5843
[ 37.210815] bus: 'i2c': really_probe: probing driver hmc5843 with device 2-001e
[ 37.224884] HMC5843 initialized
[ 37.228759] ------------[ cut here ]------------
[ 37.233612] kernel BUG at mm/slab.c:505!
[ 37.237701] Internal error: Oops - BUG: 0 [#1] PREEMPT
[ 37.243103] Modules linked in:
[ 37.246337] CPU: 0 Not tainted (3.3.1-gta04+ #28)
[ 37.251647] PC is at kfree+0x84/0x144
[ 37.255493] LR is at kfree+0x20/0x144
[ 37.259338] pc : [<c00b408c>] lr : [<c00b4028>] psr: 40000093
[ 37.259368] sp : de249cd8 ip : 0000000c fp : 00000090
[ 37.271362] r10: 0000000a r9 : de229eac r8 : c0236274
[ 37.276855] r7 : c09d6490 r6 : a0000013 r5 : de229c00 r4 : de229c10
[ 37.283691] r3 : c0f00218 r2 : 00000400 r1 : c0eea000 r0 : c00b4028
[ 37.290527] Flags: nZcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 37.298095] Control: 10c5387d Table: 9e1d0019 DAC: 00000015
[ 37.304107] Process sh (pid: 91, stack limit = 0xde2482f0)
[ 37.309844] Stack: (0xde249cd8 to 0xde24a000)
[ 37.314422] 9cc0: de229c10 de229c00
[ 37.322998] 9ce0: de229c10 ffffffea 00000005 c0236274 de140a80 c00b4798 dec00080 de140a80
[ 37.331573] 9d00: c032f37c dec00080 000080d0 00000001 de229c00 de229c10 c048d578 00000005
[ 37.340148] 9d20: de229eac 0000000a 00000090 c032fa40 00000001 00000000 00000001 de229c10
[ 37.348724] 9d40: de229eac 00000029 c075b558 00000001 00000003 00000004 de229c10 c048d594
[ 37.357299] 9d60: 00000000 60000013 00000018 205b0007 37332020 3432322e 5d343838 c0060020
[ 37.365905] 9d80: de251600 00000001 00000000 de251600 00000001 c0065a84 de229c00 de229c48
[ 37.374481] 9da0: 00000006 0048d62c de229c38 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.383056] 9dc0: 00000000 c048d62c 00000000 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.391632] 9de0: 00000000 c048d62c 00000000 c0330164 00000000 de1f6c20 c048d62c de1f6c00
[ 37.400207] 9e00: c0330078 de1f6c04 c078d714 de189b58 00000000 c02ccfd8 de1f6c20 c0795f40
[ 37.408782] 9e20: c0238330 00000000 00000000 c02381a8 de1b9fc0 de1f6c20 de1f6c20 de249e48
[ 37.417358] 9e40: c0238330 c0236bb0 decdbed8 de7d0f14 de1f6c20 de1f6c20 de1f6c54 de1f6c20
[ 37.425933] 9e60: 00000000 c0238030 de1f6c20 c078d7bc de1f6c20 c02377ec de1f6c20 de1f6c28
[ 37.434509] 9e80: dee64cb0 c0236138 c047c554 de189b58 00000000 c004b45c de1f6c20 de1f6cd8
[ 37.443084] 9ea0: c0edfa6c de1f6c00 dee64c68 de1f6c04 de1f6c20 dee64cb8 c047c554 de189b58
[ 37.451690] 9ec0: 00000000 c02cd634 dee64c68 de249ef4 de23b008 dee64cb0 0000000d de23b000
[ 37.460266] 9ee0: de23b007 c02cd78c 00000002 00000000 00000000 35636d68 00333438 00000000
[ 37.468841] 9f00: 00000000 00000000 001e0000 00000000 00000000 00000000 00000000 0a10cec0
[ 37.477416] 9f20: 00000002 de249f80 0000000d dee62990 de189b40 c0234d88 0000000d c010c354
[ 37.485992] 9f40: 0000000d de210f28 000acc88 de249f80 0000000d de248000 00000000 c00b7bf8
[ 37.494567] 9f60: de210f28 000acc88 de210f28 000acc88 00000000 00000000 0000000d c00b7ed8
[ 37.503143] 9f80: 00000000 00000000 0000000d 00000000 0007fa28 0000000d 000acc88 00000004
[ 37.511718] 9fa0: c000e544 c000e380 0007fa28 0000000d 00000001 000acc88 0000000d 00000000
[ 37.520294] 9fc0: 0007fa28 0000000d 000acc88 00000004 00000001 00000020 00000002 00000000
[ 37.528869] 9fe0: 00000000 beab8624 0000ea05 b6eaebac 600d0010 00000001 00000000 00000000
[ 37.537475] [<c00b408c>] (kfree+0x84/0x144) from [<c0236274>] (device_add+0x530/0x57c)
[ 37.545806] [<c0236274>] (device_add+0x530/0x57c) from [<c032fa40>] (iio_device_register+0x8c8/0x990)
[ 37.555480] [<c032fa40>] (iio_device_register+0x8c8/0x990) from [<c0330164>] (hmc5843_probe+0xec/0x114)
[ 37.565338] [<c0330164>] (hmc5843_probe+0xec/0x114) from [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8)
[ 37.574737] [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8) from [<c02381a8>] (driver_probe_device+0x118/0x218)
[ 37.584777] [<c02381a8>] (driver_probe_device+0x118/0x218) from [<c0236bb0>] (bus_for_each_drv+0x4c/0x84)
[ 37.594818] [<c0236bb0>] (bus_for_each_drv+0x4c/0x84) from [<c0238030>] (device_attach+0x78/0xa4)
[ 37.604125] [<c0238030>] (device_attach+0x78/0xa4) from [<c02377ec>] (bus_probe_device+0x28/0x9c)
[ 37.613433] [<c02377ec>] (bus_probe_device+0x28/0x9c) from [<c0236138>] (device_add+0x3f4/0x57c)
[ 37.622650] [<c0236138>] (device_add+0x3f4/0x57c) from [<c02cd634>] (i2c_new_device+0xf8/0x19c)
[ 37.631805] [<c02cd634>] (i2c_new_device+0xf8/0x19c) from [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130)
[ 37.641754] [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130) from [<c0234d88>] (dev_attr_store+0x18/0x24)
[ 37.651611] [<c0234d88>] (dev_attr_store+0x18/0x24) from [<c010c354>] (sysfs_write_file+0x10c/0x140)
[ 37.661193] [<c010c354>] (sysfs_write_file+0x10c/0x140) from [<c00b7bf8>] (vfs_write+0xb0/0x178)
[ 37.670410] [<c00b7bf8>] (vfs_write+0xb0/0x178) from [<c00b7ed8>] (sys_write+0x3c/0x68)
[ 37.678833] [<c00b7ed8>] (sys_write+0x3c/0x68) from [<c000e380>] (ret_fast_syscall+0x0/0x3c)
[ 37.687683] Code: 1593301c e5932000 e3120080 1a000000 (e7f001f2)
[ 37.700775] ---[ end trace aaf805debdb69390 ]---
Client data was assigned to iio_dev structure in probe but in
hmc5843_init_client function casted to private driver data structure which
is wrong. Possibly calling mutex_init(&data->lock); corrupt data
which the lead to above crash.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
elements out of iio_dev.
This was suggested by Arnd Bergmann, Other elements may well
move in here in future, but it definitely makes sense for these.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Suggested by Arnd Bergmann. Note this will break ALL drivers that
are out of mainline. The fix is trivial change of
iio_allocate_device() -> iio_allocate_device(0)
Sorry if this causes issues for any one!
V2: Include new drivers in the update
this one completes my last patch set to compile fine for all drivers.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
Signed-off-by: Datta, Shubhrajyoti <shubhrajyoti@ti.com>
i2c_smbus_read_byte_data() returns an s32 type. We need to change
"rate" to signed for the error handling to work.
Also I changed it to propogate the error code instead of just returning
-EINVAL. Other error codes could be -EAGAIN for example.
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Adjust the error handling code so that it benefits from the call to
mutex_unlock at the end of the function.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@rcu exists@
position p1;
expression E;
mutex_lock@p1(E);
mutex_unlock(E);
@exists@
position rcu.p1;
expression E;
*mutex_lock@p1(E);
... when != mutex_unlock(E);
?*return ...;
// </smpl>
Adding support for the Honeywell HMC5843. The interface to the device is
i2c
TODO:
Adding the documentation
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
